- Version: 1.0 -
Managing a door contact
In this blueprint I try to exploit a sensor port for multiple uses.
Automation is divided into two parts:
- Turns on a light when the door is opened for a customizable time by following rules:
- Let it be after sunset
- You can insert switch and light
- The light is turned on/off only if the initial state was not on
- The light is turned off after a customizable time that starts from the moment the door is closed
- Receive an alert in case the door was left open for a customizable time:
- You can decide whether to enable push notification.
- You can decide whether to enable TTS notification.
- You can decide whether to enable Alexa notification.
- You can customize the text of the notification.
- You can opt out of receiving alerts by not enabling any of the notify services
Requirements:
In order to use the project:
- The door sensor must be device_class: door: If the senor does not have the device_class indicated, you can set it from settings-devices and services-entities-select entity and set port to show-like
Installation
To be able to install the blueprint you can import it tramitè the dedicated button or alternatively you can compiare the file in the path \config\blueprints\automation
MY OTHER BLUEPRINTS
Never without power again
Automatic air conditioner
Alexa actionable notification rooms presence
