Regular Button Color via Theme File
Using the dark theme and trying to just make modifications to the regular old button in Lovelace. Anyone know how to do that? I want to change the text color and background color.
dark_theme:
  # Main colors
  primary-color: '#383C45'                                                        # Header
  accent-color: '#5eb3e4'                                                         # Accent color
  dark-primary-color: 'var(--accent-color)'                                       # Hyperlinks
  light-primary-color: 'var(--accent-color)'                                      # Horizontal line in about
      # Text colors
  primary-text-color: '#b8b8b8'                                                   # Primary text colour, here is referencing dark-primary-color was #fff
  text-primary-color: 'var(--primary-text-color)'                                 # Primary text colour
  secondary-text-color: '#5294E2'                                                 # For secondary titles in more info boxes etc.
  disabled-text-color: '#7F848E'                                                  # Disabled text colour
  label-badge-border-color: 'green'                                               # Label badge border, just a reference value
      # Background colors
  primary-background-color: '#383C45'                                             # Settings background
  secondary-background-color: '#383C45'                                           # Main card UI background
  divider-color: 'rgba(0, 0, 0, .12)'                                             # Divider
      # Table rows
  table-row-background-color: '#353840'                                           # Table row
  table-row-alternative-background-color: '#3E424B'                               # Table row alternative
      # Nav Menu
  paper-listbox-color: 'var(--primary-color)'                                     # Navigation menu selection hoover
  paper-listbox-background-color: '#2E333A'                                       # Navigation menu background
  paper-grey-50: 'var(--primary-text-color)'
  paper-grey-200: '#414A59'                                                       # Navigation menu selection
      # Paper card
  paper-card-header-color: 'var(--accent-color)'                                  # Card header text colour
  paper-card-background-color: '#434954'                                          # Card background colour
  paper-dialog-background-color: '#434954'                                        # Card dialog background colour
  paper-item-icon-color: 'var(--primary-text-color)'                              # Icon color
  paper-item-icon-active-color: '#F9C536'                                         # Icon color active
  paper-item-icon_-_color: 'green'
  paper-item-selected_-_background-color: '#434954'                               # Popup item select
  paper-tabs-selection-bar-color: 'green'
      # Labels
  label-badge-red: 'var(--accent-color)'                                          # References the brand colour label badge border
  label-badge-text-color: 'var(--primary-text-color)'                             # Now same as label badge border but that's a matter of taste
  label-badge-background-color: '#2E333A'                                         # Same, but can also be set to transparent here
  # Switches
  paper-toggle-button-checked-button-color: 'var(--accent-color)'
  paper-toggle-button-checked-button-background-color: 'red'
  paper-toggle-button-checked-bar-color: 'var(--accent-color)'
  paper-toggle-button-checked-ink-color: 'var(--accent-color)'
  paper-toggle-button-unchecked-button-color: 'var(--disabled-text-color)'
  paper-toggle-button-unchecked-button-background-color: 'red'
  paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)'
  paper-toggle-button-unchecked-ink-color: 'var(--disabled-text-color)'
      # Sliders
  paper-slider-knob-color: 'var(--accent-color)'
  paper-slider-knob-start-color: 'var(--accent-color)'
  paper-slider-pin-color: 'var(--accent-color)'
  paper-slider-active-color: 'var(--accent-color)'
  paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
  paper-slider-secondary-color: 'var(--secondary-background-color)'
  paper-slider-disabled-active-color: 'var(--disabled-text-color)'
  paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
      # Google colors
  google-red-500: '#E45E65'
  google-green-500: '#39E949'
  paper-button-ink-color: "#5294E2"
  paper-button-color: "#5294E2"
This is very useful for trying to work out what colours are what: Theme Color Chart - My UGLY Theme
Unfortunately it does not show those buttons and I think the button colour is the same as the card background colour (paper-card-background-color).
Try applying the ugly theme and see if you can work out which text the buttons use by referencing the yaml file.
Very useful theme thanks @tom_l !
I guess what i am looking for is what is the less code for the button
Like i always see the toggle buttons in there
What would be the code for just a regular old button?
Iā€™ve tried with no luck
Yeah thatā€™s for what we commonly call toggle switches:
I donā€™t know. You could try asking the frontend developers discord forum if you dont get an answer here.
Yea i knew that is what the toggle color is and where it effects it.
Just crazy to me, i went through a lot of themes and no one changes the regular button color or background color.
If you see the original (blog?) post about themes itā€™s not listed so I guess it is either not exposed for theming or it is but is undocumented and no one has worked out what the object is called.
hey @tom_l mind sharing the original blog post so i can ask the question?
Seems I might be miss remembering:
Sent @audrey a message
Iā€™m assuming that you are using the alarm panel card in lovelace?
Are you sure the card doesnā€™t just hard code the buttons and text to match the background/text theme colors?
so it might not be a theme problem, per se, but a color coding in the card of which theme elements to use for the colors.
Nope happens to execute button for script domain. Input select dropdown, door locks
I am trying to create new themes and I also face similar problems. A small tip to find what is applying a color is to use browser inspection. I use it in chrome quite often. It seems however, that the top bar is linked to a lot of the text:
Iā€™m no expert at this at all so I might be completely wrong, but it looks like the text should get itā€™s own ā€œvariableā€ to set a color to. Maybe this can be a feature request so more advanced themes can be made?
I guess this could be a feature request?
Has anyone figured this out yet? I changed the header to dark and yes, itā€™s tied to a lot of text (status of my locks, the logbook, ect.). I would have thought that the header color would be itā€™s own element.
I have not figured it out. Seems pretty trivial for a less based web appā€¦
@undertoe @bigmac You could try compact custom header. That will let you style the header separately so you can pick a more suitable color for the buttons.
I guess thatā€™s what happens when you donā€™t pay attentionā€¦ very simple (and I already had compact header in use). A simple addition of background: ā€˜#1F1F28ā€™ is all it took under main_configā€¦
Thanks @apop!
