I am not 100% sure.
but until someone corrects me with the right answer I would look at these two in your themes yaml file.
# Home Assistant override
ha-card-box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.16)
ha-card-border-width: 1px
I am not 100% sure.
This doesnāt affect Mushroom cards unfortunately.
Edit: Hereās the fix, if anyone is interested. ![]()
card-mod-card: |
mushroom-shape-icon {
--shape-color: none !important;
--shape-color-disabled: none;
sorry I completely missed the little black line. I thought you were pointing to the card border.
This was exactly what i was looking for. Thank you!
no problem if you wanted them closer together you can add some margin. like this.
type: custom:stack-in-card
cards:
- type: vertical-stack
cards:
- type: custom:mushroom-entity-card
card_mod:
style: |
ha-card {
border: 0px;
box-shadow: none;
entity: light.diner
icon: mdi:sprinkler
- type: custom:mushroom-number-card
card_mod:
style: |
ha-card {
border: 0px;
box-shadow: none;
margin-top: -20px
entity: input_number.daily_energy_cost
display_mode: buttons
primary_info: none
secondary_info: none
icon_type: none
Hi there!
Guys, in chipās ha-card:after is possible to set color of border line?
- type: template
entity: sensor.electricity_input_wh_to_kwh_bimonthly
content: "{{ states('sensor.electricity_input_wh_to_kwh_bimonthly') }} kWh"
icon: mdi:calendar-weekend
icon_color: "#44739e"
tap_action:
action: more-info
double_tap_action:
action: none
hold_action:
action: more-info
card_mod:
style: |
ha-card:after {
content: "{{ states('sensor.money_total_bimonthly') }} Š³ŃŠ½";
position: absolute;
display: flex;
justify-content: center;
align-items: center;
background: rgb(var(--rgb-white));
color: black;
font-weight: bolder;
border-radius: 15px 15px 15px 15px;
top: -5px;
right: -5px;
width: 50px;
height: 11px;
font-size: 10px;
Yes add border: 2px solid red;
type: custom:mushroom-chips-card
chips:
- type: template
tap_action:
action: more-info
double_tap_action:
action: none
hold_action:
action: more-info
card_mod:
style: |
ha-card:after {
position: absolute;
display: flex;
color: black;
top: -5px;
right: -5px;
width: 50px;
height: 11px;
font-size: 10px;
I want to implement this across my entire dashboard using my theme, instead of having to add it to each card individually.
Can someone help me figure out how to solve this?
card_mod:
style:
mushroom-shape-icon$: |
.shape {
background: none !important;
You can put it in your configuration.yaml file. Here is an extract from mine, where I wanted the same effect replicated across all cardsā¦
frontend:
themes:
Mushroom Custom:
card-mod-theme: "Mushroom Custom"
card-mod-card: |
ha-card:active {
background: rgba(var(--rgb-disabled), 0.1);
transition: 0s;
Iām unable to insert that. Iām using this theme, can it be inserted into that file?
####################### LIGHT MODE ####################
MiniHass_Light:
contrast-0: ā#ffffffā
contrast-10: ā#F2F2F2ā
contrast-20: ā#e5e5e5ā
contrast-33: ā#888888ā
contrast-66: ā#444444ā
contrast-100: ā#000000ā
color-green: ā#39bb4fā
color-yellow: rgb(253 204 18)
color-blue: rgba(159,204,250,1)
ā¦
according to @sooty post it has to be in the configuration.yaml file. should be at the top of that file
you will more than likely already have this.
#Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
Is there a option to show the time for last-changed in a mushroom card like in this sample:
I need this to see, how long a state is actually on
This my code, it works but in english. Can I change it?
{{ relative_time(states.switch.Pool_0.last_updated) }}
I need hours and minutes whe the device is on for more than 60minutes not only hours.
Hi @Stevengerrard08, I tend to bumble my way through this stuff largely by making lots of mistakes. However, to get this working I referenced these two documents around Card-Mod Themes which you may also find helpfulā¦
You can have a look for the hacs integration easy time. There you have many options. Also to translate
Here is one example: {{ easy_relative_time(states.sensor.my_energy_meter.last_updated, language= 'de') }}
GrüĆe
I really like the style of these cards and itās nice to see other projects adopting the same principles (eg. Timer Card), gives the whole experience a uniform feel.
What i was missing was a card with the information a gauge card can give, an indication of the position of a value in a range and itās severity. The original gauge card feels a bit bulky, especially compared with the mushroom guidelines. The same info can be given with the Bar Card, but its style also doesnāt match with what i want.
I tried to tweak the styling with css, I shared the code for those interested in this post.
Is it possible to animate a chip card icon? If so, how? I could not find anything helpful in this post or this other one, this is how my card config looks like:
chips:
- type: entity
entity: person.person_1
hold_action:
action: none
double_tap_action:
action: none
use_entity_picture: true
content_info: name
icon_color: primary
- type: conditional
conditions:
- condition: state
entity: group.all_lights
state: "on"
chip:
type: template
icon: mdi:lightbulb
icon_color: amber
content: >-
{{ expand(states.group.all_lights) | selectattr( 'state', 'eq', 'on') |
list | count }}
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
- type: conditional
conditions:
- condition: state
entity: fan.all_fans
state: "on"
chip:
type: template
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:fan
icon_color: blue
content: >-
{{ expand(states.fan.all_fans) | selectattr( 'state', 'eq', 'on') | list | count }}
card_mod:
style: |
ha-state-icon {
{% if is_state(config.entity, 'on') %}
animation: rotate .5s infinite linear}
@keyframes rotate {
0% {
transform: rotate(0deg);
100% {
transform: rotate(-359deg);
{% endif %}
- type: conditional
conditions:
- condition: state
entity: group.door_windows_sensors
state: "on"
chip:
type: template
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:door-sliding-open
icon_color: red
content: >-
{{ expand(states.group.door_windows_sensors) | selectattr( 'state', 'eq', 'on') | list | count }}
- type: conditional
conditions:
- condition: numeric_state
entity: sensor.batteries_status
below: 20
chip:
type: template
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:battery-20
icon_color: red
content: >-
{{ expand(states.sensor.batteries_status) | selectattr( 'state', 'eq', '20.0') | list | count }}
This should work for youā¦
chips:
- type: entity
hold_action:
action: none
double_tap_action:
action: none
content_info: name
icon_color: primary
- type: conditional
conditions:
- condition: state
state: 'on'
chip:
type: template
icon: mdi:lightbulb
icon_color: amber
content: >-
list | count }}
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
- type: conditional
conditions:
- condition: state
state: 'on'
chip:
type: template
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
icon: mdi:fan
icon_color: blue
content: >-
| count }}
- type: conditional
conditions:
- condition: state
state: 'on'
chip:
type: template
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
icon_color: red
content: >-
- type: conditional
conditions:
below: 20
chip:
type: template
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
icon_color: red
content: >-
card_mod:
style:
mushroom-conditional-chip:nth-child(3):
mushroom-template-chip$: |
ha-state-icon {
{% if is_state('fan.all_fans', 'on') %}
animation: rotate .5s infinite linear; }
@keyframes rotate {
0% { transform: rotate(0deg); }
100% {transform: rotate(-359deg); }
{% endif %}
it is in the guide:
I tried making a template for the action confirmation, but that does not seem to work on the mushroom-template-card.
Is there any way around this, or any other good way to have a nice looking confirmation for opening the garage door for example?
tap_action:
action: call-service
service: script.gardiner_oppna_stang
confirmation:
text: 'Vill du {{''ƶppna'' if is_state(entity, ''closed'') else ''stƤnga''}} gardinerna?'
Hereās the complete code:
type: horizontal-stack
cards:
layout: vertical
icon_color: light-blue
tap_action:
confirmation:
hold_action:
action: none
double_tap_action:
action: none
icon: 'mdi:roller-shade{{''-closed'' if is_state(entity, ''closed'')}} '
entity: cover.gardiner
card_mod:
style: |
ha-card {
background: var(ācard-background-color);
width: 70px;
border-radius: 40px;
margin-left: auto;
margin-right: auto;
margin-bottom: 2px;
border-width: 2px;
{% if states('cover.gardiner') == 'open' %}
border-color: none;
{% else %}
border-color: rgba(62, 160, 255, 0.5);
{% endif %}
layout: vertical
icon_color: red
tap_action:
service: script.garageport_oppna_stang
confirmation:
text: Vill du ƶppna/stƤnga garageport?
hold_action:
action: none
double_tap_action:
action: none
icon: 'mdi:garage{{''-open'' if is_state(entity, ''open'')}} '
entity: cover.garageport
card_mod:
style: |
ha-card {
width: 70px;
margin-left: auto;
margin-right: auto;
margin-bottom: 2px;
border-width: 2px;
{% if states('cover.garageport') == 'closed' %}
border-color: none;
{% else %}
border-color: rgba(255, 62, 62, 0.5);
{% endif %}
entity: lawn_mower.robotgrasklippare
layout: vertical
icon_color: orange
tap_action:
service: script.robotgrasklippare_starta_pausa
confirmation:
text: Vill du starta/pausa robotgrƤsklippare?
hold_action:
service: script.robotgrasklippare_docka
confirmation:
text: Vill du docka robotgrƤsklippare?
double_tap_action:
action: none
icon: 'mdi:mower{{''-on'' if is_state(entity, ''error'' )}} '
card_mod:
style: |
ha-card {
width: 70px;
margin-left: auto;
margin-right: auto;
margin-bottom: 2px;
border-width: 2px;
{% if states('lawn_mower.robotgrasklippare') == 'docked' %}
border-color: none;
{% else %}
border-color: rgba(255, 160, 62, 0.5);
{% endif %}
entity: vacuum.robotdammsugare
layout: vertical
icon_color: green
tap_action:
service: script.robotdammsugare_starta_pausa
confirmation:
text: Vill du starta/pausa robotdammsugare?
hold_action:
service: script.robotdammsugare_docka
confirmation:
text: Vill du docka robotdammsugare?
double_tap_action:
action: none
icon: 'mdi:robot-vacuum-variant{{''-alert'' if is_state(entity, ''error'')}} '
badge_color: ''
card_mod:
mushroom-state-info$: |
.container {
--card-secondary-font-size: 5px!important;
style: |
ha-card {
width: 70px;
margin-left: auto;
margin-right: auto;
margin-bottom: 2px;
border-width: 2px;
{% if states('vacuum.robotdammsugare') == 'docked' %}
border-color: none;
{% else %}
border-color: rgba(202, 246, 180, 0.5);
{% endif %}
As I know, confirmation text could not be a template, text only.
I would also like template support.
