Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
I wasnt giving you my code (as its way to long to post) and i wasnt giving you the code for the room card you posted. I just gave you an example of how it is built. You should be able to build it yourself from there. Just add more chips and if you dont want the background of the chip to be colored. Then remove the card mod code under the chip.
Here is the code for 1 room card with all of the tap actions stripped out.
Code
type: custom:stack-in-card
cards:
  - type: custom:stack-in-card
    entity: light.lounge_lights
    cards:
        primary: Lounge
        secondary: >-
          {{ '{0:.2f}'.format( (
          state_attr('climate.thermostat','current_temperature')|float))}}°C |
          {{'{0:.0f}'.format((states('sensor.lounge_downstairs_humidity')
          |float))}}%
        icon: mdi:sofa
        icon_color: |-
          {% if is_state(config.entity, 'on') %}
            {% if state_attr(config.entity,'rgb_color') != none %}
              {{state_attr(config.entity,'rgb_color')[0] * 0.5, state_attr(config.entity,'rgb_color')[1] * 0.5, state_attr(config.entity,'rgb_color')[2] * 0.5 }}
            {% else %}
              #694311
            {% endif %}
          {% else %}
            #ba03fc
          {% endif %}
        tap_action:
          action: navigate
          navigation_path: /lovelace/lounge
        hold_action:
          action: call-service
          service: light.toggle
            entity_id:
              - light.lounge_lights
              - light.lounge_tv_light
          data: {}
        double_tap_action:
          action: none
        fill_container: false
        multiline_secondary: false
        badge_icon: ''
        badge_color: ''
        card_mod:
          style: |
            ha-card {
              padding-bottom: 0px !important;
            mushroom-shape-icon {
              position: absolute;
              top: -57px;
              left: -40px;
            mushroom-state-info {
              padding-left: 34px;
              z-index: 1;
            :host {
              --mush-icon-size: 2.84em;
              --mush-icon-symbol-size: 1em
      - type: custom:mushroom-chips-card
        chips:
          - type: template
            double_tap_action:
              action: none
            tap_action:
              action: none
            hold_action:
              action: none
            content: ''
            icon: |-
              {% if expand(states.light)
                |selectattr('state', 'eq', 'on')
                |selectattr('entity_id', 'in', area_entities('Lounge'))
                |rejectattr('entity_id', 'search', 'master')
                |map(attribute='entity_id')
                |list | count > 1
                mdi:lightbulb-multiple
              {% else %}
                mdi:lightbulb
              {% endif %}
            icon_color: |-
                |list | count > 0
                {% else %}
                  #694311
                {% endif %}
              {% else %}
                none
              {% endif %}
            card_mod:
              style: |
                ha-card {
                  {% if states(config.entity) == 'on' %}
                      background-color: rgba{{(state_attr(config.entity,'rgb_color')[0] * 0.85, state_attr(config.entity,'rgb_color')[1] * 0.85, state_attr(config.entity,'rgb_color')[2] * 0.85) + (0.6,)}} !important;
                    {% else %}
                      background-color: rgba(105, 67, 17, 0.2) !important;
                    {% endif %}
                  {% else %}
                    background-color: rgba(var(--rgb-disabled), 0.2) !important;
                  {% endif %}
                  box-shadow: none !important;
                  border: none !important;
                  min-width: 0px !important;
                  width: 32px !important;
                  height: 32px !important;
                  justify-content: center;
                ha-card::after {
                  content: '{{ expand(states.light) |selectattr('state', 'eq', 'on') |selectattr('entity_id', 'in', area_entities('Lounge')) |rejectattr('entity_id', 'search', 'master') |map(attribute='entity_id') |list | count }}';
                  position: absolute;
                  top: -11%;
                  right: -11%;
                  display: flex;
                  align-items: center;
                  width: 15px;
                  height: 15px;
                  font-size: 9px;
                  font-weight: 700;
                      background-color: rgba{{(state_attr(config.entity,'rgb_color')[0] * 0.65, state_attr(config.entity,'rgb_color')[1] * 0.65, state_attr(config.entity,'rgb_color')[2] * 0.65) + (0.6,)}} !important;
                    {% else %}
                      background-color: rgba(105, 67, 17, 0.5) !important;
                    {% endif %}
                  {% else %}
                    background-color: rgba(var(--rgb-disabled), 0.5) !important;
                  {% endif %}
                  border-radius: 50%;
          - type: template
            icon: mdi:thermostat
            icon_color: '#e85c10'
            content: ''
            double_tap_action:
              action: none
            tap_action:
              action: none
            hold_action:
              action: none
            card_mod:
              style: |
                ha-card {
                  {% if states('light.lounge_lights') == 'on' %}
                    background-color: rgba{{(state_attr('light.lounge_lights','rgb_color')[0] * 0.85, state_attr('light.lounge_lights','rgb_color')[1] * 0.85, state_attr('light.lounge_lights','rgb_color')[2] * 0.85) + (0.6,)}} !important;
                  {% else %}
                  {% endif %}
                ha-card::after {
                  content: '{{state_attr('climate.thermostat','temperature') | round }}';
                  position: absolute;
                  top: -11%;
                  right: -11%;
                  display: flex;
                  width: 15px;
                  height: 15px;
                  font-size: 9px;
                  font-weight: 700;
                  background: rgba(232, 92, 16, 0.5);
                  border-radius: 50%;
          - type: template
            icon: mdi:door-open
            icon_color: '#ff6f00'
            content: ''
            double_tap_action:
              action: none
            tap_action:
              action: none
            hold_action:
              action: none
            card_mod:
              style: |
                ha-card {
                  {% else %}
                  {% endif %}
          - type: template
            icon: mdi:battery-10
            icon_color: '#ff0000'
            content: ''
            double_tap_action:
              action: none
            tap_action:
              action: none
            hold_action:
              action: none
            card_mod:
              style: |
                ha-card {
                  {% else %}
                  {% endif %}
                ha-card::after {
                  content: '{{expand(states.sensor)
                              |selectattr('entity_id', 'search', 'battery')
                              |selectattr('attributes.device_class', 'defined')
                              |selectattr('attributes.device_class', 'eq', 'battery')
                              |rejectattr('entity_id', 'in', integration_entities('mobile_app'))
                              | map(attribute='state')
                              | reject('in', ['unknown', 'unavailable'])
                              | map('int', -1)
                              | select('le', 10)
                              | select('ge', 0)
                              | list
                              | count
                  position: absolute;
                  top: -11%;
                  right: -11%;
                  display: flex;
                  width: 15px;
                  height: 15px;
                  font-size: 9px;
                  font-weight: 700;
                  background: rgba(232, 32, 16, 0.4);
                  border-radius: 50%;
        alignment: end
        card_mod:
          style:
              mushroom-template-chip:nth-child(1) {
                {% if states('light.lounge_lights') == 'off' %}
                  margin-right: 0px;
                  display: none !important;
                {% else %}
                {% endif %}
              mushroom-template-chip:nth-child(2) {
                {% if states('input_boolean.heating') == 'off' %}
                  margin-right: 0px;
                  display: none;
                {% else %}
                {% endif %}
              mushroom-template-chip:nth-child(3) {
                {% if states('binary_sensor.lounge_back_door_contact') == 'off' %}
                  margin-right: 0px;
                  display: none;
                {% else %}
                {% endif %}
              mushroom-template-chip:nth-child(4) {
                {% if expand(states.sensor)
                  | map('int', -1)
                  | select('le', 10)
                  | select('ge', 0)
                  | list
                  | count <= 0
                  margin-right: 0px;
                  display: none;
                {% else %}
                {% endif %}
              ha-card {
                --chip-spacing: 3px;
                padding-right: 5px;
                padding-bottom: 2px;
                height: 35px;
    card_mod:
      style: |
        ha-card {
          {% if is_state(config.entity,'on') %}
            --primary-text-color: #1f1f1f !important;
            --secondary-text-color: #292929;
            background-color: rgba{{state_attr(config.entity,'rgb_color') + (1,)}}
          {% endif %};
If i kept the tap actions the code would be far too long :slight_smile:
@BMWAddict, take a look at this one for my actual room card code.
If the name is short this will center the name under the icon:
type: custom:mushroom-person-card
entity: person.tom
primary_info: name
secondary_info: none
icon_type: entity-picture
card_mod:
  style:
    mushroom-state-item$: |
      .container {
        display: flex;
        flex-direction: column !important;
    mushroom-state-info$: |
      .container {
        width: 83%;
    mushroom-shape-avatar$: |
      .picture {
        display: flex;
        border-radius: 50%;
        {% if states(config.entity) == 'home' %}
          animation: pinggreen 6s infinite;
        {% else %}
          animation: pingred 6s infinite;
        {% endif %}
      @keyframes pinggreen {
        0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-green), 0.9);}
        100% {box-shadow: 0 0 5px 15px transparent;}
      @keyframes pingred {
        0% {box-shadow: 0 0 5px 3px rgba(var(--rgb-red), 0.9);}
      ha-card {
        --icon-size: 72px;
        width: fit-content;
thanks thanks thanks
Is is possible a dead link ?
Oops! That page doesn’t exist or is private.
KR,
Bart
Hi, i have a problem, can you explain me how to create other buttons for light, cover and other entities to show when i click on lightbulb for example?
Oh, I did not create it. I guess it is private to only the creator and me. I sent invite to you
How can I change the background color of a chip card?
I thought something like this. But unfortunately the background of the chip does not change
Also ich meine die Chips selber, nicht den Hintergrund der Card
chips:
  - type: template
    card_mod:
      style: |
        ha-card {
          --ha-card-background: #97a59c;
    content: KÜCHE
    icon_color: amber
    icon: bha:thermostat
close:
chips:
  - type: template
    card_mod:
      style: |
        ha-card {
          background: #97a59c !important;
    content: KÜCHE
    icon_color: amber
Check out my guide, think it will help you a lot :slight_smile:
I need help
  1. to align all items within the pink area to right.
  2. also would like to have width of aqua and pink area to 33% and 66%.
my code:
type: horizontal-stack
cards:
  - type: custom:mod-card
    card_mod:
      style:
        layout-card$:
          grid-layout$: |
            :host {
              padding: 0px !important;
              background-color: white;
            #root {
              margin: 0px !important;
              justify-content: start;
              background-color: aqua;
    card:
      type: custom:layout-card
      layout_type: custom:grid-layout
      cards:
        - type: custom:mushroom-entity-card
          entity: person.madir
          layout: vertical
          primary_info: none
          card_mod:
            style: >
              ha-card { #background: none;  width: 42px;  padding: 0px
              !important; border-radius: 50% !important;  display: block;
              transform: scale(0.85);  border-radius: 50% !important; grid-area:
              i1;   }
          view_layout:
            grid-area: i1
          layout: vertical
          primary_info: none
          card_mod:
            style: >
              i2;   }
          view_layout:
            grid-area: i2
      layout:
        grid-template-columns: min-content min-content
        grid-template-rows: auto
        grid-template-areas: |
          "i1 i2  "
    card_mod:
      style:
        layout-card$:
          grid-layout$: |
            :host {
            #root {
              background-color: pink;
    card:
      cards:
        - type: custom:mushroom-climate-card
          entity: climate.thermostat_bedroom_1
          icon: mdi:fire
          primary_info: none
          icon_type: icon
          tap_action:
            service: script.off_auto_heat
            target: {}
          hold_action:
            action: more-info
          double_tap_action:
            action: none
          card_mod:
            style: >
              i1;  }
          view_layout:
            grid-area: i1
          icon: |
            {% if is_state('light.bedroom_1_all_lights', 'on') %}
              mdi:lightbulb-group
            {% else %}
              mdi:lightbulb-group
            {% endif %}
          icon_color: |
            {% if is_state('light.bedroom_1_all_lights','on') %}
              orange
            {% else %}
            {% endif %}
          badge_icon: |-
            {% set all = expand('light.bedroom_1_all_lights') | list %}
            {% set on_lights = all | selectattr('state', 'eq', 'on') | list %}
            {% if on_lights %}
              {{ on_lights | count }}
            {% endif %}
          badge_color: |
            {% set all = expand('light.bedroom_1_all_lights')| list -%}
            {% set open1 = all | selectattr('state','eq','on')|list|count%}
            {% if open1 == 0 %}
            {% else %}
              orange
            {% endif %}
          entity: light.bedroom_1_lights
          multiline_secondary: true
          secondary: ''
          primary: ''
          tap_action:
            action: toggle
          hold_action:
            action: more-info
          double_tap_action:
            action: none
          card_mod:
            style: >
              {% set all_lights = expand('light.bedroom_1_all_lights') | list %}
              {% set on_lights = all_lights | selectattr('state', 'eq', 'on') |
              list %} {% if on_lights %}
                mushroom-badge-icon:after {
                  content: "{{ on_lights | count }}";
                  position: absolute;
                  display: flex;
                  color: var(--card-background-color);
                  font-weight: bolder;
                  border-radius: 50%;
                  top: 0;
                  width: 100%;
                  height: 100%;
                  font-size: 0.8em;
              {% else %}
                  display: none;
              {% endif %}
              i1; }
          view_layout:
            grid-area: i2
          layout: vertical
          primary_info: none
          card_mod:
            style: >
              i3; float: right; }
          view_layout:
            grid-area: i3
          layout: vertical
          primary_info: none
          card_mod:
            style: >
              i4; }
          view_layout:
            grid-area: i4
      layout:
        grid-template-columns: min-content min-content min-content min-content
          "i4 i3 i2 i1"
My opinion is that you should rework this entire thing to use the chip cards instead. it will just be easier for you to align things with it, as it natively supports aligning to end vs aligning start (or justify, or center alignment).
you could do it pretty easily something like this:
Code
card_mod:
  style:
    layout-card$:
      grid-layout$: |
        :host {
        #root {
          background-color: none;
card:
  cards:
      chips:
        - type: template
          icon: mdi:account
          icon_color: blue
          card_mod:
            style: |
              ha-card {
                background: #d6e6f6 !important;
        - type: template
          icon: mdi:account
          icon_color: blue
          card_mod:
            style: |
              ha-card {
      card_mod:
        style: |
          ha-card {
            background: cyan !important;
      chips:
        - type: template
          icon: mdi:account
          icon_color: blue
          card_mod:
            style: |
              ha-card {
        - type: template
          icon: mdi:account
          icon_color: blue
          card_mod:
            style: |
              ha-card {
        - type: template
          icon: mdi:lightbulb-group
          entity: light.office_lights_toggle
          icon_color: amber
          card_mod:
            style: |
              ha-card {
                background: #f7e6d3 !important;
              ha-card::after {
                content: '{{ expand(states.light) |selectattr('state', 'eq', 'on') |selectattr('entity_id', 'in', area_entities('Office')) |rejectattr('entity_id', 'search', 'master') |map(attribute='entity_id') |list | count }}';
                position: absolute;
                top: -11%;
                right: -11%;
                display: flex;
                width: 15px;
                height: 15px;
                font-size: 10px;
                font-weight: 700;
                  background-color: rgba(var(--rgb-amber), 1) !important;
                {% else %}
                  background-color: rgba(var(--rgb-disabled), 1) !important;
                {% endif %}
                border-radius: 50%;
        - type: template
          icon: mdi:fire
          icon_color: |-
              {% if state_attr(config.entity,'hvac_action') == 'idle' %}
                green
              {% else %}
                red
              {% endif %}
          entity: climate.office_heating
          card_mod:
            style: |
              ha-card {
                  background: #dcead9 !important;
                {% else %}
                  background-color: #ffb5a8 !important;
                {% endif %}
              ha-card::after {
                content: '{% if state_attr(config.entity,'hvac_action') == 'idle' %} schedule {% else %} local_fire_department {% endif %}';
                position: absolute;
                top: -11%;
                right: -11%;
                display: flex;
                width: 15px;
                height: 15px;
                font-size: 10px;
                font-weight: 700;
                font-family: 'Material Icons';
                {% else %}
                  background-color: rgba(var(--rgb-red), 1) !important;
                {% endif %}
                border-radius: 50%;
      alignment: end
      card_mod:
        style: |
          ha-card {
            background: pink !important;
  layout:
    grid-template-columns: 33.3333% 66.6666%
    max_cols: 2
I do use the material icons font to have the icon in the climate “badge” otherwise it wont display an icon. It is just a google font that can be installed. Explained here:
Its possible to fix bottom this card?
If you are talking about the card i posted above then yes:
Summary
card_mod:
  style:
    layout-card$:
      grid-layout$: |
        :host {
        #root {
      :host {
        position: sticky !important;
        z-index: 9;
        bottom: 0px;
card:
  cards:
      chips:
        - type: template
          icon: mdi:account
          icon_color: blue
          card_mod:
            style: |
              ha-card {
        - type: template
          icon: mdi:account
          icon_color: blue
          card_mod:
            style: |
              ha-card {
      card_mod:
        style: |
          ha-card {
      chips:
        - type: template
          icon: mdi:account
          icon_color: blue
          card_mod:
            style: |
              ha-card {
        - type: template
          icon: mdi:account
          icon_color: blue
          card_mod:
            style: |
              ha-card {
        - type: template
          icon_color: amber
          card_mod:
            style: |
              ha-card {
              ha-card::after {
                position: absolute;
                top: -11%;
                right: -11%;
                display: flex;
                width: 15px;
                height: 15px;
                font-size: 10px;
                font-weight: 700;
                {% else %}
                {% endif %}
                border-radius: 50%;
        - type: template
          icon: mdi:fire
          icon_color: |-
              green
            {% else %}
              red
            {% endif %}
          card_mod:
            style: |
              ha-card {
                {% else %}
                {% endif %}
              ha-card::after {
                position: absolute;
                top: -11%;
                right: -11%;
                display: flex;
                width: 15px;
                height: 15px;
                font-size: 10px;
                font-weight: 700;
                {% else %}
                {% endif %}
                border-radius: 50%;
      alignment: end
      card_mod:
        style: |
          ha-card {
  layout:
    max_cols: 2
Keep in mind once you add the code you need to fully exit editing mode for it to take effect that it is stuck at the bottom.
This section is the important section:
      :host {
        z-index: 9;
        bottom: 0px;
great… thanks thanks and thanks.
last question: if i woul change background colors from pink/lightblue, or the background color of single chips from white to system auto (should be white on day and black during the night), should i change ‘background’, or delete? if i have to change in?
thank you again
You could probably just delete the section. It will then follow system default from the theme you are using.
yes, im only deleted the colour, so if im going to change idea i will set another colour.
Anyway, can you help me to set this menu? im finding to create a button to call this menù…
type: custom:local-conditional-card
default: show
card:
  mode: vertical
  cards:
      primary: Home
      secondary: ''
      icon: mdi:home
      icon_color: white
      layout: vertical
      tap_action:
        action: fire-dom-event
        local_conditional_card:
          action: set
          ids:
            - rooms: toggle
      card_mod:
        style: |
          ha-card {
            width: 210px;
            height: 20px;
            --spacing: 0px;
            padding-top: 10px !important;
            //box-shadow: var(--ha-card-box-shadow) !important;
            //border-radius: 10px 10px 10px 10px !important;
            transition: all 0s;
            --icon-size: 60px;
            --shape-color: rgba(var(--rgb-{{ 'white' if is_state('input_select.seleziona_stanza', 'Home') else 'none' }}), 0.4) !important;
      primary: Cucina
      secondary: ''
      icon: mdi:fridge
      icon_color: white
      layout: vertical
      entity: input_select.seleziona_stanza
      tap_action:
        service: input_select.select_option
          entity_id: input_select.seleziona_stanza
          option: Cucina
      card_mod:
        style: |
          ha-card {
            width: 210px;
            height: 20px;
            --spacing: 0px;
            transition: all 0s;
            --icon-size: 60px;
            --shape-color: rgba(var(--rgb-{{ 'white' if is_state('input_select.seleziona_stanza', 'Cucina') else 'none' }}), 0.4) !important;
      primary: Salotto
      secondary: ''
      icon: mdi:sofa
      icon_color: white
      layout: vertical
      tap_action:
          option: Salotto
      card_mod:
        style: |
          ha-card {
            width: 210px;
            height: 20px;
            --spacing: 0px;
            transition: all 0s;
            --icon-size: 60px;
            --shape-color: rgba(var(--rgb-{{ 'white' if is_state('input_select.seleziona_stanza', 'Salotto') else 'none' }}), 0.4) !important;
  card_mod:
    style: |
      ha-card {
        position: fixed !important;
        top: auto;
        bottom: 75px;
        left: 15px;
        right: 0;
        animation: slide-up 0.5s;
        z-index: 5 !important;
        width: 210px;
        height: 400px !important;
        padding: 0px;
        overflow-y: hidden;
        border-radius: 35px 35px 35px 35px !important;
      @keyframes slide-up {
        from {
          transform: translateY(100%);
        to {
          transform: translateY(0);
persist_state: false
Thanks a lot.
the https://fonts.googleapis.com/icon?family=Material+Icons as a Stylesheet Resource seems not to work! what am I doing wrong?
I cant get the Tile-icon to change/animate, this is what I have, do anyone see any obvious errors?
features:
  - type: target-temperature
  - type: climate-hvac-modes
    hvac_modes:
      - 'off'
      - heat
      - dry
      - cool
      - fan_only
      - heat_cool
type: tile
entity: climate.varmepumpe
card_mod:
  style:
    ha-tile-icon$: |
      ha-svg-icon {
        --card-mod-icon: mdi:fire;
        animation: heat 2s infinite;
      @keyframes heat {
        0%, 100% { --icon-color: rgba(var(--rgb-red), 1); }
        10%, 90% { --icon-color: rgba(var(--rgb-red), 0.8); }
        20%, 80% { --icon-color: rgba(var(--rgb-red), 0.6); }
        30%, 70% { --icon-color: rgba(var(--rgb-red), 0.4); }
        40%, 60% { --icon-color: rgba(var(--rgb-red), 0.2); }
        50% { --icon-color: rgba(var(--rgb-red), 0); }
Honestly dont know!
I went settings. Dashboard. Three dots top right menu. Resources. Add resources. Pasted in the URL. Select Style Sheet. Create.
Now I have to ask something again. sorry sorry sorry
Have now also already found in the great documentation some, which is important for styling.
How can I now still replace my mini climate card by Mush.
I’m just missing small chips above the slider, where I can show info,
so like mini-climate-card
entity: climate.bad
secondary_info: state
show_temperature_control: true
card_mod:
  style:
    mushroom-climate-temperature-control$:
      mushroom-input-number$: |
        #container .button:nth-child(1) {
          --card-mod-icon-color: rgb(255, 191, 0);
        #container .button:nth-child(3) {
      ha-state-icon {
        --icon-symbol-size: 34px;
