Müller Licht tint remote
Forked from @Bram_Kragten 5 Button IKEA Remote blueprint.
Easily select the lights you want to control using the remote. Supports on/off, brightness, colour temp and RGB. Also, easily allocate a scene to each scene button on the remote.
Notes:
You need to add one of the lights you’ve selected to the ‘Colour Temperature Reference’. This overcomes a current shortcoming in blueprints and syncs all other lights colour temp to the chosen reference light.
You must select a scene for each button for the automation to work. Blueprints don’t seem to allow optional inputs yet.
Blueprint
Click the badge to import this Blueprint: (needs Home Assistant Core 2021.3 or higher)
Or import this Blueprint by using the forum topic URL:
blueprint:
  name: Muller Licht Remote
  description: Control lights with a Muller Licht Tint RGB Remote
  domain: automation
  input:
    remote:
      description: Muller Licht Tint remote to use
      selector:
        device:
          integration: deconz
          manufacturer: MLI
          model: ZBT-Remote-ALL-RGBW
    target_light:
      description: The light(s) to control
      selector:
          entity:
            domain: light
    colour_ref:
      name: Colour Temperature Refence
      description: The light to use as a colour temp reference
      selector:
        entity:
          domain: light
    working_scene:
      description: The scene to be triggered when the Working Light button is pressed
      selector:
        entity:
          domain: scene
    sunset_scene:
      description: The scene to be triggered when the Sunset button is pressed
      selector:
        entity:
          domain: scene
    party_scene:
      description: The scene to be triggered when the Party button is pressed
      selector:
        entity:
          domain: scene
    night_scene:
      description: The scene to be triggered when the Night button is pressed
      selector:
        entity:
          domain: scene
    campfire_scene:
      description: The scene to be triggered when the Campfire button is pressed
      selector:
        entity:
          domain: scene
    romantic_scene:
      description: The scene to be triggered when the Romantic button is pressed
      selector:
        entity:
          domain: scene
    force_brightness:
      name: Force turn on brightness
      description: 'Force the brightness to the set level below, when the "on" button on the remote is pushed and lights turn on.'
      default: false
      selector:
        boolean: {}
    brightness:
      description: Brightness of the light(s) when turning on
      default: 50
      selector:
        number:
          min: 0.0
          max: 100.0
          mode: slider
          step: 1.0
          unit_of_measurement: "%"
    step_value:
      name: Brightness increment/decrement percent
      description: Set the step percent value for brightness and color warmth
      default: 10
      selector:
        number:
          min: 1.0
          max: 20.0
          mode: slider
          step: 1.0
mode: restart
max_exceeded: silent
variables:
  force_brightness: !input "force_brightness"
  step_value: !input "step_value"
  colour_ref: !input "colour_ref"
  - platform: event
    event_type: deconz_event
    event_data:
      device_id: !input "remote"
  - variables:
      event: "{{ trigger.event.data.event }}"
  - choose:
      - conditions:
          - "{{ event == 1002 }}"
          - choose:
              - conditions: "{{ force_brightness }}"
                  - service: light.toggle
                    target: !input target_light
                      brightness_pct: !input "brightness"
            default:
      - conditions:
          - "{{ event == 2002 }}"
          - service: light.turn_on
              brightness_step_pct: "{{ step_value }}"
              transition: 1
      - conditions:
          - "{{ event == 3002 }}"
              brightness_step_pct: "-{{ step_value }}"
              transition: 1
      - conditions:
          - "{{ event == 4002 }}"
              color_temp: "{{state_attr(colour_ref, 'color_temp')|int + 60}}"
      - conditions:
          - "{{ event == 5002 }}"
              color_temp: "{{state_attr(colour_ref, 'color_temp')|int - 60}}"
      - conditions:
          - "{{ event == 6002 }}"
              xy_color:
                - "{{ trigger.event.data.xy.0 }}"
                - "{{ trigger.event.data.xy.1 }}"
      - conditions:
          - "{{ event == 7002 }}"
          - service: homeassistant.turn_on
            entity_id: !input working_scene
      - conditions:
          - "{{ event == 8002 }}"
            entity_id: !input sunset_scene
      - conditions:
          - "{{ event == 9002 }}"
            entity_id: !input party_scene
      - conditions:
          - "{{ event == 10002 }}"
            entity_id: !input night_scene
      - conditions:
          - "{{ event == 11002 }}"
            entity_id: !input campfire_scene
      - conditions:
          - "{{ event == 12002 }}"
            entity_id: !input romantic_scene
thanks for this! I have some problems importing the button in deconz- are you using that or something else?
I’m using Deconz with Conbee II on RPi4. Added to switches section:
It’s possible to make this blueprint works with zigbee2mqtt?
I’ve managed to adapt the blueprint for the ZHA Integration.
However, none of the scene buttons triggers any event (at least none that I notice).
Do you have any advice for me how I can detect the occuring events?
This is the adapted blueprint I am currently using with the Livarno Lux lights from LIDL
blueprint:
  domain: automation
  input:
    remote:
      selector:
        device:
          integration: zha
          manufacturer: MLI
    target_light:
      selector:
          entity:
            domain: light
    colour_ref:
      selector:
        entity:
          domain: light
    working_scene:
      selector:
        entity:
          domain: scene
    sunset_scene:
      selector:
        entity:
          domain: scene
    party_scene:
      selector:
        entity:
          domain: scene
    night_scene:
      selector:
        entity:
          domain: scene
    campfire_scene:
      selector:
        entity:
          domain: scene
    romantic_scene:
      selector:
        entity:
          domain: scene
    force_brightness:
      description: Force the brightness to the set level below, when the "on" button
      default: false
      selector:
        boolean: {}
    brightness:
      default: 50
      selector:
        number:
          min: 0.0
          max: 100.0
          mode: slider
          step: 1.0
          unit_of_measurement: '%'
    step_value:
      default: 10
      selector:
        number:
          min: 1.0
          max: 20.0
          mode: slider
          step: 1.0
  source_url: https://community.home-assistant.io/t/muller-licht-tint-remote/283190
mode: restart
variables:
  force_brightness: !input 'force_brightness'
  step_value: !input 'step_value'
  colour_ref: !input 'colour_ref'
- platform: event
  event_type: zha_event
  event_data:
    device_id: !input 'remote'
- variables:
    event: '{{ trigger.event.data.cluster_id }}'
- choose:
  - conditions:
    - '{{ event == 6 }}'
    - choose:
      - conditions: '{{ force_brightness }}'
          target: !input 'target_light'
            brightness_pct: !input 'brightness'
      default:
  - conditions:
    - '{{ event == 8 }}'
    - '{{ trigger.event.data.args==[0,43,10] }} '
        brightness_step_pct: '{{ step_value }}'
        transition: 1
  - conditions:
    - '{{ trigger.event.data.args==[1,43,10] }}'
        brightness_step_pct: -{{ step_value }}
        transition: 1
  - conditions:
    - '{{ trigger.event.data.command == ''move_to_color_temp'' }}'
        color_temp: '{{ trigger.event.data.args[0] }}'
  - conditions:
    - '{{ event == 5002 }}'
        color_temp: '{trigger.event.data.args[0] |int}}'
  - conditions:
    - '{{ trigger.event.data.command == ''move_to_color'' }}'
        xy_color: '[{{ trigger.event.data.args[0]|float/45875 }}, {{trigger.event.data.args[1]|float/45875 }}]'
  - conditions:
    - '{{ event == 7002 }}'
      entity_id: !input 'working_scene'
  - conditions:
    - '{{ event == 8002 }}'
      entity_id: !input 'sunset_scene'
  - conditions:
    - '{{ event == 9002 }}'
      entity_id: !input 'party_scene'
  - conditions:
    - '{{ event == 10002 }}'
      entity_id: !input 'night_scene'
  - conditions:
    - '{{ event == 11002 }}'
      entity_id: !input 'campfire_scene'
  - conditions:
    - '{{ event == 12002 }}'
      entity_id: !input 'romantic_scene'
Yes, you need to go to Developer Tools > Events, then enter zha_event into the ‘Listen to events’ box, then click start listening. Now press the scene buttons on the remote and you’ll get the event details.
That’s the way I did it for the other buttons. In the image you can see the output for the ‘reduce brightness’ button.
Before taking the screenshot, I also pressed all scene buttons (single/double/long press). Those do not show up at all, even when showing all events (’*’ as event type)
I’d say the issue would be with the ZHA support of the device. I find the Blackaddr list a useful resource for working out how well devices are supported by the various Zigbee options: Müller Licht Tint Remote Control 404011 Zigbee compatibility info (blakadder.com)
Hi!
I have imported your template. I was able to integrate the Müller Licht remote control via deconz without any problems.
I then used your template to create an automation and set all the scenes and entities.
However, when I trigger the automation, I get the following error message:
Error: UndefinedError: 'dict object' has no attribute 'event'
Now, unfortunately, I don’t know what to do either.
Can anyone help me?
Best regards!
hi, have you optimized the code for ZHA more? or is this definitive? if yes, can you share the new blueprint code? Thanks :slightly_smiling_face:
Just found this thread and it helped me figure it out. So in case you’re still looking, this is how you can catch the scene buttons:
          - '{{ trigger.event.data.command == ''attribute_updated'' }}'
          - '{{ trigger.event.data.args.value == 3 }}'
Hey there, is that code for zha or deconz? Where would I add it? Can I make the above blueprint work with ZHA? I tried vaincinders blueprint but the remote doesn’t show up in the device list of the automation
I am trying to get my remote to work but to no avail. If somebody could make a Tint ZHA walkthrough for dummies I’d be very thankful
Sorry didn’t see your message earlier. I went of vaincinders blueprint and adjusted it. What exactly are the issues you’re running into?
I added the remote through zha but with the blueprint it needs a remote to be set, but there isnt one.Could you maybe shre your solution so I can find where I went wrong?
EDIT: Seems I have the same issue as @MaSt above
EDIT2: One issue might be that I have added this via ZHA and not with deconz as stated in the blueprint. But I replaced deconz with zha, no luck. Still, the remote looks odd in HA.
Hi guys! I have the exact same model (ZBT-Remote-ALL-RGBW) which I paired with ZHA. However, when adding the blueprint and started to configure an automation based on the blueprint, my remote is not in the list if available remotes:
I do not know if the remote was added correctly. Someone had the same experience?
Is there in the meantime an update on this? I have the same problem as described above: using the bleuprint, I cannot select the remote to use.
The remote is paired succesfully via ZHA, and I can listen to the ZHA_Events
Hi there, i bought the remote and wanted to implement it in HA, i managed to connect it to deconz and its also showing in the area devices in HA, but when i want to use the blueprint i cannot select it. Also in Deconz it doesnt recognise the vendor MLI, it just has a number.
I have the same Problem!
Is there a solution?
Delete these lines and it will work, it seems to be picky on the spelling of the integration and names. But then it will show ALL devices. I just left the “manufacturer” line
