Continue Discussion 207 replies
Nov '18
touliloup
Crazy release again with tons of new thing :smile:
Concerning the google home bluetooth tracker, does someone know what it can detect and how well does it work? Will it for example detect a phone with bluetooth enable? Or a connected watch with BLE?
Nov '18
Sunonline
Thank you very much. So happy with the new light switch.
Nov '18
joshmd
Can anyone explain how the Google Home BLE device tracker works?
https://www.home-assistant.io/components/device_tracker.googlehome/
The input is just IP of the Home, but how do we know what devices it is going to look for or report on? is it based on your google account or do you need to tell it specific bluetooth MAC addresses?
Nov '18
Sunonline
Furthermore regarding Owntracks, so on HA part I don’t need to put owntracks under device_tracker anymore?
Nov '18
hulkhaugen
Just upgraded from 0.81.6 to 0.83.0, and I also changed out device_tracker with asuswrt in configuration.yaml, and commented out the track_new_devices: false, as that is not supported by the asuswrt component. However, I only get errors, using a Asus RT-AC66U with Telnet:
Error during setup of component asuswrt
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
    hass, processed_config)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/asuswrt.py", line 57, in async_setup
    await api.connection.async_connect()
  File "/srv/homeassistant/lib/python3.6/site-packages/aioasuswrt/connection.py", line 100, in async_connect
    self._host, self._port)
  File "/usr/local/lib/python3.6/asyncio/streams.py", line 75, in open_connection
    lambda: protocol, host, port, **kwds)
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 777, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.6/asyncio/base_events.py", line 764, in create_connection
    yield from self.sock_connect(sock, address)
  File "/usr/local/lib/python3.6/asyncio/selector_events.py", line 451, in sock_connect
    return (yield from fut)
  File "/usr/local/lib/python3.6/asyncio/selector_events.py", line 481, in _sock_connect_cb
    raise OSError(err, 'Connect call failed %s' % (address,))
ConnectionRefusedError: [Errno 111] Connect call failed ('192.168.1.1', 22)
Is there something I’m overlooking?
Nov '18 ▶ joshmd
touliloup
It will report all mac addresses it sees.
1 reply
Nov '18 ▶ joshmd
phairplay
I’m also interest in this.
I currently use my rpi bluetooth to track when we are home, it would be good if my bedroom G mini could detect when we go to bed and then turn everything off downstairs.
Or am I missing the point of this?
I was using the yale smart alarm but they change their api and I’m hoping someone can fix it
1 reply
Nov '18 ▶ phairplay
joshmd
No this is my understanding of it too. I have a few GH in my house so I’m now thinking I can effectively set up room-level presence detection with nothing more than the GH devices.
Nov '18
markbajaj
I had to roll back to 0.82.1 as just hung when I updated. Nothing obvious in the logs, though I suspect maybe Xiaomi devices may have something to do with it as my friend had to do the same and it was erroring on his Xiaomi sensors.
I’ll give it a go again in a bit and see if I can fully debug.
Nov '18
Sunonline
For Owntracks. the setting in configuration.yaml
owntracks:
Restart show intergration in config but no device.
CONFIGURING THE APP - IOS
Install the OwnTracks application for iOS.
In the OwnTracks app, tap the (i) in the top left and click on settings. Change the following settings:
1 reply
Nov '18 ▶ joshmd
davefrooney
I haven’t gotten the upgrade yet but i’ve had a look at the code. It seems to look for BLE devices similar to the ble_tracker. I assume it will use the known_devices.yaml to specify what to track
1 reply
Nov '18 ▶ davefrooney
phairplay
would you be able to track the same device on a different Bluetooth tracker?
I find the Google home has a short range (based on using it to stream music) yet the RPI never skips a beat.
1 reply
Nov '18 ▶ phairplay
joshmd
Short range could be good here if we’re looking at room presence detection though.
1 reply
Nov '18
Choffa
How does locking via google assistant work if I need to enter a pin-code to lock?
Nov '18
Martin_Granger
Not seeing the update in my hassio setup??
Nov '18 ▶ Sunonline
No restart needed when configuring OwnTracks. Devices don’t show up under integrations yet but device tracker entries will show up.
Nov '18 ▶ Martin_Granger
joshmd
Hassio update normally takes a few hours to show up I find.
1 reply
Nov '18
johnflorin
Google Home Bluetooth tracker seems amazing!
Even if it doesn’t work well enough for room-level detection, it would be an ideal way for home presence detection for all of us not using a Raspberry Pi for its Bluetooth.
Nov '18 ▶ joshmd
Martin_Granger
Can it be manually updated? I’m desperate to see if I can get my AsusWRT working again!
Nov '18
silvrr
Nov '18 ▶ markbajaj
touliloup
It is said in the doc that some index need to be migrated and that it might take a while. Have you been patient enough?
1 reply
Nov '18 ▶ joshmd
phairplay
I agree
What I’m curious about is can I still use the rpi bluetooth which detect us when on our drive and also use google home for room detection.
Nov '18 ▶ touliloup
maurizio53
Is someone aware of these errors?
2018-11-29 12:59:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
    result = coro.send(None)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 343, in _async_add_entity
    raise HomeAssistantError(msg)
homeassistant.exceptions.HomeAssistantError: Entity id already exists: group.all_switches
homeassistant.exceptions.HomeAssistantError: Entity id already exists: group.calendar
Nov '18 ▶ maurizio53
touliloup
Did you maybe declare a group calendar 2 times by mistake?
1 reply
Nov '18
0rn0lf
This release is so awesome! 17track is now an offical component and the best is, I can now finally use the fritzbox callmonitor component :tada:
Thank you really much
Nov '18 ▶ touliloup
maurizio53
No, it’s an open issue with 0.83.0 waiting to be fixed…
All group_all set to initial state ‘on’ have this problem…
Nov '18
Gipnokote
I also have problems with 0.83
When I restart HA I see some activity in the logs, and the last records are:
Nov 29 14:13:59 raspberrypi3 hass[31567]: 2018-11-29 14:13:59 INFO (Thread-14) [homeassistant.components.device_tracker.fritz] Successfully connected to FRITZ!Box 7560 (UI)
Nov 29 14:13:59 raspberrypi3 hass[31567]: 2018-11-29 14:13:59 INFO (Thread-14) [homeassistant.components.device_tracker.fritz] Scanning
Nov 29 14:14:02 raspberrypi3 hass[31567]: 2018-11-29 14:14:02 INFO (Thread-18) [homeassistant.components.device_tracker.fritz] Scanning
and it stops after this. Before this fritzbox tracker was scanning and leaving the log records periodically, each 5 seconds or so, but not after this update.
I also notice that some part of HA works, because it writes something into InfluxDB - I can see the changing numbers and graphs in Grafana which visualizes InfluxDB data, and it is only possible if HA is alive. But I cannot open HA in my browser.
I was patient enough to comment out sections in configuration.yaml to see what makes HA hang, and I found that OwnTracks is the culprit. This is my configuration:
device_tracker:
  - platform: fritz
    interval_seconds: 10
    consider_home: 180
    track_new_devices: yes
  - platform: owntracks
    max_gps_accuracy: 200
As soon as I comment out owntracks, HA starts fine.
1 reply
Nov '18
Sunonline
I got problem with google tts after update to 0.83
Thu Nov 29 2018 20:47:12 GMT+0700 (Indochina Time)
Error executing service <ServiceCall tts.google_say (c:6ed4b19be7494df8970833f467b0c61f): entity_id=['media_player.home_speaker'], message=how are you>
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/core.py", line 1177, in _event_to_service_call
    await service_handler.func(service_call)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 137, in async_say_handle
    options=options
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 306, in async_get_url
    engine, key, message, use_cache, language, options)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 318, in async_get_tts_audio
    message, language, options)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/tts/google.py", line 83, in async_get_tts_audio
    token.calculate_token, part)
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/srv/homeassistant/lib/python3.6/site-packages/gtts_token/gtts_token.py", line 28, in calculate_token
    seed = self._get_token_key()
  File "/srv/homeassistant/lib/python3.6/site-packages/gtts_token/gtts_token.py", line 57, in _get_token_key
    tkk_expr = re.search(".*?(TKK=.*?;)W.*?", line).group(1)
AttributeError: 'NoneType' object has no attribute 'group'
Also for lovelace.
## Log Details (ERROR)
Thu Nov 29 2018 20:47:07 GMT+0700 (Indochina Time)
https://192.168.1.60:8123/frontend_latest/app-0fd67575.js:89:305 Uncaught TypeError: Cannot read property 'toUpperCase' of null
Thu Nov 29 2018 20:47:01 GMT+0700 (Indochina Time)
https://192.168.1.60:8123/frontend_latest/app-0fd67575.js:89:305 Uncaught TypeError: Cannot read property 'state' of undefined
1 reply
Nov '18 ▶ Gipnokote
Ernst
Aha, thanks. Had the same issue of HA not showing the web-interface. Commenting out owntracks helped for now. Have to dig into the breaking change for owntracks, but at least HA is up and running again now.
jono
I’m seeing the same errors.
1 reply
Nov '18
Gerben321
17track is not working for me: [homeassistant.components.sensor.seventeentrack] Invalid username and password provided
Nov '18 ▶ jono
maurizio53
Someone told me it’s related to the google calendar component… if you use it try to comment out that and restart…
1 reply
jono
No, I don’t even use Google Calendar.
I do use Owntracks and commented that out, but it won’t load the Lovelace fontend (and I can’t figure out how to disable Lovelace to go back to the old UI).
Nov '18 ▶ jono
maurizio53
Hmm ok… so we must only wait for a fix… I was back to 0.82.1
Nov '18 ▶ jono
kevjs1982
Change “/lovelace” to “/states”
However it’s totally dead for me - starts up then just hangs -still running but nothing in the log - and that’s the chatty journalctl -fu [email protected] log file which stops after a short while.
The database upgrade went quickly and successfully
Downgrading to 0.82 hasn’t helped :sob:
(Removed a comment RE: Google Calendar - it’s called Google and doesn’t mention calendar)
Nov '18
jono
Thanks, that did it :+1:t3:
Nov '18
hulkhaugen
Downgrading to 0.81.6 gives me trouble also now. Seems to have something to do with auth token, i have no idea what to do now. This error comes over and over again:
2018-11-29 15:33:07 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1706082512] Unexpected error inside websocket API
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/websocket_api/http.py", line 140, in async_handle
    connection = await auth.async_handle(msg)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/websocket_api/auth.py", line 76, in async_handle
    msg['access_token'])
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/auth/__init__.py", line 362, in async_validate_access_token
    cast(str, unverif_claims.get('iss')))
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/auth/__init__.py", line 325, in async_get_refresh_token
    return await self._store.async_get_refresh_token(token_id)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/auth/auth_store.py", line 190, in async_get_refresh_token
    await self._async_load()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/auth/auth_store.py", line 247, in _async_load
    name=group_dict['name'],
KeyError: 'name'
Nov '18 ▶ kevjs1982
Ernst
Do you use owntracks? You have to change your owntracks config. It has moved from device_tracker: to its own component owntracks:. After this change, the web interface became up and running again (for me) after a restart of HA.
1 reply
Nov '18 ▶ kevjs1982
jncanches
If you are using owntrack, its configuration has to be moved from device_tracker: to the root of configuration.yaml
for example:
device_tracker:
becomes
owntracks:
Hope this help. My UI was stuck too before I changed that
Nov '18 ▶ Ernst
kevjs1982
Commented Owntracks out and that made no difference.
Disabling all Device Trackers and it’s working. Now to narrow down the culprit…
1 reply
Nov '18
hulkhaugen
Nope, but i use asuswrt, which has become it’s own component as well. It hasn’t been working since 0.81.6. I did move the settings back. Now i’ve upgraded to 0.83.0 again, but i have a failing “device tracker”, despite having the settings as they should (configuration.yaml):
asuswrt:
  host: 192.168.1.1
  username: !secret asuswrt_username
  password: !secret asuswrt_password
  protocol: telnet
From the logs:
2018-11-29 15:50:41 ERROR (MainThread) [homeassistant.setup] Error during setup of component asuswrt
    raise exceptions[0]
EDIT: Thought the OwnTracks post was for me. Still relevant though.
1 reply
Nov '18
bachoo786
Have updated to 0.83 but HA does not load ?
1 reply
Nov '18 ▶ kevjs1982
kevjs1982
Got it - had to remove the Bluetooth Tracker Too…
- platform: bluetooth_tracker
  request_rssi: true
  consider_home: 180
Now to work out what is flooding the logs with:-
Nov 29 15:02:19 haas hass[4241]: Traceback (most recent call last):
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 390, in start
Nov 29 15:02:19 haas hass[4241]:     resp = await self._request_handler(request)
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_app.py", line 366, in _handle
Nov 29 15:02:19 haas hass[4241]:     resp = await handler(request)
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_middlewares.py", line 106, in impl
Nov 29 15:02:19 haas hass[4241]:     return await handler(request)
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/ban.py", line 66, in ban_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/auth.py", line 97, in auth_middleware
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/view.py", line 115, in handle
Nov 29 15:02:19 haas hass[4241]:     result = await result
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/homeassistant/components/api.py", line 220, in post
Nov 29 15:02:19 haas hass[4241]:     if not request['hass_user'].is_admin:
Nov 29 15:02:19 haas hass[4241]:   File "/home/pi/homeassistant/lib/python3.5/site-packages/aiohttp/web_request.py", line 201, in __getitem__
Nov 29 15:02:19 haas hass[4241]:     return self._state[key]
Nov 29 15:02:19 haas hass[4241]: KeyError: 'hass_user'
1 reply
Nov '18 ▶ bachoo786
Ernst
@bachoo786 See above, probably OwnTracks or Asuswrt component that you have to change in your config.
1 reply
Nov '18
Sunonline
Also anyone have problem with broadlink switch? I cannot control all my broadlink switch.
Nov '18 ▶ kevjs1982
kevjs1982
Ah, looks like it’s all my HTTP Sensors…
HASS is returning
<html><head><title>500 Internal Server Error</title></head>
<body><h1>500 Internal Server Error</h1>Server got itself in trouble</body></html>
1 reply
Nov '18
finity Regular
Does anyone definitively know if the asuswrt component using SSH works in this release? I don’t want to upgrade if the asuswrt device tracker component is still broken.
And to clarify since the docs are pretty vague -
Do we just need to setup the asuswrt component and that will automatically start tracking devices or do we still need to add the asuswrt device tracker config to the "device_tracker: " section?
Assuming it’s the former then if I have a asuswrt device tracker set up then do I need to remove that config entry?
1 reply
Nov '18 ▶ Ernst
bachoo786
Nope I don’t have any of those components in my config.
It’s been over an hour now it’s not working.
Nov '18 ▶ hulkhaugen
masterkenobi
Telnet port is 23. Add port: 23 into the configuration.
Nov '18
eryk
I’ve stuck on loading 0.83 but after i read to remove OwnTracks in config i finally got it HA working again.
1 reply
Nov '18
bachoo786
I am having the following errors:
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 343, in _async_add_entity
2018-11-29 15:55:41 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
1 reply
Nov '18
TaperCrimp
Same here. I actually forgot I had it enabled since I don’t use it anymore. Everything seemed to come up just fine, but the UI wasn’t loading. There wasn’t anything apparent in the logs at the warn level either. I saw this thread, removed the config, restarted the container, and everything came up as expected.
Nov '18 ▶ touliloup
masterkenobi
@touliloup,
Does the Google Home Bluetooth tracker works for Google Home Mini?
1 reply
Nov '18 ▶ masterkenobi
touliloup
I don’t know, I believe it does but I haven’t tested with one.
Nov '18 ▶ touliloup
masterkenobi
I think it does. I went to http://[My Google Home Mini IP]:8008/setup/eureka_info and I see a bunch of info.
hulkhaugen
That did the trick :smiley:
EDIT: only 10 mins of joy, back to troubleshooting.
Nov '18
speedmann
Anyone here care to explain why we need this “config entry” stuff?
For me it looks like it just makes everything more complicated and less comfortable. I just do not find a way to store my config in a version controll system anymore with this.
1 reply
Nov '18 ▶ speedmann
kevjs1982
So newbies can run through a setup wizard and configure everything - no need for SSH/Samba etc. Supposadly easy to do sensible migrations so OwnTracks changing doesn’t break load of installs
Is a pain to backup/disable if stuff goes wrong.
Nov '18
speedmann
This needs a good solution… I run home assistant as docker container for a reason and i really like a “fallback” when i mess up my config… And i ocassionally do
1 reply
hulkhaugen
Short joy, after approx 10 minutes, all devices were apparently away, and also the upload/download sensor seems to fail, spamming my log:
2018-11-29 18:23:28 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.asuswrt_download fails
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
    await self.async_device_update()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 347, in async_device_update
    await self.async_update()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/asuswrt.py", line 106, in async_update
    await super().async_update()
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/asuswrt.py", line 54, in async_update
    self._speed = await self._api.async_get_current_transfer_rates()
  File "/srv/homeassistant/lib/python3.6/site-packages/aioasuswrt/asuswrt.py", line 217, in async_get_current_transfer_rates
    self._rx_latest = data[0]
IndexError: list index out of range
2018-11-29 18:23:28 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.asuswrt_upload_speed fails
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/asuswrt.py", line 88, in async_update
1 reply
Nov '18
jeanniquini
Has anyone managed to make the downgrade work? When I go back to version 0.82.1 it does not work.
Nov '18 ▶ kevjs1982
kevjs1982
HTTP Sensors are broke at 0.83 apparently. https://github.com/home-assistant/home-assistant/pull/18733
A fix has been added to the queue of stuff in 0.83.1
Anyone know if it’s possible to switch to the Long Lived Tokens on HTTP Sensors and if they work?
calypso
asuswrt broken for me too.
Im getting the same error and i have the same router.
Nov '18
ATXcoder
upgraded to 0.83 and now HA will not start. Seeing this in the logs. Any ideas?
2018-11-29 11:48:15 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 390, in start
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_app.py", line 366, in _handle
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 106, in impl
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 66, in ban_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 97, in auth_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 115, in handle
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/api.py", line 85, in get
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_request.py", line 201, in __getitem__
masterkenobi
yes you are right. i was using telnet too. I have changed it to SSH and port 22. It seems to be working now.
Nov '18
thaihung9221
TTS Error - This error seems to affect quite a lot of people, looking forward to early patches, thanks to the programmer
Nov '18
BadHass
If I track 2 phones with Owntracks, do I use the same url for both phones?
Nov '18 ▶ ATXcoder
bachoo786
Same error I got downgrading to 0.82.1
1 reply
Nov '18 ▶ bachoo786
ATXcoder
I just saw that someone else had this error too. Looks to be related to users who have systems that are making calls to HA REST using the Legacy Password. My Node-Red connects to HA’s REST API using the Legacy Password. Going to see if I can re-configure Node-Red to use token instead, but also see a fix has been issued in 83.1 (https://github.com/home-assistant/home-assistant/issues/18783)
1 reply
gregg098
I have the same issue with various groups. No changes to config other than upgrading.
Nov '18 ▶ bachoo786
maurizio53
same here… back to 0.82.1
Nov '18
gregg098
I added my Google Homes (7 of them) as device trackers, and Home Assistant never finishes starting up. I let it sit for 45 minutes earlier and I could barely navigate the UI, Z wave components get stuck in initializing, other components don’t show up on the front end, etc. Tried restarting a few times with the same problem.
There are no log entries that seem to indicate any issues. When I comment out the Google Home entries, Home Assistant starts up really quick with no issues (other than a few random log errors as others noted such as the group already exists error).
Anyone else having this issue? Will try just adding one of them at a time later today to see if it helps.
Nov '18 ▶ touliloup
masterkenobi
OK. Confirm Google Home Mini is supported! :smiley:
Nov '18 ▶ ATXcoder
bachoo786
back to 0.82.1 getting the same errors and now frontend wont load together with that getting these issues:
2018-11-29 18:21:12 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True or False: 14
2018-11-29 18:21:12 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True or False: 63
2018-11-29 18:21:30 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True or False: 14
2018-11-29 18:21:31 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True or False: 63
2018-11-29 18:22:03 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True or False: 14
2018-11-29 18:22:03 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True or False: 63
2018-11-29 18:22:36 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True or False: 14
2018-11-29 18:22:36 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True or False: 63
1 reply
Nov '18
WedHumpDay
This resolved my stuck UI.
1 reply
Nov '18
woody4165
Hi all
I’m experiencing a white page in lovelace with this card, was working before upgrading and no modification was done.
  - id: 2  # Automatically created id
    title: Meteo
    icon: mdi:weather-partlycloudy
    cards:
      - id: xxxxxx  # Automatically created id
        type: vertical-stack
        cards:
          - type: entities
            title: Temperature
            show_header_toggle: false
            entities:
              - sensor.patio_temp
              - sensor.patio_umidita
              - type: divider
              - sensor.temperature_xxxxx
              - sensor.humidity_xxxxx
              - type: divider
              - sensor.temperature_yyyyy
              - sensor.humidity_yyyy
              - type: divider
              - sensor.rmpro_sala_temperature
              - sensor.rmpro_letto_temperature
              - type: divider
              - sensor.tempest
              - sensor.tempesthum
              - sensor.tempestbat
          - type: entities
            title: Umidità, pressione e pioggia
            entities:
              - sensor.dark_sky_temperature
              - sensor.dark_sky_humidity
              - sensor.dark_sky_pressure
              - sensor.dark_sky_wind_speed
              - sensor.dark_sky_wind_bearing
              - sensor.dark_sky_summary
              - sensor.dark_sky_cloud_coverage
              - sensor.dark_sky_precip_intensity
              - sensor.dark_sky_precip_probability
          - type: entities
            title: Daily Forecast
            show_header_toggle: true
            entities:
              - sensor.pws_weather_1d_metric
              - sensor.pws_weather_1n_metric
              - type: divider
              - sensor.pws_weather_2d_metric
              - sensor.pws_weather_2n_metric
              - type: divider
              - sensor.pws_weather_3d_metric
              - sensor.pws_weather_3n_metric
              - type: divider
              - sensor.pws_weather_4d_metric
              - sensor.pws_weather_4n_metric
I have also done the modification in the dark_sky platform sensor adding the 0
  - platform: darksky
    api_key: !secret darksky_api_key
    forecast:
      - 0
      - 1
      - 2
      - 3
      - 4
      - 5
    update_interval:
      minutes: 5
    monitored_conditions:
Strangely, this happens only in lovelace, with standard UI I get all the sensors showed.
What can I check?
Nov '18
woody4165
A new issue for me after upgrading.
I have Node Red installed on a separate server, working until update to 0.83.
Now the connection to Hassio is not working anymore.
I’m using API pass (in the picture removed) and it’s defined in secrets.yaml
Is there anything new that I have missed?
Nov '18 ▶ woody4165
kevjs1982
That’s probably related to https://github.com/home-assistant/home-assistant/pull/18733 - fix due in 0.83.1
Another poster was going to see if they could get it to worth with the moder tokens.
1 reply
Nov '18 ▶ kevjs1982
woody4165
Thanks.
I am going to downgrade to 0.82.x, but I don’t remember what was the latest NON-beta version, any help please?
1 reply
Nov '18
jusdwy
0.83 broke my Lovelace
http://hassio.local:8123/frontend_latest/app-0fd67575.js:89:305 Uncaught TypeError: Cannot read property ‘state’ of undefined
2:49 PM components/system_log/init.py (ERROR)
http://hassio.local:8123/local/custom_ui/dark-sky-weather-card.js?v=4:144:85 Uncaught TypeError: Cannot read property ‘state’ of undefined
2:43 PM components/system_log/init.py (ERROR)
still can load /states without issue. No states in /dev-state seem to be acting up, and everything was working previous to upgrading from 0.82.1
update:
not sure what happened, but when I went from /states to /lovelace it partially loaded. the main page view is blank, but I can click thru my others views without issue. main page does include the custom dark sky card.
and when i comment out the dark sky card it works. something changed with how HA interprets custom cards?
update update: (SOLVED!)
issue was with entity_forecast_low_temp_1: sensor.dark_sky_overnight_low_temperature not starting at 1 in ui_lovelace.yaml.
(also minor change in the dark-sky-weather-card.js to update pressure to mbar)
Nov '18 ▶ woody4165
silvrr
82.1
adsfasdfasdfa
Nov '18
Schneider
Hello guys! Thanks for this awesome update.
I am amazed how fast lovelace UI loads now, great work!
Asus component working fine now, just a bug (maybe?) on how download/upload sensors shows data:
Both sensors shows the other’s value. In the image above, I was just downloading, at 50mbps, no upload whatsoever… Very strange.
Here is how it shows on the Asus WebUI:
Also: any adive on using track_new_devices parameter now? I ratter set it manually for each new device.
Thanks!
1 reply
Nov '18 ▶ markbajaj
markbajaj
Working now.
Followed advice from someone on here (sorry can’t see your post now!)
remove OwnTracks from device_tracker and put in the configuration.yaml on its own
OwnTracks:
Nov '18
gregg098
Anyone else seeing issues with Schlage Z wave locks? Have a BE468 and a BE469. Both respond to local operation of the lock, but if I lock/unlock through Hass, the status never updates. Saw the update in the change log so I’m guessing it has something to do with that PR.
Nov '18
skynet01
Any update on when an updated version of DenonAVR will be merged into the release? It’s been about 2 month since it got updated (https://github.com/scarface-4711/denonavr ) Would love to use my new receiver :slight_smile: :slight_smile:
1 reply
Bogdan_Mazurenko
RT-AX88U - everything works, but i cant disable track mode for new devices for it.
Nov '18
gurbyz
I also have this error with google tts since today, but I’m still on 0.81.6 (HassIO). So I think this error is not related to the new release directly.
1 reply
Nov '18 ▶ gurbyz
cogneato
Google changed the token.
https://github.com/home-assistant/home-assistant/issues/16905#issuecomment-442912708
Nov '18 ▶ ATXcoder
Dinges28
Having the same issue here…
Hass works normaly, but every 2 minutes log is flooded with this message
Nov '18 ▶ Schneider
hulkhaugen
Is it still working? Mine was only working for 10 mins, but i’m using telnet on a RT-AC66U.
1 reply
Schneider
I am using SSH and it works great, apart from the Download/Upload sensor data. Not sure how to set track_new_devices now. Thanks.
Nov '18 ▶ ATXcoder
jeanniquini
Same here. Did the downgrade work for you?
Nov '18 ▶ ATXcoder
Fixed in 0.83.1
Nov '18 ▶ balloob
jeanniquini
node-red is not connecting to the HA.
Login attempt or request with invalid authentication from 192.168.X.X
Nov '18 ▶ balloob
jeanniquini
@balloob
This error is occurring when I run an ifttt webhook:
Error executing service <ServiceCall switch.turn_off (c:4eb3ebc0579844abb7deb328c5253e54): entity_id=[‘switch.lampada’]>
File “/home/jean/apps/Homeassistant/lib/python3.5/site-packages/homeassistant/core.py”, line 1177, in _event_to_service_call
File “/home/jean/apps/Homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py”, line 177, in handle_service
self._platforms.values(), func, call
File “/home/jean/apps/Homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py”, line 250, in entity_service_call
permission=POLICY_CONTROL
homeassistant.exceptions.Unauthorized: Unauthorized
Nov '18 ▶ skynet01
tielemans.jorim
What do you mean? denonavr already uses the latest package available (0.7.6).
We can’t update the component if the PR (I assume you want https://github.com/scarface-4711/denonavr/pull/65) for support isn’t merged and a new version gets released on pypi.
Nov '18 ▶ balloob
bachoo786
Updated to 0.83.1 now getting failed login attempt even though I am logged in.
Nov '18
kcarriello
Update server is informing the wrong version and crashing hassio installations. I checked the server (https://s3.amazonaws.com/hassio-version/stable.json) and it’s informing 0.82.1 as the latest, even for whom is already on 0.83. So if someone proceed with the suggested upgrade it will corrupt the installation. That just happened to me.
1 reply
Nov '18 ▶ kcarriello
dustardly2
same for me :triumph:
Nov '18
kcarriello
I forced the upgrade to 0.83.1 using the following cli command, using ssh, and it fixes the problem.
hassio ha update --options version=0.83.1
