It works as standard switch, plus you can choose to use it with bluetooth or zigbee.
It just arrived, I am trying it as zigbee: it is recognised in HA as light. I am using deCONZ+ conbee II.
I do not know if I will be able to control the led (it is multicolor), but with his propetary app in BT mode you can.
I already have all switches from the same vendor all around the house, this is the perfect solution for me as I can add it also in existing elecrical system without any issue.
Ciao Andrea, come sta andando il progetto? Io ho un impianto domotico Vimar vecchio,senza nessuna connessione remota ed ero interessato anch’io a questo tipo di interruttore perchè mi interessa gestire solo qualche luce di servizio, tipo ingresso e disimpegno…
Hey @Andrea_Pasqualini, I also would be very interested to know if you made any progress with integrating that switch with HA. I am considering putting a bunch of those switches in my next home, and I would like to hear your experiences.
apologize for late reply.
Unfortunately I didn’t make any additional test since, when I put under load the switch, I broke it down. I will rebuy the same one but this time an electrician will assist me
From the test I did (deCONZ+ conbee II) it recognised it as light, but when i press the phisical button HA do not show any change (probably because there weren’t any light attached to it), while activating from HA switch respond correctly.
I will make an uptdate once i will mount the new one. It will take a while since HA is not working anymore (probably sd error).
I call my electrician and, unfortunatly, my electrical system do not allow this button.
I should replace every buttons even if they refer to the same lamp; it is not my intention to proceed in this way, so I am looking for another solution.
I my use it for the lamp that are commanded by a single button, in case I will update you.
Ciao @Stacco76, anch’io ho/avevo un vecchio impianto domotico vimar. Tanto per capire il by-me. L’ho trasformato in un impianto connesso cambiando un solo componente. Se sei interessato rispondimi o apri una discussione (linkando il link discussione)
Ciao Daniele, ho visto ora il tuo messaggio. Sarei interessato a sapere come hai modificato l’impianto. Anche se ho visto che è uscita la linea Idea aggiornata con interruttore Zigbee, che sarebbe proprio quello che serve a me. Sto aspettando che l’elettricista me lo procura per installarlo.
nel tuo impianto cosa c’è integrato? in linea di massima ti basta prendere il vimar 01411 e rifare la programmazione tramite PC con il software Gratuito Vimar View pro(fessionisti), poi autoconsegnarti l’impianto su app vimar view e collegare vimar view con google o alexa
Ciao a tutti,
I have been using the vimar smart switch 14592.0 (deviatore connesso) since last summer and I must say that it has always worked very well. I control it via deconz and conbee ii key. With the recent firmware update it no longer works as it should, instead of doing On or OFF it just TOGGLE the power. So, if in the group there is a light on and the others are off, the group state is ON, but if I try to turn off the group all the lights turn on and the one that was on turns off.
I can’t solve this problem. Help!
Ho acquistato 1 deviatore, 1 controller tapparella e 1 attuatore da 16A. Proverò ad integrarli via zigbee a zha. In teoria l’altra strada prevede l’integrazione tramite home kit, ma si è costretti a passare dal agteway di vimar stessa, cosa che vorrei evitare.
I have the same problem, I noticed it when I inserted the switch in an automation.
The switch_on or switch_off commands is like toggle.
You have news ?
Was the problem always present with previous Conbee firmware?
Hi, any update about Vimar? I used with ConBee II and DeCONZ and it has been recognized as switch, now that I moved to ZHA as integration I cannot find it anymore. Someone is using correctly with ZHA? Thanks!
son in fase di ristrutturazione casa, compreso l’impianto elettrico. Stavo quindi valutando varie soluzioni di demotica per luci, tapparelle. Mi chiedevo appunto se Vimar potesse fare al caso mio, se conviene installare i singoli switch nuovi di Vimar in modo che funzionino con Homeassistant e ZHA, oppure se far metter by-me.
Dici che hai sostituito un solo componente per far vedere a HA tutto l’impianto by-me?
They just updated the app. It brings the new zigbee firmware. Later I’ll try to update to see if the behavior in Deconz is correct respect current “light” setup.
This the response from Vimar about the Zigbee limit:
Con riferimento alla richiesta di supporto tecnico inviataci siamo a comunicare che il prodotto è progettato e testato per lavorare specificamente con l’hub ZigBee integrato a bordo di alcuni assistenti vocali Amazon (es. Echo); possiamo tuttavia anticipare che stiamo già lavorando ad una nuova versione firmware per il deviatore connesso in questione che uscirà prossimamente, quindi consigliamo di attendere il nuovo aggiornamento che verrà reso disponibile nel relativo store per l’app VIEW Wireless: ad app aggiornata ed accedendo al suo menù Azioni → Gestisci dispositivo potrà applicare il nuovo firmware sull’apparecchiatura.
A disposizione per eventuali chiarimenti, porgiamo Cordiali Saluti.
Diciamo che sono due cose ben diverse. Il by-me è un vero sistema domotico, quindi più flessibile (per avere più pulsanti che accendono la stessa luce non devi “portare in giro” altri fili) e completo(termostati intelligenti, videocitofonia, controllo carichi, diffusione sonora, ecc.). Con specifici componenti puoi installare addirittura by-me su componenti di terze parti, ossia avere Gewiss o BTicino come “interruttore” a vista e by-me che lo fa funzionare. sicuramente è un po’ più costosa ed è cablata, per casa deve girare un cavo bus. per me questo è un vantaggio perché in assenza di internet hai ancora tutte le funzionalità, scenari compresi, perché, appunto, le informazioni viaggiano sul bus( logico, non c’è comunicazione con Google o Alexa). inoltre puoi usare il software vimar per la programmazione che io ho trovato già molto completo e facile da imparare, senza dover installare firmware diversi sui dispositivi. I nuovi componenti sinceramente mi hanno un po’ deluso, vero hanno dalla loro il prezzo, che non è poco, ma ad esempio se tu hai una luce ti devi portare in giro per casa i fili in rame per tutti i pulsanti che servono per accenderla da tutti i punti che vuoi. in più i punti aggiuntivi per la stessa luce non hanno i led sul pulsante stesso, a meno che lo fai tu a parte ma vorrebbe dire altri fili da tirare, led da installare, ecc.
Io la vedo così…
I nuovi deviatori smart sono una soluzione a basso prezzo per chi si accontenta di avere le luci e le prese smart (comandabili vocalmente) fatte in qualche modo.
Il by-me è la Domotica, quella vera, più costosa, ma che fa tutto, in modo professionale.
Grazie per il feedback Daniele.
In effetti ero propenso ad installare il by-me (quindi col cavo bus). Mi chiedevo soltanto se poi c’era modo di interfacciare tutto il sistema con Home Assistant, in modo da poter fare automazioni “spinte” che controllino anche altre cose non gestite da by-me: tv, casse sonos, qualche sensore o striscia led, ecc.
Sai se è fattibile?
UPDATE: Works as before (firmware Zigbee 2.0.1) so in a bad way with HA.
If you toggle from the button, HA is not updated in anyway, no status on/off and no toggle. If you toggle from HA it works just as a push button with no state, just toggle.
For me it’s useless, I expected it worked like a pushbutton in monostable relay, but as a switch in bistable. I’ll try using MQTT, but definely not the best solution.
UPDATE 2: This the response to my last mail.
Pur confermando che effettivamente il prodotto in questione a livello ZigBee è progettato principalmente per l’interfacciamento con l’hub ZigBee integrato a bordo di alcuni assistenti Amazon Alexa, possiamo consigliare di verificare il carico collegato al deviatore in questione: è infatti importante che il prodotto rilevi un assorbimento sulla propria uscita di almeno 2W per poter funzionare correttamente. Confermiamo che oltre a questa condizione, una volta aggiornato il firmware ZigBee alla versione 2.0.1, non vi sono altre verifiche da condurre.
