Netatmo in HA 0.105
I have made available my HA instance in the port 443 and I still have the issue. Maybe @cgtobi can help?
The integration connects fine with netatmo, and gets registered (through config.yml)
The webhooks are not banned
I see in the logs:
2020-06-28 14:26:37 INFO (MainThread) [homeassistant.components.netatmo] Register Netatmo webhook: https://home.xxxxx.duckdns.org/api/webhook/[a id]
If I access trough browser, It says 405: Method Not Allowed (dunno if I need more params and call from any API client)
I don’t have netatmo error logs. This are the other logs with “netatmo” string. logger set as “info”. Should I look for another thing?
	Line 175: 2020-06-28 14:26:10 INFO (MainThread) [homeassistant.setup] Setting up netatmo
	Line 185: 2020-06-28 14:26:11 INFO (MainThread) [homeassistant.setup] Setup of domain netatmo took 0.1 seconds.
	Line 438: 2020-06-28 14:26:12 INFO (MainThread) [homeassistant.components.camera] Setting up camera.netatmo
	Line 439: 2020-06-28 14:26:12 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.netatmo
	Line 447: 2020-06-28 14:26:12 INFO (MainThread) [homeassistant.components.climate] Setting up climate.netatmo
I don’t see more things than
Errors in response: {'status': 'ok', 'time_server': 1593354373, 'body': {'home': {'id': 'a id'}, 'errors': [{'code': 6, 'id': 'a mac'}]}}
No entities in the component.
I am out of ideas now, what can I do or look for?
My setup is Home Assistant (not hassio), in a python env, port 443 forwarded to 8123 in the router. No reverse proxy, and this is my http is
http:
  ssl_certificate: HIDDEN AND WORKING
  ssl_key: HIDDEN AND WORKING
  base_url: https://home.xxxx.duckdns.org
  server_port: 8123
Ok, solved. As usual, was the user fault.
Looks like the relay failed at the moment of the update (Murphy law) and it wasn’t even accesible by the netatmo app. An old unplug and plug solved the issue :sweat_smile:
Sorry for the noise
Glad to hear it’s working again.
Although it’s not required and doesn’t add functionality right now I suggest to get webhook working. It’ll improve responsiveness in an upcoming release.
Check the pre-release custom component for more info: Testers wanted - Netatmo integration
Sure, now I have it working, but if possible I recommend to make it available in other ports, as tons of users have their instance only available in the default 8123 port
There is nothing I can do about the port since that is dictated by Netatmo.
Sorry for the silly question, I’m new to HA, do you add this in the configuration file just after the Netatmo initial config ?
netatmo:
client_id: YOUR_CLIENT_ID
client_secret: YOUR_CLIENT_SECRET
Yes, this is exactly all you need:
# Example configuration.yaml entry
netatmo:
See the integration documentation.
Thank you for the reply, sorry my post wasn’t very clear, I have this and it’s working fine, I was wondering how do you get the light and sensor too? with the current settings I only have the live stream of two cameras but nothing else, I was wondering if I had to also add in the configuration file the code that @gerard33 posted on mar 28
To get the light working you need webhook. Please check your logs to see if your webhook is working.
If you see a line in the logs like the following, you’re good:
2020-11-01 01:07:49 INFO (MainThread) [homeassistant.components.netatmo.data_handler] Netatmo webhook successfully registered
Thank you I’ll check this in a min but it’s probably not gonna work for me (for now) as I have an issue with SSL(assuming it’s required)
As long as you’re using your personal dev account non-SSL should work, but I would not recommend it.
Logger: homeassistant.components.netatmo
Source: components/netatmo/init.py:159
Integration: Netatmo (documentation, issues)
First occurred: 20:30:40 (3 occurrences)
Last logged: 20:33:58
Error during webhook registration - 400 - Bad request - Allowed ports for webhooks are 443 and 80. (21) when accessing ‘https://api.netatmo.com/api/addwebhook
Although that was an hour ago, not sure that was before I have the live streaming working
From some days netatmo add in for climate - i also own weather station - it is not working in HA dockerized on rpi3. No update HA. It suddenly show in log an error related to webhook that in past i never used. The netatmo climate worked nice for many years and now suddenly i found this error. The entities of course are unavailable. I tried to patch refreshing client and secret in configuration.yaml. Any suggestion?
First, please don’t hijack old threads with different topics.
Second, please give more information about what version you’re currently running on.
First excuse me for coming in this thread.
Ha frontend ver. 20210407.3-latest
Ver. core-2021.4.3
I uninstalled today the netatmo plugin and after reinstall i found all entities unavailable. More than this installing plugin it recognizes only the weather station but output entities all unavailable.
In configuration.yaml:
netatmo:
  client_id: 12312312312312345
  client_secret: 123123123123123123311
Error in log:
2021-05-12 16:38:08 ERROR (MainThread) [homeassistant.components.netatmo] Error during webhook registration - 400 - Bad request - Allowed ports for webhooks are 80, 88, 443 and 9443. (21) when accessing 'https://api.netatmo.com/api/addwebhook'
More than this I also have in configuration.yaml
homekit:
For years the plugin worked flawlessy . I don’t understand. Thanks for your time
There have been changes by Netatmo. Those are addressed in 2021.5.2+. Please update. And please check the forums/github/discord next time. There are already plenty posts regarding this issue.
Thanks for info. I’ll follow on discord next time.
Do you mean a simple HA update is enough?
Hello. I have access through nabu casa and I have the same message, what should I change ??
