I know this doesn’t help solve your problem, but it’s one of the many reasons I avoid bluetooth devices when there are alternatives.
check for “sensor last updated” time…create an automation that notifies you if the weber sensor hasn’t updated in two (or whatever you want) minutes.
eg…one discussion: Sensor - last updated monitor - Configuration - Home Assistant Community (home-assistant.io)
