Sprinkler Irrigation by Volume, Rain and Soil Moisture (Tuya GiEX Zigbee) Dashboard
Feature Overview: I will update the pictures for when there is a rainy week.
V1.0 Initial
  • Water only if below a measured Median Soil Moisture Level.
  • Set Garden Area for Water Volume Calculations.
  • Set Weekly mm of water per square meter of Garden Area.
  • Dynamically change charts based on settings.
  • Automatically Set irrigation valve Volume Required.
  • Calculate Total Rain Volume and mm over a 7 day period.
  • Calculate Water volume required minus Rain Fall Volume.
  • Water only on Set Days of the Week.
  • Divide Total Weekly Water Required over set days.
  • Calculate Water Consumed Monthly & Annual
V1.1 Update
  • New Picker for Garden Settings.
  • Volume Required is Divided over two watering session per day
  • Volume Required is further Divided into 7 sessions per week.
  • Times can now be set from the UI with a time picker.
V1.2 Update
  • New number picker for Area & Weekly Water.
  • Custom Expander Card used to hide stats and enable easier viewing of multiple beds.
  • Improvement for mobile and tablet viewing, uses Sections View (experimental).
V1.3 Update
  • Utilises Expander Card to make more room on a single dashboard.
  • New number picker for Number of Cycles and Set Cycle Interval.
  • Adjustment to Water Consumed Daily Statistics Sensor Reduced to 1 Day.
  • Rain Delay 24hrs if more than 10mm forecast next day, Will deliver residual volume after rain.
  • Updated Node Red Flow
  • Prevent Run-Off Water
    • Deliver Volume Required over multiple Cycles with Cycle Interval Delay in-between.
  • Sensor Set Valve Cycle Helper,
    • Work around for valve cycle behavior.
    • Valve: 0 = No Cycles, 1 = 2 Cycles, 2 = 2 Cycles, 3 = 3 Cycles.
    • Sensor Set Valve Cycle Helper: 1 = 0 No Cycles, 2 = 2 Cycles, 3 = 3 Cycles.
    • For the Volume Per Cycle Sensor to work, this cannot be divided by 0 giving a Div0 error.
  • Volume Per Cycle Sensor Added
    • This now sends the volume to the valve.
    • = ((((VOLUME REQUIRED) / DAYS PER WEEK)) / TIMES PER DAY)) / SET NUMBER CYCLES)
  • Water Volume Required Sensor
    • This is used to populate the Volume Per Cycle Sensor - No longer sends to valve.
    • = (WEEK TARGET VOLUME - RAIN VOLUME 7 DAYS)
V1.4 Update
  • Valve Volume Per Cycle changed for Big Number Card
  • Minor update to Daily Monthly Rain Graph (Fix X Axis)
  • Rain Delay 24hrs - Wait until Tomorrows Rain Chance Less Than 20%.
    • Will continue to account for any rain in the 24hr wait period, then deliver residual amount once below 20%
    • Use BOM Australia Sensor chance of rain, can be exchanged for a mm of rain forecast sensor.
V1.5 Update
  • New ON/OFF button for Water Valve
  • Adjusted card layout to suit Sections View
  • Mobile View located HERE
  • Large Screen View located HERE
Requirements -
Showing Default View
  • Multiple gardens on one page.
  • Statistics hidden.
  • Expander Card can be conditionally expanded or contracted by screen size. Settings in card.
Showing Expanded View
Most of the sprinkler & irrigation integrations I could find, only provided time based watering rather than volume based watering, with no moisture meter. I also could find very little information on ideal soil moisture levels and volumes required. Most likely because the technology has not been there for that style of watering.
The resource this is based on.
Tesselaar Best Way To Water Your Garden was one of the few resources I found for Australia. I use a garden weeper hose for irrigation. Over watering during winter is a problem, with the high rainfall we get in Tasmania.
Also based on Accurite Soil Moisture Guide
WHY IS IT BEST TO WATER THE SOIL AROUND THE ROOTS?
The roots are where the plants access the water and utilise it for growth and function. Watering the foliage can encourage fungal disease, especially in spring and autumn as the foliage stays wet during the cool of the evening. In hot weather, if you water the foliage in the heat of the day, and the total dissolved salts is high, it can burn the foliage.
  1. Deep, regular watering every week to ten days provides consistent moisture to enable the plant roots to grow at a healthy rate and create a strong, disease resistant plant.
  2. Watering too much too often – the roots are not proliferating because there is not enough air in the soil to thrive.
  3. Shallow, frequent watering encourages the roots to grow at the top of the soil where they are easily damaged and unable to access the stores lower in the soil profile, so less likely to survive dry conditions.
You should aim to apply around 24L per square metre every seven to ten days to keep your plants happy and healthy. Plants absorb water from the root zone which is usually 15-20cm below the soil, so aim to wet this deeply when you water.
This 24L is roughly equal to 24mm of rain. So when you hear the meteorologist tell you there has been 1-2mm of rain for the week, you still need to water, especially if the weather has been warm. The soil might look wet, but if you dig down you will see the rain has just touched the surface. However as the rain has touched the surface, it is a good idea to water, as it will help push the water down into the soil profile.
If the weather has been hot and dry for many weeks, or the soil has dried out, you may need to increase the amount and frequency you are watering in order to re-wet the soil. Re-wetting the soil ultimately uses more water than maintaining a constant watering program.
Zigbee Soil Moisture Meter
I bought 3 of these for each garden bed, to ascertain a median soil moisture. Connected with Zigbee2MQTT. Good signal from outside, I only have 1 coordinator and two zigbee repeaters in my network.
  • Zigbee Model TS0601.
  • Manufacturer TuYa.
  • Model TS0601_soil
  • Supplier AliExpress AUD $23.50
Zigbee Irrigation Valve
I bought 1 of these per garden bed. Yes they are compatible with Australian garden taps. The adapter is handy, if you need to use it at the top, the thread will be correct at the bottom. If you use it at the bottom the thread will be correct at the top.
V1.5 Sensors in configuration.yaml - You will need to set these up manually.
    sensors:
      # Back Garden Water Valve - 0 or 1 for Mini Graph Card
      back_garden_valve_on_off:
        unique_id: 686b9ef3-26fa-4057-9734-f4cd39f41749
        friendly_name: "Back Garden Water Valve ON OFF"
        value_template: >-
          {%- if is_state('switch.0xa4c13839477a051c_state', 'on') %}
          0
          {%- elif is_state('switch.0xa4c13839477a051c_state', 'off') %}
          1
          {% else %}
          1
          {%- endif -%}
      # Template for RAIN VOLUME LAST 7 DAYS - Back Garden - (= Rain 7 Days * Set Garden Area)
      rain_volume_7_days:
        unique_id: 88518e81-3826-4efa-9501-388afc1dfeaa
        friendly_name: Rain Volume Last 7 Days
        unit_of_measurement: L
        value_template: "{{(states('sensor.rain_last_7_days') | float(0)) * (states('input_number.back_garden_set_area') | float(0)) | round(1)}}"
      # Template for WEEK TARGET VOLUME - Back Garden - (= Set Rain mm/m2 * Set Garden Area)
      week_target_volume_back_garden:
        unique_id: bff13231-85e3-4e7b-8714-42ba761fedd3
        friendly_name: Back Garden - Week Target Volume
        value_template: "{{(states('input_number.back_garden_set_mm_m2') | float(0)) * (states('input_number.back_garden_set_area') | float(0)) | round(1)}}"
      # Template for DAYS PER WEEK - Back Garden - (= Count Number of Days) UI Buttons
      back_garden_days_per_week:
        unique_id: 57fbc2fd-1970-4470-9477-71c4a7d44dc7
        friendly_name: "Back Garden Days Per Week"
        unit_of_measurement: "days"
        value_template: >
          {{[ states.input_boolean.back_garden_1_sun,
              states.input_boolean.back_garden_2_mon,
              states.input_boolean.back_garden_3_tue,
              states.input_boolean.back_garden_4_wed,
              states.input_boolean.back_garden_5_thu,
              states.input_boolean.back_garden_6_fri,
              states.input_boolean.back_garden_7_sat ]
            | selectattr('state', 'eq', 'on') | list | count}}
      # Template for TIMES PER DAY - Back Garden - (= Count Number of Times Per Day) UI Input Buttons
      back_garden_times_per_day:
        unique_id: a72a4376-adba-4d9c-8307-6ece98cff2b0
        friendly_name: "Back Garden Times Per Day"
        value_template: >
          {{[ states.switch.back_garden_set_time_switch_1,
              states.switch.back_garden_set_time_switch_2 ]
      # Template for SETTING CYCLES IN VALVE - Back Garden - (1.0 = 0) Otherwise return value (work around for valve behaviour 1=2) UI Input Buttons
      back_garden_set_valve_cycles_helper:
        unique_id: 0d24edfc-f35f-4d37-80d9-da64c50e6bd9
        friendly_name: "Back Garden Set Valve Cycles Helper"
        value_template: >-
          {%- if is_state('input_number.back_garden_water_valve_set_number_cycles', '1.0') %}
          0
          {% else %}
          {{(states('input_number.back_garden_water_valve_set_number_cycles')) | round(0)}}
          {%- endif %}
      # Template for WATER VOLUME REQUIRED - Back Garden - (= (WEEK TARGET VOLUME - RAIN VOLUME 7 DAYS)
      water_volume_required_back_garden:
        unique_id: 6e67a45d-40b7-4150-adfd-3c3404b7795c
        friendly_name: Back Garden - Water Volume Required
        value_template: "{{(states('sensor.week_target_volume_back_garden') | float(0)) | round(0) - (states('sensor.rain_volume_7_days') | float(0)) | round(0)}}"
      # Template for VOLUME PER CYCLE - Back Garden - (= ((((VOLUME REQUIRED) / DAYS PER WEEK)) / TIMES PER DAY)) / SET NUMBER CYCLES)
      back_garden_water_volume_per_cycle:
        unique_id: 06073478-c0b1-4512-acea-53a518dc0178
        friendly_name: Back Garden - Water Volume Per Cycle
        value_template: "{{ [0, (((((states('sensor.week_target_volume_back_garden') | float(0)) - (states('sensor.rain_volume_7_days') | float(0))) / (states('sensor.back_garden_days_per_week') | float(0))) / (states('sensor.back_garden_times_per_day') | float(0))) / (states('input_number.back_garden_water_valve_set_number_cycles') | float(0))) | round(0)] | max }}"
      # Side Garden Water Valve - 0 or 1 for Mini Graph Card
      side_garden_valve_on_off:
        unique_id: e7f3ccc8-4e0e-46d2-84c7-fb67ee57af5d
        friendly_name: "Side Garden Water Valve ON OFF"
        value_template: >-
          {%- if is_state('switch.side_garden_water_valve_state', 'on') %}
          0
          {%- elif is_state('switch.switch.side_garden_water_valve_state', 'off') %}
          1
          {% else %}
          1
          {%- endif -%}
      # Template for RAIN VOLUME LAST 7 DAYS - Side Garden - (= Rain 7 Days * Set Garden Area)
      rain_volume_7_days_side_garden:
        unique_id: 4139880b-2739-458c-b3a6-41388be472ea
        friendly_name: Rain Volume Last 7 Days_Side_Garden
        value_template: "{{(states('sensor.rain_last_7_days') | float(0)) * (states('input_number.side_garden_set_area') | float(0)) | round(1)}}"
      # Template for WEEK TARGET VOLUME - Side Garden - (= Set Rain mm/m2 * Set Garden Area)
      week_target_volume_side_garden:
        unique_id: 2a0ee17a-a95e-4dde-aa50-500534c0c1e3
        friendly_name: Side Garden - Week Target Volume
        value_template: "{{(states('input_number.side_garden_set_mm_m2') | float(0)) * (states('input_number.side_garden_set_area') | float(0)) | round(1)}}"
      # Template for DAYS PER WEEK - Side Garden - (= Count Number of Days) UI Buttons
      side_garden_days_per_week:
        unique_id: 75750189-318e-4fd5-b760-a68a1b7fc0fc
        friendly_name: "Side Garden Days Per Week"
        value_template: >
          {{[ states.input_boolean.side_garden_1_sun,
              states.input_boolean.side_garden_2_mon,
              states.input_boolean.side_garden_3_tue,
              states.input_boolean.side_garden_4_wed,
              states.input_boolean.side_garden_5_thu,
              states.input_boolean.side_garden_6_fri,
              states.input_boolean.side_garden_7_sat ]
      # Template for TIMES PER DAY - Side Garden - (= Count Number of Times Per Day) UI Input Buttons
      side_garden_times_per_day:
        unique_id: 36b12fb0-cf90-439b-b171-c0a0cb2a07e1
        friendly_name: "Side Garden Times Per Day"
        value_template: >
          {{[ states.switch.side_garden_set_time_switch_1,
              states.switch.side_garden_set_time_switch_2 ]
      # Template for SETTING CYCLES IN VALVE - Side Garden - (1.0 = 0) Otherwise return value (work around for valve behaviour 1=2) UI Input Buttons
      side_garden_set_valve_cycles_helper:
        unique_id: a39d7332-e7e5-43f1-951d-4165b3019034
        friendly_name: "Side Garden Set Valve Cycles Helper"
        value_template: >-
          {%- if is_state('input_number.side_garden_water_valve_set_number_cycles', '1.0') %}
          0
          {% else %}
          {{(states('input_number.side_garden_water_valve_set_number_cycles')) | round(0)}}
          {%- endif %}
      # Template for WATER VOLUME REQUIRED - Side Garden - (= (WEEK TARGET VOLUME - RAIN VOLUME 7 DAYS)
      water_volume_required_side_garden:
        unique_id: 17cb8057-6150-4edc-a0ac-bea1bc2bd843
        friendly_name: Side Garden - Water Volume Required
        value_template: "{{(states('sensor.week_target_volume_side_garden') | float(0)) | round(0) - (states('sensor.rain_volume_7_days_side_garden') | float(0)) | round(0)}}"
      # Template for VOLUME PER CYCLE - Side Garden - (= ((((VOLUME REQUIRED) / DAYS PER WEEK)) / TIMES PER DAY)) / SET NUMBER CYCLES)
      side_garden_water_volume_per_cycle:
        unique_id: 2f979891-be33-449c-8972-f88eee697abf
        friendly_name: Side Garden - Water Volume Per Cycle
        value_template: "{{ [0, (((((states('sensor.week_target_volume_side_garden') | float(0)) - (states('sensor.rain_volume_7_days_side_garden') | float(0))) / (states('sensor.side_garden_days_per_week') | float(0))) / (states('sensor.side_garden_times_per_day') | float(0))) / (states('input_number.side_garden_water_valve_set_number_cycles') | float(0))) | round(0)] | max }}"
  # Rain Last 7 Days (mm) (Outputs Rain Accumulation Last 7 Days) - Common to ALL
  - platform: statistics
    name: "Rain last 7 days"
    unique_id: afe4b9f2-d0a6-4c42-86eb-786737f2ea14
    entity_id: sensor.netatmo_devonport_tas_indoor_rain_rain_today
    state_characteristic: sum_differences_nonnegative
    max_age:
      minutes: 10080
    precision: 1
    keep_last_sample: true
  # Back Garden Valve 1 Day (mm) (Outputs Water Consumed Last 1 Day - Used for Apex Charts Card)
    name: "Back Garden Water Consumed Daily"
    unique_id: 42572c8b-e257-430a-98eb-791a525b8212
    entity_id: sensor.0xa4c13839477a051c_water_consumed
    max_age:
      minutes: 1440
    precision: 1
  # Side Garden Valve 1 Day (mm) (Outputs Water Consumed Last 1 Day - Used for Apex Charts Card)
    name: "Side Garden Water Consumed Daily"
    unique_id: ecd3ee50-f10f-4590-8092-6188ef6814ba
    entity_id: sensor.side_water_valve_water_consumed
    max_age:
      minutes: 1440
    precision: 1
# Template Time Since Last ON Back Garden (Outputs timestamp of last ON)
template:
  - trigger:
      - trigger: state
        entity_id: switch.back_garden_water_valve_state
        to: "on"
      - name: back_garden_valve_last_on
        unique_id: 5b10c14e-ee8e-4b7f-9d83-db7189ece96b
        state: "{{ as_timestamp(states('sensor.date_time_iso')) | timestamp_custom('%H:%M %a %b %d') }}"
  # Template Time Since Last ON Side Garden (Outputs timestamp of last ON)
  - trigger:
      - trigger: state
        entity_id: switch.side_garden_water_valve_state
        to: "on"
      - name: side_garden_valve_last_on
        unique_id: 07805459-cad0-4bf2-9c8f-6d9201144267
V1.5 Helpers Required
V1.4 NODE RED FLOW
NODE RED FLOW WRITTEN UP IN THIS LINK:
Use the above link to import the flow, one flow will do one Garden Bed.
APEX RAIN FALL GRAPHS, YEAR, MONTH, DAY, HOUR
V1.5 THE ENTIRE DASH BOARD YAML
The whole dashboard has got too big to fit here 422 Error.
SECTION 1 of 3 MOBILE
Done in the new Sections View, good for phone and tablet.
  - title: Garden Irrigation
    path: garden-irrigation
    type: sections
    max_columns: 3
    sections:
      - type: grid
        cards:
          - type: heading
            icon: mdi:flower
            heading: Back Garden
            heading_style: subtitle
            badges: []
          - type: horizontal-stack
            cards:
              - type: custom:mushroom-number-card
                entity: input_number.back_garden_set_moisture
                display_mode: slider
                name: Back Garden Set Moisture
                icon_type: none
                layout: horizontal
                card_mod:
                  style:
                    mushroom-number-value-control$: |
                      mushroom-slider {
                        {% set nbr= states('input_number.back_garden_set_moisture') | float %}
                        {% if nbr<21 %}
                        --main-color: #F75050 !important;
                        --gradient: -webkit-linear-gradient(360deg, rgba(112,7,0,1) 20%, rgba(115,117,0,1) 21%, rgba(115,117,0,1) 40%, rgba(0,97,34,1) 41%, rgba(0,97,34,1) 60%, rgba(0,104,117,1) 61%) !important;
                        {% elif nbr<41 %}
                        --main-color: #55E84A !important;
                        {% elif nbr<61 %}
                        --main-color: seagreen !important;
                        {% elif nbr<100 %}
                        --main-color: #39BEEA !important;
                        {% endif %}
            layout_options:
              grid_columns: 4
              grid_rows: 1
          - type: gauge
            entity: sensor.back_garden_median_moisture
            needle: true
            min: 0
            max: 100
            segments:
                color: '#F75050'
                color: '#55E84A'
                color: seagreen
                color: '#39BEEA'
            name: Back Garden Median Moisture
          - type: custom:expander-card
            title: Back Garden Soil Moisture Stats
            clear: true
            expanded: false
            cards:
              - type: custom:mini-graph-card
                icon: mdi:water-percent
                entities:
                  - sensor.back_garden_median_moisture
                color_thresholds:
                  - value: 0
                    color: '#F75050'
                  - value: 21
                    color: '#EEE049'
                  - value: 41
                    color: '#55E84A'
                  - value: 61
                    color: '#39BEEA'
                hours_to_show: 168
                show:
                  icon: false
                  state: false
                  average: true
                  extrema: true
                points_per_hour: 0.25
                cards:
                    entities:
                      - sensor.0xa4c1387409af9c37_soil_moisture
                    color_thresholds:
                      - value: 0
                        color: '#F75050'
                      - value: 21
                        color: '#EEE049'
                      - value: 41
                        color: '#55E84A'
                      - value: 61
                        color: '#39BEEA'
                    hours_to_show: 168
                    show:
                      icon: false
                      state: true
                    entities:
                      - sensor.0xa4c138d47993fb2f_soil_moisture
                    color_thresholds:
                      - value: 0
                        color: '#F75050'
                      - value: 21
                        color: '#EEE049'
                      - value: 41
                        color: '#55E84A'
                      - value: 61
                        color: '#39BEEA'
                    hours_to_show: 168
                    show:
                      icon: false
                      state: true
                    entities:
                      - sensor.0xa4c138add8f4df84_soil_moisture
                    color_thresholds:
                      - value: 0
                        color: '#F75050'
                      - value: 21
                        color: '#EEE049'
                      - value: 41
                        color: '#55E84A'
                      - value: 61
                        color: '#39BEEA'
                    hours_to_show: 168
                    show:
                      icon: false
                      state: true
                cards:
                    entities:
                      - sensor.0xa4c1387409af9c37_temperature
                    color_thresholds:
                      - value: 0
                        color: '#F75050'
                      - value: 21
                        color: '#EEE049'
                      - value: 41
                        color: '#55E84A'
                      - value: 61
                        color: '#39BEEA'
                    hours_to_show: 168
                    show:
                      icon: false
                      state: true
                    entities:
                      - sensor.0xa4c138d47993fb2f_temperature
                    color_thresholds:
                      - value: 0
                        color: '#F75050'
                      - value: 21
                        color: '#EEE049'
                      - value: 41
                        color: '#55E84A'
                      - value: 61
                        color: '#39BEEA'
                    hours_to_show: 168
                    show:
                      icon: false
                      state: true
                    entities:
                      - sensor.0xa4c138add8f4df84_temperature
                    color_thresholds:
                      - value: 0
                        color: '#F75050'
                      - value: 21
                        color: '#EEE049'
                      - value: 41
                        color: '#55E84A'
                      - value: 61
                        color: '#39BEEA'
                    hours_to_show: 168
                    show:
                      icon: false
                      state: true
              - show_name: true
                show_icon: true
                show_state: true
                type: glance
                entities:
                  - entity: sensor.0xa4c1387409af9c37_battery
                  - entity: sensor.0xa4c138d47993fb2f_battery
                  - entity: sensor.0xa4c138add8f4df84_battery
                  - entity: sensor.0xa4c13839477a051c_battery
                state_color: true
            gap: 0px
            expanded-gap: 0px
            padding: 0px
            child-padding: 0px
            child-margin-top: 8px
        visibility:
          - condition: screen
            media_query: '(min-width: 0px) and (max-width: 767px)'
SECTION 2 of 3 MOBILE
      - type: grid
        cards:
          - type: custom:bignumber-card
            title: Back Garden Water Valve Volume Per Cycle
            entity: number.0xa4c13839477a051c_irrigation_target
            min: 0
            max: 422
            bnStyle: dodgerblue
            scale: 18px
            hideunit: false
            layout_options:
              grid_columns: 3
              grid_rows: 1
          - type: custom:button-card
            entity: switch.0xa4c13839477a051c_state
            icon: mdi:water-pump
            color_type: card
            color: auto
            show_state: true
            show_name: false
            layout_options:
              grid_columns: 1
              grid_rows: 1
          - type: custom:apexcharts-card
            chart_type: donut
            header:
              show: true
              show_states: true
              floating: true
              colorize_states: true
            experimental:
              color_threshold: true
            apex_config:
              grid:
                padding:
                  left: 0
                  right: 0
                  bottom: -100
                  top: 4
              chart:
                height: 182px
              plotOptions:
                pie:
                  startAngle: -90
                  endAngle: 90
                  donut:
                    labels:
                      show: true
                      total:
                        show: true
                        label: Target Volume
                        formatter: |
                          EVAL:function(w) {
                            return w.globals.seriesTotals.reduce((a, b) => {return (a + b)} , 0).toFixed(0) + " L"
              legend:
                show: false
                floating: true
                fontSize: 15px
                position: bottom
                offsetX: 0
                offsetY: 0
              dataLabels:
                enabled: false
            series:
              - entity: sensor.rain_volume_7_days
                color: turquoise
                show:
                  legend_value: false
              - entity: sensor.water_volume_required_back_garden
                color: dodgerblue
                show:
                  legend_value: false
            gap: 0.0em
            expanded-gap: 0.0em
            padding: 0.0em
            clear: true
            title: Back Garden Rain & Water Stats
            overlay-margin: 0.0em
            child-padding: 0.0em
            button-background: transparent
            expander-card-background: var(--ha-card-background,var(--card-background-color,#fff))
            header-color: var(--primary-text-color,#fff)
            arrow-color: var(--arrow-color,var(--primary-text-color,#fff))
            expander-card-display: block
            title-card-clickable: false
            min-width-expanded: 0
            max-width-expanded: 0
            cards:
                cards:
                  - type: custom:rain-gauge-card
                    entity: sensor.netatmo_devonport_tas_indoor_rain_rain_today
                    hourly_rate_entity: sensor.netatmo_devonport_tas_indoor_rain_rain_last_hour
                    show_warning: false
                    show_error: false
                    fill_drop_colour: turquoise
                    card_mod:
                      style: |
                        ha-card {
                          --ha-card-header-font-size: 18px;
                          --ha-card-header-color: silver;
                          height: 200px !important;
                    entities:
                      - entity: sensor.rain_last_7_days
                        color: turquoise
                    name: Rain Last 7 Days
                    group_by: date
                    show:
                      graph: bar
                      extrema: false
                    hours_to_show: 168
                    points_per_hour: 1
                    cache: true
                    animate: true
                    aggregate_func: last
                graph_span: 30d
                span:
                  end: day
                header:
                  show: true
                  show_states: true
                apex_config:
                  fill:
                    type: gradient
                    gradient:
                      type: vertical
                      shadeIntensity: 0
                      opacityFrom: 1
                      opacityTo: 0.5
                      stops: 10
                  chart:
                    height: 150px
                  grid:
                    show: false
                    borderColor: darkslateblue
                    strokeDashArray: 2
                  dataLabels:
                    background:
                      borderWidth: 0
                      opacity: 0
                      foreColor: white
                    offsetY: -10
                    style:
                      fontSize: 9px
                  plotOptions:
                    bar:
                      borderRadius: 0
                      dataLabels:
                        position: top
                series:
                  - entity: sensor.netatmo_devonport_tas_indoor_rain_rain_today
                    color: turquoise
                    type: column
                    group_by:
                      func: max
                      duration: 1d
                      fill: zero
                    statistics:
                      type: state
                      period: day
                      align: end
                    show:
                      name_in_header: true
                      datalabels: true
                      in_chart: true
                      legend_value: false
                      extremas: false
                    name: Rain Last 30 Days
                    color: deepskyblue
                    type: column
                    group_by:
                      func: sum
                      duration: 30d
                      fill: zero
                    statistics:
                      type: state
                      period: day
                      align: end
                    show:
                      datalabels: false
                      in_chart: false
                      legend_value: false
                entities:
                  - entity: sensor.back_garden_valve_on_off
                    color: deepskyblue
                show:
                  icon: true
                  state: false
                name: Irrigation Last 30 Days
                hours_to_show: 1
                points_per_hour: 60
                animate: true
                line_width: 2
                smoothing: false
                state_map:
                  - value: '1'
                  - value: '0'
        gap: 0px
        expanded-gap: 0px
        padding: 0px
        child-padding: 0px
        visibility:
          - condition: screen
SECTION 3 of 3 MOBILE
      - type: grid
        cards:
          - square: false
            type: grid
            cards:
                entity: switch.back_garden_set_time_switch_1
                color_type: card
                color: auto
                entity: input_boolean.rain_delay_toggle
                name: 24hr Rain Delay
                color_type: card
                color: cornflowerblue
                entity: switch.back_garden_set_time_switch_2
                color_type: card
                color: auto
            columns: 3
            cards:
              - type: custom:time-picker-card
                entity: input_datetime.back_garden_set_time_1
                hour_mode: 12
                hour_step: 1
                minute_step: 1
                layout:
                  hour_mode: double
                  align_controls: left
                  embedded: true
                  thin: true
                hide:
                  seconds: true
                  icon: true
                link_values: false
                name: Set Time 1
                entity: input_datetime.back_garden_set_time_2
                hour_mode: 12
                hour_step: 1
                minute_step: 5
                layout:
                  hour_mode: double
                  embedded: true
                  thin: true
                hide:
                  seconds: true
                  icon: true
                link_values: false
                name: Set Time 1
          - square: false
            type: grid
            cards:
                entity: input_boolean.back_garden_1_sun
                color_type: card
                color: auto
                entity: input_boolean.back_garden_2_mon
                color_type: card
                color: auto
                entity: input_boolean.back_garden_3_tue
                color_type: card
                color: auto
                entity: input_boolean.back_garden_4_wed
                color_type: card
                color: auto
                entity: input_boolean.back_garden_5_thu
                color_type: card
                color: auto
                entity: input_boolean.back_garden_6_fri
                color_type: card
                color: auto
                entity: input_boolean.back_garden_7_sat
                color_type: card
                color: auto
            columns: 7
            gap: 0.0em
            expanded-gap: 0.0em
            padding: 0.0em
            clear: true
            title: Back Garden Settings, Cycles & Valve Stats
            cards:
                cards:
                  - type: custom:numberbox-card
                    border: true
                    entity: input_number.back_garden_set_area
                    icon: false
                    min: 1
                    card_mod:
                      style: >
                        .body{display:block!important}
                        .body::after{text-align:center;font-size:10px;content:"Set
                        Garden Area";display:block!important}
                    border: true
                    entity: input_number.back_garden_set_mm_m2
                    icon: false
                    min: 1
                    card_mod:
                      style: >
                        Weekly Water";display:block!important}
                cards:
                    border: true
                    entity: input_number.back_garden_water_valve_set_number_cycles
                    icon: false
                    min: 1
                    card_mod:
                      style: >
                        Number of Cycles";display:block!important}
                    border: true
                    entity: number.0xa4c13839477a051c_cycle_irrigation_interval
                    icon: false
                    min: 1
                    step: 60
                    card_mod:
                      style: >
                        Cycle Interval Delay";display:block!important}
              - type: entities
                entities:
                  - entity: sensor.back_garden_valve_last_on
                    name: Water Last Delivered
                  - entity: sensor.0xa4c13839477a051c_water_consumed
                    name: Water Volume Delivered
                  - entity: sensor.0xa4c13839477a051c_last_irrigation_duration
                graph_span: 12month
                span:
                  end: month
                  offset: '-0d'
                header:
                  show: true
                  show_states: true
                apex_config:
                  fill:
                    type: gradient
                    gradient:
                      type: vertical
                      shadeIntensity: 0
                      opacityFrom: 1
                      opacityTo: 0.5
                      stops: 10
                  chart:
                    height: 150px
                  grid:
                    show: false
                    strokeDashArray: 2
                  dataLabels:
                    background:
                      borderWidth: 0
                      opacity: 0
                      foreColor: white
                    offsetY: -10
                  plotOptions:
                    bar:
                      borderRadius: 0
                      dataLabels:
                        position: top
                series:
                  - entity: sensor.back_garden_water_consumed_30_days
                    name: Irrigation This Month
                    color: deepskyblue
                    type: column
                    group_by:
                      func: max
                      duration: 30day
                      fill: zero
                    show:
                      datalabels: true
                      in_chart: true
                      legend_value: false
                      extremas: false
                    name: Irrigation Last 12 Months
                    color: deepskyblue
                    type: column
                    group_by:
                      func: sum
                      duration: 12month
                      fill: zero
                    statistics:
                      type: state
                      period: month
                      align: start
                    show:
                      datalabels: false
                      in_chart: false
                      legend_value: false
            title-card-button-overlay: false
        visibility:
          - condition: screen
Thanks for weiting this up and sharing it with the community :slight_smile: i really like the way you presented your dashboard and the festures included - awesome!!
Greetings
Thanks @Flipso I appreciate it. I have read so many posts to set things up in my house, it is now time for me to give back to the community.
V1.1 Update - New Picker for Garden Settings.
  • Target Volume is Divided over two watering session per day
  • Target Volume is further Divided into 7 sessions per week.
Take note of the Target Volume in the below.
I will update the above code in good time.
1 Time per day Active and 1 Day per week Active.
2 Times per day Active and 1 Day per week Active.
2 Times per day Active and 2 Days per week Active.
2 Times per day Active and 7 Days per week Active.
V1.1 Updated Node Red Flow
Any chance that you could provide the yaml code behind your active screen. Thanks.
I have updated everything in the above posts as V1.1 I will continue to update this as it progresses, adding in multiple garden beds and most likely an irrigation home screen which will lead out to the separate garden bed pages.
I have also created a Node Red Flow Write Up that is linked on the Node Red website. Flow can be downloaded from there.
V1.2
V1.2 Update
Hi looks interesting. Did you consider using Smart Irrigation for including Transpiration of water in your automations?
I did look at the HA Smart Irrigation Custom Component to bring in the Evapotranspiration (ET) estimation in or;
Figure out a way to bring the ET estimation in straight from BOM Australia.
I also looked at creating the Penman-Monteith Equation myself in a sensor. It is very complex and at the end of the day is is just an estimation which has been shown to be the most accurate in many areas of the world. An estimation used in the absence of soil moisture meters.
I am measuring soil moisture direct. The automation to deliver water does not fire unless the soil is below the set moisture target, in my case 40% Soil Moisture.
We are in the middle of winter in Tasmania at the moment my soil is at a measured Soil Moisture Median of 72%, with winter and spring rainfall ahead.
I live in a climate where mother nature provides sufficient irrigation most of the year round.
I am not expecting my irrigation to activate automatically (soil moisture drop below 40%) until October or November. January and February is where I could expect to use Evaprotranspiration, where we see sustained high temperatures and lack of rain fall. ET would act only to increase the calculated Volume Required slightly.
The main thing I am trying to achieve is not over-watering and maintaining a set soil moisture content. Also when watering (Every 7 Days) delivering a deep penetrating amount of water, equivalent to 24mm of rain per m2 of garden area per week. This also to reduce the water bill.
From sources I have read this should be adjusted to 25mm per week for lawns and only new lawns needing a daily water. I also have yet to experiment with vegetable garden irrigation, I am currently unsure of the volume of water or soil moisture recommended for veggies.
Adding Evapotranspiration
Looking at the documentation for the HA Smart Irrigation Custom Component, Example behavior in a week
I would need to figure out a way to use the either of the below readings as a multiplier against the calculated Target Volume. Then adding this to the Volume Required.
  • Np = Netto Precipitation (=P-Et)
  • B = Bucket during the day
Jeroen ter Heerdt edited this page on Jun 5, 2020 · 1 revision
This page provides insight into how this component should behave in certain weather conditions. With this you should be able to do a sanity check against your configuration and make sure everything is working correctly.
The scenario is as follows - we will look at several days, the precipitation and evapotranspiration for those days, the effects on the various calculations that this component makes and whether or not irrigation should be triggered. Note the values for precipitation and evapotranspiration are made up and are not representative of any real-life situation.
Initialization
Initially, the bucket=0, so the daily adjusted run time (ART)=0 as well.
Variables
  • P: Precipitation
  • Et:Evapotranspiration
  • D = Daily Adjusted Run Time
  • Bu = Bucket after update (=B+Np)
  • Du = Daily Adjusted Run Time after update (seconds)`
Example scenario
Day P Et Np B D Bu Du Irrigation required
1 0.5 0.1 0.4 0 0 0.4 0 No
2 0 0.6 -0.6 0.40 0 -0.2 180 Yes - bucket should be reset afterwards
3 1 0.2 0.8 0 (reset) 0 0.8 0 No
4 0.2 0.4 -0.2 0.8 0 0.6 0 No
5 0 1.5 -1.5 0.6 0 -0.9 600 Yes - bucket should be reset afterwards
6 0 0.4 -0.4 0 (reset) 0 -0.4 300 Yes - bucket should be reset afterwards
7 0.5 0.2 0.3 0 (reset) 0 0.3 0 No
There is also these few interesting posts but again these are based on time not volume.
Thank you for providing all those details! How do you calculate the target Volume? It’ takes the size of your lawn into account? And why do you use volume rather then time? Does the valves have a flow sensor to bring out a defined amount?
In the Smart Irrigation Integration you provide size of lawn and the flow rate of your watering system and it calculates the runtime for you. In the end it’s also volume based since you can calculate the volume by multiplying runtime with your flow rate.
  • I am expecting rain today, I will be able to show some screen shots of what the graphs do when rain is present.
  • When I looked at that integration it was only outputting a runtime. My valve only gives a volume Delivered and there is no flow rate given. If I was to use the runtime, I would be guessing at what the actual flow rate would be through the valve. Or do a calculation based on time vs volume delivered.
  • I have attached below what the valve exposes are in Zigbee2MQTT.
  • Yes the UI buttons set the (Target Volume) by inputting (Garden/Lawn Area) and Multiplying that by the (Target Rain Fall per Square Meter of Garden/Lawn Area)
  • Then (Actual Rain Fall Volume) for the set garden/lawn area is then subtracted from the Target Volume. To Give Volume Required.
  • Target Volume Sensor calculation is in the below.
V1.3 Sensors in configuration.yaml - You will need to set these up manually.
        value_template: >-
          0
          1
          {% else %}
          1
          {%- endif -%}
      rain_volume_7_days:
        unit_of_measurement: 'days'
        value_template: >
        value_template: >
        value_template: >-
          0
          {% else %}
          {%- endif %}
        value_template: "{{(((((states('sensor.week_target_volume_back_garden') | float(0)) - (states('sensor.rain_volume_7_days') | float(0))) / (states('sensor.back_garden_days_per_week') | float(0))) / (states('sensor.back_garden_times_per_day') | float(0))) / (states('input_number.back_garden_water_valve_set_number_cycles') | float(0))) | round(0)}}"
    max_age:
      minutes: 10080
    precision: 1
    max_age:
      minutes: 1440
    precision: 1
template:
  - trigger:
      - platform: state
        entity_id: switch.0xa4c13839477a051c_state
        to: 'on'
        unique_id: b54c02fb-d1d8-48a5-b263-d797b60fc875
V1.3 Update
V1.4 Update
7 Days per Week, Once a Day
3 Days per Week, Once a Day
1 Day per Week, Twice a Day
V1.5 Update
    • Mobile view code is located here using media_query: '(min-width: 0px) and (max-width: 767px)'.
    • Larger screen code located below, will ensure that 3 sections remain horizontal.
V1.5 HORIZONTAL VIEW CODE media_query: '(min-width: 768px)'
      - type: grid
        cards:
          - type: heading
            icon: mdi:flower
            heading: Side Garden
            cards:
                cards:
                    cards:
                        entity: input_number.side_garden_set_moisture
                        name: Side Garden Set Moisture
                        icon_type: none
                        layout: horizontal
                        card_mod:
                          style:
                              mushroom-slider {
                                {% if nbr<21 %}
                                {% elif nbr<41 %}
                                {% elif nbr<61 %}
                                {% elif nbr<100 %}
                                {% endif %}
                    layout_options:
                      grid_columns: 4
                      grid_rows: 1
                  - type: custom:layout-card
                    layout_type: custom:grid-layout
                    cards:
                        title: Side Garden Water Valve Volume Per Cycle
                        entity: number.side_garden_water_valve_irrigation_target
                        min: 0
                        max: 288
                        bnStyle: dodgerblue
                        scale: 18px
                        hideunit: false
                        entity: switch.side_garden_water_valve_state
                        color_type: card
                        color: auto
                        show_state: true
                        show_name: false
                    layout:
                      margin: '-4px'
                      align-self: start
                      grid-template-columns: 1fr 20%
                      grid-template-areas: |
                        "left right"
                  - square: false
                    type: grid
                    cards:
                        entity: switch.side_garden_set_time_switch_1
                        color_type: card
                        color: auto
                        color_type: card
                        entity: switch.side_garden_set_time_switch_2
                        color_type: card
                        color: auto
                    columns: 3
                layout_options:
                  grid_columns: 4
                  grid_rows: 1
            layout_options:
              grid_columns: full
            cards:
              - type: gauge
                entity: sensor.side_garden_median_moisture
                needle: true
                min: 0
                max: 100
                segments:
                    color: '#F75050'
                    color: '#55E84A'
                    color: seagreen
                    color: '#39BEEA'
                name: Side Garden Median Moisture
                chart_type: donut
                header:
                  show: true
                  show_states: true
                  floating: true
                experimental:
                apex_config:
                  grid:
                    padding:
                      left: 0
                      right: 0
                      bottom: -100
                      top: 4
                  chart:
                    height: 182px
                  plotOptions:
                    pie:
                      startAngle: -90
                      endAngle: 90
                      donut:
                        labels:
                          show: true
                          total:
                            show: true
                            formatter: |
                              EVAL:function(w) {
                  legend:
                    show: false
                    floating: true
                    fontSize: 15px
                    position: bottom
                    offsetX: 0
                    offsetY: 0
                  dataLabels:
                    enabled: false
                series:
                  - entity: sensor.rain_volume_7_days_side_garden
                    color: turquoise
                    show:
                      legend_value: false
                  - entity: sensor.water_volume_required_side_garden
                    color: dodgerblue
                    show:
                      legend_value: false
              - type: vertical-stack
                cards:
                    cards:
                        entity: input_datetime.side_garden_set_time_1
                        hour_mode: 12
                        hour_step: 1
                        minute_step: 1
                        layout:
                          hour_mode: double
                          embedded: true
                          thin: true
                        hide:
                          seconds: true
                          icon: true
                        link_values: false
                        name: Set Time 1
                        entity: input_datetime.side_garden_set_time_2
                        hour_mode: 12
                        hour_step: 1
                        minute_step: 5
                        layout:
                          hour_mode: double
                          embedded: true
                          thin: true
                        hide:
                          seconds: true
                          icon: true
                        link_values: false
                        name: Set Time 1
                  - square: false
                    type: grid
                    cards:
                        entity: input_boolean.side_garden_1_sun
                        color_type: card
                        color: auto
                        entity: input_boolean.side_garden_2_mon
                        color_type: card
                        color: auto
                        entity: input_boolean.side_garden_3_tue
                        color_type: card
                        color: auto
                        entity: input_boolean.side_garden_4_wed
                        color_type: card
                        color: auto
                        entity: input_boolean.side_garden_5_thu
                        color_type: card
                        color: auto
                        entity: input_boolean.side_garden_6_fri
                        color_type: card
                        color: auto
                        entity: input_boolean.side_garden_7_sat
                        color_type: card
                        color: auto
                    columns: 7
            layout_options:
              grid_columns: full
              grid_rows: auto
            cards:
                title: Side Garden Soil Moisture Stats
                clear: true
                expanded: false
                cards:
                    entities:
                      - sensor.side_garden_median_moisture
                    color_thresholds:
                      - value: 0
                        color: '#F75050'
                      - value: 21
                        color: '#EEE049'
                      - value: 41
                        color: '#55E84A'
                      - value: 61
                        color: '#39BEEA'
                    hours_to_show: 168
                    show:
                      icon: false
                      state: false
                      average: true
                      extrema: true
                    cards:
                        entities:
                          - sensor.soil_moisture_4_soil_moisture
                        color_thresholds:
                          - value: 0
                            color: '#F75050'
                          - value: 21
                            color: '#EEE049'
                          - value: 41
                            color: '#55E84A'
                          - value: 61
                            color: '#39BEEA'
                        hours_to_show: 168
                        show:
                          icon: false
                          state: true
                        entities:
                          - sensor.soil_moisture_5_soil_moisture
                        color_thresholds:
                          - value: 0
                            color: '#F75050'
                          - value: 21
                            color: '#EEE049'
                          - value: 41
                            color: '#55E84A'
                          - value: 61
                            color: '#39BEEA'
                        hours_to_show: 168
                        show:
                          icon: false
                          state: true
                        entities:
                          - sensor.soil_moisture_6_soil_moisture
                        color_thresholds:
                          - value: 0
                            color: '#F75050'
                          - value: 21
                            color: '#EEE049'
                          - value: 41
                            color: '#55E84A'
                          - value: 61
                            color: '#39BEEA'
                        hours_to_show: 168
                        show:
                          icon: false
                          state: true
                    cards:
                        entities:
                          - sensor.soil_moisture_4_temperature
                        color_thresholds:
                          - value: 0
                            color: '#F75050'
                          - value: 21
                            color: '#EEE049'
                          - value: 41
                            color: '#55E84A'
                          - value: 61
                            color: '#39BEEA'
                        hours_to_show: 168
                        show:
                          icon: false
                          state: true
                        entities:
                          - sensor.soil_moisture_5_temperature
                        color_thresholds:
                          - value: 0
                            color: '#F75050'
                          - value: 21
                            color: '#EEE049'
                          - value: 41
                            color: '#55E84A'
                          - value: 61
                            color: '#39BEEA'
                        hours_to_show: 168
                        show:
                          icon: false
                          state: true
                        entities:
                          - sensor.soil_moisture_6_temperature
                        color_thresholds:
                          - value: 0
                            color: '#F75050'
                          - value: 21
                            color: '#EEE049'
                          - value: 41
                            color: '#55E84A'
                          - value: 61
                            color: '#39BEEA'
                        hours_to_show: 168
                        show:
                          icon: false
                          state: true
                  - show_name: true
                    show_icon: true
                    show_state: true
                    type: glance
                    entities:
                      - entity: sensor.soil_moisture_4_battery
                      - entity: sensor.soil_moisture_5_battery
                      - entity: sensor.soil_moisture_6_battery
                      - entity: sensor.side_garden_water_valve_battery
                    state_color: true
                gap: 0px
                expanded-gap: 0px
                padding: 0px
                child-padding: 0px
                gap: 0.0em
                expanded-gap: 0.0em
                padding: 0.0em
                clear: true
                title: Side Garden Rain & Water Stats
                cards:
                    cards:
                        hourly_rate_entity: >-
                        show_warning: false
                        show_error: false
                        card_mod:
                          style: |
                            ha-card {
                        entities:
                            color: turquoise
                        group_by: date
                        show:
                          graph: bar
                          extrema: false
                        hours_to_show: 168
                        points_per_hour: 1
                        cache: true
                        animate: true
                    graph_span: 30d
                    span:
                      end: day
                    header:
                      show: true
                      show_states: true
                    apex_config:
                      fill:
                        type: gradient
                        gradient:
                          type: vertical
                          shadeIntensity: 0
                          opacityFrom: 1
                          opacityTo: 0.5
                          stops: 10
                      chart:
                        height: 150px
                      grid:
                        show: false
                        strokeDashArray: 2
                      dataLabels:
                        background:
                          borderWidth: 0
                          opacity: 0
                          foreColor: white
                        offsetY: -10
                        style:
                          fontSize: 9px
                      plotOptions:
                        bar:
                          borderRadius: 0
                          dataLabels:
                            position: top
                    series:
                        color: turquoise
                        type: column
                        group_by:
                          func: max
                          duration: 1d
                          fill: zero
                        statistics:
                          type: state
                          period: day
                          align: end
                        show:
                          datalabels: true
                          in_chart: true
                          legend_value: false
                          extremas: false
                        color: deepskyblue
                        type: column
                        group_by:
                          func: sum
                          duration: 30d
                          fill: zero
                        statistics:
                          type: state
                          period: day
                          align: end
                        show:
                          datalabels: false
                          in_chart: false
                          legend_value: false
                    entities:
                      - entity: sensor.side_garden_valve_on_off
                        color: deepskyblue
                    show:
                      icon: true
                      state: false
                    hours_to_show: 1
                    points_per_hour: 60
                    animate: true
                    line_width: 2
                    smoothing: false
                    state_map:
                      - value: '1'
                      - value: '0'
                gap: 0.0em
                expanded-gap: 0.0em
                padding: 0.0em
                clear: true
                title: Side Garden Settings, Cycles & Valve Stats
                cards:
                    cards:
                        border: true
                        entity: input_number.side_garden_set_area
                        icon: false
                        min: 1
                        card_mod:
                          style: >
                        border: true
                        entity: input_number.side_garden_set_mm_m2
                        icon: false
                        min: 1
                        card_mod:
                          style: >
                    cards:
                        border: true
                        entity: input_number.side_garden_water_valve_set_number_cycles
                        icon: false
                        min: 1
                        card_mod:
                          style: >
                        border: true
                        entity: >-
                          number.side_garden_water_valve_cycle_irrigation_interval
                        icon: false
                        min: 1
                        step: 60
                        card_mod:
                          style: >
                  - type: entities
                    entities:
                      - entity: sensor.side_garden_valve_last_on
                      - entity: sensor.side_garden_water_valve_water_consumed
                      - entity: >-
                          sensor.side_garden_water_valve_last_irrigation_duration
                    graph_span: 12month
                    span:
                      end: month
                      offset: '-0d'
                    header:
                      show: true
                      show_states: true
                    apex_config:
                      fill:
                        type: gradient
                        gradient:
                          type: vertical
                          shadeIntensity: 0
                          opacityFrom: 1
                          opacityTo: 0.5
                          stops: 10
                      chart:
                        height: 150px
                      grid:
                        show: false
                        strokeDashArray: 2
                      dataLabels:
                        background:
                          borderWidth: 0
                          opacity: 0
                          foreColor: white
                        offsetY: -10
                      plotOptions:
                        bar:
                          borderRadius: 0
                          dataLabels:
                            position: top
                    series:
                        color: deepskyblue
                        type: column
                        group_by:
                          func: max
                          duration: 30day
                          fill: zero
                        show:
                          datalabels: true
                          in_chart: true
                          legend_value: false
                          extremas: false
                        color: deepskyblue
                        type: column
                        group_by:
                          func: sum
                          duration: 12month
                          fill: zero
                        statistics:
                          type: state
                          period: month
                          align: start
                        show:
                          datalabels: false
                          in_chart: false
                          legend_value: false
            layout_options:
              grid_columns: full
        column_span: 3
        visibility:
          - condition: screen
This looks amazing.
I’ve copied it into a new flow but I’m such a beginner I’ve no idea where to start to get it to work with my GIEX Sprinkler and moisture sensor :frowning:
Hello how I can install all this? Does anyone can help me regards
Of course will be a pay job.
