Card is slightly updated now (here). solarnet is the solar power going back into the grid (so after deduction of own use of solar). The bars are actual power consumption. Green area = solar power generated
So to change, say, the blue used in a Mushroom card, I still need to use mush-rgb-blue: n, n, n
in my own theme?
Yes, that is correct.
hi there everybody. Maybe someone here knows if its possible to merge these two together to one chip?
And were ist the sidebar defined? i donât get it.
I have a 2 sensors called sensor.gad_today
and sensor.gad_tomorrow
. They hold fixed values: None, gft, papier, pmd or restafval. In the âcustom button cardâ I can change the image that is shown in the button based on the state (see code below).
I know want to transform this into a button that belongs to the look and feel of Mushroom, like the rest of my dash. So the mushroom âiconâ should show an icon when value is non and use the pictures if any of the other states.
Probably can be done by a template but have not found one yet where an image is loaded. Help appreciated
So currently I have this:
My current custom button code:
`cards:
- entity: sensor.gad_today
icon: mdi:trash-can
layout: icon_name_state2nd
show_entity_picture: true
show_last_changed: false
show_name: âyesâ
show_state: true
state:- entity_picture: /local/green.png
value: gft - entity_picture: /local/paper.png
value: papier - entity_picture: /local/pmd.png
value: pmd - entity_picture: /local/grey.png
value: restafval
styles:
card:- height: 67px
entity_picture: - padding: 5px 60px 0px px
name: - padding: 0px 10px
- font-size: 15px
- font-family: Helvetica
- justify-self: end
state: - font-size: 15px
- padding: 0px 10px
- justify-self: end
- text-transform: capitalize
- font-weight: bold
tap_action:
action: more-info
type: custom:button-card
- height: 67px
- entity: sensor.gad_tomorrow
icon: mdi:trash-can
show_name: âyesâ
show_state: true
value: restafval
styles:
card:- height: 67px
- font-size: 15px
- justify-self: end
- padding: 0px 10px
- justify-self: end
- font-weight: bold
tap_action:
action: more-info
type: horizontal-stack`
- height: 67px
The sidebar is made using the Custom sidebar card: GitHub - DBuit/sidebar-card
You can see my sidebar code here: Mushroom Cards - Build a beautiful dashboard easily đ - #129 by Roflcopterer
Hi thee, I have the following card:
This was created with the following YAML:
type: custom:mushroom-climate-card
entity: climate.bathroom
primary_info: none
icon_type: none
show_temperature_control: true
secondary_info: none
card_mod:
style:
mushroom-climate-temperature-control$:
mushroom-input-number$: |
#container {
background: none;
padding: 0px;
#container .button {
height: 100%;
width: 30%;
#container .button:nth-child(1) {
background: rgba(var(--rgb-blue), 0.2);
#container .button:nth-child(3) {
background: rgba(var(--rgb-red), 0.2);
What I would like to do is remove or reduce the white space at the top of the card. Any ideas anyone?
Maybe Iâve missed it because Iâm on mobile and currently out so apologies if this has been explained before.
Everything on my dashboard now has an outline around it since updating to 2022.11 how do I remove this back to how it looked before?
Is this what you wanted?
primary_info: none
icon_type: none
card_mod:
style:
#container {
background: none;
padding: 0px;
height: 100%;
width: 30%;
ha-card {
padding-top: 0px !important;
Have a look here:
Morning Intro_Verti,
this conditional approach for having an overview on the main dashboard is awesome. I will have a look into this for sure and as far as I understood this correctly it can be used for all kind of things with an entity e.g. a disk in my NAS is not ok, but the state is not âonâ or âoffâ so something to consider, or one of many docker containers which I use is down etc.
Thanks for sharing this with us
Cheers
P4SQL
Rhys, that is exactly what I wanted . I couldnât work out how to insert the ha-card modifier. Thanks, you are a genius.
If you want to use the animations with the Tile Card Iâve added some instructions to Part 4.
Did you find a solution?
A custom Spotify page created with Mushroom.
This when a music is being played.
And this when nothing is played.
- Media players are listed as buttons below the image and with a press you can easily navigate between them.
- Music follow integration are also implemented. Spotify music follows you around the house automatically. It can also be turned off with a simple button.
- There is a hidden feature under the Spotify logo. When you press it, the music starts on the last motion detected rooms media player.
- Force start will be implemented if nothing was playing at the moment.
- Media controls are down below of the page.
- Total time of which you listened Spotify is also implented in time details.
- One Media player controls all others
- Spotify playlists are also displayed in the page and with a simple click you can start listening right away on your media player.
Maybe this is what youâre looking for? Mushroom Cards - Build a beautiful dashboard easily đ - #2142 by rhysb
The custom:mushroom-template-card has a picture option, where you can add a template. If sensor value is âpapierâ show that image, etc. Else no picture, just the mdi:delete icon.
Iâm using it in a simplistic weather card, to show an icon based on the current weather. Itâs with images from the web, but should be possible with local files too?
Code
type: custom:mushroom-template-card
primary: 'Nu: {{states(''sensor.openweathermap_weather'')}}'
secondary: '{{states(''sensor.openweathermap_temperature'') | round(1) }} ÂșC'
icon: mdi:weather-partly-cloudy
entity: sensor.openweathermap_condition
picture: >-
{% set cloud = states("sensor.openweathermap_cloud_coverage")|int %} {% set
rain = states("sensor.buienalarm_precipitation")|float %} {% if entity ==
"exceptional" %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/isolated_scattered_tstorms_day_dark_color_96dp.png
{% elif entity == "fog" %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/haze_fog_dust_smoke_dark_color_96dp.png
{% elif entity == "hail" %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/wintry_mix_rain_snow_dark_color_96dp.png
{% elif entity == "lightning" %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/strong_tstorms_dark_color_96dp.png
{% elif entity == "lightning-rainy" %}
{% elif entity == "snowy" %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/flurries_dark_color_96dp.png
{% elif entity == "snowy-rainy" %}
{% elif rain > 0 and rain <= 0.5 %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/drizzle_dark_color_96dp.png
{% elif rain > 0.5 and rain <= 1.5 %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/showers_rain_dark_color_96dp.png
{% elif rain > 1.5 %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/heavy_rain_dark_color_96dp.png
{% elif states("sun.sun") == "below_horizon" %} {% if cloud < 20 %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/clear_night_dark_color_96dp.png
{% elif cloud < 40 %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/mostly_clear_night_dark_color_96dp.png
{% elif cloud < 60 %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/partly_cloudy_night_dark_color_96dp.png
{% elif cloud < 80 %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/mostly_cloudy_night_dark_color_96dp.png
{% else %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/cloudy_dark_color_96dp.png
{% endif %} {% else %} {% if cloud < 20 %}
http://www.gstatic.com/images/icons/material/apps/weather/2x/sunny_dark_color_96dp.png
http://www.gstatic.com/images/icons/material/apps/weather/2x/mostly_sunny_dark_color_96dp.png
http://www.gstatic.com/images/icons/material/apps/weather/2x/partly_cloudy_dark_color_96dp.png
http://www.gstatic.com/images/icons/material/apps/weather/2x/mostly_cloudy_day_dark_color_96dp.png
{% elif cloud <= 100 %}
{% else %} none {% endif %} {% endif %}
multiline_secondary: false
icon_color: grey
tap_action:
action: navigate
navigation_path: /lovelace-tablet/weather
card_mod:
style: |
ha-card {
{% if config.entity == "exceptional" %}
background: rgba(var(--mush-rgb-orange), 0.3);
{% elif config.entity == "fog" or config.entity == "snowy" or config.entity == "snowy-rainy" %}
background: rgba(var(--mush-rgb-blue-grey), 0.3);
{% elif config.entity == "hail" or config.entity == "lightning" or config.entity == "lightning-rainy" or (states("sensor.buienalarm_precipitation") | float) > 0 %}
background: rgba(var(--mush-rgb-indigo), 0.3);
background: rgba(var(--mush-rgb-deep-purple), 0.4);
{% else %}
background: rgba(var(--mush-rgb-blue), 0.3);
{% endif %}
Cool. Thanks, will try that
Iâm making everything new with Mushroom and now I have borders and can not remove these. I try many hints from here but maybe Iâm wron. I using newest version without special theme:
type: custom:vertical-stack-in-card
cards:
- cards: null
type: custom:mushroom-title-card
title: Umgebung
subtitle: null
entity: sensor.dwd_wetterwarnung_current_warning_level
layout: horizontal
primary: DWD Wetterwarnung
tap_action:
action: more-info
secondary: >-
{% if
is_state_attr('sensor.dwd_wetterwarnung_current_warning_level','warning_count',0)
Keine
{% elif
(state_attr('sensor.dwd_wetterwarnung_current_warning_level','warning_count',0)|int)
> 0 %}
{{ state_attr('sensor.dwd_wetterwarnung_current_warning_level','warning_1_name') }}
{% else %}
Unbekannt
{% endif %}
icon: >-
{% if
mdi:check-circle
{% elif
> 0 %}
mdi:alert-outline
{% else %}
mdi:circle-outline
{% endif %}
icon_color: >-
{% if
green
{% elif
> 0 %}
red
{% else %}
grey
{% endif %}
- type: custom:vertical-stack-in-card
horizontal: true
cards:
entity: sensor.netatmo_terrasse_temperature
primary: AuĂentemperatur
secondary: >-
{{- states('sensor.netatmo_terrasse_temperature') -}} {{- " " -}} {{-
state_attr('sensor.netatmo_terrasse_temperature','unit_of_measurement')
icon: mdi:thermometer
icon_color: grey
tap_action:
action: more-info
- type: custom:layout-card
layout_type: custom:masonry-layout
layout:
width: 220
max_cols: 2
height: auto
padding: 0px
card_margin: var(--masonry-view-card-margin, 4px 4px 4px 4px)
cards:
- type: custom:mini-graph-card
entities:
- entity: sensor.netatmo_terrasse_temperature
state_adaptive_color: true
show_fill: false
decimals: 1
hour24: true
hours_to_show: 24
height: 80
line_width: 4
show:
graph: line
icon: false
state: false
legend: false
points: false
labels: false
color_thresholds:
- color: '#636154'
value: 0
- color: '#6ac6f9'
value: 10
- color: '#fbed63'
value: 20
- color: '#ffb748'
value: 30
- color: '#f0341f'
value: 40
card_mod:
style: |
ha-card {
background: none;
box-shadow: none;
--ha-card-border-width: 0;
horizontal: true
cards:
entity: sensor.sts_terrassetemp_min
primary: 24h Min.
secondary: >-
{{- states('sensor.sts_terrassetemp_min') -}} {{- " " -}} {{-
state_attr('sensor.sts_terrassetemp_min','unit_of_measurement') -}}
icon: mdi:thermometer-minus
icon_color: blue
tap_action:
action: more-info
entity: sensor.sts_terrassetemp_mean
primary: 24h Ă
secondary: >-
{{- states('sensor.sts_terrassetemp_mean') -}} {{- " " -}} {{-
state_attr('sensor.sts_terrassetemp_mean','unit_of_measurement') -}}
icon: mdi:thermometer-off
tap_action:
action: more-info
entity: sensor.sts_terrassetemp_max
primary: 24h Max.
secondary: >-
{{- states('sensor.sts_terrassetemp_max') -}} {{- " " -}} {{-
state_attr('sensor.sts_terrassetemp_max','unit_of_measurement') -}}
icon: mdi:thermometer-plus
icon_color: red
tap_action:
action: more-info
horizontal: true
cards:
entity: sensor.mmx_haus_temp_average
layout: horizontal
primary: Innen Lufttemperatur
secondary: >-
{{ "Ă " }} {{- states('sensor.mmx_haus_temp_average') | round(1) -}}
state_attr('sensor.mmx_haus_temp_average','unit_of_measurement') -}}
tap_action:
action: more-info
icon: >-
{%- set temp = states('sensor.mmx_haus_temp_average') | float -%} {%-
if (temp >= 23.0) -%}
mdi:alert-outline
{%- elif (temp >= 22.0) -%}
mdi:alert-circle-outline
{%- elif (temp >= 20.5) -%}
mdi:check-circle
{%- elif (temp >= 19.5) -%}
{%- else -%}
mdi:alert-outline
{%- endif -%}
icon_color: >-
red
yellow
green
yellow
{%- else -%}
red
{%- endif -%}
entity: group.grp_innenco2
layout: horizontal
primary: Innen LuftqualitÀt
secondary: >-
{% set thresholdWarn = 1200 %} {% set thresholdAlarm = 2200 %} {% set
output = namespace(wert=0) %} {% for entity in
states.group.grp_innenco2.attributes.entity_id %}
{% if float(states(entity),0) > thresholdWarn %}
{% set output.wert = output.wert + 1 %}
{% elif float(states(entity),0) > thresholdAlarm %}
{% set output.wert = output.wert + 11 %}
{% endif %}
{% endfor %} {% if output.wert > 10 %}
{{- 'COÂČ Alarm - Ă ' -}}
{{- states('sensor.mmx_haus_co2_average') | round(0) -}}
{{- ' ppm' -}}
{% elif output.wert > 0 %}
{{- 'COÂČ Warnung - Ă ' -}}
{{- ' ppm' -}}
{% else %}
OK
{% endif %}
tap_action:
action: more-info
icon: >-
{% endif %}
mdi:alert-outline
{% else %}
mdi:check-circle
{% endif %}
icon_color: >-
{% endif %}
red
yellow
{% else %}
green
{% endif %}
Thansk for help, Steffen
