💡 Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time - Light Control - Device Tracker - Night Lights
@lucascoco
Looks like you need my :shower: Bathroom Humidity Exhaust Fan blueprint. It will also control the fan and keep the light on. It also has a automation link so you can use this blueprint and the other one.
The other way is to use a template sensor (REF - TS-3 in the link below for template sensors) so when your bathroom is above 60% it turns the bypass on. Probably use option 3 in the by-pass and maybe an auto off.
A better way that I would recommend is to get a door contact sensor and use :honeybee: Bee In The Hive Sensor :honeybee: template sensor. You will love it. The how to and all my examples of template sensors Click Here.
Blacky :smiley:
