Hi everybody!, I’m sharing my recent dashboard I’ve created. I took inspiration by the community. This is running a wall mounted tablet with Kios Mode.
How it looks like (V2!) 01-05-2022:
Home-Assistant
Right now I’m running Home-Assistant on a Raspberry Pi4 Model B + Raspbee II for Zigbee
Custom Frontend componenets
- Button Custom Card
- Weather Card
- Bar Card
- Mini Graph Card
- Simple Thermostat
- Vertical Stack in Card
- Auto Entities
- Card Mod
- Layout Card
- State Switch
Custom Integration componenets
- Browser Mod
- PfSense Integration
Features
- Popups to manage the system
- Notification based on sensors alerts for all the house
* CSS Animation for entities
* Custom designed buttons - Settings mode to access high impact sensors and freeze Automation in the house. All accessed by a code
The Sidebar
- Custom clock sensor
* Custom grid to access main shortcuts with CSS animation, notification for errors, and loading for slow responding entities - Weather card with additional details inside
* Sensors to identify system warning or issues (RIGHT)
* Sensor to identify system updates (LEFT)
Widgets
- Room widgets have room temperature, air quality sensor + on lights
- Home widget has summarized sensor status
- Additional details can be found inside
Details
Light: Mainly managed by Shelly 1 V3 and Shelly 2.5. I also have the Zigbee gateway to manage Ikea lights;
Energy: Energy consumptions is managed by shelly sensors (1PM + 2.5);
Sensors: Aqara Sensors for doors, windows, water and air quality. Temp sensors are Sonoff;
Heating: Tado Thermostat
Nuki Door Lock for the main door
Broadlink Mini 3 to manage the Air Conditioning, a spare Vacuum cleaner and some other remotes.
Amazon Fire Stick as a Media Player in parallel with my TVs
Amazon Echo as a Speaker for announcements and music. I’ve setup Alexa in order to power her on or off based on time.
PfSense My Firewall is a PfSense based; I’ve used the PfSense integration available on HACS to manage rules and statistics from my network.
Pi-Hole Is my tool to block ads from the TV
Qnap is my nas configured as a media server
What i’m working to
* Additional information to be displayed to the Sidebar
Move to Raspberry Pi 4 with SSD- Integrate the floorplan to the dashboard
* Vaccum cleaner integration - Rhasspy Integration
- Still working on the UI design because every time I look it, I change it
I really have to thank all of you for the huge contents you bring every day, for the custom components and for the all of this. This community & Home Assistant break the limits of the imagination.
for my project I took a lot of inspiration by these people: (Thanks gents!)
Mattias Persson Topic
for CSS code, and very clean and detailed design!
danieljarhult Topic
for the UI design, theme and the overall system!
Tben Topic
For the cleanest design and buttons!
V2 Changes
- Removed CSS Animation and merged configuration with Minimalist Setup
- Aligned all the custom buttons with Minimalist
- Brand new clean and fresh layout
- Moved to Raspy 4!
- Improved Sidebar display of information
