Hörmann garage door via MQTT
Hi ,
I have also released a version based on the one of pboschi.
GitHub - 14yannick/HCPBridgeMqtt at development I added a switch to put my garage in venting position. I had to put a small hack to make it work with as my motor didn’t return the status “venting”. in the hciemulator.h the param #define VENT_POS 0x08 is set to 08 because my door is in the position when venting. If it don’t work out of the box maybe you have to adjust the value with your venting position. The read.me is not updated yes. Feel free to open an issue if you have some trouble.
I have compiled the binary flashed to esp and still do not see access point. Any hints?
Thanks this was the culprit… I was mad why it not getting flashed :rofl: should be added to github
Hi again.
I’m trying to set up an order on PCBWay based on the files in your github repo, but they keep asking about a BOM file (Bill of Materials) in excel format
Do you have a file like that? Or can I generate one myself based on some other file in your repo?
In my repo you can find a BOM here.
But you have to convert it to the format PCBWay requires it. You maybe also have to add additional infos.
Hey man,
Sorry for bumping this thread. Do you still have one? I have a E4 too.
Thanks,
Hi everyone, thanks for all the great work in this Thread!
I recently got a new Garage Door with an E4 Motor and was searching for exactly such an adapter.
Just ordered some PCBs, if it works well i will sell the other PCBs either raw or fully assembled inside Europe for Costs of Parts+a Coffee.
regards,
Manuel
I’m sorry but I need to bother you some more with this.
The parts list contains over 50 lines, but I guess it’s not 50 parts we are talking about.
If I sort the lists after what is named Device, I count 16 different parts, which is more plausible.
But it says nothing how many items of each part.
And what is the Value field for?
I’m confused
Let me know, I’d possibly like to buy an fully assembled one :slight_smile:
Currently waiting on the PCBs and parts, will keep you all updated when i got them ready and have a Price :slight_smile:
I have a ProMatic 4, which should have the same interface.
If anyone is selling an assemble PCB I’d be happy to buy one.
Right now I don’t have the energy to chase down parts, so preferably assembled but a DIY all-in kit is also acceptable.
Many thanks for your post and linking to Hörmann garage door via MQTT - #83 by virtualdj
I’ve been wanting a garage door open/closed sensor in HA for a while but all the hardware that seemed to be involved put me right off. After reading your post, following a few links and installing the Passive BLE Monitor integration I have garage door open and close status in HA (via RPi onboard bluetooth interface).
The integration automatically detected the door opener and created three sensors.
What a result - thank you and to @Ernst for the integration.
Got my PCBs today, will tell you all a Price and place to order soon.
UPDATE: Was able to get my first PCB Working with my ProMatic 4, but i’m still trying to find the best Fork, any tips are welcome :slight_smile: Also the red blinking LED (it’s i known Bug i have read) is strange, something can’t be correct with that.
Got the RJ12 Sockets today and with that the last parts missing for my PCBs. If anyone needs a PCB or a complete Unit inside the EU just send me a DM.
A complete & tested Unit including the ESP32 and a 30cm RJ12 Cable will be 35€ without Shipping.
Shipping via DHL with tracking would be 5€ inside Germany, rest of EU 13€. Cheaper rates without tracking on Request.
Here are some images:
And of course a big thank you to @vladimirzrnic for the PCB Design and everyone that worked/works on the Software! great work!
I currenlty use the following Software on my Board:
regards,
Manuel
UPDATE: All Units of this Batch are Sold
Does this site even have DMs? o_O Or do you mean on Discord or Twitter or something?
@Dal , you are talking about this list?
The BOM consists of 58 parts but not 58 different parts.
Value is the most important field. 10k e.g. means a 10k resistor, but only in combination with the package field you know which one (know its size). To be honest there are even more parmaters like e.g. accuracy and temperature drift but this is just a hobbiest project so i didn’t specify them all.
Only parts where Value, Device and Package are equal are one and the same part.
yes there are DMs on here or over Twitter, my user there is also @Tysonpower :slight_smile:
Well I certainly can’t find the button for it here, so I threw you a DM on Twitter
Hey guys, is there a summary of this topic?
I have a ProMatic 4 and was wondering if there is a plug and play solution for it?
Or maybe a repo I can visit.
I have seen a lot of repos here but im losing my bearings with ProMatic 3.4.
I still have some assembled boards left if you wan’t to buy a plug and play solution.
You only need to flash the firmware with your wifi and MQTT credentials.
Here is the Post: Hörmann garage door via MQTT - #242 by Tysonpower
