Hi @rhysb,
i have made a general mushroom - card-mod styling guide that i have posted here. i have linked to your resource on animations from it because it is great. however since it was made a few things have changed with the way that animations are applied and we get a bunch of questions regarding it right now because people want to use your animations. so i hope you dont mind that i have gone through and updated each of your animations below and will be posting them as a reply here.
i will also link to both your original post and my updated ones in my guide, but i will send people to your post for giving it a like ![]()
Built-in Mushroom Animations
There are two built-in animations for Mushroom cards that can be used without specifying any @keyframes. These are spin, which is used for the rotating fan, and pulse, which fades in and out.
Built-in Spin Animation (changed):
type: custom:mushroom-template-card
primary: Spin
icon: mdi:fan
icon_color: teal
card_mod:
style: |
ha-state-icon {
animation: spin 1s linear infinite;
Built-in Pulse Animation (changed):
icon: mdi:pulse
icon_color: red
primary: Pulse
card_mod:
style: |
ha-state-icon {
animation: pulse 2s ease-in-out infinite;
Animated Mushroom Cards
Mushroom Media Player Card (unchanged):
Media Player Animated Icons
type: custom:mushroom-media-player-card
entity: media_player.currently_playing
icon: mdi:play
use_media_info: true
use_media_artwork: false
show_volume_level: false
media_controls:
- play_pause_stop
- previous
- next
volume_controls:
- volume_buttons
- volume_set
fill_container: false
card_mod:
style: |
mushroom-shape-icon {
display: flex;
{% set media_type = state_attr(config.entity, 'media_content_type') %}
{% if media_type == 'tvshow' %}
--card-mod-icon: mdi:television-classic;
animation: flicker 1s linear infinite alternate;
{% elif media_type == 'movie' %}
--card-mod-icon: mdi:movie-roll;
animation: spin 2s linear infinite reverse;
{% elif media_type == 'music' %}
--card-mod-icon: mdi:music;
animation: beat 1.3s ease-out infinite both;
{% elif media_type == 'playlist' %}
--card-mod-icon: mdi:play;
@keyframes flicker {
0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { --icon-color: rgba(var(--rgb-indigo), 1); }
32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { --icon-color: rgba(var(--rgb-indigo), 0.6); }
@keyframes beat {
0%, 60% { --icon-symbol-size: 21px; }
5%, 17%, 57% { --icon-symbol-size: 22px; }
10%, 20%, 51% { --icon-symbol-size: 23px; }
25%, 45% { --icon-symbol-size: 24px; }
30%, 39% { --icon-symbol-size: 25px; }
33% { --icon-symbol-size: 26px; }
ha-card {
{% if not is_state(config.entity, 'off') %}
background: rgba(var(--rgb-card-background-color), 0.6) url( '{{ state_attr(config.entity, "entity_picture") }}' ) center no-repeat;
background-size: cover;
background-blend-mode: overlay;
Mushroom Climate Card (unchanged):
Climate Animated Icons
type: custom:mushroom-climate-card
entity: climate.office_air_conditioner
hvac_modes:
- heat_cool
- heat
- cool
- fan_only
- dry
show_temperature_control: true
collapsible_controls: false
name: Air Conditioner
card_mod:
style: |
{% if is_state(config.entity, 'heat_cool') %}
--card-mod-icon: mdi:autorenew;
animation: spin 3s ease-in-out infinite alternate;
{% elif is_state(config.entity, 'heat') %}
--card-mod-icon: mdi:fire;
animation: heat 2s infinite;
{% elif is_state(config.entity, 'cool') %}
--card-mod-icon: mdi:snowflake;
animation: cool 6s ease-in-out infinite;
{% elif is_state(config.entity, 'dry') %}
--card-mod-icon: mdi:water-percent;
animation: dry 1.5s linear infinite;
{% elif is_state(config.entity, 'fan_only') %}
--card-mod-icon: mdi:fan;
--card-mod-icon: mdi:air-conditioner;
display: flex;
@keyframes cool {
0%, 100% { transform: rotate(25deg); }
25% { transform: rotate(-25deg); }
50% { transform: rotate(50deg); }
75% { transform: rotate(-50deg); }
@keyframes heat {
0%, 100% { --icon-color: rgba(var(--rgb-red), 1); }
10%, 90% { --icon-color: rgba(var(--rgb-red), 0.8); }
20%, 80% { --icon-color: rgba(var(--rgb-red), 0.6); }
30%, 70% { --icon-color: rgba(var(--rgb-red), 0.4); }
40%, 60% { --icon-color: rgba(var(--rgb-red), 0.2); }
50% { --icon-color: rgba(var(--rgb-red), 0); }
@keyframes dry {
0%, 100% { --icon-symbol-size: 21px; }
10%, 90% { --icon-symbol-size: 22px; }
20%, 80% { --icon-symbol-size: 23px; }
30%, 70% { --icon-symbol-size: 24px; }
40%, 60% { --icon-symbol-size: 25px; }
50% { --icon-symbol-size: 26px; }
Mushroom Card Icon Animations
Boil Animation (changed)
primary: Boil
icon: mdi:kettle-steam
icon_color: red
card_mod:
style: |
ha-state-icon {
animation: boil 500ms infinite;
@keyframes boil {
0%, 100% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
10% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); clip-path: polygon(0 0, 66% 10%, 67% 30%, 88% 52%, 100% 100%, 0 100%); }
20% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
30% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
40% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
50% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
60% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
70% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
80% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
90% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
Fire Animation (changed)
primary: Fire
icon: mdi:fire
icon_color: red
card_mod:
style: |
ha-state-icon {
animation: fire 1.5s infinite;
transform-origin: 50% 85%;
@keyframes fire {
0% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
5% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
10% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
15% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
20% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
25% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
30% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
35% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
40% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
45% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
50% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
55% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
60% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
65% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
70% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
75% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
80% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
85% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
90% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
95% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
100% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
Shower Animation (changed)
icon: mdi:shower-head
icon_color: light-blue
primary: Shower
card_mod:
style: |
ha-state-icon {
animation: clip 0.7s ease-out infinite;
@keyframes clip {
0% {clip-path: inset(0 0 45% 0); }
100% { clip-path: inset(0 0 0 0); }
Sprinkler Animation (changed)
icon: mdi:sprinkler
icon_color: cyan
primary: Sprinkler
card_mod:
style: |
ha-state-icon {
animation: sprinkle 2s linear infinite;
transform-origin: 29% 88%;
@keyframes sprinkle {
0%, 15%, 30%, 45%, 60%, 100% { clip-path: inset(0 55% 0 0); transform: rotate(0deg); }
1%, 16%, 31%, 46% { clip-path: inset(0 0 0 0); transform: rotate(-10deg); }
6%, 21%, 36%, 51% { transform: rotate(2deg); }
Washing Machine Animation (changed)
icon: mdi:washing-machine
icon_color: amber
primary: Washing Machine
card_mod:
style: |
ha-state-icon {
animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
transform-origin: 50% 110%;
@keyframes shake {
0%, 100% { transform: translate(0, 0) rotate(0); }
20% { transform: translate(0.4px, -0.4px) rotate(-4deg); }
40% { transform: translate(-0.4px, 0.4px) rotate(4deg); }
60% { transform: translate(0.4px, 0.4px) rotate(-4deg); }
80% { transform: translate(-0.4px, -0.4px) rotate(4deg); }
@keyframes drum {
50% { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
Dishwasher Animation (changed)
icon: mdi:dishwasher
icon_color: blue
primary: Dishwasher
card_mod:
style: |
ha-state-icon {
animation: bounce 1.5s ease-in-out infinite, wash 1s ease-in-out infinite;
transform-origin: 50% 75%;
@keyframes bounce {
0%, 20%, 50%, 80%, 100% {transform: translateY(0); }
40% { transform: translateY(-1.2px) rotate(5deg); }
60% { transform: translateY(-1.1px) rotate(-4deg); }
@keyframes wash {
50% { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
Dryer Animation (changed)
icon: mdi:tumble-dryer
icon_color: teal
primary: Dryer
card_mod:
style: |
ha-state-icon {
animation: shake 400ms ease-in-out infinite, drum 1s infinite;
transform-origin: 50% 65%;
@keyframes shake {
0%, 100% { transform: rotate(4deg); }
50% { transform: rotate(-4deg); }
@keyframes drum {
Ding Animation (changed)
primary: Ding
icon: mdi:bell-ring
icon_color: indigo
card_mod:
style: |
ha-state-icon {
animation: ring 4s linear infinite;
transform-origin: 50% 15%;
@keyframes ring {
0% { transform: rotate(0); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
2% { transform: rotate(30deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
6% { transform: rotate(-28deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
10% { transform: rotate(34deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
14% { transform: rotate(-32deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
18% { transform: rotate(30deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
22% { transform: rotate(-28deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
26% { transform: rotate(26deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
30% { transform: rotate(-24deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
34% { transform: rotate(22deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
38% { transform: rotate(-20deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
42% { transform: rotate(18deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
46% { transform: rotate(-16deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
50% { transform: rotate(14deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
54% { transform: rotate(-12deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
58% { transform: rotate(10deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
62% { transform: rotate(-8deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
66% { transform: rotate(6deg); }
70% { transform: rotate(-4deg); }
74% { transform: rotate(2deg); }
78% { transform: rotate(-1deg); }
82% { transform: rotate(1deg); }
86% { transform: rotate(0); }
100% { transform: rotate(0); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
Alarm Animation (changed)
icon: mdi:alarm
icon_color: red
primary: Alarm
card_mod:
style: |
ha-state-icon {
animation: alarm 0.8s ease infinite;
@keyframes alarm {
0%, 80%, 100% { transform: translateY(0); }
10% { transform: translateY(-2px) rotate(-27deg); }
20% { transform: translateY(-2px) rotate(21deg); }
30% { transform: translateY(-2px) rotate(-15deg); }
40% { transform: translateY(-2px) rotate(9deg); }
50% { transform: translateY(0); }
60% { transform: translateY(-1.2px) }
Rocket Man Animation (changed)
icon: mdi:rocket-launch
icon_color: deep-orange
primary: Rocket Man
card_mod:
style: |
ha-state-icon {
animation: thrust 100ms infinite, motion 3s ease-in-out infinite;
@keyframes thrust {
0% { clip-path: polygon(0 0, 0 47%, 22% 57%, 28% 63%, 0 91%, 11% 100%, 37% 73%, 45% 77%, 55% 100%, 100% 100%, 100% 0%); }
33% { clip-path: polygon(0 0, 0 47%, 24% 59%, 42% 76%, 54% 100%, 100% 100%, 100% 0); }
66% { clip-path: polygon(0 0, 0 92%, 28% 64%, 36% 72%, 9% 100%, 100% 100%, 100% 0%); }
@keyframes motion {
0%, 100% { transform: translateY(-2px) translateX(-3px); }
50% { transform: translateY(3px) translateX(2px); }
Fountain Animation (changed)
primary: Fountain
icon: mdi:fountain
card_mod:
style: |
ha-state-icon {
animation: fountain 1.5s ease infinite;
@keyframes fountain {
0%, 100 { clip-path: polygon(0 100%, 0 0, 100% 0, 100% 100%); }
50% { clip-path: polygon(0 100%, 0 47%, 100% 47%, 100% 100%); }
60% { clip-path: polygon(0 100%, 100% 100%, 100% 37%, 79% 36%, 71% 21%, 56% 25%, 44% 25%, 31% 20%, 20% 36%, 0 36%); }
70% { clip-path: polygon(0 100%, 100% 100%, 100% 36%, 79% 36%, 71% 22%, 81% 1%, 24% 0, 31% 21%, 20% 36%, 0 36%); }
80% { clip-path: polygon(0 100%, 100% 100%, 100% 36%, 79% 36%, 76% 28%, 100% 0, 0 0, 23% 28%, 20% 36%, 0 36%); }
Motion Animation (changed)
icon: mdi:motion-sensor
icon_color: blue
primary: Motion
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--shape-animation: motion 2s linear infinite;
@keyframes motion {
0%, 100% { --shape-color: rgba(var(--rgb-blue), 0.3); }
50% { --shape-color: rgba(var(--rgb-blue), 0.2); }
ha-state-icon {
animation: clip 2s linear infinite;
@keyframes clip {
50% { clip-path: polygon(0 0, 55% 0, 100% 100%, 0 100%); }
Cog Animation (changed)
primary: Cog
icon: mdi:cog
icon_color: grey
card_mod:
style: |
ha-state-icon {
animation: spin 1.5s steps(5) infinite;
Signal Animation (changed)
icon: mdi:wifi
icon_color: green
primary: Signal
card_mod:
style:
.shape {
--shape-animation: ping 2s infinite;
@keyframes ping {
60% { box-shadow: 0 0 0 0 rgba(var(--rgb-green), 0.7); }
100% { box-shadow: 0 0 5px 15px transparent; }
ha-state-icon {
animation: clip 2s steps(1) infinite;
@keyframes clip {
0% { clip-path: circle(0% at 50% 85%); }
20% { clip-path: circle(30% at 50% 85%); }
40% { clip-path: circle(55% at 50% 85%); }
60% { clip-path: circle(80% at 50% 85%); }
Alert Animation (changed)
icon: mdi:alarm-light
icon_color: red
primary: Alert
card_mod:
style:
.shape {
--shape-animation: alert-shape 0.8s infinite;
@keyframes alert-shape {
0%, 100% { --shape-color: rgba(var(--rgb-orange), 0.2); }
60% { --shape-color: rgba(var(--rgb-red), 0.2); }
ha-state-icon {
animation: alert 0.8s infinite;
@keyframes alert {
0%, 100% { color: rgb(var(--rgb-orange)); }
50% { clip-path: polygon(0% 55%, 25% 55%, 25% 35%, 35% 25%, 50% 18%, 65% 20%, 75% 35%, 75% 55%, 100% 55%, 100% 100%, 0 100%); color: rgb(var(--rgb-red)); }
Console Animation (changed)
icon: mdi:console-line
icon_color: grey
primary: Console
card_mod:
style: |
ha-state-icon {
animation: console 1s infinite;
@keyframes console {
50% { clip-path: polygon(0 0, 100% 0, 24% 100%, 0 100%); }
Keypad Animation (changed)
icon: mdi:dialpad
icon_color: blue
primary: Keypad
card_mod:
style:
.shape {
--shape-animation: ping 4s infinite;
@keyframes ping {
55% { box-shadow: 0 0 1px 0px rgba(var(--rgb-blue), 0.3) inset; }
100% { box-shadow: 0 0 5px 15px transparent inset; }
ha-state-icon {
animation: pin 4s infinite;
@keyframes pin {
0%, 15%, 25%, 35%, 45%, 55% { clip-path: inset(0 0 0 0); }
10% { clip-path: polygon(0% 100%, 1% 23%, 36% 23%, 36% 0%, 100% 0, 100% 100%); }
20% { clip-path: polygon(0% 100%, 0 0, 62% 0, 61% 25%, 100% 24%, 100% 100%); }
30% { clip-path: polygon(0 0, 100% 0, 100% 100%, 0 100%, 0 25%, 36% 25%, 37% 50%, 63% 49%, 62% 26%, 0 25%); }
40% { clip-path: polygon(0 51%, 0 0, 100% 0, 100% 100%, 36% 100%, 37% 51%); }
50% { clip-path: polygon(0 100%, 0 0, 100% 0, 100% 50%, 64% 50%, 64% 100%); }
Eye Animation (changed)
icon: mdi:eye
icon_color: blue
primary: Eye
card_mod:
style: |
ha-state-icon {
animation: wink 4s ease-in-out infinite;
@keyframes wink {
0%, 100% { transform: scale(1, 1); }
19% { transform: scale(1.05, 0.6); }
20% { clip-path: polygon(0 100%, 100% 100%, 100% 49%, 86% 51%, 79% 59%, 70% 66%, 57% 71%, 43% 71%, 29% 65%, 21% 57%, 13% 49%, 0 49%); }
25% { transform: scale(1, 1); }
28% { transform: scale(0.95, 1.05); }
30% { clip-path: inset(0 0 0 0); }
Camera #1 Animation (changed)
icon: mdi:cctv
icon_color: deep-purple
primary: 'Camera #1'
card_mod:
style: |
ha-state-icon {
animation: flip 8s ease-in-out infinite alternate;
@keyframes flip {
50% { transform: rotateY(180deg); }
Camera #2 Animation (changed)
primary: 'Camera #2'
icon: mdi:cctv
card_mod:
style: |
ha-state-icon {
animation: scan 5s ease-in-out infinite;
transform-origin: 90% 80%
@keyframes scan {
0%, 100% { transform: rotate(20deg); }
50% { transform: rotate(-15deg); }
Battery #1 Animation (changed)
icon: mdi:battery
icon_color: green
primary: 'Battery #1'
card_mod:
style: |
ha-state-icon {
animation: charge 3s linear infinite;
@keyframes charge {
0%, 80% { clip-path: inset(0 0 0 0); }
10% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 74%, 34% 74%, 34% 100%, 100% 100%, 100% 0%); }
30% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 54%, 34% 54%, 34% 100%, 100% 100%, 100% 0%); }
50% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 34%, 34% 34%, 34% 100%, 100% 100%, 100% 0%); }
70% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
Battery #2 Animation (changed)
icon: mdi:battery-high
icon_color: green
primary: 'Battery #2'
card_mod:
style: |
ha-state-icon {
animation: charge 3s steps(1) infinite;
@keyframes charge {
20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
Wrench Animation (changed)
primary: Wrench
icon: mdi:wrench
icon_color: grey
card_mod:
style: |
ha-state-icon {
animation: tighten 1.5s ease-in-out infinite;
transform-origin: 31% 31%
@keyframes tighten {
0%, 100% { transform: rotate(-20deg); }
80% { transform: rotate(15deg); }
This is just part 1 of the pack created by @rhysb. the remaining 4 more parts will be posted as i complete reviews of them to see what has changed. if you like any of these animations please go to the original post here and give it a like. i didnt create any of these animations. i just updated them for the newest format ![]()
Updated Posts ![]()
Part 1, Part 2, Part 3, Part 4, Part 5
Original Posts by @rhysb
please only like his posts.
