DB image malformed. How to fix it?
Hi, after some hussel around sd card images (i.e. restoring snapshots) and some updates this errors occures:
2018-11-01 22:37:01 ERROR (SyncWorker_4) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT events.event_id AS events_event_id, events.event_type AS events_event_type, events.event_data AS events_event_data, events.origin AS events_origin, events.time_fired AS events_time_fired, events.created AS events_created, events.context_id AS events_context_id, events.context_user_id AS events_context_user_id \nFROM events LEFT OUTER JOIN states ON events.event_id = states.event_id \nWHERE events.event_type IN (?, ?, ?, ?, ?, ?) AND events.time_fired > ? AND events.time_fired < ? AND (states.last_updated = states.last_changed OR states.state_id IS NULL) ORDER BY events.time_fired'] [parameters: ('state_changed', 'logbook_entry', 'homeassistant_start', 'homeassistant_stop', 'alexa_smart_home', 'homekit_state_change', '2018-10-31 23:00:00.000000', '2018-11-01 23:00:00.000000')] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-11-01 22:37:02 ERROR (SyncWorker_4) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT events.event_id AS events_event_id, events.event_type AS events_event_type, events.event_data AS events_event_data, events.origin AS events_origin, events.time_fired AS events_time_fired, events.created AS events_created, events.context_id AS events_context_id, events.context_user_id AS events_context_user_id \nFROM events LEFT OUTER JOIN states ON events.event_id = states.event_id \nWHERE events.event_type IN (?, ?, ?, ?, ?, ?) AND events.time_fired > ? AND events.time_fired < ? AND (states.last_updated = states.last_changed OR states.state_id IS NULL) ORDER BY events.time_fired'] [parameters: ('state_changed', 'logbook_entry', 'homeassistant_start', 'homeassistant_stop', 'alexa_smart_home', 'homekit_state_change', '2018-10-31 23:00:00.000000', '2018-11-01 23:00:00.000000')] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-11-01 22:37:02 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/engine/base.py", line 1193, in _execute_context
    context)
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/engine/default.py", line 509, in do_execute
    cursor.execute(statement, parameters)
sqlite3.DatabaseError: database disk image is malformed
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 390, in start
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_app.py", line 366, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 106, in impl
    return await handler(request)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 66, in ban_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 68, in auth_middleware
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 113, in handle
    result = await result
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/logbook.py", line 155, in get
    return await hass.async_add_job(json_events)
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/logbook.py", line 153, in json_events
    _get_events(hass, self.config, start_day, end_day, entity_id)))
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/logbook.py", line 338, in _get_events
    events = execute(query)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/recorder/util.py", line 64, in execute
    (row.to_native() for row in qry)
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/orm/query.py", line 2988, in __iter__
    return self._execute_and_instances(context)
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/orm/query.py", line 3011, in _execute_and_instances
    result = conn.execute(querycontext.statement, self._params)
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/engine/base.py", line 948, in execute
    return meth(self, multiparams, params)
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/sql/elements.py", line 269, in _execute_on_connection
    return connection._execute_clauseelement(self, multiparams, params)
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/engine/base.py", line 1060, in _execute_clauseelement
    compiled_sql, distilled_params
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/engine/base.py", line 1200, in _execute_context
    context)
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/engine/base.py", line 1413, in _handle_dbapi_exception
    exc_info
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/util/compat.py", line 265, in raise_from_cause
    reraise(type(exception), exception, tb=exc_tb, cause=cause)
  File "/usr/local/lib/python3.6/site-packages/sqlalchemy/util/compat.py", line 248, in reraise
    raise value.with_traceback(tb)
    context)
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT events.event_id AS events_event_id, events.event_type AS events_event_type, events.event_data AS events_event_data, events.origin AS events_origin, events.time_fired AS events_time_fired, events.created AS events_created, events.context_id AS events_context_id, events.context_user_id AS events_context_user_id \nFROM events LEFT OUTER JOIN states ON events.event_id = states.event_id \nWHERE events.event_type IN (?, ?, ?, ?, ?, ?) AND events.time_fired > ? AND events.time_fired < ? AND (states.last_updated = states.last_changed OR states.state_id IS NULL) ORDER BY events.time_fired'] [parameters: ('state_changed', 'logbook_entry', 'homeassistant_start', 'homeassistant_stop', 'alexa_smart_home', 'homekit_state_change', '2018-10-31 23:00:00.000000', '2018-11-01 23:00:00.000000')] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-11-01 22:37:04 ERROR (SyncWorker_5) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT states.state_id AS states_state_id, states.domain AS states_domain, states.entity_id AS states_entity_id, states.state AS states_state, states.attributes AS states_attributes, states.event_id AS states_event_id, states.last_changed AS states_last_changed, states.last_updated AS states_last_updated, states.created AS states_created, states.context_id AS states_context_id, states.context_user_id AS states_context_user_id \nFROM states JOIN (SELECT max(states.state_id) AS max_state_id \nFROM states JOIN (SELECT states.entity_id AS max_entity_id, max(states.last_updated) AS max_last_updated \nFROM states \nWHERE states.last_updated >= ? AND states.last_updated < ? GROUP BY states.entity_id) AS anon_2 ON states.entity_id = anon_2.max_entity_id AND states.last_updated = anon_2.max_last_updated GROUP BY states.entity_id) AS anon_1 ON states.state_id = anon_1.max_state_id \nWHERE states.domain NOT IN (?, ?) AND states.domain NOT IN (?, ?)'] [parameters: ('2018-10-29 20:44:05.094442', '2018-10-31 23:00:00.000000', 'zone', 'scene', 'zone', 'scene')] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-11-01 22:37:05 ERROR (SyncWorker_5) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT states.state_id AS states_state_id, states.domain AS states_domain, states.entity_id AS states_entity_id, states.state AS states_state, states.attributes AS states_attributes, states.event_id AS states_event_id, states.last_changed AS states_last_changed, states.last_updated AS states_last_updated, states.created AS states_created, states.context_id AS states_context_id, states.context_user_id AS states_context_user_id \nFROM states JOIN (SELECT max(states.state_id) AS max_state_id \nFROM states JOIN (SELECT states.entity_id AS max_entity_id, max(states.last_updated) AS max_last_updated \nFROM states \nWHERE states.last_updated >= ? AND states.last_updated < ? GROUP BY states.entity_id) AS anon_2 ON states.entity_id = anon_2.max_entity_id AND states.last_updated = anon_2.max_last_updated GROUP BY states.entity_id) AS anon_1 ON states.state_id = anon_1.max_state_id \nWHERE states.domain NOT IN (?, ?) AND states.domain NOT IN (?, ?)'] [parameters: ('2018-10-29 20:44:05.094442', '2018-10-31 23:00:00.000000', 'zone', 'scene', 'zone', 'scene')] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-11-01 22:37:05 ERROR (MainThread) [aiohttp.server] Error handling request
    context)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/history.py", line 332, in get
    entity_ids, self.filters, include_start_time_state)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/history.py", line 93, in get_significant_states
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/history.py", line 239, in states_to_json
    for state in get_states(hass, start_time, entity_ids, filters=filters):
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/history.py", line 214, in get_states
    return [state for state in execute(query)
    context)
    exc_info
    context)
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT states.state_id AS states_state_id, states.domain AS states_domain, states.entity_id AS states_entity_id, states.state AS states_state, states.attributes AS states_attributes, states.event_id AS states_event_id, states.last_changed AS states_last_changed, states.last_updated AS states_last_updated, states.created AS states_created, states.context_id AS states_context_id, states.context_user_id AS states_context_user_id \nFROM states JOIN (SELECT max(states.state_id) AS max_state_id \nFROM states JOIN (SELECT states.entity_id AS max_entity_id, max(states.last_updated) AS max_last_updated \nFROM states \nWHERE states.last_updated >= ? AND states.last_updated < ? GROUP BY states.entity_id) AS anon_2 ON states.entity_id = anon_2.max_entity_id AND states.last_updated = anon_2.max_last_updated GROUP BY states.entity_id) AS anon_1 ON states.state_id = anon_1.max_state_id \nWHERE states.domain NOT IN (?, ?) AND states.domain NOT IN (?, ?)'] [parameters: ('2018-10-29 20:44:05.094442', '2018-10-31 23:00:00.000000', 'zone', 'scene', 'zone', 'scene')] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-11-01 22:37:17 WARNING (MainThread) [homeassistant.components.sensor] Updating mitemp_bt sensor took longer than the scheduled update interval 0:00:30
2018-11-01 22:37:23 ERROR (SyncWorker_17) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT states.state_id AS states_state_id, states.domain AS states_domain, states.entity_id AS states_entity_id, states.state AS states_state, states.attributes AS states_attributes, states.event_id AS states_event_id, states.last_changed AS states_last_changed, states.last_updated AS states_last_updated, states.created AS states_created, states.context_id AS states_context_id, states.context_user_id AS states_context_user_id \nFROM states JOIN (SELECT max(states.state_id) AS max_state_id \nFROM states JOIN (SELECT states.entity_id AS max_entity_id, max(states.last_updated) AS max_last_updated \nFROM states \nWHERE states.last_updated >= ? AND states.last_updated < ? GROUP BY states.entity_id) AS anon_2 ON states.entity_id = anon_2.max_entity_id AND states.last_updated = anon_2.max_last_updated GROUP BY states.entity_id) AS anon_1 ON states.state_id = anon_1.max_state_id \nWHERE states.domain NOT IN (?, ?) AND states.domain NOT IN (?, ?)'] [parameters: ('2018-10-29 20:44:05.094442', '2018-10-31 23:00:00.000000', 'zone', 'scene', 'zone', 'scene')] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-11-01 22:37:24 ERROR (MainThread) [aiohttp.server] Error handling request
    context)
    context)
    exc_info
    context)
2018-11-01 22:37:30 ERROR (SyncWorker_7) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT states.state_id AS states_state_id, states.domain AS states_domain, states.entity_id AS states_entity_id, states.state AS states_state, states.attributes AS states_attributes, states.event_id AS states_event_id, states.last_changed AS states_last_changed, states.last_updated AS states_last_updated, states.created AS states_created, states.context_id AS states_context_id, states.context_user_id AS states_context_user_id \nFROM states JOIN (SELECT max(states.state_id) AS max_state_id \nFROM states JOIN (SELECT states.entity_id AS max_entity_id, max(states.last_updated) AS max_last_updated \nFROM states \nWHERE states.last_updated >= ? AND states.last_updated < ? GROUP BY states.entity_id) AS anon_2 ON states.entity_id = anon_2.max_entity_id AND states.last_updated = anon_2.max_last_updated GROUP BY states.entity_id) AS anon_1 ON states.state_id = anon_1.max_state_id \nWHERE states.domain NOT IN (?, ?) AND states.domain NOT IN (?, ?)'] [parameters: ('2018-10-29 20:44:05.094442', '2018-10-31 23:00:00.000000', 'zone', 'scene', 'zone', 'scene')] (Background on this error at: http://sqlalche.me/e/4xp6)
2018-11-01 22:37:30 ERROR (MainThread) [aiohttp.server] Error handling request
    context)
    context)
    exc_info
    context)
Connected
I already tried to delete log file from /homeassistant/config/home-assistant.log, but this error still occures everytime I am trying to access History tab.
Any ideas please?
This has nothing to do with home-assistant.log. The file you want to delete is home-assistant_v2.db. That is the one containing the history database. If you delete it, and restart home-assistant it will recreate an empty database.
thanks, that did the trick!
Experiencing the same issue after SD card snapshot restore:
[SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id) VALUES (?, ?, ?, ?, ?, ?, ?)]
[parameters: ('state_changed', '{"entity_id": "sensor.power_consumption_phase_l2", "old_state": {"entity_id": "sensor.power_consumption_phase_l2", "state": "1.949", "attributes": {" ... (534 characters truncated) ... :00", "last_updated": "2019-06-14T07:47:40.495309+00:00", "context": {"id": "0d0214ec3fdb4f1db157e5f81379d396", "parent_id": null, "user_id": null}}}', 'LOCAL', '2019-06-14 07:47:40.495385', '2019-06-14 07:47:40.587635', '0d0214ec3fdb4f1db157e5f81379d396', None)]
As I understand correctly, deleting home-assistant_v2.db will lose my history?
Is there no way to repair the home-assistant_v2.db file and preserve my history data?
tx a lot :slight_smile:
For all ya googlers (or ducckduckgoers). I fixed mine!
  • shut down HA
  • via shell cd into config folder and execute:
sqlite3 ./home-assistant_v2.db ā€œ.dumpā€ | sqlite3 ./home-assistant_v2.db.fix
mv ./home-assistant_v2.db ./home-assistant_v2.db.broken
mv ./home-assistant_v2.db.fix ./home-assistant_v2.db
  • Start ha and check logs and history via ui if fixed
  • Delete home-assistant_v2.db.broken
Thanks @eddriesen for posting this!
However, the command sqlite3 ./home-assistant_v2.db ā€œ.dumpā€ | sqlite3 ./home-assistant_v2.db.fix generates an error in my case: -bash: sqlite3: command not found
Do you have any clue how to solve this?
Might have an older sqlite? Type sqli and hit tab a few times. Might of be that your platform had another version installed.
It did it outside of the container Shell, via host os Shell in /var/lib/docker/volumes/havolumename/_data/ because my host os had sqlite 3 installed.
If not, install it via your guest/host os. Example ā€œapt install sqlite3ā€
Thanks again @eddriesen. I’m using Hass.io on a raspberry pi. I couldn’t figure out how to install sqlite3 in that ā€˜OS’. Seems that this is really beyond my current knowledge level. For now I think I just leave it. I made a backup of the database, deleted it and let Hass.io create a new database. It’s a pity I cannot see my old data anymore in Home Assistant, but it’s not critical.
Thank you, it save my logs :slight_smile:
Same issue here after I needed to restore from a snapshot image so seems to be a common thing. Deleting home-assistant_v2.db did the trick.
Not working for me… really pisses me off
In hassio i cant install sqlite3. For this reason i have used windows:
First stop hassio than:
  1. Download sqlite3 browser from https://sqlitebrowser.org/dl/
  2. Apening home-assistant_v2.db with thsi program
  3. On the menù export create a sql file
  4. Close and reopen sqlitebrowser
  5. On the menu import select the sql created before
  6. Create a new db file
  7. Copy the new db in /config of hassio
  8. Rename broken db file in hassio
  9. rename new db file to home-assistant_v2.db
  10. start hassio
Yes but so you lost the history
is there no chance to install sqlite on the hass.io raspberry image?!
i’m also stucked in this
Faced same issue
But after deleting home-assistant_v2.db (renamed) Im unable to connect to my HA over SSH and HTTP, even its pingable
Any suggestions?
UPD: First issue on connected monitor - ā€œFailed to mount HassOS overlay partitionā€
UPD2: Fixed with checking filesystem tool (ExtFS Paragon for MacOS)
If you are using hassio then sqlite3 can be installed from the CLI of the docker instance itself (install the ssh add on from the hass web interface) using
apk add sqlite
then you can continue and follow the instructions given by @eddriesen
Little update;
After another corrupt db and bad overall performance (i have a LOT of sensors) i just went with mysql which was allready installed and used on the host system. Much faster at rendering history now!
Thanks @redlegoman!
meanwhile I figured out annother way (inspired by the posts of @eddriesen and @antoweb76:
  1. Stop HA via the SSH CLI using hassio ha stop
  2. Move the database-file to my windows computer using samba
  3. download sqlite CLI for windows from https://www.sqlite.org/download.html
  4. perform sqlite3 ./home-assistant_v2.db_old ".dump" | sqlite3 ./home-assistant_v2.db_fix
  5. move the new db-file back using samba
  6. rename the db-file (remove the _fix part)
  7. re-start HA via the SSH CLI using hassio ha start
Your solution seems even more simple though and I managed to install sqlite the way you mentioned. I’ll try it next time :smirk:
@eddriesen - could you expand please? It looks to me like the engine is installed within the docker as I had to install it to fix the database.
I ended up with a zero size ā€˜fix’ file so I’m guessing the whole file is goosed!
