MC6 Thermostat
After some testing and debugging I’m posting here also a MQTT “native” configuration for this thermostat.
I have a 2 pipes fancoil device with Modbus and MQTT settings available (MQTT OR Modbus, not both)
This config allow for HA to subscribe and publish relevant messages to read and write settings to the device.
The config has been only lightly tested so it may contain some errors, post here if you find some.
MQTT
PRO: all feature available by design (fan, modes), with a little patience it should be possible to also send scheduling programs
CONS: no direct connection from HA to MC6, so if a message is lost/gets error the feedback is missing and the climate entity revert to its previous state when MC6 publish a new message; missing power command options (needs separate MQTT switch, with the same problems as the climate entity)
MODBUS
PRO: direct connection with the thermostat, automation gets immediate response to action (or get immediately an error)
CONS: missing fan mode feature, ATM needs modification to HA modbus code to modify temp settings
mqtt:
  - climate:
      object_id: mc6_1
      unique_id: mc6_1
      # MC6 gets updates immediately but sends status messages only after some minutes, so it's better to update the UI optimistically
      optimistic: true
      # MC6 in MQTT config supports only 4 modes, cooling,heating,fan only and dehumidifying
      # MC6 discard the dry mode when sent by mqtt, it may report it's status if the dehumid settings is enabled on the thermostat (not tested)
      modes:
        - "cool"
        - "heat"
        - "fan_only"
        - "dry"
      mode_state_topic: "updData/MACADDRESS-lowercase"
      # from MC6 manual: mode(1 cool, 2 heat, 3 vent, 4 auto), but in my thermostat the Auto fnction is replaced by Dehumid
      mode_state_template: >-
        {% if value_json.mode == 1 %}
          cool
        {% elif value_json.mode == 2 %}
          heat
        {% elif value_json.mode == 3 %}
          fan_only
        {% elif value_json.mode == 4 %}
          dry
        {% endif %}
      mode_command_topic: "MACADDRESS-lowercase"
      mode_command_template: >-
        {% if (value | string) == "cool" %}
          { "mode": 1 }
        {% elif (value | string) == "heat" %}
          { "mode": 2 }
        {% elif (value | string) == "fan_only" %}
          { "mode": 3 }
        {% elif (value | string) == "dry" %}
          { "mode": 4 }
        {% endif %}
      # from MC6 manual: fan speed(1 high, 2 medium, 3 low, 4 auto)
      fan_modes:
        - "High"
        - "Medium"
        - "Low"
        - "Auto"
      fan_mode_state_topic: "updData/MACADDRESS-lowercase"
      fan_mode_state_template: >-
       {% if value_json.fan == 1 %}
          High
        {% elif value_json.fan == 2 %}
          Medium
        {% elif value_json.fan == 3 %}
          Low
        {% elif value_json.fan == 4 %}
          Auto
        {% endif %}
      fan_mode_command_topic: "MACADDRESS-lowercase"
      fan_mode_command_template: >-
       {% if value == "High" %}
         { "fan":3  }
        {% elif value == "Medium" %}
         { "fan":2  }
        {% elif value == "Low" %}
         { "fan":1  }
        {% elif value == "Auto" %}
         { "fan":4  }
        {% endif %}
      min_temp: 5
      max_temp: 30
      temp_step: 0.5
      current_temperature_topic: "updData/MACADDRESS-lowercase"
      # dividing by 10 when reading the settings
      current_temperature_template: "{{ value_json.temp | float / 10  }}"
      temperature_state_topic: "updData/MACADDRESS-lowercase"
      temperature_state_template: "{{ value_json.settemp | float / 10  }}"
      temperature_command_topic: "MACADDRESS-lowercase"
      # multiplying by 10 when writing the settings
      temperature_command_template: "{ \"settemp\":{{ (value * 10) | int }} }"
      current_humidity_topic: "updData/MACADDRESS-lowercase"
      current_humidity_template: "{{ value_json.humi | int  / 10  }}"
      precision: 0.1
      retain: false
      qos: 1
  - switch:
      unique_id: mc6_1_switch_onoff
      object_id: mc6_1_switch_onoff
      name: "MC6-1 Switch-onoff"
      optimistic: true
      state_on: "ON"
      state_off: "OFF"
      value_template: >-
       {% if value_json.onoff == 1 %}
          "ON"
        {% elif value_json.onoff == 2 %}
          "OFF"
        {% endif %}
      payload_on: '{"onoff":1 }'
      payload_off: '{"onoff":2 }'
template:
  - sensor:
    - name: "MC6-1-Humi"
      device_class: humidity
      unit_of_measurement: '%'
      state: "{{ state_attr('climate.mc6_hvac', 'current_humidity') | float }}"
Would it be possible to share this again as it has expired.
MC6-259-MQTT-OT.hex and 2 more files
enjoy
Thanks, but it says the transfer is expired. Did you initiated a new transfer?
maybe you should not wait that long before starting the download :wink:
Yes, sorry. When I googled we transfer expiration it said they were alive for 30 days, but other hits I read now say 7 days.
Thanks for the help
Please, can some body publish a new link for OLD/NEW MC6 to enable MQTT? Thanks!
This IS my PCB but after few reads of the topics… Can be flashed without STLink? USB pinout work but only to get de bmp resources… Maybe SWDI with TTL USB?
From your picture it is not clear what’s you display release. You should check the batch number of this thermostat labelled on the display flat cable.
Programming can ONLY be done using the following:
JLink
ST jtag
OLD&NEW display FW
link expires on 25/12/2023
Hello.
Can anybody share latest firmware for old and new hardware?
Thanks in advance.
Cheers,
Mateusz
Hello, I’m using the MC6 Thermostat with modbus integration. Everything was fine but the time synchronization of the device. Once settled to MODBUS the automatic time synchonization doesen’t work. Anyone knows how to fix it? Is the MC6 using the NTP protocol to the MODBUS server instead of the default one? Or is there any command to configure date and time via MODBUS?
Regards,
Diego
Time sync doesen’t work in modbus only in mqtt , setting the time zone.
I’ve asked this in the past to YuQiang and this is reply:
for the Modbus register it has not time and date , we will add this later
For the time sync in MQTT you can use the topc “Timezone” , if you want to enable the time sync just modify the data to the time zone you want to set , please note the time zone range is -12 to 12, if you want to disable the Time sync just set the time zone data to be 13 ;
As you know the time sync only works in Coud server mode, so if thermostat works in Modbus TCP this time sync feature would not work.
mc6-259-mqtt-ot-hex_2023-05-28_0802.zip
Got this from ringhio80 in October. After installing it the thermostat found version 2.70 by itself and I upgraded again.
Thank you very much! :slight_smile:
Cheers,
Mateusz
@YuQiang any chance to include in the mqtt messages the valve status? like the modbus have? or the automatic time sync in the modbus?
Any chance to release it OTA, it is really time consuming to take the thermostats from the wall to update.
Hi bmpalmeida,
OTA feature has already released if your thermostat firmware is later than 242 .
We will add the valve status in next firmware 271 when we are not too busy .
Thanks.
Regards
Yu
Hi All ,
We have released a new version MC6 , please check attached picture, this new version MC6 has different firmware and MCU with old MC6, it has all exist MC6 features and these new functions below :
1) LoRaWAN option (868mhz, 915mhz)
2) BACnet MSTP, IP
3) Tuya App option.
4) Seasonal auto changable ( the work mode auto change according to the external sensor in 2 pipes fan coil type thermostat )
5) Open window feature (Heating type thermostat)
6) Adaptive heating feature (Heating type thermostat)
7) Measuring the load current (Electric heating type thermostat) .
This new version MC6-v2 would be started to delivery early this month , we will mainly upgrade this new MC6 firmware, for the old version MC6 firmware we also upgrade it when we are not busy .
Regards
Yu
After all. The version 2.70 is not working properly. The reading of the temperature is very different from before. More than 2 degrees higher. But the main problema is that the brightness control doesn’t work.
Hello, where can I buy this new version MC6-v2? Is MC6 the same product as TMC6? It looks the same?
/Jan
MC6-V2 has different hardware and firmware .
you can email us your shippding details and which part number do you need, we will arrange sales to contact you.
This is the email : [email protected]
Hi, I have the MC6, but not the Mch1, but Mch2 (CO2 sensor). Is it possible to also work with MQTT on this version? The software version is 3.44U(HA1). The login via screen lock code works, but asks for a server, not a MQTT server.
Many thanks in advance!
