Love the fact this gives me practically an extra chip to play with Only question is how would I go about adding a light count to display on the lightbulb entity? Cheers!
Give this a try:
badge_icon: |
{% if states(entity) == 'on' %}
mdi:numeric-{{expand(state_attr(entity, 'entity_id'))| selectattr('state','eq','on')|map(attribute='entity_id')|list|count}}
badge_color: |
red
It kind of butts up against the edges of the card so you may want to slightly adjust the card-mod section to move the bulb and chips slightly down
ha-card {
width: 66px;
margin-left: 68%;
top: -176px;
background: none;
Changing it from -178 to -176 should do the trick
Did you ever figure this out. I am in the same position. Don’t know what to do with the excess code.
Friend, can you help me?
How did you create “update.wud_container_local_adguardhome”?
I would love to use your system on my home assistant, but I’m quite new to home. Could you explain me? I’ve replaced the switch.docker_cloudflared_tunnel id with mine, but it looks like “update.wud_container_local_adguardhome” is a custom entity being used to control or monitor the update state of a specific Docker container called “adguardhome”.
Help me create this entity?
Guys, please… As stated in the first post,
this thread is for showing-off, what you have achieved with Mushroom. If you have any questions, please ask them in the corresponding mushroom thread, that you can find here:
Thanks a lot!
Thank you for the code
Is it possible to get it full?
And how can the cubes be made - I need 4 but not one under the other I want one next to the other
Mushroom-Internet-State-Card
Made with Mushroom-Card and Button-Card.
The card shows
- the state of my internet-connection (binary_sensor from fritz.box)
- a button to toggle guest-wifi (switch from fritz.box)
- the upload, download and ping (sensors from speedtest.net)
The Download, Upload and Ping Icons turn green (good), orange (average) or red (poor) matching your rules in the “variables”-section.
You just to need to fill in your entities in the “variables:”-section.
YAML-Code
(little update - just found out that i need to add “triggers_update” so that updates to the entities will show as they happen)
type: custom:button-card
variables:
internet_state: binary_sensor.fb_keller_connection
wifi_switch: switch.fb_keller_wi_fi_guestwifi
download_state: sensor.speedtest_download
upload_state: sensor.speedtest_upload
ping_state: sensor.speedtest_ping
download_good_above: 350
download_average_above: 200
download_poor_below: 200
upload_good_above: 150
upload_average_above: 100
upload_poor_below: 100
ping_good_below: 20
ping_average_below: 40
ping_poor_above: 40
triggers_update:
- '[[[ return variables.internet_state ]]]'
- '[[[ return variables.wifi_switch ]]]'
- '[[[ return variables.download_state ]]]'
- '[[[ return variables.upload_state ]]]'
- '[[[ return variables.ping_state ]]]'
show_name: false
show_state: false
show_icon: false
styles:
card:
- padding: 3px
grid:
- grid-template-areas: '"oben" "unten"'
- grid-template-columns: auto
- grid-template-rows: 1fr 1fr
custom_fields:
oben:
- filter: opacity(100%)
- overflow: visible
unten:
- overflow: visible
custom_fields:
oben:
card:
type: custom:mushroom-template-card
entity: '[[[ return variables.internet_state ]]]'
tap_action:
action: navigate
navigation_path: /lovelace/internet
icon: |
{% if is_state(entity, "on") %}
mdi:web-check
{% elif is_state(entity, "off") %}
mdi:web-cancel
icon_color: |
green
red
primary: |
online
offline
secondary: '{{ state_attr(entity,"friendly_name") }}'
card_mod:
style: |
ha-card {
padding: 0px !important;
padding-bottom: 3px !important;
text-align: left !important;
border: none !important;
box-shadow: none !important;
unten:
card:
type: grid
columns: 4
square: false
cards:
- type: custom:button-card
entity: '[[[ return variables.wifi_switch ]]]'
layout: icon_state
show_name: false
show_state: true
show_label: true
label: Gast
state:
- value: 'on'
state_display: an
styles:
icon:
- color: green
- value: 'off'
state_display: aus
styles:
icon:
- color: darkcyan
state:
- font-size: 0.7rem
- font-weight: bold
label:
- font-size: 0.7rem
card:
- background: rgba(var(--rgb-primary-text-color), 0.05)
- height: 3rem
- border: none
- box-shadow: none
entity: '[[[ return variables.download_state ]]]'
layout: icon_state
show_name: false
show_state: true
show_label: true
label: Mbit/s
state_display: >-
[[[ return
Math.round(Number(states[variables.download_state].state)).toFixed(0);
state:
- value: '[[[ return variables.download_good_above ]]]'
operator: ">"
styles:
icon:
- color: green
- value: '[[[ return variables.download_average_above ]]]'
operator: ">="
styles:
icon:
- color: darkorange
- value: '[[[ return variables.download_poor_below ]]]'
operator: "<"
styles:
icon:
- color: red
styles:
state:
- font-size: 0.7rem
- font-weight: bold
label:
- font-size: 0.7rem
card:
- height: 3rem
- border: none
- box-shadow: none
entity: '[[[ return variables.upload_state ]]]'
layout: icon_state
show_name: false
show_state: true
show_label: true
label: Mbit/s
state_display: >-
[[[ return
Math.round(Number(states[variables.upload_state].state)).toFixed(0);
state:
- value: '[[[ return variables.upload_good_above ]]]'
operator: ">"
styles:
icon:
- color: green
- value: '[[[ return variables.upload_average_above ]]]'
operator: ">="
styles:
icon:
- color: darkorange
- value: '[[[ return variables.upload_poor_below ]]]'
operator: "<"
styles:
icon:
- color: red
styles:
state:
- font-size: 0.7rem
- font-weight: bold
label:
- font-size: 0.7rem
card:
- height: 3rem
- border: none
- box-shadow: none
entity: '[[[ return variables.ping_state ]]]'
layout: icon_state
show_name: false
show_state: true
show_label: true
label: ms
state_display: >-
[[[ return
Math.round(Number(states[variables.ping_state].state)).toFixed(0);
state:
- value: '[[[ return variables.ping_good_below ]]]'
operator: "<"
styles:
icon:
- color: green
- value: '[[[ return variables.ping_average_below ]]]'
operator: "<="
styles:
icon:
- color: darkorange
- value: '[[[ return variables.ping_poor_above ]]]'
operator: ">"
styles:
icon:
- color: red
styles:
state:
- font-size: 0.7rem
- font-weight: bold
label:
- font-size: 0.7rem
card:
- height: 3rem
- border: none
- box-shadow: none
You can also have the cards above in this way
All you need to to ist to change this
grid:
- grid-template-columns: 100%
- grid-template-rows: 1.3fr 1fr
to that
grid:
- grid-template-areas: '"oben unten"'
- grid-template-columns: 1fr 1fr
- grid-template-rows: 100%
Mushroom-Printer-State-Card
The card shows
- the state of my printer (sensor from IPP-Integration)
- the fill of the toners Cyan, Magenta, Yellow, Black (sensors from IPP-Integration)
YAML-Code
variables:
printer_state: sensor.ecosys_m5521cdn
c_state: sensor.ecosys_m5521cdn_cyan_tk_5230cs
y_state: sensor.ecosys_m5521cdn_yellow_tk_5230y
m_state: sensor.ecosys_m5521cdn_magenta_tk_5230m
k_state: sensor.ecosys_m5521cdn_black_tk_5230k
triggers_update:
- '[[[ return variables.printer_state ]]]'
- '[[[ return variables.c_state ]]]'
- '[[[ return variables.y_state ]]]'
- '[[[ return variables.m_state ]]]'
- '[[[ return variables.k_state ]]]'
show_name: false
show_state: false
show_icon: false
styles:
card:
- padding: 3px
grid:
custom_fields:
oben:
- overflow: visible
unten:
- overflow: visible
custom_fields:
oben:
card:
type: custom:mushroom-entity-card
entity: '[[[ return variables.printer_state ]]]'
tap_action:
action: more-info
icon: mdi:printer-outline
card_mod:
style: |
ha-card {
unten:
card:
type: grid
columns: 4
square: false
cards:
entity: '[[[ return variables.k_state ]]]'
layout: icon_state
styles:
icon:
- color: DimGray
state:
- font-size: 0.7rem
- font-weight: bold
label:
- font-size: 0.7rem
card:
- height: 3rem
show_name: false
show_state: true
show_label: true
label: >-
[[[ return states[variables.k_state].attributes.friendly_name
state_display: >-
[[[ return
Math.round(Number(states[variables.k_state].state)).toFixed(0) +
states[variables.k_state].attributes.unit_of_measurement; ]]]
icon: mdi:water
card_mod:
style: |
ha-card {
padding: 3px !important;
margin: 0px !important;
entity: '[[[ return variables.c_state ]]]'
layout: icon_state
styles:
icon:
- color: darkcyan
state:
- font-size: 0.7rem
- font-weight: bold
label:
- font-size: 0.7rem
card:
- height: 3rem
show_name: false
show_state: true
show_label: true
label: >-
[[[ return states[variables.c_state].attributes.friendly_name
state_display: >-
[[[ return
Math.round(Number(states[variables.c_state].state)).toFixed(0) +
states[variables.c_state].attributes.unit_of_measurement; ]]]
icon: mdi:water
card_mod:
style: |
ha-card {
entity: '[[[ return variables.m_state ]]]'
layout: icon_state
styles:
icon:
- color: darkmagenta
state:
- font-size: 0.7rem
- font-weight: bold
label:
- font-size: 0.7rem
card:
- height: 3rem
show_name: false
show_state: true
show_label: true
label: >-
[[[ return states[variables.m_state].attributes.friendly_name
state_display: >-
[[[ return
Math.round(Number(states[variables.m_state].state)).toFixed(0) +
states[variables.m_state].attributes.unit_of_measurement; ]]]
icon: mdi:water
card_mod:
style: |
ha-card {
entity: '[[[ return variables.y_state ]]]'
layout: icon_state
styles:
icon:
- color: darkorange
state:
- font-size: 0.7rem
- font-weight: bold
label:
- font-size: 0.7rem
card:
- height: 3rem
show_name: false
show_state: true
show_label: true
label: >-
[[[ return states[variables.y_state].attributes.friendly_name
state_display: >-
[[[ return
Math.round(Number(states[variables.y_state].state)).toFixed(0) +
states[variables.y_state].attributes.unit_of_measurement; ]]]
icon: mdi:water
card_mod:
style: |
ha-card {
grid:
to that
grid:
Mushroom-Desk-Card
The card shows
- the state of my desk (height-sensor from this ESP-Home-Project → [No issue] working setup for Home Assistant + ESPHome + esp32dev + CB28M1B-1 + HS13A-1 · Issue #30 · iMicknl/LoctekMotion_IoT · GitHub)
- Buttons for UP (switch-entity), PAUSE (script) and DOWN (switch-entity) (Pause needs an script to swith UP and DOWN to “off”)
- Buttons for SIT and STAND-positions (button-entities)
YAML-Code
(little update - just found out that i need to add “triggers_update” so that updates to the entities will show as they happen - also changed the “mushroom”-card a little bit)
variables:
desk_cover: cover.desk
desk_height: sensor.desk_height
up_switch: switch.up
down_switch: switch.down
stop_script: script.schreibtisch_anhalten
sit_button: button.sit
stand_button: button.stand
triggers_update:
- '[[[ return variables.desk_cover ]]]'
- '[[[ return variables.desk_height ]]]'
- '[[[ return variables.up_switch ]]]'
- '[[[ return variables.stop_script ]]]'
- '[[[ return variables.sit_button ]]]'
- '[[[ return variables.stand_button ]]]'
show_name: false
show_state: false
show_icon: false
styles:
card:
- padding: 3px
grid:
custom_fields:
oben:
- overflow: visible
unten:
- overflow: visible
custom_fields:
oben:
card:
entity: '[[[ return variables.desk_height ]]]'
tap_action:
action: more-info
entity: '[[[ return variables.desk_cover ]]]'
icon_color: blue
primary: '{{ state_attr(entity,"friendly_name") }}'
secondary: '{{ states(entity) }} {{ state_attr(entity,"unit_of_measurement") }}'
icon: '{{ state_attr(entity,"icon") }}'
card_mod:
style: |
ha-card {
unten:
card:
type: grid
columns: 5
square: false
cards:
tap_action:
action: call-service
service: switch.turn_on
service_data:
entity_id: '[[[ return variables.down_switch ]]]'
show_state: false
show_name: false
show_icon: true
icon: mdi:arrow-down
styles:
card:
- padding: 3px
- height: 3rem
- box-shadow: none
- border: none
icon:
- height: 1.5rem
- width: 1.5rem
tap_action:
service: '[[[ return variables.stop_script ]]]'
show_state: false
show_name: false
show_icon: true
icon: mdi:pause
styles:
card:
- padding: 3px
- height: 3rem
- box-shadow: none
- border: none
icon:
- height: 1.5rem
- width: 1.5rem
tap_action:
service_data:
entity_id: '[[[ return variables.up_switch ]]]'
show_state: false
show_name: false
show_icon: true
icon: mdi:arrow-up
styles:
card:
- padding: 3px
- height: 3rem
- box-shadow: none
- border: none
icon:
- height: 1.5rem
- width: 1.5rem
tap_action:
service: button.press
service_data:
entity_id: '[[[ return variables.sit_button ]]]'
show_state: false
show_name: false
show_icon: true
icon: mdi:chair-rolling
styles:
card:
- padding: 3px
- height: 3rem
- box-shadow: none
- border: none
icon:
- height: 1.5rem
- width: 1.5rem
tap_action:
service_data:
entity_id: '[[[ return variables.stand_button ]]]'
show_state: false
show_name: false
show_icon: true
icon: mdi:human-handsup
styles:
card:
- padding: 3px
- height: 3rem
- box-shadow: none
- border: none
icon:
- height: 1.5rem
- width: 1.5rem
grid:
to that
grid:
How can delete the shadows behind the squares? I’m trying and nothing at all! Can you help me because it’s perfect for mine but I don’t want the shadows. Thanks!
A quote from the first post, and some other in between the thread:
Mushroom-Bar-Card
Why this card when there is a mushroom-number-card?
I wanted to have a card to display a number value on a bar, but has no option to change the value.
Made with Mushroom-Card, Button-Card and Bar-Card.
The card shows
- the state of a sensor entity in relation to a “max”-entity
- a bar with the state of an entity in relation to a “max”-entity
YAML-Code
entity: sensor.stromeinspeisung_kwh_bisher
variables:
max_entity: input_select.senec_cloud # the entity, that has the "max"-value
name: '[[[ return entity.attributes.friendly_name ]]]' # name to display (defaults to the entities friendly-name)
color: purple # the color the bar and mushroom-card shut be (attention: mushroom-cards dont accept all color names!)
units: '[[[ return entity.attributes.unit_of_measurement ]]]' # the unit of measurement to display (defaults to the unit of measurement of the entity)
icon: mdi:cloud-arrow-up-outline # the icon the mushroom-card should have
show_name: false
show_state: false
show_icon: false
styles:
card:
- padding: 3px
grid:
- grid-template-areas: '"mush bar"'
custom_fields:
mush:
- overflow: visible
bar:
- overflow: visible
custom_fields:
mush:
card:
tap_action:
action: more-info
entity: '[[[ return entity.entity_id ]]]'
icon_color: '[[[ return variables.color ]]]'
secondary: '[[[ return variables.name ]]]'
primary: >-
[[[ return entity.state + "/" + states[variables.max_entity].state +
" " + variables.units ]]]
icon: '[[[ return variables.icon ]]]'
card_mod:
style: |
ha-card {
background: none !important;
bar:
card:
type: custom:bar-card
max: '[[[ return states[variables.max_entity].state ]]]'
min: 0
unit_of_measurement: >-
[[[ return "/ " + states[variables.max_entity].state + " " +
variables.units ]]]
decimal: 0
entity_row: true
positions:
icon: 'off'
indicator: 'off'
minmax: inside
title: 'off'
value: 'off'
style: |-
.contentbar-direction-right {
flex-direction: row;
bar-card-contentbar {
align-items: flex-end;
display: flex;
justify-content: space-between;
bar-card-backgroundbar, bar-card-currentbar {
left: 0px !important;
bar-card-iconbar {
color: white;
bar-card-name {
margin-top: 2px;
margin-bottom: 2px;
margin-left: 2px;
margin-right: 2px;
font-size: 1em;
font-weight: bold;
color: white;
bar-card-value {
margin-top: 2px;
margin-bottom: 2px;
margin-left: 2px;
margin-right: 2px;
font-size: 1em;
font-weight: bold;
color: white;
bar-card-max {
display: none;
bar-card-divider {
display: none;
.min-direction-right {
display: none;
grid:
to that:
grid:
- grid-template-areas: '"mush" "bar"'
would be wonderfull if you shared how you did that in code.
Maybe a bit off-topic but i think my energie-card fits perfectly to my mushroom-cards dashboard, so here is my
Energy-Dashboard-Card
For this you will need:
- Mushroom-Card (HACS)
- Button-Card
- Apexcharts-Card (HACS)
- Sankey-Card (HACS)
- Stack in a Card (HACS)
- Energy Period Selector Plus (Custom HACS)
This Icons has a link to another Tab in Home Assistant with a full-screen-view of the Apex-Charts-Card
These Chip-Cards Link to Subviews for Electrical Energy, Gas and Water-Usage.
type: grid
columns: 1
square: false
cards:
chips:
- type: template
content: Energie
icon: mdi:home-import-outline
tap_action: none
card_mod:
style: |
ha-card {
font-size: 3.5rem !important;
- type: template
content: Strom
icon: mdi:lightning-bolt-circle
icon_color: orange
tap_action:
action: navigate
navigation_path: /lovelace/energie-dashboard
- type: template
content: Wasser
icon: mdi:waves
icon_color: blue
tap_action:
action: navigate
navigation_path: /lovelace/wasser
- type: template
content: Gas
icon: mdi:gas-burner
icon_color: purple
tap_action:
action: navigate
navigation_path: /lovelace/gas
- type: custom:stack-in-card
card_mod:
style: |
ha-card {
padding: 0px;
mode: vertical
keep:
background: true
border_radius: true
box_shadow: true
margin: true
outer_padding: true
cards:
- type: horizontal-stack
cards:
- type: custom:apexcharts-card
card_mod:
style: |
ha-card {
padding: 0px 0px 0px 0px;
border: none;
box-shadow: none;
margin-bottom: -15px;
#state__value > #state {
font-size: 1.2em !important;
.apexcharts-tooltip-series-group {
padding-top: 0px !important;
padding-bottom: 0px !important;
margin-top: 0px !important;
margin-bottom: 0px !important;
display: none;
text-align: left;
justify-content: left;
align-items: center;
#header {
apex_config:
chart:
height: 120px
legend:
show: false
tooltip:
items:
display: flex
title:
text: Stromverbrauch
align: center
margin: 0
offsetX: 0
offsetY: 15
floating: true
style:
fontSize: 1rem
fontWeight: bold
color: var(--primary-text-color)
yaxis:
- min: ~0
max: ~500
decimals: 0
apex_config:
tickAmount: 4
forceNiceScale: true
title:
text: W
rotate: 0
all_series_config:
stroke_width: 2
float_precision: 0
show:
in_header: raw
legend_value: false
type: area
opacity: 0.2
statistics:
type: mean
period: 5minute
span:
end: minute
graph_span: 24h
header:
show: false
title: ''
show_states: true
colorize_states: true
standard_format: true
floating: true
series:
- entity: sensor.senec_house_power
color: grey
- entity: sensor.senec_solar_generated_power
color: var(--energy-solar-color)
- entity: sensor.senec_grid_imported_power
color: var(--energy-grid-consumption-color)
- entity: sensor.senec_battery_import_power
color: var(--energy-battery-out-color)
invert: true
- entity: sensor.senec_battery_export_power
color: var(--energy-battery-in-color)
- entity: sensor.senec_grid_exported_power
color: var(--energy-grid-return-color)
invert: true
tap_action:
action: navigate
navigation_path: /lovelace/energie-aktuell
icon: mdi:magnify-expand
styles:
card:
- width: 3.5rem
- border: none
- box-shadow: none
- margin-left: '-40px'
- type: custom:sankey-chart
show_names: true
show_icons: false
wide: true
round: 0
height: 70
show_units: true
min_box_height: 10
card_mod:
style: |
ha-card {
background: var(card-background-color);
padding: 0px;
#border-radius: 0px;
font-size: 0.8rem;
font-weight: bold;
border: none;
box-shadow: none;
overflow-x: clip !important;
.container {
sections:
- entities:
- entity_id: sensor.senec_solar_generated_power
children:
- sensor.senec_solar_house_used_power
- sensor.produced_power_produktionsueberschuss
- entity_id: sensor.senec_grid_imported_power
children:
- sensor.senec_grid_house_used_power
- entity_id: sensor.senec_battery_export_power
children:
- sensor.senec_battery_house_used_power
- sensor.senec_grid_exported_power
- entities:
- entity_id: sensor.senec_solar_house_used_power
children:
- sensor.senec_house_power
- sensor.shelly_pool_energy_power
- entity_id: sensor.senec_grid_house_used_power
type: passthrough
children:
- entity_id: sensor.senec_battery_house_used_power
type: passthrough
children:
- entity_id: sensor.produced_power_produktionsueberschuss
children:
- sensor.senec_battery_import_power
- entities:
- entity_id: sensor.senec_house_power
color: grey
subtract_entities:
- entity_id: sensor.shelly_pool_energy_power
color: grey
- entity_id: sensor.senec_grid_exported_power
- entity_id: sensor.senec_battery_import_power
card_mod:
style: |
ha-card {
padding: 0px;
mode: vertical
keep:
background: true
border_radius: true
box_shadow: true
margin: true
outer_padding: true
cards:
cards:
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
display: none;
text-align: left;
#header {
yaxis:
- id: first
decimals: 0
min: -2500
max: 2500
apex_config:
tickAmount: 4
forceNiceScale: false
title:
text: W
rotate: 0
labels:
style:
colors:
- var(--energy-battery-out-color)
- grey
- var(--energy-battery-in-color)
- id: second
opposite: true
decimals: 0
min: 0
max: 100
apex_config:
tickAmount: 4
title:
text: '%'
rotate: 0
labels:
style:
colors: grey
apex_config:
chart:
height: 120px
legend:
show: false
title:
text: Senec Batteriespeicher
align: center
margin: 10
offsetX: 0
offsetY: 10
floating: true
style:
fontSize: 1rem
fontWeight: bold
span:
end: minute
graph_span: 24h
header:
show: false
title: ' '
show_states: true
all_series_config:
statistics:
type: mean
period: 5minute
show:
in_header: raw
opacity: 0.2
type: area
stroke_width: 2
series:
- entity: sensor.senec_battery_charge_power
yaxis_id: first
- entity: sensor.senec_battery_charge_percent
yaxis_id: second
color: grey
- entity: sensor.senec_battery_discharge_power
yaxis_id: first
invert: true
tap_action:
action: navigate
navigation_path: /lovelace/senec-speicher
styles:
card:
- width: 3.5rem
- border: none
- box-shadow: none
primary: Speicher-Status
multiline_secondary: true
secondary: |-
{% set state = states('sensor.senec_system_state') %}
{% if state == 'CHARGE' %}
{{ states(entity, with_unit=True) }} - Speicher wird mit {{ states("sensor.senec_battery_import_power", with_unit=True) }} geladen
{% elif state == 'ABSORPTION PHASE' %}
{{ states(entity, with_unit=True) }} - Nachlade-Phase
{% elif state == 'BATTERY FULL' %}
{{ states(entity, with_unit=True) }} - Speicher vollständig geladen
{% elif state == 'OWN CONSUMPTION' %}
{{ states(entity, with_unit=True) }} - Selbstverbrauch von Solarenergie
{% elif state == 'DISCHARGE' %}
{{ states(entity, with_unit=True) }} - Speicher wird mit {{ states('sensor.senec_battery_export_power', with_unit=True) }} entladen
{% elif state == 'BATTERY EMPTY' %}
{{ states(entity, with_unit=True) }} - Speicher ist leer
{% elif state == 'PV + DISCHARGE' %}
{{ states(entity, with_unit=True) }} - Solarstrom und Speicher mit {{ states('sensor.senec_battery_export_power', with_unit=True) }} entladen
{% elif state == 'GRID + DISCHARGE' %}
{{ states(entity, with_unit=True) }} - Strom aus dem Netz und Speicher mit {{ states('sensor.senec_battery_export_power', with_unit=True) }} entladen
{% elif state == 'BATTERY DIAGNOSIS' %}
{{ states(entity, with_unit=True) }} - Speicher im Diagnosemodus
{% elif state == 'PASSIVE' %}
{{ states(entity, with_unit=True) }} - Speicher im Standby-Modus
{% elif state == 'EMERGANCY CHARGE' %}
{{ states(entity, with_unit=True) }} - Notladung
{{ states('sensor.senec_battery_charge_percent') }}% - Status nicht bekannt
icon: |-
mdi:battery-arrow-up
mdi:battery
mdi:recycle
mdi:battery-arrow-down
mdi:battery-10
mdi:progress-question
mdi:sleep
mdi:alert
icon_color: |-
green
blue
green
orange
red
red
red
red
blue
blue
red
blue
fill_container: true
tap_action:
action: more-info
card_mod:
style: |
ha-card {
background: rgba(var(--rgb-primary-text-color), 0.05) !important;
#border: none !important;
#box-shadow: none !important;
card_mod:
style: |
ha-card {
padding: 0px;
mode: vertical
keep:
background: true
border_radius: true
box_shadow: true
margin: true
outer_padding: true
cards:
cards:
stacked: true
card_mod:
style: |
ha-card {
border: none;
box-shadow: none;
#header {
apex_config:
chart:
height: 120px
legend:
show: false
tooltip:
shared: true
title:
text: Energieverbrauch heute
align: center
margin: 0
offsetX: 0
offsetY: 15
floating: true
style:
fontSize: 1rem
fontWeight: bold
span:
start: day
graph_span: 1d
header:
show: false
title: ''
show_states: true
floating: false
yaxis:
- min: ~0
max: ~1
apex_config:
tickAmount: 3
title:
text: kWh
all_series_config:
stroke_width: 2
opacity: 0.2
float_precision: 1
show:
in_header: raw
legend_value: false
type: column
statistics:
type: sum
group_by:
func: diff
start_with_last: true
duration: 1hour
series:
- entity: sensor.grid_imported_daily
- entity: sensor.battery_charged_daily
invert: true
- entity: sensor.battery_discharged_daily
- entity: sensor.solar_produced_daily
- entity: sensor.grid_exported_daily
invert: true
- entity: sensor.house_consumed_daily
type: area
opacity: 0.2
color: grey
tap_action:
action: navigate
navigation_path: /energy
styles:
card:
- width: 3.5rem
- border: none
- box-shadow: none
energy_date_selection: true
show_names: true
show_icons: false
wide: true
unit_prefix: k
round: 1
height: 70
show_units: true
min_box_height: 10
card_mod:
style: |
ha-card {
#color: rgb(50,50,50);
# --primary-text-color: rgb(50,50,50);
# --secondary-text-color: rgb(50,50,50);
padding: 0px;
font-size: 0.8rem;
font-weight: bold;
border: none;
box-shadow: none;
.container {
sections:
- entities:
- entity_id: sensor.senec_solar_total_generated
children:
- sensor.senec_grid_total_export
- sensor.senec_battery_total_charged
- sensor.whatever
- entity_id: sensor.senec_grid_total_import
children:
- sensor.senec_grid_total_import
- entity_id: sensor.senec_battery_total_discharged
children:
- sensor.senec_battery_total_discharged
- entities:
- entity_id: sensor.senec_grid_total_export
type: passthrough
children:
- entity_id: sensor.senec_battery_total_charged
type: passthrough
children:
- entity_id: sensor.whatever
type: remaining_parent_state
children:
- sensor.senec_house_total_consumption
type: passthrough
children:
type: passthrough
children:
- entities:
- entity_id: sensor.senec_house_total_consumption
- type: custom:energy-period-selector-plus
card_background: false
today_button: true
prev_next_buttons: true
compare_button_type: ''
today_button_type: icon
custom_period_label: Custom
compare_button_label: Daten vergleichen
period_buttons:
- day
- month
- year
I’m using the Sidebar Card, and have it configured to only display when the screen size is large enough. As far as the layout goes, it’s all done in the Lovelace dashboard using layout-card with the following settings:
.Each tile is its own entity using Mushroom cards with vertical layouts.
I have made a mushroom inspired battery card (can also be used for other bar style cards). It is built entirely out of the auto entities card and the bar card.
Does not work without auto entities! Please use auto entities even if you have just 1 bar. It will not work without it
What it looks like with multiple entities.
All you have to do is fill in the <=> sections your colors and icons you want use for the severity. And then choose the entity/entities you want to target with auto entities.
The color of the icon and the bar+background will then update to reflect your colors set automatically.
type: custom:auto-entities
card:
card_mod:
style: |
ha-card {
padding-top: 5px;
filter:
include:
- entity_id: sensor.office_blinds**battery
options:
card_mod:
style: |
bar-card-currentbar, bar-card-backgroundbar {
border-radius: 13px;
height: 43px !important;
margin-top: -8px;
bar-card-row {
margin-bottom: 14px !important;
bar-card-name {
color: black;
margin-top: -10px;
bar-card-value {
color: black;
margin-top: -10px;
ha-icon{
padding: 11px;
border-radius: 100px;
margin-top: -12px;
bar-card-row bar-card-currentbar,
ha-icon, bar-card-backgroundbar {
--bar-color:
{% if states(config.entity) | int <= 10 %}
#ff0026 !important;
--card-mod-icon: mdi:battery-10 !important;
{% elif states(config.entity) | int <= 20 %}
#ff4d00 !important;
--card-mod-icon: mdi:battery-20 !important;
{% elif states(config.entity) | int <= 30 %}
#ff9900 !important;
--card-mod-icon: mdi:battery-30 !important;
{% elif states(config.entity) | int <= 40 %}
#ffcc00 !important;
--card-mod-icon: mdi:battery-40 !important;
{% elif states(config.entity) | int <= 50 %}
#e7fc03 !important;
--card-mod-icon: mdi:battery-50 !important;
{% elif states(config.entity) | int <= 60 %}
#aaff00 !important;
--card-mod-icon: mdi:battery-60 !important;
{% elif states(config.entity) | int <= 70 %}
#aaff00 !important;
--card-mod-icon: mdi:battery-70 !important;
{% elif states(config.entity) | int <= 80 %}
#22c402 !important;
--card-mod-icon: mdi:battery-80 !important;
{% elif states(config.entity) | int <= 90 %}
#22c402 !important;
--card-mod-icon: mdi:battery-90 !important;
{% elif states(config.entity) | int <= 100 %}
#22c402 !important;
--card-mod-icon: mdi:battery !important;
blue
mdi:bug
bar-card-row ha-icon {
color: color-mix(in srgb, var(--bar-color) 100%, transparent);
background: color-mix(in srgb, var(--bar-color) 20%, transparent);
ha-card {
margin: -3px !important;
height: 60px;
sort:
method: state
numeric: true
ip: false
ignore_case: false
reverse: false
show_empty: true
card_param: cards
This is the section you will want to change the colors, icons, and the values of for your own purpose:
--bar-color:
#ff0026 !important;
#ff4d00 !important;
#ff9900 !important;
#ffcc00 !important;
#e7fc03 !important;
#aaff00 !important;
#aaff00 !important;
#22c402 !important;
#22c402 !important;
#22c402 !important;
blue
mdi:bug
And this is the section you will want to change to target your specific entity/entities:
filter:
include:
You can also use a grid card instead of the stack in card. I just prefer the single card with multiple bars look
The post above should get you on your way for setting up the general layout. Here is code for my Garage section. Each of the individual rooms is a section similar to what I am posting now. Just add a new card and throw this code in. Then substitute your own entities and such. Entities will show up in rows of 3.
square: false
columns: 1
type: grid
cards:
- type: vertical-stack
cards:
- type: custom:mushroom-title-card
title: ''
subtitle: Garage
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
width: 300
grid-template-columns: 130px 130px 130px
cards:
- type: custom:mushroom-cover-card
entity: cover.garage
layout: vertical
- type: custom:mini-graph-card
entities:
- sensor.garage_freezer_temperature
line_color: lightblue
line_width: 4
font_size: 50
font_size_header: 10
align_icon: state
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: Shopping List
content:
cards:
- type: custom:gap-card
height: 24
- type: shopping-list
height: 50
card_mod:
style: |
ha-card {
max-height: 120px;
- type: custom:mushroom-entity-card
entity: input_boolean.help_needed_when_arriving_home
icon: phu:rooms-carport
icon_color: red
layout: vertical
tap_action:
action: toggle
entity: sensor.waste_collection_trash_formated
primary: Trash Day
secondary: '{{ states(''sensor.waste_collection_trash_formated'') }}'
icon: mdi:trash-can
layout: vertical
icon_color: >
{% if is_state('sensor.waste_collection_trash_formated', 'Today')
%} lime {% endif %}
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
entity: sensor.waste_collection_recycle_formated
primary: Recycling Day
secondary: '{{ states(''sensor.waste_collection_recycle_formated'') }}'
icon: mdi:recycle
layout: vertical
icon_color: >
{% if is_state('sensor.waste_collection_recycle_formated',
'Today') %} purple {% endif %}
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
primary: Garage Door
secondary: >-
{% if
is_state("binary_sensor.lumi_lumi_sensor_magnet_aq2_opening",
"off") -%}
Closed
{%- elif
"on") -%}
Open
Unknown
{%- endif %}
icon: >-
{% if
is_state('binary_sensor.lumi_lumi_sensor_magnet_aq2_opening',
'on') %} mdi:door-open {%- else -%} mdi:door {% endif %}
entity: binary_sensor.lumi_lumi_sensor_magnet_aq2_opening
layout: vertical
icon_color: >
{% if
'on') %} red {% endif %}
tap_action:
action: more-info
I am also using a custom theme.
homekit:
modes:
light:
# Background image
lovelace-background: 'center / cover no-repeat url("https://hassio_url/local/images/backgrounds/light-theme-wallpaper.png") fixed'
ha-card-background: '#f6f6f6'
dark:
# Background image
lovelace-background: 'center / cover no-repeat url("https://hassio_url/local/images/backgrounds/homekit_bg_dark.png") fixed'
primary-color: steelblue
# blurring-background-behind-popup
dialog-backdrop-filter: blur(5px)
dialog-border-radius: 20px;
dialog-box-shadow: 0em 0em 0.5em;
iron-overlay-backdrop-opacity: 0.5
iron-overlay-backdrop-background-color: rgba(0, 0, 0, 0.32)
mdc-dialog-box-shadow: 0em 0em 15px 15px slategray
mdc-shape-medium: 25px
As a general recommendation, if you ask a question in a topic, at least partailly read the first post and the title of that topic.
That would’ve led you to this thread
where your questions are welcome and hopefully will be answered.
Thank you!
