I think I’ve found a case where the card fails to load. The built-in Synology integration provides a sensor whose value is the system uptime in Days, Hours, and Minutes combined.
Thanks to @Mariusthvdb, I’ve realized I confused the synologydsm component with a custom SNMP sensor I borrowed from someone else (I believe it was petro). I won’t pretend that I know what is going on in that value template other than I know it works. . That said, this is how I am getting the aforementioned output.
- platform: snmp
host: !secret synology_host
community: !secret synology_snmp
version: !secret snmp_version
baseoid: 1.3.6.1.2.1.25.1.1.0
value_template: >
{%- set time = value | int // 100 %}
{%- set minutes = ((time % 3600) // 60) %}
{%- set minutes = '{}min'.format(minutes) if minutes > 0 else '' %}
{%- set hours = ((time % 86400) // 3600) %}
{%- set hours = '{}hr '.format(hours) if hours > 0 else '' %}
{%- set days = (time // 86400) %}
{%- set days = '{}d '.format(days) if days > 0 else '' %}
{{ 'Less than 1 min' if time < 60 else days + hours + minutes }}
@AmoebeLabs - To follow up, I think my previously reported string issue is actually an issue where flex-horseshoe wont display the value of an entity if it is derived from a value_template within a Template Sensor.
Take a look at the screenshot below. Do you see how the Storage value is missing? Similar to the aforementioned SNMP value, the Storage value is derived by a calculation done within a value template, or in this case adding the total storage of two separate entities within a Template Sensor (included below). The output in this case is far less complex than my previous example. Is it possible that flex-horsehoe doesn’t properly support value_templates?
Side Note - THANK YOU!!! I’m loving what can be done with this card!
Thanx for that great screenshot
I have never worked with value_templates and/or template sensors, so it might be the case that the horseshoe doesn’t support them. I never thought that these are different from ordinary sensors, so never bothered to check those situations.
I guess I have to look into that
You don’t get errors in the log btw as a hint for what is going wrong??
Nice! Now I see what you’re making, I understand the question about disabling the horseshoe and have a free-format card. I really like this view you have made. The other parts are other cards I presume?
In that case you will like my new experiments I guess. The next example has 14 states, 7 names, 14 segmented arcs, 2 icons, 7 lines and 1 area on the card. It needs 600 lines of yaml to define & place every object
Sidenote 1: text is a bit small on a mobile…
Sidenote 2: you can see the bugs in the arcs on the 71% humidity…
Sidenote 3: with a lot of copy/paste it was 10-15 minutes of work to create this card…
And an example with only two sensors, with actual and historic data:
I was wondering whether there is a way to have the background of the inside of the horseshoe use a different colour than the outside and, if not, whether this could be added as a feature? This would be useful for creating an old fashioned gauge style appearance, something like this (mocked up):
I can add a background color, which would be a circle as your mockup shows.
However, the shadows as currently implemented - and shown in the mockup - won’t work anymore, as the shadows only work on the complete SVG elements: everything in the circle will become ‘flat’.
As you can see, the original global filter (with the light colored drop shadow) is completely gone in the inside of the horseshoe.
In the next screenshot I’ve added some hard-coded SVG filters on several objects.
Also, drop shadows don’t work out of the box on lines as you also see.
But, yes it can be done.
If you don’t want the shadows, adding a setting for the background should not be that difficult. If you do want the shadows, it is more work to implement and configure.
I’ve actually worked out a way of doing this without needing changes to the card. I have card-mod installed, and using this I was able to apply a background to the card like this:
The only other thing to do was to set the fill style of the text items and the stroke style of the lines to a dark colour, so there won’t be a problem if it is used with a dark theme. With some other tweaking for the layout, this is what my system monitor card now looks like:
Yeah I used HACS for installation and did add the things to my yaml.
I can also get it working for some of the examples, so I just dont understand why some others dont
I’ve received a couple of requests for the yaml pertaining to this particular card. I’m placing it here since it’s the most appropriate location for Flex Card discussions. A couple of things to note:
I use custom:card-modder to set the background transparency. Custom:card-modder has been replaced (by custom:card-mod) but since it still works, I still use it.
The bulk of the card is a Decluttering Template. If you don’t know what that is, it’s time to read up.
All values that are encased within <> MUST be replaced with actual entities, attributes, or values. Otherwise, the card may not load.
The entities list at the bottom of the Decluttering Card declaration can display any attribute you want, except for attributes derived from a Template. This is a limitation of FHC at the moment. If you are savvy enough, you might be able to work around the limitation using iantrich’s Template Card.
# Card Declaration for dc_horseshoe_cpu_three_stats_layout. Put this part in your actual view.
# - type: custom:decluttering-card
# template: dc_horseshoe_cpu_three_stats_layout
# variables:
# - entity_id: <the_target_vm>
# - vm_name: <Whatever_name_you_want_displayed_on_the_card>
decluttering_templates:
dc_horseshoe_cpu_three_stats_layout:
card:
type: custom:card-modder
style:
--paper-card-background-color: rgba(0, 0, 0, 0.0)
--ha-card-background: rgba(0, 0, 0, 0.0)
--ha-card-box-shadow: none
card:
type: custom:flex-horseshoe-card
layout:
hlines:
- id: 0
xpos: 50
ypos: 42
length: 40
styles:
- stroke: var(--primary-text-color);
- stroke-width: 5;
- stroke-linecap: round;
- opacity: 0.7;
states:
# States 0 refers to the first entity in the list, ie index 0
- id: 0
entity_index: 0
xpos: 50
ypos: 26
styles:
- font-size: 2em;
# States 1 refers to the second entity in the list, ie index 1
- id: 1
entity_index: 1
xpos: 40
ypos: 57
styles:
- text-anchor: start;
- font-size: 1.5em;
# States 2 refers to the third entity in the list, ie index 2
- id: 2
entity_index: 2
xpos: 40
ypos: 72
styles:
- font-size: 1.5em;
icons:
# Icons 0 refers to the second entity in the list, ie index 1
- id: 0
entity_index: 1
xpos: 37
ypos: 57
align: end
# Icons 1 refers to the third entity in the list, ie index 2
- id: 1
entity_index: 2
xpos: 37
ypos: 72
align: end
names:
# Names 0 refers to the first entity in the list, ie index 0
- id: 0
entity_index: 0
xpos: 50
ypos: 95
areas:
- id: 0
entity_index: 0
xpos: 50
ypos: 36
styles:
- font-size: 1.0em;
show:
horseshoe_style: 'colorstopgradient'
# Scale set to -10 to +40 degrees celcius
horseshoe_scale:
min: 0
max: 100
# color stop list with two colors. With the `lineargradient` fill style, only the
# colors are used. The thresholds are ignored with this setting.
color_stops:
33: 'green'
66: 'yellow'
100: 'red'
entities:
- entity: '[[entity_id]]'
attribute: <your_entitys_attribute_name_goes_here>
decimals: 2
unit: '%'
area: CPU Usage
icon: mdi:memory
decimals: 0
unit: 'MB'
icon: mdi:chip
decimals: 0
unit: 'GB'
icon: mdi:harddisk
