Thanks for the blueprint. A suggestion, maybe move the time setting to the top, instead of the end. For me I need to make semi frequent changes to the time and I would think that this would be the most used section anyway.
Thanks…Steely
Thanks…Steely
Thanks for your suggestion, I will add it to the list and keep it in mind.
Blacky
Hi Blacky,
I’m just feeling very stupid, I can’t seem to get the automation to work. I have a hue light and it looks like the only requirement is the first field which is specified with the entity of the hue, which can toggle using the entities page.
what am i missing, i’m so desperate to use some of your great additions.
dumfounded dan
This blueprint can turn ON and OFF your light. You get to choose what you would like out of the 4 options. You can choose more than one option.
If you are more after a sensor light that works from a PIR type of sensor then look at my sensor light blueprint.
Blacky
Hi
in part i have discovered part of my problem
I’m using momentary buttons for my switches, and as such the light comes ON with press and then OFF with release.
There may be some workaround but is it possible to add an on transition of state. When you create a standard automation using state as trigger you have the option of selecting a from/to state or both, but for a momentary button only one is required.
I will be interested in you thoughts on this.
looking up daniel
Hi Daniel,
I have 2 blueprints for this that you can check out;
Probably it would be best if you explain what you are trying to do, then I will be able to help and not give you a bum steer.
Blacky
This is my first message on this board so i hope i do i right.
First, thanks for this amazing blueprint but i have a question and can’t find the answer yet.
I’m not sure how the ON/OFF features relates to each other (AND/OR?)
This my use-case:
If it is a weekday AND after 16:00 AND LUX became below 300 (somewhere after 16:00), then turn on lights untill 22:00, After 22:00 do nothing.
This is what i have now:
alias: "- Woonkamerverlichting blueprint voor licht"
description: ""
use_blueprint:
path: Blackshome/entities-on-off-trigger-conditions.yaml
input:
entity_switch:
entity_id:
- light.ecodim_bv_ecodim_zigbee_3_0_level_on_off
- switch.servieskast_on_off
- light.televisie_rechts_level_light_color_on_off
- light.tz3000_49qchf10_ts0502a_24741efe_level_light_color_on_off
- light.zitbank_links_level_light_color_on_off
- light.zitbank_rechts_level_light_color_on_off
include_light_control: use_brightness
include_entity_input: entity_disabled
include_ambient: ambient_enabled
ambient_light_sensor: sensor.xiaomi_lumi_sen_ill_mgl01_illuminance
ambient_light_value: 300
ambient_light_value_off: 800
after_time: "16:00:00"
before_time: "22:00:00"
include_weekdays: weekday_enabled
weekday_options:
- mon
- tue
- wed
- thu
- fri
light_brightness: 50
Is this possible?
Firstly welcome to the community
Your welcome and thanks for your kind words.
Nice you put in a use case as this realy helps me answer your question.
Try this I have the same thing you are trying to do;
Hope this helps you and let us know how you go.
Blacky
Thanks Blacky for this great response.
I think i’ve set it al up but have one more question (for now ).
I’m not sure what to do with the Sun Elevation because i want it to depend on the weather conditions. IF it is a rainy day, lights go on after 16:00. But when it’s sunny, lights stay off till LUX drops below ambient threshold (between 16:00 and 22:00).
alias: "-LICHT: Woonkamerverlichting"
description: >-
Schakel woonkamerverlichting aan na 16:00 (werkdagen) en als LUX lager is dan
300. Schakel licht uit als LUX hoger is dan 600. Na 22:00 niet meer doen.
use_blueprint:
path: Blackshome/sensor-light.yaml
input:
motion_trigger:
- schedule.ikbenthuis
light_switch:
entity_id:
ambient_light_high_value: 600
weekday_options:
- mon
- tue
- wed
- thu
- fri
Time to test. See if i can generate some rainy clouds
All looks good. The days to run should be selected in your schedule but I can see that time is not enabled anyway so all should be good.
Yea then what you have selected “Ambient Options” will work for what you are trying to do. Perfect
Blacky
It works and i’m very happy.
One little thing, not all entities go OFF when LUX is above high threshold.
Entity: light.ecodim_bv_ecodim_zigbee_3_0_level_on_off will stay on.
They should all go OFF. I would suspect a loss in communication or something on your end as we send the data to all.
It’s all working perfectly. Thanks for your help!
Sorry its taken time to get back to you. I have 7 RPi’s connected via the remote RPi integration which in turn support about 60 push buttons, they are mostly for Hue lights of different flavors, but some fans and a couple of heaters.
They are working via simple automations and basically just turn on/off.
I saw you great blueprint that could control a whole range of different functions.
I’m interested in turning some lights on/off at specific times and also some with reference to the sun.
Like: sunset + 1 hour → turn light on
Turn light on/off according to the current ambient light level (i have a number of hue motion sensors that also include ambient light sensors)
I would also in the future like to dim lights using the button (which i can do using the app)
this is why i was drawn to your blueprint
daniel
If you would like this then you will need this blueprint Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time
For this use a schedule in the linked blueprint above (Sensor Light)
We use sun elevation as HA recommend this. You can read up more on this in the FAQ of the sensor light blueprint.
No problem in the sensor light blueprint.
You can do this i the sensor light blueprint and the light will stay that way until it is turn OFF then it will rest back to your settings in the blueprint next time it is turned ON.
Hope this helps you.
Blacky
I’m loving the versatility of this blueprint! I’m using it to control the lighting in my reptile room, with a motion sensor. However, I want the lights to COME ON during the day, based on sun elevation, to provide a more natural seasonal cycle. As near as I can tell, this will only turn the lights on when the sun is moving high → low. Is there a way to invert the sun logic?
Of course I posted in the wrong thread I am using the Sensor Light blueprint, I’ll move the discussion there
Hi Blacky, and Happy New Year.
I’m trying to figure out if this is the right Blueprint for what I’m trying to do. I have a bathroom with two separate light circuits. One is dim and soft that turns on and off with Sensor Light whenever motion is triggered. The second one, bright for shaving primarily, I turn on manually at the light switch box.
I’d like to have a situation where the bright manual-on light turns off concurrent with the Sensor Light timing out of the main soft light.
Basically I don’t want to have to remember to turn the bright shaving off manually at the wall switch. Is this the correct blueprint? Or perhaps it is the Trigger Run-On Timer?
Thank you
