2024.8: Beautiful badges!
Select Display type: Standard (icon and state)
and State content: Name
The DOM is not updated properly as there are other artefacts experienced, and in the case of the automations, browser not the issue.
For those impacted with the Alexa custom component not working itā€™s fixed in failed to SignIn Ā· Issue #2407 Ā· alandtse/alexa_media_player Ā· GitHub (with an upstream dependency)ā€¦component seems to be pending a new Release as of now but the instructions to manually fix (update requirements in manifest.json) while running v4.12.6 are in the linked issueā€¦
@tomkHA @Xitee @CChris you all mentioned the issue in this thread so just FYI
True, the ā€œbadgeā€ is not new but as the previous badge element was effectively replaced by a completely new look, which canā€™t be switched, we could just call it a new card :slight_smile:
Anyhow, you completely missed the point: The forced bi-directional relation between the top row and the badge card is unnecessary.
I am loving the new badges but I would like to see more flexibility:
  • using chips also in sections, so on complete dashboard (like normal cards)
  • using normal cards also as badges (I have display devices where the chips are so small that they can hardly be selected on that dashboard, for these I need bigger cards)
  • what about optional sidebar(s), header, footer?
This notice applies only if you use the recorder integration with a MySQL or PostgreSQL database. If you are using the default SQLite database, you can ignore it.
What happens when i have mariadb?
My database size is 5GB. I am using HABlue to run HA. How much time should i expect?
a little bit chalk and cheese as not same machine, but my 4.5GB mariadb database took just over 70 mins to update on a PI5
(a notification appears in HA when the conversion starts and dissapears once complete so you know when youā€™re doneā€¦itā€™s in the logs too)
The qBittorrent integration has stopped working after upgrading to 2024.8. I have the following in my logs:
Logger: homeassistant.setup
Source: setup.py:334
First occurred: 17:48:29 (1 occurrences)
Last logged: 17:48:29
Setup failed for 'qbittorrent': Unable to import component: cannot import name 'TorrentStatusesT' from 'qbittorrentapi.torrents' (/usr/local/lib/python3.12/site-packages/qbittorrentapi/torrents.py)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1007, in async_get_component
    comp = await self.hass.async_add_import_executor_job(
  File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1067, in _get_component
    ComponentProtocol, importlib.import_module(self.pkg_path)
  File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 995, in exec_module
  File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
  File "/usr/src/homeassistant/homeassistant/components/qbittorrent/__init__.py", line 30, in <module>
    from .coordinator import QBittorrentDataCoordinator
  File "/usr/src/homeassistant/homeassistant/components/qbittorrent/coordinator.py", line 16, in <module>
    from qbittorrentapi.torrents import TorrentStatusesT
ImportError: cannot import name 'TorrentStatusesT' from 'qbittorrentapi.torrents' (/usr/local/lib/python3.12/site-packages/qbittorrentapi/torrents.py). Did you mean: 'TorrentStates'?
  File "/usr/src/homeassistant/homeassistant/setup.py", line 334, in _async_setup_component
    component = await integration.async_get_component()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1027, in async_get_component
    self._component_future.result()
  File "/usr/src/homeassistant/homeassistant/loader.py", line 1019, in async_get_component
    comp = self._get_component()
Logger: homeassistant.config_entries
Source: config_entries.py:2871
First occurred: 17:57:57 (2 occurrences)
Last logged: 17:58:01
Error occurred loading flow for integration qbittorrent: cannot import name 'TorrentStatusesT' from 'qbittorrentapi.torrents' (/usr/local/lib/python3.12/site-packages/qbittorrentapi/torrents.py)
I discovered what the issue was. Badges using the entity filter donā€™t convert into new style badges using equivalent viability rules. You need to remove the entity filter using the complete Dashboard Yaml editor and readd to use visibility.
What about new notification groups? I am using yaml until now to group my mobile app notification services. I tried to mimic the same in UI, but these notification entities for mobile apps donā€™t show up in the dropdown. Is there any limitation?
I am not sure what happened there. It didnt take much time :-/
2024-08-08 09:49:53.883 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2024.8.0
2024-08-08 09:49:53.885 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/odroid-n2-homeassistant:2024.7.4 to ghcr.io/home-assistant/odroid-n2-homeassistant:2024.8.0
2024-08-08 09:49:53.885 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/odroid-n2-homeassistant with tag 2024.8.0.
2024-08-08 09:51:55.818 INFO (SyncWorker_9) [supervisor.docker.manager] Stopping homeassistant application
2024-08-08 09:52:19.650 INFO (SyncWorker_9) [supervisor.docker.manager] Cleaning homeassistant application
2024-08-08 09:52:20.379 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2024-08-08 09:52:20.776 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/odroid-n2-homeassistant with version 2024.8.0
2024-08-08 09:52:20.776 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2024-08-08 09:52:47.758 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-08-08 09:52:48.070 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-08-08 09:52:50.852 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2024-08-08 09:52:52.728 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'addons'
2024-08-08 09:52:53.078 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache
2024-08-08 09:53:27.576 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
2024-08-08 09:53:27.924 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache
2024-08-08 09:53:52.403 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='STARTING', offline_db_migration=False)
2024-08-08 09:53:58.454 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2024-08-08 09:53:58.454 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2024-08-08 09:53:58.454 INFO (MainThread) [supervisor.homeassistant.core] Successfully started Home Assistant 2024.8.0
2024-08-08 09:53:58.582 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/odroid-n2-homeassistant:2024.7.4']
think those logs are just for the Core upgrade finishingā€¦the DB will update the schema separatelyā€¦youā€™ll see a Notification when it starts (and is in logs for Core too)
It looks like it took around 30 min.
If youā€™re ok with modifying the manifest file for AMPā€¦ the comment in this bug report fixed it for me (upgrades alexa.py):
Am I the only one who upgraded and still see the old badges with no way to add new ones as shown here? Quite sure Iā€™m missing something but could not figure out whatā€¦
yes, these groups work with notify entities, and mobile_app doesnā€™t have these (yet) so cant be used with notify groups
I had also updates for my nanoleaf products.
It worked for me after I tried it a second time per each device. And only if I selected one at the same time.
maybe try to refresh your cache and check your frontend is truly on this version:
that was itā€¦ the browser cache. Didnā€™t think about it :sweat_smile:
thank you
Why are you commenting here? Post on the authorā€™s GitHub.
