Power control --Never without power again
Consumption control and appliance management
- Version: 1.1 -
As an alternative to blueperint you can choose to use the pkg
This project was done for shutting down household appliances by checking the instantaneous absorption in the house, to avoid the general meter shutdown.
When the instantaneous consumption is greater than the set value, for a customizable time, automation comes into play that performs checks to the selected entities:
  • If the entity is available and not in on.
  • If the entity’s device is associated with a sensor with device class power it will check if the power draw is greater than 15 w. If less, the device is considered off, otherwise on and will be added to the list of devices to be turned off. In the absence of the device_class it will just see the status of the group entity (on/off).
    This in my opinion is a nice part of the project because we imagine that we are controlling a washing machine, generally we leave the switch on, even if the washing machine is off and thanks to the absorption control we can see if it is really running.
Once filtered the appliances will start to turn off one at a time respecting the order of the selection and the set waiting time.
When the process is finished and consumption is within limits for a customizable time, the turned off appliances will be turned back on (from the last one turned off to the first one).
You can receive a notification for each automation step (Push, TTS, Alex).
Installation
As a first step, you need to enter the pkg_consumption_control_and_appliance_management.yaml in the folder package, restart HomeAssistant and import the project.
In case you cannot import the file into the packages it is possible to replicate the entities maintaining the entity_id.
group:
list_loads:
  entities:
input_boolean:
off_on_detachment:
  initial: 'off'
input_text:
list_loads:
  initial: 'none'
  max: 255
Changelog
Version: 1.1
  • Only the text selector has been eliminated and replaced with a select that allows language selection in English and Italian.
  • Changed input descriptions with Italian, English translation
MY OTHER BLUEPRINTS
Managing a door contact
Automatic air conditioner
Alexa actionable notification rooms presence
Reminders with actionable Alexa and push notifications
Very Nice. Thank you Marco
Hi Luca! I was using an old version of your Power Control System, the one with input_text selectors, which allowed to select differently switch and sensors for each and every power load and that was turning off an on the loads based on their actual level. Is this feature not available anymore? I saw in your git-hub that you mention: “If the entity’s device is associated with a sensor with device class power it will check if the power draw is greater than 15 w . If less, the device is considered off, otherwise on and will be added to the list of devices to be turned off. In the absence of the device_class it will just see the status of the group entity (on/off).” → what do you mean by “associated with a sensor…”?
Thanks and well done!
Lorenzo
if a sensor with device class power is present among the device entities
The package has been updated to version 2.0 with some new features.
there is a new version 2.1 of the original blueprint. Can you update it?
not the blueprint has been updated but the package
