ZHA and Z2M are two different ways of running Zigbee. If you just are changing the coordinator, the easiest is to edit the configuration.yaml file under the zigbee2mqtt folder to point to the new coordinator. You dont need to change anything else.
Ok, thanks for the clarification, but I have reinstalled my pi and everything on it (went to 64-bit) .
I now have a clean deployment of a homeassistant container and I added the ZHA integration to point to the SLZB-06. It found the device successfully, but I wonder if I need anything else?
I guess I don’t need the zigbee2mqtt app (container) now ?
and do I need the mqtt (mosquitto) app/container?
Thanks, that’s clear.
I am now adding some zigbee devices. so far I like Z2M. I don’t think I will miss enhanced features that mqtt and zigbee2mqtt offer.
ZHA Yeah both are good options. Sometimes you will find that one offers better support than the other on certain items, but all in all you should be good with ZHA too.
