Does anyone or do you @benct know, if there is a way to “yaml” the displayed name in the row of this great multiple entity row? I want to change this depending of criterias.
I do love the "multiple-entity-row" and use it a lot.
But there is a thing which I do not like - inability to display "last-changed" for each item.
Currently it is supported only for the main entity.
How do you like this?
It needs a "card-mod" installed.
Any way to show_icon: false on this to hide the icon? Or a card-mod way to hide it? Tried `state-badge {display: none;} but that didn’t work. Thank you!
Which icon do you want to hide - main entity, secondary items?
Anyway, you may use mdi:blank for the main entity or secondary items.
Also, "icon: false" is used to show an entity’s state instead of an icon (secondary items).
And "card-mod" may be used too…
I’m having a slight issue with formatting when using this card.
I have 4 helpers, 2 x input.datetime and 2 x input.number.
When I display the datetime helpers using this card so everything is on the same line it shows the datetime with AM / PM. I would just like it to be displayed as HH:mm, in 24 hour format.
Also, when I display the number helpers using this card it shows the number with one decimal place. I would just like it to be displayed as a whole number, ie 20, not 20.0
Here’s the code I’m using with a screenshot of what it displays, and thanks in advance for any help.
type: entities
title: Schedule 1
show_header_toggle: false
entities:
- entity: input_boolean.day_1_1
type: 'custom:multiple-entity-row'
show_state: false
state_color: true
tap_action:
action: none
entities:
toggle: true
- entity: input_datetime.workday_1_1
- entity: input_number.workday_1_1
- entity: input_datetime.offday_1_1
- entity: input_number.offday_1_1
I think it is related to the multiple-entity-row, the screenshot below shows with and without the multiple-entity-row. In the bottom part I use just a entities card without the multiple-entity-row function and the display is just fine.
Here is my proposal )))
Other solutions are like “let’s create a template sensor which is converted to 24h format - and then use the sensor in the multiple-entity-row”.
Yeah I did think of that but these are input helpers and I need t have the input functionality, so when the number clicked it opens up a window that allows me to set the temperature:
Hi Ildar_Gabdullin, I did try that but the only issue with that is the format is in hh:mm:ss, and I would just like it to display hh:mm (because having the ss showing just makes it look unsightly). If there is a way to make it display hh:mm then it would be perfect.
I have opened an issue with GitHUB so hopefully the author can check if it’s a bug or not.
