Overkiz API and Somfy API
Thanks @imick I will give this a go.
And thank you @tetienne for your efforts, it must be very frustrating dealing with Somfy on this, I need a new set of blinds for another area of the house and let’s say Somfy is not top of the list now whereas it would have been before.
@imick I have installed https://github.com/iMicknl/ha-tahoma and although it’s early days everything is working OK. In fact it’s already more stable than the Somfy API has been for the last 2 weeks! Just for info, I’ve used my Somfy credentials and using a Connexoon RTS unit with 2 roller blinds.
Thank you to you and the devs for working on this.
Are you in Australia by any chance?
I’d love to get this working.
In the UK. I understand you may have some Somfy connection issues in Australia judging by other comments?
It looks like Australia requires a login via accounts.somfy.com, where we can use the token for tahomalink.com / other server. However, this requires quite some efforts and none of us is able to finish this on short term :frowning:
Could you give https://github.com/iMicknl/ha-tahoma/archive/feature/support_connexoon_rts.zip a try? You need to unzip the package first and put the custom_components/tahoma folder in your custom_components folder.
I just tested it with the account of someone from Australia and it worked like a charm!
OMG, it works!!!
You legend!
Thanks you so much.
Is this in HACS?
not yet, but if it’s confirmed to be working, it will be released soon.
We just released v2.4.0 of the Somfy TaHoma integration to HACS. (Release v2.4.0 · iMicknl/ha-tahoma · GitHub)
Bonjour Tetienne,
Concernant la diffusion de la video des cameras de surveillance, est ce que cela est maintenant disponible au sein de HA ?
Egalement, j’ai des gestionnaires de chauffage dans mon interface Tahoma pour des gainables de PAC HITACHI, et egalement des prises connectees de la marque SOMFY. Ces 2 types de modules ne sont actuellement pas exposes par la Somfy Open API via la methode device list. Savez vous s’ils vont etre ajoutes dans la Somfy Open Api et seront ils integres dans HA ?
Cdt,
Christophe
At the moment, support is quite limited in somfy’s official API. But you can have a look at this one for larger support: Tahoma Integration Refactored
Cheers
V.
Thanks, I will have a look at this Tahoma component.
Cheers,
Christophe
Many thanks, I have finally succeeded in installing the Tahoma custom component (not so straightforward for a new user of HA :slight_smile: ).
I have almost all my Somfy devices, but the climates, a remote and the tahoma button are missing, did I miss something ? Should they be manually declared ?:
Best would be to discuss this in the Somfy TaHoma integration topic, to keep the discussion here about the Somfy integration via the official API. The readme offers guidance on how to approach devices that are currently not working yet.
Hey, this integration no longer works for me after updating to the latest version 1.10.1 (connexoon rts Australia). I get an Auth error :frowning:
I guess you are using the Somfy TaHoma integration and not the Somfy integration from core?
If true, please continue the discussion in the right topic Tahoma Integration Refactored - Share your Projects! / Custom Components - Home Assistant Community (home-assistant.io). I did create an issue on GitHub, feel free to add your context there as well.
Sorry, it’s working, I had a senior moment and wasn’t picking the right hub when logging on. Thanks for your great work :+1:
Don’t forget to change your interval to a high interval (like a month) via the options. This is something we should do by default in a new version.
I tried on my tahoma box with the homeKit pin code from tahoma custom components (as I don’t have this code on the box).
I never paired this tahoma with anything before this attempt, but I have the same error (M5: not an error or a proof).
I tried to reset it with the RST hole on the box, but I get the same result. I don’t have an iphone (nor an apple account), so I can’t try the instruction given at the end of this thread.
Did you succeed to pair your box ?
hi, though I did a search, I didn’t find the exact issue I am facing: the official Somfy integration sees all my IO roller shutters, but doesn’t see my IO garage door.
Is this a bug, or a ‘feature’ :wink:
The CC https://github.com/iMicknl/ha-tahoma sees the garage door fine, as I have installed it on my experimental system. Production system uses core only for now, so please let me know if I can find a way to see the garage door there too?
thanks
