Release Notes
Hass.IO 0.24
  • Security API with password and TOTP support
  • Local repository build now add-on local if no image is set
  • Fix HomeAssistant watchdog
Hass.IO 0.25
  • Add build to addons api
  • Better add-on data layer handling
  • Fix wrong version in installed addons
  • Fix start not running add-on after update
Hass.IO 0.26
  • Add panel for homeassistant 0.45
  • Allow local build for all addon repository types
  • Fix output of invalid options for homeassistant 0.45
Hass.IO 0.27
  • Change docker meta data from ENV to LABEL
  • ENV VERSION is now deprecated
  • Allow to use docker cache on our build system
Hass.IO 0.28
  • Add docker device support with devices addon config option
  • Maps are now default read only. For rw access use map: ["config:rw"]
Important
  • Please update all core add-ons to latest after update
  • If you core add-on is older than 1 version behind, please copy past options and reinstall this core add-on to avoid problem with last change on 0.26
Hass.IO 0.29
  • Allow to mount host /mnt for external device into add-ons with mnt map options
  • Add new map share for add-ons and homeassistant /share
  • Add new option environment to add-on config to manipulate env of add-on
Hass.IO 0.30
  • Remove mnt from map options. This can allow to brake our resinos systems from a add-in.
How to map external storage:
https://home-assistant.io/hassio/external_storage/
Hass.IO 0.31
  • Fix new panel for homeassistant 0.45
  • Add new startup type initialize
Hass.IO Image 0.8
  • Cleanup yocto layer
  • HostControll support change of hostname
  • ResinOS pump to 2.0.3
Warning:
After you start the OTA update, don’t poweroff until system is reboot! While update ist running, alls services are down.
HomeAssistant Docker 0.45
  • Hass.IO stream UI now direct to HomeAssistant for fast deployment
  • Add support for SQL Database connection
  • Add OpenAlpr and OpenCV support
We work an a new Cache System to fast Update HomeAssistant. At the moment it can take 5-15min for the Update. After that we shoudl be able to use the local cache for faster updates.
Hass.IO 0.32
  • Allow add-on to run on host netzwork host_network: true
  • Add API support for change hostname on UI
  • Add timezone support for homeassitant/addons with supervisor API.
The new core add-ons and homeassistant > 0.45.0 should support the new timezone API. Until UI support for timezone selection is done, you can use:
curl -d '{"timezone": "Europe/Zurich"}' http://hassio.local:8123/api/hassio/supervisor/options
After update you can run into a cache problem. Try CTR-F5 to reload the page cache and all work fine.
HomeAssistant Docker 0.45.1
  • Fix panel load error if homeassistant http password is set
  • Add support for new timezone support with hass.io 0.32
For update:
  • Disable password and update it on UI
  • Use curl and call the API manual with: curl -H "x-ha-access: YOUR_PASSWORD" -d '{"version": "0.45.1"}' http://hassio.local:8123/api/hassio/homeassistant/update
Hass.IO 0.33
  • Autodetect timezone if not set
  • Update add-on config on restart
Hass.IO 0.34
  • Refactory hole docker interface code
  • Add tmpfs for addons (@bestlibre)
Hass.IO 0.35
  • Add options for homeassistant to add special device
HomeAssistant 0.46
  • Add packages: certificate, bluetooth, libsodium
Look like a UI bug with long polling states. If you see a 502 error on update process, that is only on UI. Wait the update is in progress too (See the supervisor log, It is no Hass.IO error).
TIP:
Try this before you start the update: https://home-assistant.io/addons/check_config/
Hass.IO 0.36
  • Allow extend privilege for addons (need for bluetooth)
  • Make stronger validate of devices property
Hass.IO 0.37
  • Use new base image
  • Cleanup container before remove image on remove
  • Allow disable schema for addons
Hass.IO run now on python 3.6
HomeAssistant 0.47
  • Run with new base image on python 3.6 like the official docker image
