Create a bug ticket with example and images and infos, because should be fixed here:
@MelleD is it possible to Change the color from the First Line when he is expand to see that he is expand (nicer to see)? Like in collapse card
Not sure what you mean. Do you have an example?
here you the the expand first row has a different color but only when it is expand, whould be cool when you can integration this.
a) Create a feature request for the default title card
b) use e.g. a mushroom-template-card as title card and then you can use card mod
see Mushroom Cards Card Mod Styling/Config Guide
title-card:
type: custom:mushroom-template-card
primary: "Räume"
icon: "mdi-broom"
icon_color: "blue"
card_mod:
style: |
ha-card {
background-color: #002f7a;
card_mod i knows, but this is not possible when i wanna it only when the card is expand, but i create a feature request
Is your picture from another integration or you just hover over it during the picture?
it is from an other integration to visualise
Which integration? Maybe I can look there for a solution
Collapsable cards
Mhm can you not send just a link?
Any way to make the expander card smaller? There’s way to much space between the expander and the bubble separator card under it right now.
Yes you can play with the different margin options. See in the README the table with all options
Thank you, played around with it and thought i had tried it all. I’m the one who wrote on Github earlier about the refreshing by the way. Found out that i had the other expander card. Your version is working like it should.
That’s what @paddy0174 said. Maybe I should start a new Thread
Created new topic here: Expander | Accordion | Collapsible Card
Can you share a code ?
Is it just me or after the update to 0.1.0 it doesn’t work? It doesn’t recognize the custom element…
Updated and broken here too. I’ve checked config and all looks good.
