I am a newbie I’m getting error messages that I can’t fix on my own. Can you help me please?
My HA has been running for a few days and I’m getting to know it. Now error messages appear that I cannot eliminate on my own.
What do these errors mean and how can I fix them?
These are the error messages:
Unfortunately, I can’t provide a better error description yet, because I don’t know what you need to know. My HA has been running for a few days and I’m getting to know it. Now error messages appear that I cannot eliminate on my own.
Error 1:
Logger: homeassistant.setup
Source: setup.py:162
First occurred: 17. April 2022, 23:46:23 (1 occurrences)
Last logged: 17. April 2022, 23:46:23
Setup failed for resources: Integration not found.
Error 2:
Logger: homeassistant.components.hassio
Source: components/hassio/init.py:958
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 17. April 2022, 23:46:21 (53 occurrences)
Last logged: 05:53:49
Could not fetch stats for a0d7b954_sonweb: Container addon_a0d7b954_sonweb is not running
Error 3:
Source: components/hassio/init.py:663
First occurred: 06:01:21 (2 occurrences)
Last logged: 06:03:26
The system cannot restart because the configuration is not valid: Integration error: resources - Integration ‘resources’ not found.
Error 4:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/init.py:674
Integration: Home Assistant WebSocket API (documentation, issues)
[547731729184] The system cannot restart because the configuration is not valid: Integration error: resources - Integration ‘resources’ not found.
[547949049840] The system cannot restart because the configuration is not valid: Integration error: resources - Integration ‘resources’ not found.
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 193, in handle_call_service
await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 1634, in async_call
task.result()
File “/usr/src/homeassistant/homeassistant/core.py”, line 1671, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File “/usr/src/homeassistant/homeassistant/components/hassio/init.py”, line 674, in async_handle_core_service
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Integration error: resources - Integration ‘resources’ not found.
My Homeassistant runs on a Raspberry Pi 4b with the Home Assistant OS:
System Health
version: core-2022.4.5
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.9
os_name: Linux
os_version: 5.10.103-v8
arch: aarch64
timezone: Europe/Berlin
GitHub API: ok
GitHub Content: ok
GitHub Web: ok
GitHub API Calls Remaining: 4956
Installed Version: 1.24.5
Stage: running
Available Repositories: 1099
Downloaded Repositories: 2
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 7.6
update_channel: stable
supervisor_version: supervisor-2022.04.0
docker_version: 20.10.9
disk_total: 118.5 GB
disk_used: 7.6 GB
healthy: true
supported: true
board: rpi4-64
supervisor_api: ok
version_api: ok
installed_addons: Studio Code Server (4.2.0), Terminal & SSH (9.3.0), TasmoAdmin (0.17.0), ESPHome (2022.3.2), File editor (5.3.3), Mosquitto broker (6.0.1)
dashboards: 1
resources: 1
mode: storage
