FAQ - The Settings & Best Practice Guidelines
Trigger Sensor - Binary Sensors
The trigger sensors are responsible for turning the lights, switches, scenes, or scripts ON and OFF. You can choose any Binary Sensor you prefer as triggers. Alternatively, if you prefer a time-based trigger, you can also add a schedule
For more information + Pro Tips Click Here
On how to set up a schedule helper and a pro tip to use it with a sun condition please click here.
NOTE: When adding multiple trigger sensors, in particular a sensor that can remain in an ON state for long periods of time, it is recommended to group these sensors together as the automation will function correctly. Sometimes depending on many factors, just having 2 or more trigger sensors prevents the automation from function correctly and grouping these sensors together helps. For more information on how to set up group sensors please click here. If you would like to know more about groups and why we use them then please click here. Example of these sensors are;
- Presence sensor
- mm wave sensor
- Contact sensor
- Door sensor
- Window sensor
- Garage door sensor
- Motion sensors with long inbuilt delays
If you find your trigger is not triggering the automation then see below under âLights - Switches â Scenes - Scriptsâ.
If you would like to create a template trigger sensor so you can use it in the blueprint click here for some examples. This is a realy good read, and I would strongly recommend you take a look at it. This shows how you can make this blueprint even better. The âBee In The Hiveâ sensor is the one I realy love , it will take your automatons to the next level.
The lights, switches, scenes, and scripts that will be activated by the trigger sensor/s.
More information on scenes and scripts please click here
The automation exclusively supports entities. To conveniently locate your entities, you have the option to also select areas, devices and labels, providing a quick and easy method. Simply click the expand button " < > " as shown below. This expands your area, device or labels, allowing for a swift identification of your entities. Ensure your final selection is all green, containing only lights, switches, scenes, or script entities.
Areas
Devices
Labels
Entities
Scenes & Scripts - Toggle Helper
Scenes and scripts lack a discernible state within Home Assistant, making it challenging for the automation to determine their activation status. To address this, itâs recommended to use a toggle helper alongside scenes or scripts. This enables the automation system to recognize when a scene or script has been activated, ensuring smooth operation. When entering scenes or scripts in âLights - Switches - Scenes - Scriptsâ or âNight Light,â itâs advisable to create a dedicated toggle helper for each input.
If you would like to know how to create a toggle helper then please click here.
Scenes - Scripts To Turn OFF
If you have selected a scene or a script to be turned ON above in âLights - Switches - Scenes - Scriptsâ or below in âNight Lights,â and you would like it to be turned OFF after the time delay, then you must create a scene or a script with everything OFF and enter it here. See below example.
Time Delay
The time delay setting dictates how long the lights, switches, scenes, and scripts will remain active after all triggers have returned to their inactive state, effectively initiating the countdown to turn them off. Additionally, the time delay also acts as a buffer zone between trigger events, preventing the lights, switches, scenes, and scripts from turning off immediately when the trigger is deactivated. If you find that your lights are turning off and then back on again too quickly, consider extending the time delay. In cases where multiple trigger sensors are used and adjustments to the time delay arenât effective, grouping the trigger sensors may be necessary. Click here to learn more about grouping trigger sensors.
Light Control Options
This allows you to select what option you would like to control in your light entity.
- Brightness â Your light must be able to support brightness control by being able to dim the light in Home Assistant.
- Colour Temperature - Your light must be able to support colour temperature by being able to adjust the colour temperature in Home Assistant. Some LED lights that can change colour may also support colour temperature.
- Transition â If your lights support brightness or colour temperature then this is the time it will take to transition to the next state. A state change can be from OFF to ON, from ON to OFF, from normal lights to night lights and from night lights to normal lights.
For each option you select you also have the ability to adjust the setting. More information is next to each setting.
If you have selected an option and your light doesnât support it then the light will simply just turn ON.
Dynamic Lighting
This option aims to make continual adjustments in your lighting setup by modulating brightness according to floating lux values or adapting colour temperature and brightness based on the sunâs changing elevation. Choose from eight preset options available in the dropdown menu.
1 - Lux Controlled Brightness
2 - Lux Controlled Brightness Inverted
3 - Sun Elevation Lighting - Colour Temp
4 - Sun Elevation Lighting - Brightness
5 - Sun Elevation Lighting - Brightness Inverted
6 - Sun Elevation Lighting - Colour Temp + Brightness
7 - Sun Elevation Lighting - Colour Temp + Brightness Inverted
8 - Sun Elevation Lighting - Colour Temp + Lux Controlled Brightness
If you would like more information on dynamic lighting then please click here.
Trigger Sensor By-pass
The by-pass allows you to regain manual control your lights, switches and scenes. When you turn ON the by-pass the automation will be paused. When you turn OFF your by-pass the automation goes OFF pause. For the automation to work correctly the by-pass entity cannot be included in, âLights - Switches - Scenes - Scriptsâ and or âNight Lightsâ selections.
If you donât have a physical switch to use as a by-pass you can create one in Home Assistant that will allow you to use the by-pass. If you would like to create a by-pass switch in Home Assistant then follow the steps below.
How to Create a Bypass Without Using a Physical Switch and Add It to a Dashboard:
- Navigate to Settings > Devices & Services > Helpers.
- Click on the âHelpersâ tab, then click â+ CREATE HELPERâ and select âToggle.â
- Enter a name for the helper, such as âSensor Light Bypass,â and click save.
- Return to the automation settings.
- In the âUse The Bypass Options (Optional)â section, select an option youâd like to use.
- In the corresponding âBypass Switchâ field, search for and select the name you created earlier (e.g., âSensor Light Bypassâ).
- Click save to apply the changes.
How to Add a Bypass Switch to a Dashboard:
- Open your dashboard and click âEdit dashboard.â
- Click â+ ADD CARD,â then choose âButtonâ or âEntities.â
- In the entity field, search for the name (entity) you created earlier, such as âSensor Light Bypass.â
- Click save to add the card.
- Click âDONEâ to finalize the changes.
You now have a âSensor Light By-passâ switch to disable the trigger sensor of your sensor light automation.
There are also a few extra by-pass settings to set when using this option. More information is next to each setting.
By-pass 101 - For more information on the by-pass then please click here.
By-pass Auto OFF
This is used when you turn the by-pass ON and you would like the by-pass to automatically turn OFF in a set time delay.
It can also be used as a timer to turn the lights ON and then OFF if you have chosen to use âEnable the By-pass - Turn lights ONâ. When you turn ON the by-pass it will turn ON your light. When the by-pass turns OFF in its set time delay and the trigger is OFF it will turn your light OFF.
Global Conditions
All the conditions are global and can work alongside with the other conditions. You can select one or all of them but if enabled each condition must pass for the lights, switches or scenes to turn ON. Example: If you enable all of them and one of them has not been met, then the automation will not run.
Sun, ambient & time can also trigger your automation. This will only happen when the âtrigger Sensorâ is ON at the time the sensor crosses over it setting. Example: If your motion sensor is ON (motion detected) and you are using the sun as a condition, if the sun is above the âSun Elevationâ setting the light will be OFF. If the sun then crosses from above to below the âSun Elevationâ setting then the light will be turned ON. The same theory applies for ambient and time and also works for turning your lights ON and OFF.
Sun
This option is used to add a condition that only allows the automation to run when it is dark or below the âSun Elevationâ settings.
I thought about âSunsetâ and âSunriseâ but HA recommend using sun elevation as it works better throughout the year. So I took their advice and used the sun elevation.
If you would like more information on this and how to set it up correctly then please click here.
Ambient
This option is used to add a condition that only allows the automation to run when it is dark or below the âAmbientâ settings.
If youâre seeking more detailed information on the ambient settings, feel free to click here.
If you would like to use 2 or more ambient light sensors and would like to know how to set this up correctly then please click here.
Time
This option is used to add a condition that only allows the automation to run between the start time and end time settings on the selected weekdays.
If youâre seeking more detailed information on the time settings then please click here.
Device Tracker
Home Assistant can track the location of your devices (such as mobile phones) within a designated zone via the mobile app device tracker.
To utilize this option, you need to set up a zone and configure your devices for tracking in Home Assistant. There are two enable options available; âZoneâ tracks all devices within the zone, while âZone + Peopleâ allows you to track individuals within a zone.
This feature can be particularly useful if you have pets triggering the sensor, turning your lights ON and OFF when no one is home.
Night Lights
Night lights allow you to set different lights, switches, scenes or scripts by using a entity state, time or sun condition to choose when these lights will be active.
While some settings are similar to those of normal lights, night lights offer additional options tailored to nighttime lighting control. For further information on night light settings that resemble those of normal lights, please review the details provided above. However, for the unique settings exclusive to night lights, please see below.
Night Lights - Use The Light Control Options
- If lights are ON, adjust the lights when crossing over
Selecting âIf lights are ON, adjust the lights when crossing overâ option ensures that the light control settings will be applied to any lights that are already ON during the transition from normal lights to night lights and vice versa.
If the âIf lights are ON, adjust the lights when crossing overâ option is not selected, lights that are already ON when transitioning from normal lights to night lights will remain in their current state. This allows for situations where you may want the lights to stay on later at night or during gatherings without transitioning to night mode immediately. However, once these lights are turned OFF, the night mode settings will be applied the next time they are turned ON. While this option may suit some areas, it may not be preferred everywhere, providing you the flexibility to choose your desired scenario by simply ticking a box.
Regardless of whether this option is selected or not, if any lights are OFF during the transition from normal lights to night lights and their settings differ, they will either turn ON to the specified light control settings or turn OFF, depending on the configuration.
- Yes - Manage OFF script when crossing over
Selecting âYes - Manage OFF script when crossing overâ is beneficial for scripts containing if-then-else actions that toggle various functions on and off during the transition from normal lights to night lights and vice versa.
If youâre seeking more detailed information on scripts with a working example and would like to know how to set this up correctly then please click here.
Night Lights Conditions
If you choose to âEnable entity state optionâ the night lights will be active when the selected entity is ON. If you choose to âEnable time optionâ the night lights will be active during the set time period. If you choose to âEnable sun elevation optionâ the night lights will be active when the sun is below the âSun Elevationâ setting. You can enable both conditions if you like but they both must be met for the night lights to work.
Note: Night lights will still have to pass all the global conditions set for normal lights.
For more information on the entity state, then please click here.
For more information on the time settings, then please click here.
For more information on the sun settings, then please click here.
Hereâs a helpful tip: If you prefer softer, dimmer lights when using the bathroom at night, you can utilize the âNight Lightsâ feature. Simply configure one or more of the night lights conditions to activate during your typical sleeping hours. Then customize your light settings to your preference. Now, whenever you get up during the specified time period at night, your lights will automatically adjust to provide the desired ambiance.
Hope this helps to explain some of the settings
Enjoy
Blacky
Back to FAQ: Click Here
