Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Wonderful. This is very good to know. Thanks for these codes.
Also, if I want the card to only glow when a specific entity state is on then how can I implement that? It will stay without the box shadow when my lights are off.
I was trying to make sense of your code in alarm card but i don’t think that code is applicable to how I want it.
Basically take the state of any entity you have and do this:
card_mod:
  style: |
    ha-card {
      {% if states('entity_type.entity_id') == 'state' %}
        box-shadow: your box shadow settings;
        box-shadow: none (or maybe a different shadow?,
        or if you want it to go back to default just leave this entire section blank. Dont even include the box shadow reference)
The only reason i referred to config.entity in the alarm panel card is esentially a trick to use whatever entity is being used in the card itself as the entity being used for the if state template :slight_smile:
Works!
This was pretty good actually. I already had an if for lightbulb chip to appear at the bottom when the light is on but this is good to know that I could add a second if as well. Makes sense.
Hi @rhysb,
i have made a general mushroom - card-mod styling guide that i have posted here. i have linked to your resource on animations from it because it is great. however since it was made a few things have changed with the way that animations are applied and we get a bunch of questions regarding it right now because people want to use your animations. so i hope you dont mind that i have gone through and updated each of your animations below and will be posting them as a reply here.
i will also link to both your original post and my updated ones in my guide, but i will send people to your post for giving it a like :slight_smile:
Built-in Mushroom Animations
There are two built-in animations for Mushroom cards that can be used without specifying any @keyframes. These are spin, which is used for the rotating fan, and pulse, which fades in and out.
Built-in Spin Animation (changed):
Mushroom Built-in Spin
type: custom:mushroom-template-card
primary: Spin
icon: mdi:fan
icon_color: teal
card_mod:
  style: |
    ha-state-icon {
      animation: spin 1s linear infinite;
Built-in Pulse Animation (changed):
Mushroom Built-in Pulse
icon: mdi:pulse
icon_color: red
primary: Pulse
card_mod:
  style: |
    ha-state-icon {
      animation: pulse 2s ease-in-out infinite;
Animated Mushroom Cards
Mushroom Media Player Card (unchanged):
Mushroom Media Player Card with Animated Icons
Media Player Animated Icons
type: custom:mushroom-media-player-card
entity: media_player.currently_playing
icon: mdi:play
use_media_info: true
use_media_artwork: false
show_volume_level: false
media_controls:
  - play_pause_stop
  - previous
  - next
volume_controls:
  - volume_buttons
  - volume_set
fill_container: false
card_mod:
  style: |
   mushroom-shape-icon {
      display: flex;
      {% set media_type = state_attr(config.entity, 'media_content_type') %}
      {% if media_type == 'tvshow' %}
        --card-mod-icon: mdi:television-classic;
        animation: flicker 1s linear infinite alternate;
      {% elif media_type == 'movie' %}
        --card-mod-icon: mdi:movie-roll;
        animation: spin 2s linear infinite reverse;
      {% elif media_type == 'music' %}
        --card-mod-icon: mdi:music;
        animation: beat 1.3s ease-out infinite both;
      {% elif media_type == 'playlist' %}
        --card-mod-icon: mdi:play;
    @keyframes flicker {
      0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { --icon-color: rgba(var(--rgb-indigo), 1); }
      32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { --icon-color: rgba(var(--rgb-indigo), 0.6); }
    @keyframes beat {
      0%, 60% { --icon-symbol-size: 21px; }
      5%, 17%, 57% { --icon-symbol-size: 22px; }
      10%, 20%, 51% { --icon-symbol-size: 23px; }
      25%, 45% { --icon-symbol-size: 24px; }
      30%, 39% { --icon-symbol-size: 25px; }
      33% { --icon-symbol-size: 26px; }
    ha-card {
      {% if not is_state(config.entity, 'off') %}
        background: rgba(var(--rgb-card-background-color), 0.6) url( '{{ state_attr(config.entity, "entity_picture") }}' ) center no-repeat;
        background-size: cover;
        background-blend-mode: overlay;
Mushroom Climate Card (unchanged):
Mushroom Climate Card with Animated Icons
Climate Animated Icons
type: custom:mushroom-climate-card
entity: climate.office_air_conditioner
hvac_modes:
  - heat_cool
  - heat
  - cool
  - fan_only
  - dry
show_temperature_control: true
collapsible_controls: false
name: Air Conditioner
card_mod:
  style: |
      {% if is_state(config.entity, 'heat_cool') %}
        --card-mod-icon: mdi:autorenew;
        animation: spin 3s ease-in-out infinite alternate;
      {% elif is_state(config.entity, 'heat') %}
        --card-mod-icon: mdi:fire;
        animation: heat 2s infinite;
      {% elif is_state(config.entity, 'cool') %}
        --card-mod-icon: mdi:snowflake;
        animation: cool 6s ease-in-out infinite;
      {% elif is_state(config.entity, 'dry') %}
        --card-mod-icon: mdi:water-percent;
        animation: dry 1.5s linear infinite;
      {% elif is_state(config.entity, 'fan_only') %}
        --card-mod-icon: mdi:fan;
        --card-mod-icon: mdi:air-conditioner;
      display: flex;
    @keyframes cool {
      0%, 100% { transform: rotate(25deg); }
      25% { transform: rotate(-25deg); }
      50% { transform: rotate(50deg); }
      75% { transform: rotate(-50deg); }
    @keyframes heat {
      0%, 100% { --icon-color: rgba(var(--rgb-red), 1); }
      10%, 90% { --icon-color: rgba(var(--rgb-red), 0.8); }
      20%, 80% { --icon-color: rgba(var(--rgb-red), 0.6); }
      30%, 70% { --icon-color: rgba(var(--rgb-red), 0.4); }
      40%, 60% { --icon-color: rgba(var(--rgb-red), 0.2); }
      50% { --icon-color: rgba(var(--rgb-red), 0); }
    @keyframes dry {
      0%, 100% { --icon-symbol-size: 21px; }
      10%, 90% { --icon-symbol-size: 22px; }
      20%, 80% { --icon-symbol-size: 23px; }
      30%, 70% { --icon-symbol-size: 24px; }
      40%, 60% { --icon-symbol-size: 25px; }
      50% { --icon-symbol-size: 26px; }
Mushroom Card Icon Animations
Mushroom Boil
Boil Animation (changed)
primary: Boil
icon: mdi:kettle-steam
icon_color: red
card_mod:
  style: |
    ha-state-icon {
      animation: boil 500ms infinite;
    @keyframes boil {
      0%, 100% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      10% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); clip-path: polygon(0 0, 66% 10%, 67% 30%, 88% 52%, 100% 100%, 0 100%); }
      20% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      30% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      40% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      50% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      60% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      70% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      80% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      90% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
Mushroom Fire
Fire Animation (changed)
primary: Fire
icon: mdi:fire
icon_color: red
card_mod:
  style: |
    ha-state-icon {
      animation: fire 1.5s infinite;
      transform-origin: 50% 85%;
    @keyframes fire {
      0% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      5% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      10% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      15% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      20% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      25% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      30% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      35% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      40% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      45% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      50% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      55% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      60% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      65% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      70% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      75% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      80% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      85% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      90% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
      95% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-red)); opacity: {{range(7, 10) | random / 10}}; }
      100% { transform: rotate({{range(-20, 20) | random / 10}}deg) scaleY({{range(9, 12) | random / 10}}); color: rgb(var(--rgb-deep-orange)); opacity: {{range(7, 10) | random / 10}}; }
Mushroom Shower
Shower Animation (changed)
icon: mdi:shower-head
icon_color: light-blue
primary: Shower
card_mod:
  style: |
    ha-state-icon {
      animation: clip 0.7s ease-out infinite;
    @keyframes clip {
      0% {clip-path: inset(0 0 45% 0); }
      100% { clip-path: inset(0 0 0 0); }
Mushroom Sprinkler
Sprinkler Animation (changed)
icon: mdi:sprinkler
icon_color: cyan
primary: Sprinkler
card_mod:
  style: |
    ha-state-icon {
      animation: sprinkle 2s linear infinite;
      transform-origin: 29% 88%;
    @keyframes sprinkle {
      0%, 15%, 30%, 45%, 60%, 100% { clip-path: inset(0 55% 0 0); transform: rotate(0deg); }
      1%, 16%, 31%, 46% { clip-path: inset(0 0 0 0); transform: rotate(-10deg); }
      6%, 21%, 36%, 51% { transform: rotate(2deg); }
Mushroom Washing Machine
Washing Machine Animation (changed)
icon: mdi:washing-machine
icon_color: amber
primary: Washing Machine
card_mod:
  style: |
    ha-state-icon {
      animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
      transform-origin: 50% 110%;
    @keyframes shake {
      0%, 100% { transform: translate(0, 0) rotate(0); }
      20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
      40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
      60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
      80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
    @keyframes drum {
      50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
Mushroom Dishwasher
Dishwasher Animation (changed)
icon: mdi:dishwasher
icon_color: blue
primary: Dishwasher
card_mod:
  style: |
    ha-state-icon {
      animation: bounce 1.5s ease-in-out infinite, wash 1s ease-in-out infinite;
      transform-origin: 50% 75%;
    @keyframes bounce {
      0%, 20%, 50%, 80%, 100% {transform: translateY(0); }
      40% { transform: translateY(-1.2px) rotate(5deg); }
      60% { transform: translateY(-1.1px) rotate(-4deg); }
    @keyframes wash {
      50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
Mushroom Dryer
Dryer Animation (changed)
icon: mdi:tumble-dryer
icon_color: teal
primary: Dryer
card_mod:
  style: |
    ha-state-icon {
      animation: shake 400ms ease-in-out infinite, drum 1s infinite;
      transform-origin: 50% 65%;
    @keyframes shake {
      0%, 100% { transform: rotate(4deg); }
      50%  { transform: rotate(-4deg); }
    @keyframes drum {
Mushroom Ding
Ding Animation (changed)
primary: Ding
icon: mdi:bell-ring
icon_color: indigo
card_mod:
  style: |
    ha-state-icon {
      animation: ring 4s linear infinite;
      transform-origin: 50% 15%;
    @keyframes ring {
      0% { transform: rotate(0); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
      2% { transform: rotate(30deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
      6% { transform: rotate(-28deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
      10% { transform: rotate(34deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
      14% { transform: rotate(-32deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
      18% { transform: rotate(30deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
      22% { transform: rotate(-28deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
      26% { transform: rotate(26deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
      30% { transform: rotate(-24deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
      34% { transform: rotate(22deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
      38% { transform: rotate(-20deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
      42% { transform: rotate(18deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
      46% { transform: rotate(-16deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
      50% { transform: rotate(14deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
      54% { transform: rotate(-12deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
      58% { transform: rotate(10deg); clip-path: polygon(0 0, 100% 0, 100% 100%, 0% 100%); }
      62% { transform: rotate(-8deg); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
      66% { transform: rotate(6deg); }
      70% { transform: rotate(-4deg); }
      74% { transform: rotate(2deg); }
      78% { transform: rotate(-1deg); }
      82% { transform: rotate(1deg); }
      86% { transform: rotate(0); }
      100% { transform: rotate(0); clip-path: polygon(0 50%, 0 100%, 100% 100%, 100% 50%, 85% 50%, 80% 30%, 60% 5%, 40% 5%, 20% 30%, 15% 50%); }
Mushroom Alarm
Alarm Animation (changed)
icon: mdi:alarm
icon_color: red
primary: Alarm
card_mod:
  style: |
    ha-state-icon {
      animation: alarm 0.8s ease infinite;
    @keyframes alarm {
      0%, 80%, 100% { transform: translateY(0); }
      10% { transform: translateY(-2px) rotate(-27deg); }
      20% { transform: translateY(-2px) rotate(21deg); }
      30% { transform: translateY(-2px) rotate(-15deg); }
      40% { transform: translateY(-2px) rotate(9deg); }
      50% { transform: translateY(0); }
      60% { transform: translateY(-1.2px) }
Mushroom Rocket Man
Rocket Man Animation (changed)
icon: mdi:rocket-launch
icon_color: deep-orange
primary: Rocket Man
card_mod:
  style: |
    ha-state-icon {
      animation: thrust 100ms infinite, motion 3s ease-in-out infinite;
    @keyframes thrust {
      0% { clip-path: polygon(0 0, 0 47%, 22% 57%, 28% 63%, 0 91%, 11% 100%, 37% 73%, 45% 77%, 55% 100%, 100% 100%, 100% 0%); }
      33% { clip-path: polygon(0 0, 0 47%, 24% 59%, 42% 76%, 54% 100%, 100% 100%, 100% 0); }
      66% { clip-path: polygon(0 0, 0 92%, 28% 64%, 36% 72%, 9% 100%, 100% 100%, 100% 0%); }
      @keyframes motion {
      0%, 100% { transform: translateY(-2px) translateX(-3px); }
      50% { transform: translateY(3px) translateX(2px); }
Mushroom Fountain
Fountain Animation (changed)
primary: Fountain
icon: mdi:fountain
card_mod:
  style: |
    ha-state-icon {
      animation: fountain 1.5s ease infinite;
    @keyframes fountain {
      0%, 100 { clip-path: polygon(0 100%, 0 0, 100% 0, 100% 100%); }
      50% { clip-path: polygon(0 100%, 0 47%, 100% 47%, 100% 100%); }
      60% { clip-path: polygon(0 100%, 100% 100%, 100% 37%, 79% 36%, 71% 21%, 56% 25%, 44% 25%, 31% 20%, 20% 36%, 0 36%); }
      70% { clip-path: polygon(0 100%, 100% 100%, 100% 36%, 79% 36%, 71% 22%, 81% 1%, 24% 0, 31% 21%, 20% 36%, 0 36%); }
      80% { clip-path: polygon(0 100%, 100% 100%, 100% 36%, 79% 36%, 76% 28%, 100% 0, 0 0, 23% 28%, 20% 36%, 0 36%); }
Mushroom Motion
Motion Animation (changed)
icon: mdi:motion-sensor
icon_color: blue
primary: Motion
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        --shape-animation: motion 2s linear infinite;
      @keyframes motion {
        0%, 100% { --shape-color: rgba(var(--rgb-blue), 0.3); }
        50% { --shape-color: rgba(var(--rgb-blue), 0.2); }
      ha-state-icon {
        animation: clip 2s linear infinite;
      @keyframes clip {
        50% { clip-path: polygon(0 0, 55% 0, 100% 100%, 0 100%); }
Mushroom Cog
Cog Animation (changed)
primary: Cog
icon: mdi:cog
icon_color: grey
card_mod:
  style: |
    ha-state-icon {
      animation: spin 1.5s steps(5) infinite;
Mushroom Signal
Signal Animation (changed)
icon: mdi:wifi
icon_color: green
primary: Signal
card_mod:
  style:
      .shape {
        --shape-animation: ping 2s infinite;
      @keyframes ping {
        60% { box-shadow: 0 0 0 0 rgba(var(--rgb-green), 0.7); }
        100% { box-shadow: 0 0 5px 15px transparent; }
      ha-state-icon {
        animation: clip 2s steps(1) infinite;
      @keyframes clip {
        0% { clip-path: circle(0% at 50% 85%); }
        20% { clip-path: circle(30% at 50% 85%); }
        40% { clip-path: circle(55% at 50% 85%); }
        60% { clip-path: circle(80% at 50% 85%); }
Mushroom Alert
Alert Animation (changed)
icon: mdi:alarm-light
icon_color: red
primary: Alert
card_mod:
  style:
      .shape {
        --shape-animation: alert-shape 0.8s infinite;
      @keyframes alert-shape {
        0%, 100% { --shape-color: rgba(var(--rgb-orange), 0.2); }
        60% { --shape-color: rgba(var(--rgb-red), 0.2); }
      ha-state-icon {
        animation: alert 0.8s infinite;
      @keyframes alert {
        0%, 100% { color: rgb(var(--rgb-orange)); }
        50% { clip-path: polygon(0% 55%, 25% 55%, 25% 35%, 35% 25%, 50% 18%, 65% 20%, 75% 35%, 75% 55%, 100% 55%, 100% 100%, 0 100%); color: rgb(var(--rgb-red)); }
Mushroom Console
Console Animation (changed)
icon: mdi:console-line
icon_color: grey
primary: Console
card_mod:
  style: |
    ha-state-icon {
      animation: console 1s infinite;
    @keyframes console {
      50% { clip-path: polygon(0 0, 100% 0, 24% 100%, 0 100%); }
Mushroom Keypad
Keypad Animation (changed)
icon: mdi:dialpad
icon_color: blue
primary: Keypad
card_mod:
  style:
      .shape {
        --shape-animation: ping 4s infinite;
      @keyframes ping {
        55% { box-shadow: 0 0 1px 0px rgba(var(--rgb-blue), 0.3) inset; }
        100% { box-shadow: 0 0 5px 15px transparent inset; }
      ha-state-icon {
        animation: pin 4s infinite;
      @keyframes pin {
        0%, 15%, 25%, 35%, 45%, 55% { clip-path: inset(0 0 0 0); }
        10% { clip-path: polygon(0% 100%, 1% 23%, 36% 23%, 36% 0%, 100% 0, 100% 100%); }
        20% { clip-path: polygon(0% 100%, 0 0, 62% 0, 61% 25%, 100% 24%, 100% 100%); }
        30% { clip-path: polygon(0 0, 100% 0, 100% 100%, 0 100%, 0 25%, 36% 25%, 37% 50%, 63% 49%, 62% 26%, 0 25%); }
        40% { clip-path: polygon(0 51%, 0 0, 100% 0, 100% 100%, 36% 100%, 37% 51%); }
        50% { clip-path: polygon(0 100%, 0 0, 100% 0, 100% 50%, 64% 50%, 64% 100%); }
Mushroom Eye
Eye Animation (changed)
icon: mdi:eye
icon_color: blue
primary: Eye
card_mod:
  style: |
    ha-state-icon {
      animation: wink 4s ease-in-out infinite;
    @keyframes wink {
      0%, 100% { transform: scale(1, 1); }
      19% { transform: scale(1.05, 0.6); }
      20% { clip-path: polygon(0 100%, 100% 100%, 100% 49%, 86% 51%, 79% 59%, 70% 66%, 57% 71%, 43% 71%, 29% 65%, 21% 57%, 13% 49%, 0 49%); }
      25% { transform: scale(1, 1); }
      28% { transform: scale(0.95, 1.05); }
      30% { clip-path: inset(0 0 0 0); }
Mushroom Camera 1
Camera #1 Animation (changed)
icon: mdi:cctv
icon_color: deep-purple
primary: 'Camera #1'
card_mod:
  style: |
    ha-state-icon {
      animation: flip 8s ease-in-out infinite alternate;
    @keyframes flip {
      50% { transform: rotateY(180deg); }
Mushroom Camera 2
Camera #2 Animation (changed)
primary: 'Camera #2'
icon: mdi:cctv
card_mod:
  style: |
    ha-state-icon {
      animation: scan 5s ease-in-out infinite;
      transform-origin: 90% 80%
    @keyframes scan {
      0%, 100% { transform: rotate(20deg); }
      50% { transform: rotate(-15deg); }
Mushroom Battery 1
Battery #1 Animation (changed)
icon: mdi:battery
icon_color: green
primary: 'Battery #1'
card_mod:
  style: |
    ha-state-icon {
      animation: charge 3s linear infinite;
    @keyframes charge {
      0%, 80% { clip-path: inset(0 0 0 0); }
      10% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
      20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 74%, 34% 74%, 34% 100%, 100% 100%, 100% 0%); }
      30% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
      40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 54%, 34% 54%, 34% 100%, 100% 100%, 100% 0%); }
      50% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
      60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 34%, 34% 34%, 34% 100%, 100% 100%, 100% 0%); }
      70% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
Mushroom Battery 2
Battery #2 Animation (changed)
icon: mdi:battery-high
icon_color: green
primary: 'Battery #2'
card_mod:
  style: |
    ha-state-icon {
      animation: charge 3s steps(1) infinite;
    @keyframes charge {
      20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
      40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
      60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
Mushroom Wrench
Wrench Animation (changed)
primary: Wrench
icon: mdi:wrench
icon_color: grey
card_mod:
  style: |
    ha-state-icon {
      animation: tighten 1.5s ease-in-out infinite;
      transform-origin: 31% 31%
    @keyframes tighten {
      0%, 100% { transform: rotate(-20deg); }
      80% { transform: rotate(15deg); }
This is just part 1 of the pack created by @rhysb. the remaining 4 more parts will be posted as i complete reviews of them to see what has changed. if you like any of these animations please go to the original post here and give it a like. i didnt create any of these animations. i just updated them for the newest format :slight_smile:
Updated Posts :point_down:
Part 1, Part 2, Part 3, Part 4, Part 5
Original Posts by @rhysb :point_down: please only like his posts.
@Boostin4HP Do you mind sharing the code for your dashboard?
Is that a single dashboard or there is some navigation involved?
Again, please like the original post by @rhysb here i have only updated some animations that needed updating.
Mushroom Title Animations (all unchanged)
These ones run once to transition in the Mushroom Title.
Mushroom Title Typewriter
Typewriter Animation (unchanged)
type: custom:mod-card
card:
  type: custom:mushroom-title-card
  title: Mushroom.
  subtitle: Typewriter
card_mod:
  style:
    mushroom-title-card$: |
      h1 {
        width: 9ch;
        animation: typing 5s steps(9), cursor 0.25s step-end 30 alternate;
        overflow: hidden;
        border-right: 2px solid transparent;
        font-family: monospace;
       @keyframes typing {
        0% { width: 0; }
      @keyframes cursor {
        50% { border-color: var(--primary-text-color); }
Mushroom Title Scale-In
Scale-in Animation (unchanged)
card:
  title: Mushroom 🍄
  subtitle: Scale-in
card_mod:
  style:
          animation: scale-in 1s;
          transform-origin: 15%;
      @keyframes scale-in {
        0% { transform: scale(0); opacity: 0; }
        100% { transform: scale(1); opacity: 1; }
Mushroom Title Fade-In
Fade-in Animation (unchanged)
card:
  title: Mushroom 🍄
  subtitle: Fade-in
card_mod:
  style:
        animation: fade 1s ease-in;
      @keyframes fade {
        0% { opacity: 0; }
        100% { opacity: 1; }
Mushroom Title Focus
Focus Animation (unchanged)
card:
  title: Mushroom 🍄
  subtitle: Focus
card_mod:
  style:
        animation: focus 1.5s;
      @keyframes focus {
        0% { filter: blur(10px); opacity: 0; }
Mushroom Title Drop-In
Drop-in Animation (unchanged)
card:
  title: Mushroom 🍄
  subtitle: Drop-in
card_mod:
  style:
        animation: drop-in 1.1s both;
      @keyframes drop-in {
        0% { transform: translateY(-400px); animation-timing-function: ease-in; filter: blur(40px); opacity: 0; }
        38% { transform: translateY(0); animation-timing-function: ease-out; filter: blur(0); opacity: 1; }
        55% { transform: translateY(-16px); animation-timing-function: ease-in; }
        72% { transform: translateY(0); animation-timing-function: ease-out; }
        81% { transform: translateY(-7px); animation-timing-function: ease-in; }
        90% { transform: translateY(0); animation-timing-function: ease-out; }
        95% { transform: translateY(-2px); animation-timing-function: ease-in; }
        100% { transform: translateY(0); animation-timing-function: ease-out; }
Mushroom Title Slide-In
Slide-in Animation (unchanged)
card:
  title: Mushroom 🍄
  subtitle: Slide-in
card_mod:
  style:
        animation: slide-in 1.1s both;
      @keyframes slide-in {
        0% { transform: translateX(600px) scaleX(2.5) scaleY(0.2); animation-timing-function: ease-in; filter: blur(40px); opacity: 0; }
        38% { transform: translateX(0) scaleY(1) scaleX(1); animation-timing-function: ease-out; filter: blur(0); opacity: 1; }
        55% { transform: translateX(68px) scaleY(1.1) scaleX(0.95); animation-timing-function: ease-in; }
        72% { transform: translateX(0) scaleY(1) scaleX(1); animation-timing-function: ease-out; }
        81% { transform: translateX(32px) scaleY(1.05) scaleX(0.98); animation-timing-function: ease-in; }
        90% { transform: translateX(0) scaleY(1) scaleX(1); animation-timing-function: ease-out; }
        95% { transform: translateX(8px); animation-timing-function: ease-in; }
        100% { transform: translateX(0); animation-timing-function: ease-out; }
Mushroom Title Flicker
Flicker Animation (unchanged)
card:
  title: Mushroom 🍄
  subtitle: Flicker
card_mod:
  style:
        animation: flicker 1.1s both;
        0%, 10%, 10.2%, 20%, 20.6%, 30%, 30.6%, 45%, 55.1%, 57%, 60.1%, 65%, 75.1%, 77%, 85.1%, 86% { opacity: 0; }
        10.1%, 20.1%, 30.1%, 30.5%, 45.1%, 50%, 55%, 57.1%, 60%, 65.1%, 75%, 77.1%, 85%, 86.1%, 100% { opacity: 1; }
Mushroom Spinner Animations
Mushroom Comet Spinner
Comet Spinner (unchanged)
icon: none
primary: Comet
card_mod:
  style:
      .shape {
        border-right: 4px solid;
        border-bottom: 4px solid transparent;
        --shape-animation: spin 1s linear infinite, comet 10s infinite;
        --shape-color: none;
        --icon-size: 38px;
      @keyframes comet {
        0% { border-right-color: rgb(var(--rgb-red)); }
        6.25% { border-right-color: rgb(var(--rgb-deep-orange)); }
        12.5% { border-right-color: rgb(var(--rgb-orange)); }
        18.75% { border-right-color: rgb(var(--rgb-amber)); }
        25% { border-right-color: rgb(var(--rgb-yellow)); }
        31.25% { border-right-color: rgb(var(--rgb-lime)); }
        37.5% { border-right-color: rgb(var(--rgb-light-green)); }
        43.75% { border-right-color: rgb(var(--rgb-green)); }
        50% { border-right-color: rgb(var(--rgb-teal)); }
        56.25% { border-right-color: rgb(var(--rgb-cyan)); }
        62.5% { border-right-color: rgb(var(--rgb-light-blue)); }
        68.75% { border-right-color: rgb(var(--rgb-blue)); }
        75% { border-right-color: rgb(var(--rgb-indigo)); }
        81.25% { border-right-color: rgb(var(--rgb-deep-purple)); }
        87.5% { border-right-color: rgb(var(--rgb-purple)); }
        93.75% { border-right-color: rgb(var(--rgb-pink)); }
        100% { border-right-color: rgb(var(--rgb-red)); }
Mushroom Crescent Spinner
Crescent Spinner (unchanged)
icon: none
primary: Crescent
card_mod:
  style:
      .shape {
        border: 1px solid rgba(var(--rgb-disabled), 0.8);
        border-right: 3px solid rgba(var(--rgb-light-blue));
        --shape-animation: spin 1s linear infinite;
        --icon-size: 40px;
Mushroom Munch Spinner
Munch Spinner (changed)
icon: none
primary: Munch
card_mod:
  style:
      .shape {
        --shape-animation: spin 2s linear infinite;
        border-radius: 50%;
        border: 4px solid transparent;
        border-top-color: rgb(var(--rgb-amber));
        --icon-symbol-size: 34px;
        --icon-size: 34px;
      ha-state-icon {
        animation: spin 1.5s linear infinite reverse;
        border-radius: 50%;
        --icon-size: 34px;
Mushroom Double Spinner
Double Spinner (changed)
icon: none
primary: Double
card_mod:
  style:
      .shape {
        border: 4px double transparent;
        border-left-color: rgb(var(--rgb-amber));
        border-bottom-color: rgb(var(--rgb-amber));
        --icon-symbol-size: 20px;
        --icon-size: 34px;
      ha-state-icon {
        animation: spin 1s linear infinite reverse;
        border-radius: 50%;
        border-top-color: rgb(var(--rgb-deep-orange));
Mushroom St. Nick Spinner
St. Nick Spinner (changed, this one does look weird on firefox for me for some reason. works fine on mobile.)
icon: none
primary: St. Nick
card_mod:
  style:
      .shape {
        border: 4px dashed rgb(var(--rgb-green));
        --icon-symbol-size: 5px;
        --icon-size: 34px;
      ha-state-icon {
        animation: spin 0.5s linear infinite reverse;
        border-radius: 50%;
        border: 8px dotted rgb(var(--rgb-red));
Mushroom Gradient Spinner
Gradient Spinner (unchanged)
icon: none
primary: Gradient
card_mod:
  style:
      .shape {
         background: radial-gradient(farthest-side, rgb(var(--rgb-blue)) 94%, transparent) top/4px 4px no-repeat, conic-gradient(transparent 30%, rgb(var(--rgb-blue)));
         -webkit-mask: radial-gradient(farthest-side, transparent calc(100% - 4px), #000 0);
         --shape-animation: spin 1s infinite linear;
Mushroom Dots Spinner
Dots Spinner (unchanged)
icon: none
primary: Dots
card_mod:
  style:
      .shape {
          border: 4px dotted transparent;
          --shape-animation: spin 800ms ease-in-out infinite, color 10s infinite;
          --icon-size: 34px;
      @keyframes color {
        0% { border-right-color: rgb(var(--rgb-red)); border-top-color: rgb(var(--rgb-red)); }
        6.25% { border-right-color: rgb(var(--rgb-deep-orange)); border-top-color: rgb(var(--rgb-deep-orange)); }
        12.5% { border-right-color: rgb(var(--rgb-orange)); border-top-color: rgb(var(--rgb-orange)); }
        18.75% { border-right-color: rgb(var(--rgb-amber)); border-top-color: rgb(var(--rgb-amber)); }
        25% { border-right-color: rgb(var(--rgb-yellow)); border-top-color: rgb(var(--rgb-yellow)); }
        31.25% { border-right-color: rgb(var(--rgb-lime)); border-top-color: rgb(var(--rgb-lime)); }
        37.5% { border-right-color: rgb(var(--rgb-light-green)); border-top-color: rgb(var(--rgb-light-green)); }
        43.75% { border-right-color: rgb(var(--rgb-green)); border-top-color: rgb(var(--rgb-green)); }
        50% { border-right-color: rgb(var(--rgb-teal)); border-top-color: rgb(var(--rgb-teal)); }
        56.25% { border-right-color: rgb(var(--rgb-cyan)); border-top-color: rgb(var(--rgb-cyan)); }
        62.5% { border-right-color: rgb(var(--rgb-light-blue)); border-top-color: rgb(var(--rgb-light-blue)); }
        68.75% { border-right-color: rgb(var(--rgb-blue)); border-top-color: rgb(var(--rgb-blue)); }
        75% { border-right-color: rgb(var(--rgb-indigo)); border-top-color: rgb(var(--rgb-indigo)); }
        81.25% { border-right-color: rgb(var(--rgb-deep-purple)); border-top-color: rgb(var(--rgb-deep-purple)); }
        87.5% { border-right-color: rgb(var(--rgb-purple)); border-top-color: rgb(var(--rgb-purple)); }
        93.75% { border-right-color: rgb(var(--rgb-pink)); border-top-color: rgb(var(--rgb-pink)); }
        100% { border-right-color: rgb(var(--rgb-red)); border-top-color: rgb(var(--rgb-red)); }
Mushroom Radial Spinner
Radial Spinner (changed)
icon: none
primary: Radial
card_mod:
  style:
      .shape {
        border: 3px solid rgb(var(--rgb-red));
        border-right-color: transparent;
        --icon-size: 36px;
      ha-state-icon {
        animation: spin 1.5s linear infinite;
        border-radius: 50%;
        border: 3px solid rgb(var(--rgb-blue));
Mushroom Dual Spinner
Dual Spinner (unchanged)
icon: none
primary: Dual
card_mod:
  style:
      .shape {
        --shape-animation: spin 1s ease infinite;
        border-bottom-color: rgb(var(--rgb-deep-orange));
        --shape-color: none !important;
        --icon-size: 34px;
Mushroom Morse Spinner
Morse Spinner (changed)
icon: none
primary: Morse
card_mod:
  style:
      .shape {
        border: 4px dashed transparent;
        border-left-color: rgb(var(--rgb-purple));
        --icon-size: 34px;
      ha-state-icon {
        border-radius: 50%;
        border-left-color: rgb(var(--rgb-pink));
Mushroom Fade Spinner
Fade Spinner (unchanged)
icon: none
primary: Fade
card_mod:
  style:
      .shape {
        --shape-animation: fade 25s linear infinite reverse;
      @keyframes fade {
        6.24%, 12.49%, 18.74%, 24.99%, 31.24%, 37.49%, 43.74%, 49.99%, 56.24%, 62.49%, 68.74%, 74.99%, 81.24%, 87.49%, 93.74%, 100%  { box-shadow: 0 0 20px 20px transparent inset; }
        0% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.7) inset; }
        6.25% { box-shadow: 0 0 0 0 rgba(var(--rgb-deep-orange), 0.7) inset; }
        12.5% { box-shadow: 0 0 0 0 rgba(var(--rgb-orange), 0.7) inset; }
        18.75% { box-shadow: 0 0 0 0 rgba(var(--rgb-amber), 0.7) inset; }
        25% { box-shadow: 0 0 0 0 rgba(var(--rgb-yellow), 0.7) inset; }
        31.25% { box-shadow: 0 0 0 0 rgba(var(--rgb-lime), 0.7) inset; }
        37.5% { box-shadow: 0 0 0 0 rgb(var(--rgb-light-green), 0.7) inset; }
        43.75% { box-shadow: 0 0 0 0 rgb(var(--rgb-green), 0.7) inset; }
        50% { box-shadow: 0 0 0 0 rgb(var(--rgb-teal), 0.7) inset; }
        56.25% { box-shadow: 0 0 0 0 rgb(var(--rgb-cyan), 0.7) inset; }
        62.5% { box-shadow: 0 0 0 0 rgb(var(--rgb-light-blue), 0.7) inset; }
        68.75% { box-shadow: 0 0 0 0 rgb(var(--rgb-blue), 0.7) inset; }
        75% { box-shadow: 0 0 0 0 rgb(var(--rgb-indigo), 0.7) inset; }
        81.25% { box-shadow: 0 0 0 0 rgb(var(--rgb-deep-purple), 0.7) inset; }
        87.5% { box-shadow: 0 0 0 0 rgb(var(--rgb-purple), 0.7) inset; }
        93.75% { box-shadow: 0 0 0 0 rgb(var(--rgb-pink), 0.7) inset; }
Mushroom Dotty Spinner
Dotty Spinner (changed)
card_mod:
  style:
      .shape {
        border: 5px dotted transparent;
        --shape-animation: spin 2s linear infinite, color 60s infinite;
        --icon-symbol-size: 30px;
        --icon-size: 32px;
      @keyframes color {
        0% { border-color: rgb(var(--rgb-red)); color: rgb(var(--rgb-red)); }
        6.25% { border-color: rgb(var(--rgb-deep-orange)); color: rgb(var(--rgb-pink)); }
        12.5% { border-color: rgb(var(--rgb-orange)); color: rgb(var(--rgb-purple)); }
        18.75% { border-color: rgb(var(--rgb-amber)); color: rgb(var(--rgb-deep-purple)); }
        25% { border-color: rgb(var(--rgb-yellow)); color: rgb(var(--rgb-indigo)); }
        31.25% { border-color: rgb(var(--rgb-lime)); color: rgb(var(--rgb-blue)); }
        37.5% { border-color: rgb(var(--rgb-light-green)); color: rgb(var(--rgb-light-blue)); }
        43.75% { border-color: rgb(var(--rgb-green)); color: rgb(var(--rgb-cyan)); }
        50% { border-color: rgb(var(--rgb-teal)); color: rgb(var(--rgb-teal)); }
        56.25% { border-color: rgb(var(--rgb-cyan)); color: rgb(var(--rgb-green)); }
        62.5% { border-color: rgb(var(--rgb-light-blue)); color: rgb(var(--rgb-light-green)); }
        68.75% { border-color: rgb(var(--rgb-blue)); color: rgb(var(--rgb-lime)); }
        75% { border-color: rgb(var(--rgb-indigo)); color: rgb(var(--rgb-yellow)); }
        81.25% { border-color: rgb(var(--rgb-deep-purple)); color: rgb(var(--rgb-amber)); }
        87.5% { border-color: rgb(var(--rgb-purple)); color: rgb(var(--rgb-orange)); }
        93.75% { border-color: rgb(var(--rgb-pink)); color: rgb(var(--rgb-deep-orange)); }
        100% { border-color: rgb(var(--rgb-red)); color: rgb(var(--rgb-red)); }
      ha-state-icon {
        animation: spin 1s linear infinite reverse, color 60s infinite;
      @keyframes color {
Mushroom Plain Spinner
Plain Spinner (unchanged)
icon: none
primary: Plain
card_mod:
  style:
      .shape {
        border: 5px solid rgb(var(--rgb-disabled));
        border-left-color: transparent;
        --icon-size: 32px;
Mushroom Toggle Spinner
Toggle Spinner (changed)
icon: none
primary: Toggle
card_mod:
  style:
      .shape {
        border-left-color: rgb(var(--rgb-cyan));
        --icon-size: 34px;
      ha-state-icon {
        border-radius: 50%;
Mushroom Spheres Spinner
Spheres Spinner (changed, this one looks very weird on firefox for me. but works fine on mobile.)
icon: none
primary: Spheres
card_mod:
  style:
      .shape  {
        border: 12px dotted transparent;
        border-left-color: rgb(var(--rgb-red));
        --icon-symbol-size: 18px;
        --icon-size: 18px;
      ha-state-icon {
        border-radius: 50%;
        border-left-color: rgb(var(--rgb-blue));
Mushroom Triple Spinner
Triple Spinner (changed)
icon: mdi:loading
icon_color: red
primary: Triple
card_mod:
  style:
      .shape {
        border-bottom-color: rgb(var(--rgb-green));
        --icon-symbol-size: 42px;
        --icon-size: 34px;
      ha-state-icon {
        animation: spin 4s linear infinite;
        border-radius: 50%;
        border-bottom-color: rgb(var(--rgb-blue));
Mushroom Card Active Animations (all unchanged)
Mushroom Activate Background
Activate Background (unchanged)
primary: Activate Mushroom
icon: mdi:mushroom
icon_color: red
secondary: Background
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      background: rgba(var(--rgb-disabled), 0.1);
      transition: 0s;
Mushroom Activate Box-shadow
Activate Box-Shadow (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: Box-Shadow
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      box-shadow: 0 0 20px rgba(var(--rgb-disabled), 0.8);
      transition: 0s;
Mushroom Activate Scale-Out
Activate Scale-Out (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: Scale-Out
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      transform: scale(1.02);
      transition: 0s;
Mushroom Activate Scale-In
Activate Scale-In (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: Scale-In
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      transform: scale(0.975);
      transition: 0s;
Mushroom Activate Push Down
Activate Push Down (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: Push Down
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      transform: translateY(1.5px);
      transition: 0s;
      box-shadow: 0 0.5px 2px 0 rgba(0, 0, 0, 0.16);
Mushroom Activate Push In
Activate Push In (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: Push In
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      transform: translateY(-1.5px);
      transition: 0s;
Mushroom Activate Ripple
Activate Ripple (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: Ripple
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card {
      overflow: hidden;
    ha-card:after {
      display: none;
      content: "";
      position: absolute;
      border-radius: 50%;
      background-color: rgba(var(--rgb-disabled), 0.1);
      width: 100px;
      height: 100px;
      margin-top: -50px;
      margin-left: -50px;
      top: 50%;
      left: 50%;
      animation: ripple 750ms;
      opacity: 0;
    ha-card:active:after {
      display: block;
    @keyframes ripple {
      from { opacity: 1; transform: scale(0); }
      to { opacity: 0; transform: scale(10); }
Mushroom Activate 3D Perspective
Activate 3D Perspective (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: 3D Perspective
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    :host {
      perspective: 900px;
    ha-card:active {
      transform: rotateY(20deg);
      transition: 0s;
Mushroom Activate 3D Tilt
Activate 3D Tilt (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: 3D Tilt
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    :host {
      perspective: 1000px;
    ha-card:active {
      transform: rotate3d(0.5, -0.9, 0, 10deg) rotate(1deg);
      transition: 0s;
Mushroom Activate 3D Flap
Activate 3D Flap (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: 3D Flap
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    :host {
      perspective: 900px;
    ha-card:active {
      transform: rotateX(25deg);
      transform-origin: center bottom;
      transition: 0s;
Mushroom Activate Trash
Activate Icon Spin (unchanged)
icon: mdi:mushroom
icon_color: red
secondary: Icon Spin
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active mushroom-shape-icon {
        display: flex;
        #--icon-animation: spin 1s;
        transform: rotate(360deg);
        transition: 500ms;
Applying Active Animations to your Theme (unchanged)
Rather than applying the active animations to each card, you can apply the to all cards by adding the card_mod to your theme.
Mushroom Custom:
  card-mod-theme: "Mushroom Custom"
  card-mod-card: |
    ha-card:active {
      transition: 0s;
Reference documentation
Card mod Themes · thomasloven/lovelace-card-mod Wiki · GitHub
lovelace-card-mod/README-themes.md at master · thomasloven/lovelace-card-mod · GitHub
@dimitri.landerloos
I have a swipe card for my living room where it should show the temperature on the left top and chip for on/off on the right top followed by mini graph chart right underneath for temperature and humidity in my living room. I have done that successfully but unable to reduce the space between them so it can come to visually pleasing size.
I tried it in both vertical-stack way and grid way.
Here is with grid way:
lr_card_1
type: custom:swipe-card
cards:
  - type: custom:stack-in-card
    cards:
      - type: grid
        columns: 2
        cards:
          - type: custom:mushroom-entity-card
            entity: sensor.living_temperature
            icon: None
            tap_action:
              action: navigate
              navigation_path: living-room
            alignment: start
            chips:
              - type: light
                entity: light.livingroom_lights_2
                use_light_color: true
            alignment: end
      - type: custom:mini-graph-card
        keep:
          margin: false
          box_shadow: false
          background: false
        entities:
          - entity: sensor.living_temperature
            color: var(--green-color)
          - entity: sensor.living_humidity
            color: var(--blue-color)
            y_axis: secondary
        hours_to_show: 24
        line_width: 3
        font_size: 50
        animate: true
        show:
          icon: false
          state: false
          legend: false
          fill: fade
  - type: horizontal-stack
    cards:
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
        entity: light.lr_ceiling_lights
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
        entity: light.lr_ceiling_lights_2
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
        entity: light.lr_ceiling_lights_3
        icon: phu:recessed-ceiling
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
        entity: light.swing_lights
        icon: mdi:circle-double
Here it is with vertical stack way:
lr_card_2
cards:
  - type: vertical-stack
    cards:
        keep:
          margin: false
          box_shadow: false
          background: false
        mode: horizontal
        cards:
            icon: None
            tap_action:
              action: navigate
            alignment: start
            chips:
              - type: light
            alignment: end
        keep:
          margin: false
          box_shadow: false
          background: false
        entities:
            y_axis: secondary
        hours_to_show: 24
        line_width: 3
        font_size: 50
        animate: true
        show:
          icon: false
          state: false
          legend: false
          fill: fade
    cards:
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
Space in the vertical stack way shown later is preferable but without showing both cards separately.
My objective is to include all three things (temperature and chip entities horizontally on top and temperature/humidity chart right under those) while the whole card swipes to individual lights.
Where are these from btw? @galaxy
Edit: easier way is just to just declare square: false in the grid card :slight_smile:
cards:
    cards:
      - type: grid
        columns: 2
        square: false
        cards:
            icon: None
            tap_action:
              action: navigate
            alignment: start
            chips:
              - type: light
            alignment: end
        keep:
          margin: false
          box_shadow: false
          background: false
        entities:
            y_axis: secondary
        hours_to_show: 24
        line_width: 3
        font_size: 50
        animate: true
        show:
          icon: false
          state: false
          legend: false
          fill: fade
    cards:
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
Original Response:
Probably not the most elegant solution, but the first one i thought of. You could just add your vertical stack into a stack in card like this:
cards:
    cards:
      cards:
          keep:
            margin: false
            box_shadow: false
            background: false
          mode: horizontal
          cards:
              icon: None
              tap_action:
                action: navigate
              alignment: start
              chips:
                - type: light
              alignment: end
          keep:
            margin: false
            box_shadow: false
            background: false
          entities:
              y_axis: secondary
          hours_to_show: 24
          line_width: 3
          font_size: 50
          animate: true
          show:
            icon: false
            state: false
            legend: false
            fill: fade
    cards:
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
      - show_name: true
        show_icon: true
        type: button
        tap_action:
          action: toggle
Again, please ONLY like the original posts by @rhysb here i have only updated some animations that needed updating.
More Mushroom Card Icon Animations
Mushroom Flash Animation
Flash Animation (changed)
card_mod:
  style: |
    ha-state-icon {
      animation: flash 4s linear infinite;
    @keyframes flash {
      0%, 4%, 8%, 12%, 16%, 20%, 24%, 28%, 32%, 100% { transform: translate(0px,0px); }
      2% { transform: translate(-0.3px, 0px); }
      6% { transform: translate(0.3px, 0px); }
      10% { transform: translate(-0.2px, 0px); }
      14% { transform: translate(0.2px, 0px); }
      18% { transform: translate(-0.2px, 0px); }
      22% { transform: translate(0.5px, 0px); }
      26% { transform: translate(-0.5px, 0px); }
      34% { transform: translate(-1px, 5px); color: rgb(var(--rgb-amber)); }
      38% { transform: translate(0px, 0px); color: rgb(var(--rgb-white)); }
      40% { color: rgb(var(--rgb-amber)); }
Mushroom Charge Animation
Charge Animation (changed)
icon: mdi:lightning-bolt
icon_color: amber
primary: Charge
card_mod:
  style: |
    ha-state-icon {
      animation: charge 1s linear infinite;
    @keyframes charge {
      0%, 10%, 20%, 30%, 40%, 50%, 60%, 70%, 80%, 90%, 100% { transform: translate(0, 0); }
      5% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
      15% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
      25% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
      35% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
      45% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
      55% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
      65% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
      75% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
      85% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
      95% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
Mushroom Double Rainbow Animation
Double Rainbow Animation (changed)
icon: mdi:looks
primary: Double Rainbow
card_mod:
  style:
      .shape {
        --shape-animation: rainbow 40s linear infinite;
      @keyframes rainbow {
        0%, 100% {background: rgb(var(--rgb-red), 0.2);}
        6.25% { background: rgb(var(--rgb-deep-orange), 0.2);}
        12.5% { background: rgb(var(--rgb-orange), 0.2);}
        18.75% { background: rgb(var(--rgb-amber), 0.2);}
        25% { background: rgb(var(--rgb-yellow), 0.2); }
        31.25% { background: rgb(var(--rgb-lime), 0.2);}
        37.5% { background: rgb(var(--rgb-light-green), 0.2);}
        43.75% { background: rgb(var(--rgb-green), 0.2);}
        50% { background: rgb(var(--rgb-teal), 0.2);}
        56.25% { background: rgb(var(--rgb-cyan), 0.2);}
        62.5% { background: rgb(var(--rgb-light-blue), 0.2);}
        68.75% { background: rgb(var(--rgb-blue), 0.2); }
        75% { background: rgb(var(--rgb-indigo), 0.2);}
        81.25% { -background: rgb(var(--rgb-deep-purple), 0.2);}
        87.5% { background: rgb(var(--rgb-purple), 0.2);}
        93.75% { background: rgb(var(--rgb-pink), 0.2);}
      ha-state-icon {
        animation: double 3s linear infinite alternate, rainbow 40s linear infinite
      @keyframes double {
        0% { clip-path: inset(0 98% 0 0); transform: rotateY(0deg); }
        12.5% { clip-path: polygon(0 22%, 0 75%, 50% 75%); }
        25% { clip-path: inset(0 50% 0 0); }
        37.5% { clip-path: polygon(0 0, 0 75%, 50% 75%, 100% 0); }
        50% { clip-path: inset(0 0 0 0); transform: rotateY(0deg); }
        50.1% { transform: rotateY(180deg); }
        62.5% { clip-path: polygon(0 0, 0 75%, 50% 75%, 100% 0); }
        75% { clip-path: inset(0 50% 0 0); }
        87.5% { clip-path: polygon(0 22%, 0 75%, 50% 75%); }
        100% { clip-path: inset(0 98% 0 0); transform: rotateY(180deg); }
        0%, 100% {color: rgb(var(--rgb-red));}
        6.25% { color: rgb(var(--rgb-deep-orange));}
        12.5% { color: rgb(var(--rgb-orange));}
        18.75% { color: rgb(var(--rgb-amber));}
        25% { color: rgb(var(--rgb-yellow));}
        31.25% { color: rgb(var(--rgb-lime));}
        37.5% { color: rgb(var(--rgb-light-green));}
        43.75% { color: rgb(var(--rgb-green));}
        50% { color: rgb(var(--rgb-teal));}
        56.25% { color: rgb(var(--rgb-cyan));}
        62.5% { color: rgb(var(--rgb-light-blue));}
        68.75% { color: rgb(var(--rgb-blue));}
        75% { color: rgb(var(--rgb-indigo));}
        81.25% { color: rgb(var(--rgb-deep-purple));}
        87.5% { color: rgb(var(--rgb-purple));}
        93.75% { color: rgb(var(--rgb-pink));}
Mushroom Random Animation
Random Animation (unchanged, FYI if you dont know. this only updates when the page is refreshed. it is not an active animation.)
icon: none
icon_color: red
primary: Random
card_mod:
  style: |
    :host {
      --card-mod-icon: mdi:dice-{{range(1, 6) | random}};
Mushroom Sparkle Animation
Sparkle Animation (changed)
icon: mdi:shimmer
icon_color: amber
primary: Sparkle
card_mod:
  style:
      .shape {
        background: rgba(var(--rgb-disabled), 0.2);
      ha-state-icon {
        animation: stars 4s linear infinite;
      @keyframes stars {
        0%, 3.1%, 14.1%, 40.1%, 55.1% { clip-path: inset(0 0 0 0); }
        3%, 40% { clip-path: polygon(48% 100%, 48% 62%, 0 63%, 0 0, 100% 0, 99% 100%); }
        14% { clip-path: polygon(49% 45%, 48% 100%, 0 100%, 0 0, 100% 0, 100% 36%); }
        55% { clip-path: polygon(0 100%, 0 60%, 41% 65%, 49% 46%, 100% 44%, 100% 100%); }
Mushroom Eeeew Animation
Eeeew Animation (changed)
icon: mdi:bacteria
icon_color: light-green
primary: Eeeew
card_mod:
  style: |
    ha-state-icon {
      animation: wiggle 0.5s ease infinite;
      transform-origin: 80% 80%;
      display: flex;
      animation: spin 20s infinite;
    @keyframes wiggle {
      0%, 100% { transform: scale(1) rotate(1deg); }
      50% { transform: scale(1.04) rotate(-2deg); }
Mushroom Sunny Animation
Sunny Animation (changed)
primary: Sunny
icon: mdi:weather-sunny
icon_color: amber
card_mod:
  style: |
    ha-state-icon {
      animation: sunny 8s ease-in-out infinite alternate;
    @keyframes sunny {
      70% { transform: rotate(360deg) scale(1); }
      80% { transform: scale(1); }
      90% { transform: scale(1.15); }
      100% { transform: scale(1); }
Mushroom Cloudy Animation
Cloudy Animation (changed)
primary: Cloudy
icon: mdi:weather-cloudy
icon_color: grey
card_mod:
  style: |
    ha-state-icon {
      animation: cloudy 10s ease-in-out infinite;
    @keyframes cloudy {
      0%, 100% { transform: translateX(3px); }
      30% { transform: translateX(-1px); }
      45% { transform: translateX(1.5px); }
      75% { transform: translateX(-3.2px); }
Mushroom Rainy Animation
Rainy Animation (changed)
primary: Rainy
icon: mdi:weather-rainy
icon_color: blue
card_mod:
  style: |
    ha-state-icon {
      animation: cloudy 10s ease-in-out infinite, rain 1.5s infinite;
    @keyframes cloudy {
    @keyframes rain {
      50% { clip-path: polygon(0 0, 100% 0, 100% 73%, 71% 73%, 50% 39%, 29% 73%, 0 73%); }
Mushroom Pouring Animation
Pouring Animation (changed)
primary: Pouring
icon: mdi:weather-pouring
icon_color: blue
card_mod:
  style: |
    ha-state-icon {
      animation: cloudy 10s ease-in-out infinite, rain 1s infinite;
    @keyframes cloudy {
    @keyframes rain {
      0%, 50%, 100% { clip-path: inset(0 0 0 0); }
      25% { clip-path: polygon(0 0, 100% 0, 100% 83%, 54% 83%, 62% 47%, 47% 46%, 38% 83%, 0 83%); }
      75%  { clip-path: polygon(0 0, 100% 0, 100% 70%, 75% 70%, 80% 48%, 63% 48%, 54% 94%, 32% 94%, 46% 46%, 30% 46%, 23% 72%, 0 72%); }
Mushroom Tornado Animation
Tornado Animation (changed)
primary: Tornado
icon: mdi:weather-tornado
icon_color: orange
card_mod:
  style: |
    ha-state-icon {
      animation: tornado 3s ease-in-out infinite;
    @keyframes tornado {
      0%, 100% { transform: translateX(3px) rotateY(0deg); }
      0.1%, 45.1% { transform: rotateY(180deg); }
      30% { transform: translateX(-1px) rotateY(180deg); }
      30.1%, 75.1% { transform: rotateY(0deg); }
      45% { transform: translateX(1.5px) rotateY(0deg); }
      75% { transform: translateX(-3.2px) rotateY(180deg); }
Mushroom Lightning Animation
Lightning Animation (changed)
primary: Lightning
icon: mdi:weather-lightning
icon_color: amber
card_mod:
  style: |
    ha-state-icon {
      animation: cloudy 10s ease-in-out infinite, lightning 4s infinite;
    @keyframes cloudy {
    @keyframes lightning {
      10%, 15% { clip-path: polygon(0 0, 100% 0, 100% 100%, 47% 100%, 69% 55%, 66% 40%, 48% 39%, 24% 100%, 0 100%); transform: scale(1.1); }
      10.1%, 15.1% { clip-path: inset(0 0 0 0); transform: scale(1); }
Mushroom Clear Night Animation
Clear Night Animation (changed)
icon: mdi:weather-night
icon_color: amber
primary: Clear Night
card_mod:
  style: |
    ha-state-icon {
      animation: moon 10s linear infinite, stars 5s linear infinite;
    @keyframes moon {
      0%, 100% { transform: rotate(12deg); }
      30% { transform: rotate(-6deg); }
      45% { transform: rotate(8deg); }
      75% { transform: rotate(-10deg); }
    @keyframes stars {
      0%, 3.1%, 14.1% { clip-path: inset(0 0 0 0); }
      3% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 99% 62%, 68% 62%, 62% 44%, 76% 34%, 100% 34%, 99% 0%); }
      14% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 100% 25%, 51% 45%, 38% 34%, 36% 0); }
Mushroom Windy Animation
Windy Animation (changed)
primary: Windy
icon: mdi:weather-windy
icon_color: blue
card_mod:
  style: |
    ha-state-icon {
      transform-origin: 15% 50%
    @keyframes cloudy {
      0%, 100% { transform: scaleX(1.2); }
      30% { transform: scaleX(0.9); }
      45% { transform: scaleX(1.1); }
      75% { transform: scaleX(0.8); }
Mushroom Wind Animation
Wind Animation (changed)
primary: Wind
icon: mdi:weather-windy-variant
icon_color: blue
card_mod:
  style: |
    ha-state-icon {
      animation: cloudy 10s ease-in-out infinite, wind 5s infinite;
    @keyframes cloudy {
    @keyframes wind {
      25% { clip-path: inset(0 0 37% 0); }
Mushroom Snow Animation
Snow Animation (changed)
primary: Snow
icon: mdi:weather-snowy
icon_color: grey
card_mod:
  style: |
    ha-state-icon {
      animation: cloudy 10s ease-in-out infinite, snow 4s infinite;
    @keyframes cloudy {
    @keyframes snow {
      50% { clip-path: polygon(0 0, 100% 0, 100% 100%, 65% 100%, 76% 73%, 57% 49%, 34% 56%, 26% 79%, 37% 100%, 0 100%); }
      51% { clip-path: inset(0 0 0 0); }
Mushroom Hail Animation
Hail Animation (changed)
primary: Hail
icon: mdi:weather-hail
icon_color: blue
card_mod:
  style: |
    ha-state-icon {
      animation: cloudy 10s ease-in-out infinite, hail 2s infinite;
    @keyframes cloudy {
    @keyframes hail {
      0%, 26%, 51%, 76%, 100% { clip-path: inset(0 0 0 0); }
      25% { clip-path: polygon(0 0, 100% 0, 100% 100%, 62% 100%, 47% 69%, 56% 55%, 43% 43%, 31% 58%, 48% 68%, 63% 100%, 0 100%); }
      50%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 62% 100%, 61% 86%, 74% 74%, 61% 60%, 46% 69%, 60% 87%, 63% 100%, 0 100%); }
      75%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 47% 100%, 56% 83%, 42% 68%, 27% 81%, 37% 100%, 0 100%); }
Mushroom Hurricane Animation
Hurricane Animation (changed)
primary: Hurricane
icon: mdi:weather-hurricane
icon_color: red
card_mod:
  style: |
    ha-state-icon {
Mushroom Dust Animation
Dust Animation (changed)
primary: Dust
icon: mdi:weather-dust
icon_color: brown
card_mod:
  style: |
    ha-state-icon {
      animation: wind 10s ease-in-out infinite, dust 1s infinite;
    @keyframes wind {
    @keyframes dust {
      0%, 21%, 41%, 61%, 81%, 100% { clip-path: inset(0 0 0 0); }
      20% { clip-path: polygon(0 0, 69% 0, 72% 27%, 100% 30%, 100% 100%, 0 100%); }
      40%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 57% 100%, 57% 79%, 0 79%); }
      60%  { clip-path: polygon(30% 0, 100% 0, 100% 100%, 0 100%, 0 28%, 30% 28%); }
      80%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 0 100%, 0 61%, 32% 62%, 32% 46%, 0 46%); }
Mushroom Foggy Animation
Foggy Animation (changed)
primary: Foggy
icon: mdi:weather-fog
icon_color: grey
card_mod:
  style: |
    ha-state-icon {
      animation: cloudy 10s ease-in-out infinite, fog 4s infinite;
    @keyframes cloudy {
    @keyframes fog {
      0%, 26%, 76%, 100% { clip-path: inset(0 0 0 0); }
      25% { clip-path: polygon(0 0, 100% 0, 100% 59%, 60% 59%, 60% 74%, 100% 74%, 100% 100%, 0 100%); }
      75%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 26% 100%, 26% 76%, 0 76%); }
Mushroom Partly Cloudy Animation
Partly Cloudy Animation (changed)
primary: Cloudy
icon: mdi:weather-partly-cloudy
icon_color: amber
card_mod:
  style: |
    ha-state-icon {
      animation: cloudy 10s ease-in-out infinite, sun 2s infinite;
    @keyframes cloudy {
    @keyframes sun {
      50% { clip-path: polygon(0 67%, 18% 55%, 16% 31%, 41% 12%, 67% 24%, 77% 59%, 100% 64%, 100% 100%, 0 100%); }
Mushroom Fireplace Animation
Fireplace Animation (changed)
primary: Fireplace
icon: mdi:fireplace
icon_color: red
card_mod:
  style: |
    ha-state-icon {
      animation: fire 800ms infinite;
    @keyframes fire {
        0%, 19%, 23%, 39%, 43%, 49%, 53%, 69%, 73%, 89%, 93%, 100% { clip-path: polygon(0 0, 100% 0, 100% 100%, 0 100%); }
        20%, 40%, 50%, 70%, 90% { clip-path: polygon(0 0, 100% 0, 100% 100%, 65% 99%, 66% 49%, 52% 44%, 33% 48%, 33% 82%, 66% 82%, 69% 100%, 0 100%); }
Mushroom Washing Machine #2 Animation
Washing Machine #2 Animation (changed, fyi you can even make the drum a different color to the main icon.)
cards:
    icon_color: orange
    primary: 'Washing Machine #2'
    card_mod:
      style: |
          ha-state-icon {
            animation: shake 400ms ease-in-out infinite;
            transform-origin: 50% 58%;
          @keyframes shake {
    icon_color: orange
    card_mod:
      style:
          .shape {
            background: none !important;
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            clip-path: circle(21.7% at 50% 58%);
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Pot Animation
Pot Animation (changed)
icon: mdi:pot-steam
icon_color: grey
primary: Pot
card_mod:
  style: |
    ha-state-icon {
      animation: steam 2s ease-in-out infinite;
    @keyframes steam {
      50% { clip-path: inset(39% 0 0 0); }
Mushroom Serenity Animation
Serenity Animation (changed)
primary: Serenity
icon: mdi:scent
icon_color: green
card_mod:
  style:
      .shape {
        --shape-animation: color 6s ease infinite;
      @keyframes color {
        50% { background: rgba(var(--rgb-cyan), 0.2); }
      ha-state-icon {
        animation: wave 6s ease infinite;
      @keyframes wave {
        50% { transform: rotatey(180deg); color: rgb(var(--rgb-cyan)); }
Mushroom Music #1 Animation
Music #1 Animation (changed)
primary: 'Music #1'
icon: mdi:music
icon_color: blue
card_mod:
  style:
      .shape {
        perspective: 7px;
      ha-state-icon {
        animation: music 2s ease-in-out infinite alternate;
        transform-origin: 50% 100%
      @keyframes music {
        0%, 100% { transform: translateY(0px) scaleX(1); }
        20% { transform: translateY(2px) scaleX(0.9); }
        40% { transform: rotateY(10deg) rotateZ(-10deg); }
        60% { transform: translateY(-4px) scaleX(1.1); }
        80% { transform: rotateY(-10deg) rotateZ(10deg); }
Mushroom Music #2 Animation
Music #2 Animation (changed)
primary: 'Music #2'
icon: mdi:music
icon_color: blue
card_mod:
  style: |
    ha-state-icon {
      transform-origin: 50% 80%;
    @keyframes beat {
      10% { transform: scale(1.1); }
      17% { transform: scale(1.05); }
      33% { transform: scale(1.25); }
      60% { transform: scale(1); }
Mushroom Playlist Animation
Playlist Animation (changed)
icon: mdi:format-list-bulleted-square
icon_color: purple
primary: Playlist
card_mod:
  style: |
      ha-state-icon {
        animation: clip 2s steps(4) infinite;
      @keyframes clip {
        0% { clip-path: inset(0 0 85% 0); }
        100% { clip-path: inset(0 0 -5% 0); }
Mushroom Grain Animation
Grain Animation (changed)
icon: mdi:grain
icon_color: brown
primary: Grain
card_mod:
  style: |
    ha-state-icon {
      animation: flip 1s steps(1) infinite;
    @keyframes flip {
Mushroom Focus Animation
Focus Animation (changed)
icon: mdi:bullseye
icon_color: purple
primary: Focus
card_mod:
  style: |
    ha-state-icon {
      animation: focus 4s linear infinite alternate;
    @keyframes focus {
      50% { filter: blur(10px); }
Mushroom Access Point Animation
Access Point Animation (changed)
icon: mdi:access-point
icon_color: teal
primary: Access Point
card_mod:
  style:
      .shape {
        --shape-animation: ping 1.5s infinite;
      @keyframes ping {
        0% { box-shadow: 0 0 1px 1px rgba(var(--rgb-teal), 0.3) inset; }
        50% { box-shadow: 0 0 5px 15px transparent inset; }
        51% { box-shadow: 0 0 1px 1px rgba(var(--rgb-teal), 0.3); }
      ha-state-icon {
        animation: clip 1.5s infinite;
      @keyframes clip {
        0% { clip-path: circle(13.0% at 50% 50%); }
        100% { clip-path: circle(50.0% at 50% 50%); }
Mushroom Alert Animation
Alert Animation (unchanged)
primary: Alert!
icon: mdi:fire
icon_color: red
card_mod:
  style:
      .shape {
        --shape-animation: ping 1.5s infinite, blink 1.5s ease-in-out infinite;;
      @keyframes ping {
        0% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.7); }
      @keyframes blink {
        100% {opacity: 0;}
Mushroom Record Animation
Record Animation (unchanged, doesnt work well on a dark background unless you set a --shape-color.)
type: custom:mushroom-template-card
icon: mdi:record-circle
icon_color: cyan
primary: Record
card_mod:
  style:
      .shape {
        background: linear-gradient(-45deg, rgba(var(--rgb-black), 0.4) 0%, rgba(var(--rgb-black), 0.6) 50%, rgba(var(--rgb-black), 0.4) 100%);
        --shape-animation: spin 400ms linear infinite;
Mushroom Heart Animation
Heart Animation (changed)
primary: Heart
icon: mdi:heart
icon_color: red
card_mod:
  style:
      .shape {
        transform-origin: 50% 60%;
        --shape-animation: heart 1.3s ease-out infinite both;
      @keyframes heart {
        0% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.2); }
        10% { box-shadow: 0 0 5px 5px transparent; }
        17% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.2); }
        33% { box-shadow: 0 0 5px 5px transparent; }
        60% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.2); }
      ha-state-icon {
      @keyframes beat {
Mushroom Play Animation
Play Animation (changed)
icon: mdi:play
icon_color: orange
primary: Play
card_mod:
  style: |
    ha-state-icon {
      animation: spin 4s steps(4) infinite;
Mushroom Christmas Tree Animation
Christmas Tree Animation (changed)
cards:
    icon: mdi:pine-tree
    icon_color: green
    primary: Christmas Tree
    icon: mdi:star-four-points
    icon_color: yellow
    primary: Star
    card_mod:
      style:
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            animation: star 8s ease infinite alternate;
          @keyframes star {
            0%, 100% { transform: translateY(-10px) rotate(0deg) scale(0.4); }
            50% { transform: translateY(-10px) rotate(360deg) scale(0.6); }
    icon: mdi:gift
    icon_color: red
    card_mod:
      style:
          .shape {
            --icon-size: 20px;
            top: 16px;
            left: 18px;
          ha-card {
            width: 66px;
            top: -132px;
          ha-state-icon {
            animation: surprise 4s ease infinite;
          @keyframes surprise {
            0%, 20%, 100% { transform: translateY(0); }
            2.5% { transform: translateY(-2px) rotate(-27deg); }
            5% { transform: translateY(-2px) rotate(21deg); }
            7.5% { transform: translateY(-2px) rotate(-15deg); }
            10% { transform: translateY(-2px) rotate(9deg); }
            12.5% { transform: translateY(0); }
            15% { transform: translateY(-1.2px) }
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Doggy Animation
Doggy Animation (changed)
primary: Doggy
icon: mdi:dog
icon_color: brown
card_mod:
  style: |
      ha-state-icon {
        animation: huh 4s ease infinite;
      @keyframes huh {
        0%, 10%, 75%, 100% { transform: rotate(0deg); }
        15% { transform: rotate(-25deg); }
        30%, 35% { transform: rotate(-40deg); }
        50% { transform: rotate(12deg); }
        65% { transform: rotate(-8deg); }
Sorry Dimitri, but I want to like your post, as you are doing a great job! :+1: And btw. I already liked the original posts from @rhysb when I first read them :rofl: :rofl:
It’s really great, that you do give credit, where credit is due, but you do invest work and time here as well, so your work should be valued as well! :wink: Valuing the work of @rhysb doesn’t mean, your’s shouldn’t be valued! :slight_smile: :smiley:
Btw. you do not happen to know a good vacuum map card, that fits the mushroom design, do you? :slight_smile:
Mushroom Animations :mushroom: - Part 4
Even More Mushroom Card Icon Animations
Mushroom HA Animation
HA Animation (changed)
icon: mdi:home-assistant
icon_color: blue
primary: Home Assistant
card_mod:
  style: |
    ha-state-icon {
      animation: boing 3s ease infinite;
      transform-origin: 50% 90%;
    @keyframes boing {
      0% { transform: scale3d(1, 1, 1); }
      7% { transform: scale3d(1.25, 0.75, 1); }
      10% { transform: scale3d(0.75, 1.25, 1); }
      12% { transform: scale3d(1.15, 0.85, 1); }
      16% { transform: scale3d(0.95, 1.05, 1); }
      19% { transform: scale3d(1.05, 0.95, 1); }
      25% { transform: scale3d(1, 1, 1); }
Mushroom Surprise Animation
Surprise Animation (changed)
icon: mdi:gift
primary: Surprise
card_mod:
  style: |
    ha-state-icon {
      animation: surprise 3s ease infinite;
      2.5% { transform: translateY(-6px) rotate(-14deg); }
      5% { transform: translateY(-6px) rotate(11deg); }
      7.5% { transform: translateY(-6px) rotate(-8deg); }
      10% { transform: translateY(-6px) rotate(5deg); }
      15% { transform: translateY(-3px) }
Mushroom Ring Animation
Ring Animation (changed)
cards:
    icon: mdi:phone-classic
    primary: Ring
    card_mod:
      style: |
        ha-state-icon {
          clip-path: polygon(0 100%, 100% 100%, 100% 67%, 66% 39%, 66% 25%, 34% 25%, 34% 40%, 0 68%);
    icon: mdi:phone-hangup
    card_mod:
      style:
          .shape {
            top: -4px;
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            animation: ring 1s ease infinite;
          @keyframes ring {
            0%, 50%, 80%, 100% { transform: translateY(0); }
            10% { transform: translateY(-4px) rotate(-27deg); }
            20% { transform: translateY(-4px) rotate(21deg); }
            30% { transform: translateY(-4px) rotate(-15deg); }
            40% { transform: translateY(-4px) rotate(9deg); }
            60% { transform: translateY(-2.4px); }
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Marker Animation
Marker Animation (changed)
icon: mdi:map-marker
icon_color: red
primary: Marker
card_mod:
  style: |
    ha-state-icon {
    @keyframes boing {
      7% { transform: translateY(-4px) scale3d(0.75, 1.25, 1); }
      10% { transform: scale3d(1.25, 0.75, 1); }
      12% { transform: translateY(-2px) scale3d(0.85, 1.15, 1); }
      16% { transform: scale3d(1.05, 0.95, 1); }
      19% { transform: scale3d(0.95, 1.05, 1); }
Mushroom Beat Animation
Beat Animation (changed)
primary: Beat
icon: mdi:speaker
icon_color: blue
card_mod:
  style: |
    ha-state-icon {
      animation: beat 1.3s ease-out infinite both;
    @keyframes beat {
Mushroom Door Animation
Door Animation (changed)
icon: mdi:door
icon_color: brown
primary: Door
card_mod:
  style:
      .shape {
        perspective: 45px;
      ha-state-icon {
        animation: open 6s ease-in-out infinite;
        transform-origin: 30%;
      @keyframes open {
        0%, 66% { transform: rotateY(0deg); }
        33% { transform: rotateY(-120deg); }
Mushroom Bounce Animation
Bounce Animation (changed)
icon: mdi:tennis-ball
icon_color: amber
primary: Bounce
card_mod:
  style: |
    ha-state-icon {
      animation: bounce 0.6s cubic-bezier(0.30, 2.40, 0.85, 2.50) infinite;
      transform-origin: 50% 100%;
    @keyframes bounce {
      0%, 100% { transform: translateY(0px) scaleY(0.9); }
      80% { transform: translateY(-3px); }
Mushroom Ghost Animation
Ghost Animation (changed)
primary: Ghost
icon: mdi:ghost-outline
icon_color: grey
card_mod:
  style: |
    ha-state-icon {
      animation: drift 10s ease-in-out infinite, blink 4s infinite;
    @keyframes drift {
      0%, 100% { transform: translate(3px, 0px); }
      30% { transform: translate(-1px, 2px); }
      45% { transform: translate(1.5px, 0px); }
      75% { transform: translate(-3.2px, -3px); }
    @keyframes blink {
      0%, 24%, 35%, 74%, 85%, 100% { clip-path: inset(0 0 0 0); }
      25% { clip-path: polygon(0 0, 0 100%, 100% 100%, 100% 53%, 25% 52%, 27% 31%, 49% 31%, 49% 54%, 100% 54%, 100% 0); }
      75%  { clip-path: polygon(0 0, 0 100%, 100% 100%, 100% 53%, 49% 51%, 52% 30%, 73% 31%, 75% 52%, 100% 54%, 100% 0); }
Mushroom Ducky Animation
Ducky Animation (changed)
primary: Rubber Ducky
icon: mdi:duck
icon_color: amber
card_mod:
  style: |
    ha-state-icon {
      animation: ducky 2s ease-in-out infinite;
    @keyframes ducky {
      0%, 100% { transform: rotate(-15deg); }
      50% { transform: rotate(15deg); }
Mushroom Robot Animation
Robot Animation (changed)
primary: Robot
icon: mdi:robot-outline
card_mod:
  style: |
    ha-state-icon {
      animation: tilt 4s steps(1) infinite, blink 4s infinite;
      transform-origin: 50% 92%;
    @keyframes tilt {
      0%, 100% { transform: rotate(0deg); }
      33% { transform: rotate(8deg); }
      66% { transform: rotate(-8deg); }
    @keyframes blink {
      0%, 20%, 30%, 45%, 55%, 70%, 80%, 100% { clip-path: inset(0 0 0 0); }
      25% { clip-path: polygon(0 0, 100% 0, 100% 53%, 25% 52%, 24% 77%, 75% 77%, 76% 52%, 100% 52%, 100% 100%, 0 100%); }
      50%  { clip-path: polygon(0 0, 100% 0, 100% 53%, 51% 54%, 51% 76%, 76% 77%, 75% 53%, 100% 52%, 100% 100%, 0 100%); }
      75%  { clip-path: polygon(0 0, 100% 0, 100% 53%, 24% 53%, 24% 77%, 47% 77%, 47% 52%, 100% 52%, 100% 100%, 0 100%); }
Mushroom Coffee Machine Animation
Coffee Machine Animation (changed)
icon: mdi:coffee-maker
icon_color: brown
primary: Coffee Machine
card_mod:
  style: |
    ha-state-icon {
      animation: java 4s linear infinite;
    @keyframes java {
      0%, 80%, 100% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 0 100%); }
      10% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 79%, 63% 76%, 67% 70%, 66% 54%, 42% 55%, 42% 70%, 47% 77%, 55% 80%, 57% 100%, 0 100%); }
      15% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 79%, 63% 76%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 47% 77%, 55% 80%, 55% 100%, 0 100%); }
      20% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 76%, 63% 76%, 67% 70%, 66% 54%, 42% 55%, 42% 70%, 47% 76%, 55% 76%, 57% 100%, 0 100%); }
      25% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 76%, 63% 76%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 47% 76%, 55% 76%, 56% 100%, 0 100%); }
      30% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 73%, 64% 73%, 66% 70%, 66% 55%, 42% 55%, 42% 69%, 44% 73%, 55% 73%, 57% 100%, 0 100%); }
      35% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 73%, 64% 73%, 66% 70%, 66% 55%, 42% 54%, 42% 69%, 44% 73%, 55% 73%, 56% 100%, 0 100%); }
      40% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 70%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 57% 70%, 57% 100%, 0 100%); }
      45% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 70%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 55% 70%, 56% 100%, 0 100%); }
      50% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 66%, 67% 65%, 66% 54%, 42% 54%, 42% 65%, 57% 65%, 57% 100%, 0 100%); }
      55% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 66%, 67% 65%, 66% 54%, 42% 54%, 42% 65%, 55% 65%, 56% 100%, 0 100%); }
      60% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 60%, 66% 60%, 66% 54%, 42% 54%, 42% 60%, 57% 60%, 57% 100%, 0 100%); }
      65% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 60%, 66% 60%, 66% 54%, 42% 54%, 42% 60%, 55% 60%, 56% 100%, 0 100%); }
      70% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 56%, 66% 56%, 66% 54%, 42% 54%, 42% 56%, 57% 56%, 57% 100%, 0 100%); }
      75% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 56%, 66% 56%, 66% 54%, 42% 54%, 42% 56%, 55% 56%, 55% 100%, 0 100%); }
Mushroom Apple Animation
Apple Animation (changed)
primary: Apple
icon: mdi:food-apple
icon_color: green
card_mod:
  style: |
    ha-state-icon {
      animation: bite 4s infinite;
    @keyframes bite {
      0%, 19%, 100% { clip-path: inset(0 0 0 0); }
      20%, 39% { clip-path: polygon(0 0, 100% 0, 100% 30%, 78% 36%, 69% 41%, 68% 48%, 67% 55%, 69% 62%, 74% 66%, 74% 66%, 79% 70%, 100% 75%, 100% 100%, 0 100%); }
      40%, 59%  { clip-path: polygon(0 0, 100% 0, 100% 30%, 78% 36%, 69% 41%, 68% 48%, 67% 55%, 63% 60%, 61% 66%, 59% 72%, 61% 79%, 63% 85%, 66% 91%, 76% 100%, 0 100%); }
      60%, 79%  { clip-path: polygon(0 0, 100% 0, 100% 30%, 78% 36%, 69% 41%, 68% 48%, 67% 55%, 63% 60%, 61% 66%, 59% 72%, 61% 79%, 63% 85%, 66% 91%, 76% 100%, 0 100%, 0 84%, 23% 75%, 29% 71%, 33% 66%, 35% 59%, 35% 52%, 34% 45%, 29% 40%, 23% 35%, 0 27%); }
      80%, 99%  { clip-path: polygon(0 0, 100% 0, 100% 30%, 78% 36%, 69% 41%, 68% 48%, 67% 55%, 63% 60%, 61% 66%, 59% 72%, 61% 79%, 63% 85%, 66% 91%, 76% 100%, 0 100%, 32% 88%, 37% 83%, 39% 76%, 39% 67%, 35% 59%, 35% 52%, 34% 45%, 29% 40%, 23% 35%, 0 27%); }
Mushroom Memory Animation
Memory Animation (changed)
primary: Memory
icon: mdi:memory
icon_color: orange
card_mod:
  style: |
    ha-state-icon {
      animation: bit 250ms infinite;
    @keyframes bit {
      50% { clip-path: polygon(0% 0%, 0% 100%, 29% 100%, 30% 30%, 70% 30%, 70% 70%, 29% 70%, 29% 100%, 100% 100%, 100% 0%); }
Mushroom Pump Animation
Pump Animation (changed)
primary: Pump
icon: mdi:water-pump
icon_color: light-blue
card_mod:
  style: |
    ha-state-icon {
      animation: drip 2s infinite;
    @keyframes drip {
      15%, 85% { clip-path: polygon(0 0, 100% 0, 100% 57%, 64% 57%, 64% 100%, 0 100%); }
Mushroom Power Animation
Power Animation (changed)
primary: Power
icon: mdi:power
icon_color: teal
card_mod:
  style: |
    ha-state-icon {
      animation: power 1.5s infinite;
    @keyframes power {
      50% { clip-path: polygon(0 0, 42% 0, 42% 58%, 58% 58%, 58% 0, 100% 0, 100% 100%, 0 100%); }
Mushroom Garage Animation
Garage Animation (changed)
primary: Garage
icon: mdi:garage
icon_color: amber
card_mod:
  style: |
    ha-state-icon {
      animation: door 3s steps(1) infinite alternate;
    @keyframes door {
      25%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 68% 100%, 69% 73%, 32% 73%, 31% 100%, 0 100%); }
      50%  { clip-path: polygon(0 0, 100% 0, 100% 100%, 68% 100%, 69% 61%, 32% 61%, 31% 100%, 0 100%); }
      75% { clip-path: polygon(0 0, 100% 0, 100% 100%, 68% 100%, 69% 48%, 32% 48%, 31% 100%, 0 100%); }
Mushroom Coffee Animation
Coffee Animation (changed)
cards:
    icon: mdi:coffee
    icon_color: brown
    primary: Coffee
    card_mod:
      style: |
        ha-state-icon {
          transform: scaleY(0.8);
    icon: mdi:pot-steam
    icon_color: brown
    card_mod:
      style:
          .shape {
            top: -2px;
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            animation: steam 2s ease-in infinite;
            clip-path: inset(0 0 61% 0);
          @keyframes steam {
            0%, 100% { opacity: 1; }
            80% { opacity: 0; }
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Auto Fix Animation
Auto Fix Animation (changed)
icon: mdi:auto-fix
icon_color: cyan
primary: Auto Fix
card_mod:
  style: |
    ha-state-icon {
     animation: sparkle 1.8s linear infinite, kadabra 1.8s ease-in-out infinite;
     transform-origin: 10% 90%
    @keyframes sparkle {
      0%, 69%, 74%, 79%, 85% { clip-path: inset(0 0 0 0); }
      70% { clip-path: polygon(0 100%, 0 76%, 75% 0, 100% 0, 100% 100%); }
      75% { clip-path: polygon(0 100%, 0 0, 39% 0, 100% 62%, 100% 100%); }
      80% { clip-path: polygon(0 100%, 0 0, 100% 0, 100% 26%, 25% 100%); }
    @keyframes kadabra {
      0%, 65%, 100% { transform: rotate(-15deg); }
      70% { transform: rotate(20deg); }
      75% { transform: rotate(15deg); }
      80% { transform: rotate(25deg); }
Mushroom Grinder Animation
Grinder Animation (changed)
icon: mdi:blender
icon_color: orange
primary: Grinder
card_mod:
  style: |
    ha-state-icon {
      clip-path: polygon(24% 0, 100% 0, 100% 100%, 0 100%, 0 75%, 33% 62%);
    @keyframes shake {
      0%, 100% { transform: rotate(3deg); }
      50%  { transform: rotate(-3deg); }
Mushroom Solar Panel Animation
Solar Panel Animation (changed)
icon: mdi:solar-power-variant
icon_color: amber
primary: Solar Panel
card_mod:
  style: |
    ha-state-icon {
      animation: rays 2s infinite;
    @keyframes rays {
      80% { clip-path: polygon(100% 99%, 0% 99%, 11% 50%, 57% 48%, 56% 31%, 41% 31%, 33% 25%, 29% 18%, 27% 11%, 27% 6%, 74% 6%, 73% 15%, 69% 23%, 62% 29%, 71% 42%, 87% 47%); }
Mushroom Light Bulb Animation
Light Bulb Animation (changed)
icon: mdi:lightbulb-on
icon_color: amber
primary: Light Bulb
card_mod:
  style: |
    ha-state-icon {
      animation: illumination 2s infinite;
    @keyframes illumination {
      80% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
Mushroom Eureka Animation
Eureka Animation (changed)
icon_color: orange
primary: Eureka
card_mod:
  style: |
    ha-state-icon {
      animation: eureka 1.8s infinite;
    @keyframes eureka {
      0%, 45%, 55%, 100% { transform: translateY(0) scale(1); clip-path: polygon(20% 100%, 21% 38%, 36% 22%, 62% 21%, 79% 37%, 80% 100%, 53% 100%, 55% 67%, 62% 62%, 66% 55%, 67% 46%, 62% 38%, 55% 34%, 47% 34%, 39% 37%, 34% 44%, 33% 53%, 36% 60%, 41% 64%, 45% 66%, 45% 76%, 56% 76%, 54% 100%); }
      10%, 40% { transform: translateY(-5px) scale(1.12); clip-path: inset(0 0 0 0); }
      50% { transform: translateY(-2px) }
Mushroom Trash Animation
Trash Animation (changed)
cards:
    icon: mdi:trash-can
    icon_color: green
    primary: Trash
    card_mod:
      style: |
        ha-state-icon {
          clip-path: inset(26% 0 0 0);
    icon: mdi:trash-can
    icon_color: green
    card_mod:
      style:
          .shape {
            top: 0.3px;
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            animation: lid 1s ease infinite;
            clip-path: inset(0 0 75% 0);
            transform-origin: 50% 25%;
          @keyframes lid {
            10% { transform: translateY(-5px) rotate(-37deg); }
            20% { transform: translateY(-5px) rotate(31deg); }
            30% { transform: translateY(-5px) rotate(-25deg); }
            40% { transform: translateY(-5px) rotate(19deg); }
            60% { transform: translateY(-3px); }
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Heat Pump Animation
Heat Pump Animation (changed)
cards:
    icon: mdi:heat-pump-outline
    primary: Heat Pump
    card_mod:
      style: |
        ha-state-icon {
          clip-path: polygon(0% 0%, 0% 100%, 23% 100%, 23% 23%, 78% 22%, 77% 78%, 23% 78%, 22% 100%, 100% 100%, 100% 0%);
    card_mod:
      style:
        mushroom-shape-icon$: |
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            position: absolute;
            clip-path: circle(27.3% at 50% 50%);
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Air Purifier Animation
Air Purifier Animation (changed)
icon: mdi:air-purifier
icon_color: cyan
primary: Air Purifier
card_mod:
  style: |
    ha-state-icon {
      animation: air 1s infinite;
    @keyframes air {
      25% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 98% 32%, 63% 42%, 65% 58%, 100% 43%); }
      75% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 100% 44%, 64% 61%, 64% 73%, 100% 72%); }
      50% { clip-path: polygon(100% 100%, 0 100%, 0 0, 100% 0, 78% 38%, 64% 43%, 64% 72%, 100% 73%); }
Mushroom Calendar Clock Animation
Calendar Clock Animation (changed)
cards:
    icon: mdi:calendar-clock
    icon_color: purple
    primary: Calendar Clock
    card_mod:
      style: |
        ha-state-icon {
          clip-path: polygon(0 100%, 0 0, 100% 0, 100% 67%, 85% 69%, 73% 52%, 59% 52%, 59% 72%, 77% 81%, 85% 68%, 100% 67%, 100% 100%);
    icon_color: purple
    card_mod:
      style:
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            transform-origin: 67% 67%;
            clip-path: circle(17% at 67% 67%);
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom CRT Animation
CRT Animation (changed. i did also change the if statement structure here because i find this method easier to read and trouble shoot.)
primary: CRT
entity: switch.television
icon: mdi:television-classic
icon_color: '{{ ''orange'' if is_state(entity, ''on'') }}'
card_mod:
  style: |
      ha-state-icon {
      {% if is_state(config.entity, 'on') %}
        animation: tube-on 1s linear, flicker 1s linear 1s infinite alternate;
        animation: tube-off 2s linear forwards;
      @keyframes tube-off {
        1%, 15% { transform: scale(1, 0.2); }
        40%  { transform: scale(0.2); opacity: 1; }
        100%  { transform: scale(0.2); opacity: 0; }
      @keyframes tube-on {
        5%  { transform: scale(1, 0.2); opacity: 0.3; }
        15%  { transform: scale(1); opacity: 0.4; }
      @keyframes flicker {
        0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { opacity: 0.6; }
        32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { opacity: 1; }
Mushroom Microwave Animation
Microwave Animation (changed)
icon: mdi:microwave
icon_color: blue
primary: Microwave
card_mod:
  style: |
    ha-state-icon:before {
      content: "";
      position: absolute;
      width: 25%;
      height: 25%;
      margin: 10%;
      animation: cook 1s linear infinite;
    @keyframes cook {
      0%, 100% { background: linear-gradient(90deg, white 0%, transparent 50%, transparent 100%); }
      33% { background: linear-gradient(90deg, transparent 0%, white 50%, transparent 100%); }
      66% { background: linear-gradient(90deg, transparent 0%, transparent 50%, white 100%); }
Controlling the Animation in your Card
The animations can be controlled using a Jinja Template condition on the animation command.
For example if I wanted an animation when my coffee machine is on I would use an if statement like this:
{{ 'animation: java 4s linear infinite;' if is_state(config.entity, 'on') }}
Added by Dimitri.
Or you can make your if statement block like this instead. i think this is easier to read. it does take up more space in the code, but easier to see what is happening :slight_smile: the {% else %} is technically not even required.
The complete card would look like this:
Coffee Machine Card (new if statements and structure changed)
entity: switch.coffee_machine
icon_color: '{{ ''brown'' if is_state(entity, ''on'') }}'
card_mod:
  style: |
    ha-state-icon {
    @keyframes java {
Or if I wanted to have the dryer animate when the load is over 4w I would do this:
{{ 'animation: shake 400ms ease-in-out infinite, drum 1s infinite;' if states('sensor.dryer_power') | float > 4 }}
Added by Dimitri.
{% if states(sensor.dryer_power) | float > 4  %}
Dryer Card (new if statements and structure changed)
entity: switch.dryer
icon: mdi:tumble-dryer
icon_color: '{{ ''teal'' if states(''sensor.dryer_power'') | float > 4 }}'
primary: Dryer
card_mod:
  style: |
    ha-state-icon {
      transform-origin: 50% 65%;
      {% if states('sensor.dryer_power') | float > 4 %}
      {% end if %}
    @keyframes shake {
      0%, 100% { transform: rotate(4deg); }
      50%  { transform: rotate(-4deg); }
    @keyframes drum {
      50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
You will need to add the if condition for each animation:, --icon-animation: or --shape-animation: command in the card.
Added by Dimitri.
This is not true if you complete the if statements in the way that i have showed. that is unless you need the animations to be based on different conditions.
Using the Animations with Tile Card
The structure of the new Tile Card is very similar to the Mushroom Cards, so it is easy to use these animations with it.
Mushroom Card (changed)
card_mod:
  style: |
    ha-state-icon {
Tile Card (changed)
card_mod:
  style:
    ha-tile-icon$: |
      ha-icon {
Animated Tile Card (changed)
type: tile
entity: fan.bathroom_fan
color: green
card_mod:
  style:
    ha-tile-icon$: |
      ha-icon {
        animation: rotate 1s linear infinite;
      @keyframes rotate {
         100% { transform: rotate(360deg); }
Mushroom Animations :mushroom: - Part 5
Mushroom Chip Animations
Mushroom Chip Animated Scene
Chip Animated Scene (changed)
chips:
  - type: template
    icon: mdi:mushroom
    icon_color: red
  - type: template
    icon: mdi:snail
    icon_color: brown
  - type: template
    icon: mdi:flower
    icon_color: amber
  - type: template
    icon: mdi:butterfly
    icon_color: cyan
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-state-icon {
        animation: bump 10s infinite;
      @keyframes bump {
        0% { transform: translateX(0); }
        1% { transform: translateX(-0.6px) rotate(-9deg); }
        2% { transform: translateX(0.5px) rotate(7deg); }
        3% { transform: translateX(-0.3px) rotate(-5deg); }
        4% { transform: translateX(0.2px) rotate(3deg); }
        5% { transform: translateX(0); }
    mushroom-template-chip:nth-child(2)$: |
      ha-state-icon {
        animation: slip 0.5s linear infinite alternate;
        transform-origin: 100% 100%;
      @keyframes slip {
        from { transform: scale(1.05, 0.9);}
        to { transform: scale(0.9, 1.05); }
    mushroom-template-chip:nth-child(3)$: |
      ha-state-icon {
      @keyframes bump {
        50% { transform: translateX(0); }
        51% { transform: translateX(-0.6px) rotate(-9deg); }
        52% { transform: translateX(0.5px) rotate(7deg); }
        53% { transform: translateX(-0.3px) rotate(-5deg); }
        54% { transform: translateX(0.2px) rotate(3deg); }
        55% { transform: translateX(0); }
    mushroom-template-chip:nth-child(4)$: |
      ha-state-icon {
        animation: flutter 5s infinite alternate;
      @keyframes flutter {
        0% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        10% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        20% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        30% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        40% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        50% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        60% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        70% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        80% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
        90% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg) scalex({{ range(3, 7) | random / 10 }}); }
        100% { transform: translate({{ range(-20, 20) | random / 10 }}px, {{ range(-20, 20) | random / 10 }}px) rotate({{ range(-15, 15) | random }}deg); }
      .chip-container {
        background: radial-gradient(circle, rgba(var(--rgb-light-blue), 0.1) 0%, transparent 100%);
        border-bottom: 3px dotted rgba(var(--rgb-green));
        border-radius: 20%;
        box-shadow: 0 5px 1px 0.1px rgba(var(--rgb-green), 0.2)
      mushroom-template-chip:nth-child(2) {
        animation: slide 10s ease-in-out infinite;
      @keyframes slide {
        0% { transform: translate(0px, 0px) rotateY(0deg); }
        50% { transform: translate(100px, 0px) rotateY(0deg); }
        50.1% { transform: translate(100px, 0px) rotateY(180deg); }
        100% { transform: translate(0px, 0px) rotateY(180deg); }
      mushroom-template-chip:nth-child(3) {
          transform: translate(100px);
      mushroom-template-chip:nth-child(4) {
          animation: by {{ range(5, 15) | random }}s ease infinite;
      @keyframes by {
        0% { transform: translate(100px, 0px); }
        50% { transform: translate({{ range(110, 150) | random }}px, 0px); }
        100% { transform: translate(100px, 0px); }
All of the below info regarding adding animations to chips is still true.
Adding Animations to Chips
Adding an animation to a Mushroom Chip is a bit more complicated than a normal Mushroom Card. You have the Chips ‘parent’ and multiple Chip ‘children’. The card_mod can be applied differently to each.
To the Chip
The simplest method is to add the card_mod to the Chip. The disadvantage of doing this is that we can’t address the icon directly, so animations such as clip-path will not work and we can’t have any text on the Chip. This method also breaks the GUI editor of the Chips, so you have to configure with YAML.
Chip Animation (unchanged)
chips:
  - type: template
    icon: mdi:mushroom
    icon_color: red
    card_mod:
      style: |
        .content {
        @keyframes boing {
  - type: template
    icon: mdi:mushroom
    icon_color: red
    card_mod:
      style: |
        .content {
          animation: spin 3s ease 1.5s infinite;
        @keyframes spin {
To the Chips
The more complex but correct method is to add the card_mod to the Chips (parent) and then address each Chip (child). This is done by referencing the mushroom-<chip-type>-chip:nth-child(x) where x is the number of the Chip and <chip-type> is type of Chip, such as template, entity, light etc. So, if I wanted to reference the 5th Entity Chip I would use mushroom-entity-chip:nth-child(5) or the 2nd Template Chip mushroom-template-chip:nth-child(2). The functionality of the GUI editor is retained with this method.
Chips Animation (changed)
chips:
  - type: template
    icon: mdi:mushroom
    icon_color: red
  - type: template
    content: Mushroom
    icon: mdi:mushroom
    icon_color: red
  - type: light
    entity: light.rocket_man
    icon: mdi:rocket-launch
    content_info: name
card_mod:
  style:
      ha-state-icon {
      @keyframes boing {
      ha-state-icon {
      @keyframes spin {
    mushroom-light-chip:nth-child(3)$: |
      ha-state-icon {
        {{ 'animation: thrust 100ms infinite, motion 3s ease-in-out infinite;' if is_state('light.rocket_man', 'on') }}
      @keyframes thrust {
        0% { clip-path: polygon(0 0, 0 47%, 22% 57%, 28% 63%, 0 91%, 11% 100%, 37% 73%, 45% 77%, 55% 100%, 100% 100%, 100% 0%); }
        33% { clip-path: polygon(0 0, 0 47%, 24% 59%, 42% 76%, 54% 100%, 100% 100%, 100% 0); }
        66% { clip-path: polygon(0 0, 0 92%, 28% 64%, 36% 72%, 9% 100%, 100% 100%, 100% 0%); }
      @keyframes motion {
        0%, 100% { transform: translateY(-2px) translateX(-3px); }
        50% { transform: translateY(3px) translateX(2px); }
Mushroom Monitor Animation
Monitor Animation (changed)
icon: mdi:monitor
icon_color: purple
primary: Monitor
card_mod:
  style: |
      content: "";
      position: absolute;
      width: 40%;
      height: 30%;
      margin: 6%;
      animation: refresh 300ms linear infinite;
    @keyframes refresh {
      0% { background: linear-gradient(180deg, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 0%, transparent 50%, transparent 100%); }
      25% { background: linear-gradient(180deg, transparent 0%, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 25%, transparent 100%); }
      50% { background: linear-gradient(180deg, transparent 0%, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 50%, transparent 100%); }
      75% { background: linear-gradient(180deg, transparent 0%, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 75%, transparent 100%); }
      100% { background: linear-gradient(180deg, transparent 0%, transparent 50%, rgba(var(--rgb-{{ config.icon_color }}), 0.2) 100%); }
Mushroom Email Animation
Email Animation (changed)
cards:
    icon: mdi:email
    icon_color: orange
    primary: Email
    card_mod:
      style: |
        ha-state-icon {
          animation: email 4s infinite;
        @keyframes email {
          0%, 32%, 100% { opacity: 1; }
          33%, 99% { opacity: 0; }
    icon: mdi:email-open
    icon_color: orange
    card_mod:
      style:
          .shape {
            --shape-color: none;
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            animation: email-open 4s infinite;
          @keyframes email-open {
            0%, 32%, 100% { opacity: 0; }
            33%, 65% { opacity: 1; }
            66% { opacity: 0; }
    icon: mdi:email-newsletter
    icon_color: orange
    card_mod:
      style:
          .shape {
          ha-card {
            width: 66px;
            top: -132px;
          ha-state-icon {
            animation: email-newsletter 4s infinite;
          @keyframes email-newsletter {
            0%, 65% { opacity: 0; }
            66% { opacity: 1; }
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Email #2 Animation
Email #2 Animation (changed)
cards:
    icon: mdi:email
    icon_color: orange
    primary: 'Email #2'
    card_mod:
      style: |
        ha-state-icon {
          animation: email 2s infinite;
        @keyframes email {
          0%, 49%, 100% { opacity: 1; }
          50%, 99% { opacity: 0; }
    icon_color: orange
    card_mod:
      style:
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            animation: email-open 2s infinite;
            0%, 49%, 100% { opacity: 0; }
            50%, 99% { opacity: 1; }
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom Christmas Tree #2 Animation
Christmas Tree #2 Animation (changed)
cards:
    icon: mdi:pine-tree
    icon_color: green
    primary: 'Christmas Tree #2'
    icon_color: yellow
    primary: Star
    card_mod:
      style:
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
          @keyframes star {
    icon: mdi:grain
    icon_color: red
    card_mod:
      style:
          .shape {
          ha-card {
            width: 66px;
            top: -132px;
          ha-state-icon {
            animation: flash 2s steps(1) infinite, lights 2s infinite;
            clip-path: polygon(51% 15%, 24% 74%, 74% 74%);
          @keyframes flash {
            50% { transform: rotateY(180deg); }
          @keyframes lights {
            0%, 100% {color: rgb(var(--rgb-red)); }
            6.25% { color: rgb(var(--rgb-deep-orange)); }
            12.5% { color: rgb(var(--rgb-orange)); }
            18.75% { color: rgb(var(--rgb-amber)); }
            25% { color: rgb(var(--rgb-yellow)); }
            31.25% { color: rgb(var(--rgb-lime)); }
            37.5% { color: rgb(var(--rgb-light-green)); }
            43.75% { color: rgb(var(--rgb-green)); }
            50% { color: rgb(var(--rgb-teal)); }
            56.25% { color: rgb(var(--rgb-cyan)); }
            62.5% { color: rgb(var(--rgb-light-blue)); }
            68.75% { color: rgb(var(--rgb-blue)); }
            75% { color: rgb(var(--rgb-indigo)); }
            81.25% { color: rgb(var(--rgb-deep-purple)); }
            87.5% { color: rgb(var(--rgb-purple)); }
            93.75% { color: rgb(var(--rgb-pink)); }
    icon: mdi:gift
    icon_color: red
    card_mod:
      style:
          .shape {
            --icon-size: 18px;
            top: 18px;
            left: 18px;
          ha-card {
            width: 66px;
            top: -198px;
          ha-state-icon {
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom 3D Printing Animation
3D Printing Animation (changed)
cards:
    icon: mdi:printer-3d-nozzle
    icon_color: cyan
    primary: 3D Printing
    card_mod:
      style: |
        ha-state-icon {
          clip-path: inset(83% 72% 0 0);
        ha-card {
          --ha-card-border-width: 0;
    icon_color: cyan
    primary: ''
    card_mod:
      style:
          .shape {
          ha-card {
            width: 66px;
            top: -66px;
          ha-state-icon {
            animation: print 1s linear infinite alternate;
          @keyframes print {
            0% { transform: translateX(4px); }
            30% { clip-path: polygon(0 0, 100% 0%, 100% 100%, 0 100%, 0 26%); }
            100% { transform: translateX(-4px); clip-path: polygon(0 0, 100% 0%, 100% 100%, 40% 100%, 0 26%); }
card_mod:
  style: |
    ha-card {
      height: 66px;
Mushroom 3D Printer Animation
3D Printer Animation (changed)
primary: 3D Printer
card_mod:
  style: |
    ha-state-icon {
      animation: print 2s infinite;
    @keyframes print {
      0%, 100% { clip-path: polygon(0 0, 0 51%, 20% 51%, 51% 33%, 81% 53%, 100% 53%, 100% 0); }
      10% { clip-path: polygon(0 0, 0 100%, 49% 100%, 85% 83%, 49% 98%, 50% 89%, 51% 82%, 46% 79%, 36% 73%, 17% 82%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
      20% { clip-path: polygon(0 0, 0 100%, 100% 100%, 85% 83%, 66% 73%, 56% 79%, 51% 83%, 46% 79%, 36% 73%, 17% 82%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
      30% { clip-path: polygon(0 0, 0 100%, 100% 100%, 85% 83%, 66% 73%, 54% 69%, 50% 61%, 45% 69%, 36% 73%, 17% 82%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
      40% { clip-path: polygon(0 0, 0 100%, 100% 100%, 85% 83%, 66% 73%, 54% 69%, 50% 61%, 45% 69%, 34% 63%, 25% 54%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
      50% { clip-path: polygon(0 0, 0 100%, 100% 100%, 76% 51%, 66% 63%, 54% 69%, 50% 61%, 45% 69%, 34% 63%, 25% 54%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
      60% { clip-path: polygon(0 0, 0 100%, 100% 100%, 76% 51%, 66% 63%, 55% 69%, 50% 61%, 39% 55%, 32% 55%, 25% 54%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
      70% { clip-path: polygon(0 0, 0 100%, 100% 100%, 76% 51%, 68% 53%, 60% 55%, 50% 61%, 39% 55%, 32% 55%, 25% 54%, 20% 50%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
      80% { clip-path: polygon(0 0, 0 100%, 100% 100%, 76% 51%, 68% 53%, 60% 55%, 50% 61%, 50% 50%, 51% 37%, 31% 44%, 30% 35%, 51% 33%, 81% 52%, 100% 52%, 100% 0); }
      90% { clip-path: polygon(0 0, 0 100%, 100% 100%, 77% 51%, 67% 42%, 64% 34%, 56% 34%, 50% 36%, 39% 40%, 31% 44%, 30% 35%, 41% 33%, 85% 53%, 100% 52%, 100% 0); }
Mushroom Auto Fix #2 Animation
Auto Fix #2 Animation (changed)
icon: mdi:auto-fix
icon_color: cyan
primary: 'Auto Fix #2'
card_mod:
  style: |
    ha-state-icon {
      animation: sparkle 2s linear infinite, kadabra 2s ease-in-out infinite;
      0%, 68%, 100% { clip-path: polygon(0% 100%, 1% 75%, 56% 22%, 80% 43%, 26% 100%); }
Mushroom Vroom Animation
Vroom Animation (changed)
icon: mdi:car-hatchback
icon_color: red
primary: Vroom
card_mod:
  style:
      .shape {
      ha-state-icon {
        animation: vroom 2s ease-in-out infinite;
      @keyframes vroom {
        49% { opacity: 1;}
        50% { transform: translate(32px); opacity: 0; }
        51% { transform: translate(-32px); opacity: 0; }
        52% { opacity: 1; }
Mushroom Double Garage Animation
Double Garage Animation (changed)
primary: Double Garage
icon: mdi:garage-variant
icon_color: amber
card_mod:
  style: |
    ha-state-icon {
    @keyframes door {
      25%  { clip-path: polygon(0 0, 0 100%, 19% 100%, 19% 74%, 81% 74%, 81% 100%, 100% 100%, 100% 0); }
      50%  { clip-path: polygon(0 0, 0 100%, 19% 100%, 19% 60%, 81% 60%, 81% 100%, 100% 100%, 100% 0); }
      75% { clip-path: polygon(0 0, 0 100%, 19% 100%, 19% 48%, 81% 48%, 81% 100%, 100% 100%, 100% 0); }
Updated Posts :point_down:
Part 1, Part 2, Part 3, Part 4, Part 5
Original Posts by @rhysb :point_down: please only like his posts.
Does anyone see what is wrong here? The idea is to get the icon to wobble and the background of the card to be red if the state is unlocked. I have this working in another version but I was unable to get the shape color gone.
layout: vertical
secondary: |-
  {% if is_state(entity, 'unlocked') %}
  UNLOCKED
  LOCKED
entity: lock.front_door_lock
primary: |
  Front Door
icon_color: |
  red
  green
icon: |
  mdi:lock-open
  mdi:lock
tap_action:
  action: more-info
hold_action:
  action: toggle
fill_container: false
card_mod:
  style:
      .shape {
        --shape-color:;
        --icon-size: 60px;
        --icon-symbol-size: 50px
    ha-state-icon {
      {{'animation: wobbling 0.7s linear infinite alternate;' if is_state('lock.front_door_lock', 'unlocked') }}
    @keyframes wobbling {
      0% {transform: rotate(-50deg);}
      100% {transform: rotate(50deg);}
    ha-card {
    background-color: {{ 'rgba(255, 0, 0, 0.4)' if
    is_state('lock.front_door_lock', 'unlocked') else 'rgba(0, 131, 0, .4)'}};
      height:161px !important;
Only issue is your .: | placement. I also added the word none to your --shape-color entry. But i honestly dont think that this matters :slight_smile:
layout: vertical
secondary: |-
  UNLOCKED
  LOCKED
primary: |
  Front Door
icon_color: |
  red
  green
icon: |
  mdi:lock-open
  mdi:lock
tap_action:
  action: more-info
hold_action:
  action: toggle
card_mod:
  style:
      .shape {
        --icon-size: 60px;
      ha-state-icon {
      ha-card {
Appreciate the sentiment but updating them takes 100 x less time than coming up with the animations in the first place :slight_smile:
I dont know a good vacuum map card unfortunately. I dont have a robo vacuum myself so i havent done much looking to be honest…
What editor do you use? Because visually the placement looks correct but when I copy and pasted your code, it worked fine.
Just the built in editor my friend.
How the indenting is meant to look.
How yours looked.
Its not huge but there is a definite difference :slight_smile:
Basically think of the fact that the .: | should start at the same place you would place any other entry under style: see how in my example the mushroom-shape-icon$: | and the .: | start at the same indentation?
I would love to see some guru post the sollution here, I’m also looking into this.
I’m no guru, but I was looking for this a few days ago to show when a door was opened/closed. I’m not sure if it’s what you’re looking for, but I put…
{% if is_state(config.entity, 'off') %}
Closed {{ relative_time(states.binary_sensor.basement_door_state.last_changed) }} ago
{%else%}
Opened {{ relative_time(states.binary_sensor.basement_door_state.last_changed) }} ago
{%endif%}
… in and it works for me.
MrGrey.
