WTH is it difficult to replace a phone (or user's device)?
When I (or my family) gets a new phone the best option (from the forums) to make sure the name stays the same you have to:
  1. Write down/remember the current device name
  2. Remove the current device
  3. Restart Home Assistant (I’ve ran into problems if I forget this)
  4. Login to Home Assistant app on the new device
  5. Enter the same name (hopefully correctly)
  6. Resetup all the same sensor choices
I’ve ran into problems with this process a few times with my family members forgetting they had an apostrphy, or something in the device name. Then you have to go back and rejoin. A bit frustrating.
The Ideal process would be:
  1. User gets new devices
  2. Login to Home Assistant (HA) app
  3. HA server recognizes this user has 1+ devices already
  4. HA app asks (Are you replacing one of these devices?)
  5. (If yes: keep name and copy sensor settings; unless cross os mapping isn’t possible) (If no: continue as currently does)
Here are some forum posts about how this is difficult:
I like your step 4!
I’m an iOS user and got a new Android work phone, I’ve installed HA app on there to see the difference. I’ve logged in with my account. At this point, I didn’t realize this new phone was automatically added as a device tracker to my account.
Later, for my work, I was GPS spoofing and my house was doing weird things as it thought I left/came back several times.
Only a few days later, after pulling many hairs, I found out the phone was to track me.
This is really beyond just replacing a phone and speaks to replacing devices in general
There is no way to say replace sensor.xxOld with sensor.xxNew
Exactly.
Shelly 2.5 (Gen1) after 2 years are useless (they often lose wifi connection or even don’t respond to physical input) so you must replace them.
Ideally, when we discover/add a new device we should be asked if we are adding a new device or replacing an old one.
This would help a lot, especially in long-term statistics, automations, dashboards, etc
+1 on topic
Off topic but I can tell you it’s not always the case with the shellies. I’ve had 2.5PM (Gen1) open and close my roller shutters for 4 years every single day, still work like a charm.
Agreed! Can you post a WTH for this if there isn’t one already?
I searched my post history and I did vote for this device replacement feature in WTH 2022 WTH there is no easy and automated way to replace devices
Is that similar to what you’re describing?
I am also annoyed with replacing devices but this one is the most household-facing issue that affects more than just me. :slight_smile:
Lucky You :slight_smile:
I replaced around 20 Shelly 2.5 devices in my amd my parents house. Luckily I was able to replace them with Gen3 devices with 50% discount
If not already posted I will do
Agreed. And not just with “advanced” devices like phones.
While I’ve had good success with dozens of a particular zwave switch, which has about 20 associated entities, I did have one die about two weeks after installing. Replaced under warranty, but by that time, it had been integrated with many automations, scripts, and even a few scenes. Also replaced some simpler devices with only a few entities, which is manageable but annoying.
It’s be great, when HA recognizes a new device, to just say it replaces an existing device and choose which one. Then HA can match the entities and everything else still works. Or, if it’s not the same make/model, prompt the user to map entity on the device to old entity.
Make sure to go vote on @tmjpugh WTH can’t we easily replace devices
If I change my device name it shouldn’t affect all my notification calls too… Especially on iOS there’s no way to specify an SSID so sometimes I play around with device name to change my hotpsot SSID.
I think it’s actually quite easy to replace a phone or any other device. Just give it the same name as the device you’re replacing.
Name your phone “Keiths Phone” instead of “Samsung S22”
Name your living room TV “Living Room TV” instead of “Sony Bravia 3”
Name your kitchen light “Kitchen Light” instead of “EcoDim BV Dimmer-Switch-ZB3.0”
etcetera
Then when you replace any device just remove the old one and give the new one the same name.
Yes. Make it even easier now!
Good is not good enough
That indeed does work, but it takes forethought. But, for a normal non-tech user they buy a phone, log into Home Assistant app, then they don’t get notifications and wonder why it’s not working. :frowning:
Their thought process is… I logged in as me, why don’t I get my notifications.
When a Device got replaced, its LTS/History should be migrated / copied as well.
I just had that Case, and realised the new device doesnt have all the precious Statistics belonging to the Users Device.
For this Usecase I would suggest a generic possibility to migrate/copy/edit/delete the Recorder/LTS:
Just give it the same name and the statistics will be migrated.
I think i am missing a stupid little step. If i give it the same name while it exists, all entities get a “_2” suffix.
If i delete it…well…i assume it is deleted.
The device is deleted, not its statistics.
Delete the old device first, then give the new device the same name.
This also does not work if you want to keep the old device, either for a while, or forever.
I kept my old phone for a week or so just to make sure I didn’t forget to move over any MFA or whatever apps.
