In my experiance the event notification are very fast and rock solid, but since I wrote the code and it is specifically tested on my enviroment and camera models my opinion may be biased. However I also hear from other users that it seems to work very well.
Streaming does have some lack but does work properly for me, you can reduce lack by using something like go2rtc or webrtc addons, but that is a more advanced configuration.
AI people, vehicle detection works far better than motion detection (motion does have false positives from trees blowing in the wind etc.) but people detection is almost flawless for me.
motion/AI based NVR recording is really easy to setup.
If you decide to go for the Reolink cameras, please consider buying them through this affiliate link.
The detection area configured in the Reolink app should also apply to the HomeAssistant binary sensor events.
So you would need to fine-tune the detection area size, please look in the Reolink app to see if all detected events are identicall in HomeAssistant. If HomeAssistant is seeing events that are not visible in the playback of the Reolink App, then you should tell me and I can look into it, otherwise you just need to fine-tune your settings in the Reolink app.
i would like to know please why i cant have the video records in media browser with the âofficialâ integration of Reolink in HA?
In your HACS version, i have a folder Reolink where i can found all my videos records on the NVR and can browse it and play videos.
The last firmware v3.3.0.226_23031609 for RNL410-8 seems buggyâŚwhich one do you advise to use please?
playback of old recodings trough the media browser is not yet supported by the build-in reolink integration. That is the only part still missing in the current build-in integration. There is some work beeing done on this by @xannor. The HACS version has a rather complex and dirty implementation, so it needes restructuring, cleanup, simplification and needs to adhere to the HomeAssistant rules.
I am using the v3.3.0.226_23031609 on my RLN8-410 N3MB01 withouth any issues. You will need at least this firmware version for proper push messages for the binary sensors (motion, AI people, vehicle, pet, person and doorbell press). I would strongly advise to stick to that firmware untill a newer one is released.
Do you have any issues on the latest firmware with the build-in reolink integration? (besides media browser not beeing available).
Iâve got a pair of Reolink RLC-410-5MP cameras and was surprised to see that several features appear to be supported.
Am I correct in thinking that if an entity is displayed, then that feature is supported?
Also, how do I set up âEmail on Eventâ, âFTP Uploadâ and âPush Notificationsâ?
Jim
With the Trigger ON/Off of the each surveillance modes, you can activate these modes whenever you want.
So in you case, activate these modes (main enable/disable button) before you want to be apply the schedule you have defined for these surveillance modes.
For example : on the week days, you want to get inform about event through the differents surveillance mode. Activate the main button (on/off) of these surveillance modes before and you will have your events (defined by the surveillance schedules). After that, disable the main button.
Theyâre different. In Reolink app, if I activate notifications, I receive them only if a person walk by inside the detection area (not grey). If a person walk in the grey area (drawn in Reolink app), I donât receive notifications.
In HA, instead, I always receive notifications. It seems it ignores completely the detection area⌠Can you please verify it? Thank you
I assume the difference is that the reolink camera still detects there is a person (and therefore HA sensor is true) regardless of where the object is. But reolinks software says donât notify if itâs here, and HA doesnât have that same software to do the same thing.
@jimford in principle yes, if it shows up in HomeAssistant it should be supported by the camera and be available in the reolink app/client for more detailed configuration. If this is not the case and HomeAssistant is showing stuff not supported by the camera this schould be reported as a bug on github and I will fix it.
@Luca1996O I will verify on my own cameraâs once I have some time, it is noted in my to do list.
Thanks for the reply âstarkillerOGâ.
Iâd guessed that all the displayed entities are available. (I havenât worked out how to FTP into the camera yet though!)
Jim
Will it be possible for the siren.cameraname_siren state to return on/off?
Mine currently always return âunknownâ but I am able to turn on and turn off the siren through HA using the default UI on the âmore infoâ dialog window.
Have you heard back from ReoLink about whether it will be possible to trigger a smart reply manually (from Home Assistant) ? In their smartphone app you can preview each message by tapping the small white âplayâ icon on the left and the paper plane/messenger icon on the right triggers the quick reply to play on the doorbell.
Hi @LeiChat, there is, right now even in the latest firmware no API command to trigger one of these messages youâve created. I donât know if this functionnality will be added in the future.
Regards
Thank you for confirming. Fingers crossed ReoLink expose this in the API in the future.
Does the API return the state of the siren?
I had a little nose at this ReoLink PDF and found GetBuzzerAlarmV20 and AudioAlarmPlay but they might relate to other features.
I am able to start and stop the siren on the doorbell through Home Assistant dialog but it doesnât seem to affect the entity state.
The option I was considering was a boolean Helper for the alarm state that I could toggle from the sirenâs âon eventâ entity but that doesnât always seem to capture the siren being turned on.
I donât know why your doorbell siren do not understand the API command. If the API can change the state of the siren, it can start and stop his status. Perhaps itâs need a refresh of the status
Perhaps, when I have tested, I am not leaving the siren active for long enough for the API to register the change of state. I did not want to irritate my neighbours.
In another post, i explain that there are 2 modes to trigger the siren : the manual mode -included in the official reolink integration- and the repeat mode.
This last feature isnât include in official reolink integration because itâs not based to turn on or off the siren as explain before.
Please, take a look if itâs suit to your need:
Yes I just checked with my Reolink E1 Zoom, If I set HomeAssistant side by side with the reolink desktop client all person events exactly match and the grey zone works as expected. Within the grey zone a person is not detected both in desktop app as in HomeAssistant.
Note that motion detection seems to ignore the grey zone both in the reolink desktop app as in HomeAssistant.
I could not find any diffrent behaviour between HomeAssistant and the Reolink desktop app.
The grey zones are working as expected.
Have you tried putting HomeAssistant binary sensors side by side to the Reolink desktop app?
Do you see diffrent behaviour between the two?
The preset button works properly, but the left button takes the camera all the way to the stop. Any way to make it go a short distance, or would I have to use onvif for that?
Also, I see that the camera mainstream is disabled by default in the integration. How would I enable it? Thanks.
