you do know that you are referring to a bug-report, where NO supervisor -versions is mentioned, not that i can see . the reporter only says core-version and Samba version, the very same Samba-Version which supposed to change the /config folder to /homeassistant , or was that somehow supervisor 2023.11.0 which did that ?
ok, so maybe the bug-reporter is also ⌠i dont know, as he havenât mentioned it either
But tha doesnât explain âhow it worksâ , when an add-on change the name of /config to /homeassistant , and how that can conflict with supervisor, so the /config folder is not changed to /homeassistant.
So why donât you , from start actually ( as you Know How it Works ), change your attitude, and admit that is an issue for more than 1 user, most likely a handful ⌠which must likely will âdrop outâ of betas, do to your attitude
I also can not access my HA from my windows computer after updating Samba 11. Windows sees the new homeassistant folder, but I can not open it. The terminal add on program see the config directory. The windows Samba does not. I thought that this was not a major update as I did not see breaking changes and I did not backup prior to this update. Is there a method to install the 10.0.2 version of Samba?
yes in /setting/system/backups, you should have the latest backup of samba, if you have autobackup that is
I just found it. Hopefully it will work again after the restore.
Tried following this thread and other issue posted on GitHub and I donât have a clue and what they are trying to do? This change seems to break many users stuff.
All works again and my maps all came back.
Yeah, i guess they are trying to âsort it outâ , but âsomeâ people have a strange way of âcommunicatingâ in such a âbreakingâ situation
Are the people that have the new samba working on the latest HAOS (11.1)?
please everyone, read this Revert Home Assistant configuration to `/config` (#4697) ¡ home-assistant/supervisor@16b71a2 ¡ GitHub
and hold back with confusing or downright incorrect solutions/workarounds.
the devs are aware of the confusion and reconsidered.
- Revert Home Assistant configuration to
/config
With the new add-on config feature the intention is to provide a good
location for add-on specific configurations. Currently, add-ons such
as Node RED or ESPHome use the Home Assistant config directory because
this location is accessible to the user (via Samba VSCode add-on etc.).To make it clear to add-on developer that the new intention is to use
add-on specific config, the implementation now bind mounts the add-on
configuration directory to/config
. And since some add-ons still need
access to the Home Assistant configuration, its config folder is mounted
to/homeassistant
under the new scheme.However, users do know the path
/config
, and edit things e.g. through
the SSH or VS Code add-on. Also/config
is still the
directory from inside the Core container.For SSH/VS Code add-on we could work around using a symlink, but that
only works as long as these add-ons donât have a add-on config
themselfs.This all has very high confusion potential, for not much gain. The
renaming is mainly âdeveloper friendlyâ, but not really user friendly.Letâs minimize potential confusion, and keep things where they are.
The Home Assistant config directory stays at `/config, in all cases,
everwhere.Map the new add-on configuration directory to
/addon_config
In short, people who have experienced this specific âissueâ, does seems to have supervisor .dev installed 2023.11.2
And maybe people who currently have supervisor 2023.11.0 and updated to Samba 11.0.0, will have to update Samba again, unless it will be solved with other âsymlinksâ , i hope they remove the symlink my /config ⌠having a symlink in i.e /homeassistant pointing to itself doesnât feel right ( homeassistant â /homeassistant ) as of now , after i Updated Samba to 11.0.0
I guess Samba Devâs just tried to âbe aheadâ ⌠shit happens
Look here please and wait:
Samba 12 release notes mentions that this is temporary until 11.2 supervisor is rolled out. I have 11.2 and samba 11 fails for me. 12 works with no issue.
Is supervisor 11.2 rolled out and stable? No. So stop worrying about the beta version and wait until itâs officially released.
Sorry but on my system, there is no way to know if supervisor is beta or released. My about shows 11.2. How can I tell if it is beta, dev or released if the version doesnât show it? I.e core and os does.
Are we seriously going to have this conversation again? The answer is exactly the same the last time we had this conversation on discord which sparked your FR for having beta in the supervisor name.
View beta versions here â https://github.com/home-assistant/version/blob/11c87980f0237425fd26be84955baae59a79ffaf/beta.json
view stable versions here â https://github.com/home-assistant/version/blob/11c87980f0237425fd26be84955baae59a79ffaf/stable.json
I have HAOS, samba addon. No beta channel(s). I have the issue that /config is not there anymore and changed to /homeassistant. This is a breaking change for me since I (also) backup config files that way.
I am up to date to all âlatestâ (again I run HAOS).
Do I understand correctly this is going to be changed back again to /config? Or is this there to stay and should I change scprits?
Itâs getting reverted. Donât do anything
I believe we should. Supervisor updates automatically (unless blocked by a user configuration). Why is it unreasonable for a user to be able to see on their system that they have a beta supervisor installed? What will supervisor 11.2 beta 2 be called?
And by the way I know of no other software that uses the same numbering for released vs beta, vs alpha, etc. Most developers that I have worked with always track software versions carefully.
So after upgrading to Samba 11.0.0 I have spent an hour or so changing all my windows paths for VS Code editor and other code editors as well as stored workspaces, I now find I have to change them all back after Samba 12.0.0 !!
Not impressed.
If you use pins for your network path instead of mapped network drives, you wonât have this problem ever. Iâve fully switched and never run into network mapping issues on windows anymore. The 10 â 11 â 12 caused me to update 1 pin twice and open/close vscode project twice. Nothing else.
