Forked from @Bram_Kragten 5 Button IKEA Remote blueprint.
Easily select the lights you want to control using the remote. Supports on/off, brightness, colour temp and RGB. Also, easily allocate a scene to each scene button on the remote.
Notes:
You need to add one of the lights you’ve selected to the ‘Colour Temperature Reference’. This overcomes a current shortcoming in blueprints and syncs all other lights colour temp to the chosen reference light.
You must select a scene for each button for the automation to work. Blueprints don’t seem to allow optional inputs yet.
Blueprint
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic URL:
blueprint:
name: Muller Licht Remote
description: Control lights with a Muller Licht Tint RGB Remote
domain: automation
input:
remote:
description: Muller Licht Tint remote to use
selector:
device:
integration: deconz
manufacturer: MLI
model: ZBT-Remote-ALL-RGBW
target_light:
description: The light(s) to control
selector:
entity:
domain: light
colour_ref:
name: Colour Temperature Refence
description: The light to use as a colour temp reference
selector:
entity:
domain: light
working_scene:
description: The scene to be triggered when the Working Light button is pressed
selector:
entity:
domain: scene
sunset_scene:
description: The scene to be triggered when the Sunset button is pressed
selector:
entity:
domain: scene
party_scene:
description: The scene to be triggered when the Party button is pressed
selector:
entity:
domain: scene
night_scene:
description: The scene to be triggered when the Night button is pressed
selector:
entity:
domain: scene
campfire_scene:
description: The scene to be triggered when the Campfire button is pressed
selector:
entity:
domain: scene
romantic_scene:
description: The scene to be triggered when the Romantic button is pressed
selector:
entity:
domain: scene
force_brightness:
name: Force turn on brightness
description: 'Force the brightness to the set level below, when the "on" button on the remote is pushed and lights turn on.'
default: false
selector:
boolean: {}
brightness:
description: Brightness of the light(s) when turning on
default: 50
selector:
number:
min: 0.0
max: 100.0
mode: slider
step: 1.0
unit_of_measurement: "%"
step_value:
name: Brightness increment/decrement percent
description: Set the step percent value for brightness and color warmth
default: 10
selector:
number:
min: 1.0
max: 20.0
mode: slider
step: 1.0
mode: restart
max_exceeded: silent
variables:
force_brightness: !input "force_brightness"
step_value: !input "step_value"
colour_ref: !input "colour_ref"
- platform: event
event_type: deconz_event
event_data:
device_id: !input "remote"
- variables:
event: "{{ trigger.event.data.event }}"
- choose:
- conditions:
- "{{ event == 1002 }}"
sequence:
- choose:
- conditions: "{{ force_brightness }}"
sequence:
- service: light.toggle
target: !input target_light
brightness_pct: !input "brightness"
default:
- conditions:
- "{{ event == 2002 }}"
sequence:
- service: light.turn_on
brightness_step_pct: "{{ step_value }}"
transition: 1
- conditions:
- "{{ event == 3002 }}"
sequence:
brightness_step_pct: "-{{ step_value }}"
transition: 1
- conditions:
- "{{ event == 4002 }}"
sequence:
color_temp: "{{state_attr(colour_ref, 'color_temp')|int + 60}}"
- conditions:
- "{{ event == 5002 }}"
sequence:
color_temp: "{{state_attr(colour_ref, 'color_temp')|int - 60}}"
- conditions:
- "{{ event == 6002 }}"
sequence:
xy_color:
- "{{ trigger.event.data.xy.0 }}"
- "{{ trigger.event.data.xy.1 }}"
- conditions:
- "{{ event == 7002 }}"
sequence:
- service: homeassistant.turn_on
entity_id: !input working_scene
- conditions:
- "{{ event == 8002 }}"
sequence:
entity_id: !input sunset_scene
- conditions:
- "{{ event == 9002 }}"
sequence:
entity_id: !input party_scene
- conditions:
- "{{ event == 10002 }}"
sequence:
entity_id: !input night_scene
- conditions:
- "{{ event == 11002 }}"
sequence:
entity_id: !input campfire_scene
- conditions:
- "{{ event == 12002 }}"
sequence:
entity_id: !input romantic_scene
