PlayStation 5 Command Line Sensor Help - Command Failed/Empty JSON
Sure. I made a feature request for a new integration. I think the ps4 integration could just be ported basically.
Could you show an example of use?
$ ./ps5.py --help
usage: ps5.py [-h] [-b] host
Query a PS5 for state. Prints ON/STANDBY/OFF (Unreachable host = OFF)
positional arguments:
  host
optional arguments:
  -h, --help         show this help message and exit
  -b, --binary-mode  Report standby as OFF
$ ./ps5.py 192.168.0.37
STANDBY
$ ./ps5.py -b 192.168.0.37
OFF
I have it set up like this in binary_sensors.yaml:
- platform: command_line
  command: /config/sensors/ps5.py -b 192.168.0.37
  scan_interval: 10
Thank you!
I am unable to find the user-credential part.
I tried using tcpdump as well but no luck, any advice?
Hi all and thanks Mattias.
I’m getting:
Template variable error: ā€˜value_json’ is undefined when rendering ā€˜{% if value_json.code == ā€˜200’ | int %} on {% elif value_json.code == ā€˜620’ | int %} standby {% else %} off {% endif %}’
It could be due to the non declaration of the variables, will look into it. The rest seems to work fine!
Hello can someone help me??? I want to turn my PlayStation 5 on and off using the Home Assistant. I’ve already found out the user credentia. How can I now integrate my PlayStation as a switch in the Home Assistant? Unfortunately, I’m not getting any further.
So how far did you get ? Do you have it working from the command line yet? Also last I checked you could not put it in rest mode only wake up, but I haven’t really been keeping up on it so it’s possible someone made some progress with that if you check the GitHub
So far I’ve only found out the user-credential via wireshark. Unfortunately, I don’t really understand how I integrate that into Home Assistant.
unfortunately i don’t have that much experience in home assistant. especially with manual integrations
user-credential: 194931325
what exactly do I have to install now? and how and where exactly?
For example, I tried to install ps5-wake on home assistant. Unfortunately it does not work.
Welcome to the Home Assistant command line.
System information
  IPv4 addresses for eth0:  192.168.xxx.xx/xx
  IPv6 addresses for eth0:  2003:ea:2728:xxxx:xxxx:xxxx:80a2:b017/64, fd64:17b0:4047:6:c5ef:xxxx:xxxx:xxxxx/64, fe80::f412:64d2:a5e1:e213/64
  IPv4 addresses for wlan0:
  OS Version:               Home Assistant OS 5.13
  Home Assistant Core:      2021.6.0
  Home Assistant URL:       http://homeassistant.local:8123
  Observer URL:             http://homeassistant.local:4357
āžœ  ~ git clone https://github.com/iharosi/ps5-wake
fatal: destination path 'ps5-wake' already exists and is not an empty directory.
āžœ  ~ cd ps5-wake/
āžœ  ps5-wake git:(master) sudo make install
sudo: make: command not found
This post has somewhat of a guide:
There is also this post which mentions the error you are getting:
I would see if you can get it working from the command line with the commands mentioned here:
Ich hatte dem Führer bereits gefolgt. Und wegen des Fehlers in der Installation. Leider funktioniert auch der angegebene Befehl nicht.
āžœ ~ apt-get install build-essential
zsh: Befehl nicht gefunden: apt-get
Und wo sollte ich testen, welches Kommando ich hatte es bereits in der Schale und auf Home Assist
As already mentioned, I am unfortunately not at all familiar with the manual area. so far i had only installed finished platforms and stored them in the resources.
it would be really great if you could help me somehow
Many Thanks
Unfortunately I do not use Home Assistant OS so I am not sure what would need to be done to get apt-get working… I know I have seen the question in these forums previously… maybe try searching here for apt-get Homeassistant OS ? Or hopefully someone familiar with it can chime in
Edit: Use apt-get commands
I have now installed everything on another raspberry pi. everything works there. how do I create a switch that executes a command on another device via ssh
Are you familiar with shell_commands ? The command in this post would be running it on a remote machine… the same way you could test to see if working before putting it into a sensor
I’ve now installed everything so far.
In the shell of home assistant I can already log into the other raspberry pi via ssh without a password and execute the command to start the playstation.
I used the following instructions for logging in loosely
http://linuxproblem.org/art_9.html
so far everything works.
Now I want a switch to send this command, but I don’t know how to create this switch.
āžœ  ~ ssh [email protected]
Linux raspberrypi 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Jun  3 18:50:42 2021 from 192.168.xxx.xx
[email protected]:~ $ cd ps5-wake/
[email protected]:~/ps5-wake $ ./ps5-wake -vW -194931325 -H 192.168.178.xx
Device found: PS5-248 [PS5/78C881B8BD09]: Home Screen
Sending wake-up...
I have now integrated it that way. Unfortunately the switch doesn’t work. Since the Playstation cannot be switched off, I would like the command to switch on the play for every switch operation
switch:
    switches:
      ps5:
        command_on: "ssh [email protected] | cd ps5-wake/ | ./ps5-wake -vW -194931325 -H 192.168.178.62"
        command_off: "ssh [email protected] | cd ps5-wake/ | ./ps5-wake -vW -194931325 -H 192.168.178.62"
        friendly_name: 'Playstation 5'
Do you know how to get the bash shell inside the home assistant container? I use supervised so I’m not sure if the steps are the same on HaOS… but I would try that command from there so you can see the output… most likely you need to do ssh keygen so HA can run that command without issue… testing in the shell will let you see the error… I will edit post in a minute and link a post that walked me through that process…
So I’m assuming you got it working when manually typing the commands directly on that new pi?
Also the ps5 can automatically turn on and off based on the input of your tv changing… so you can have it shut off as soon as you switch off that input
So I enter the command in the shell directly on Home Assistant and from the home assistant I connect to the other raspberry pi.
this works. but not the platform
an ssh keygen has already been created by me in order to be able to switch to the pi via ssh one password. see my other post the link
Updated with working standby
Using a pi because I already use that for bluetooth → switchbot and, besides containers, I don’t want to install stuff on my NAS, where I run hass.
If your always-on computer is running hass os this probably will not work.
Install npm
sudo apt install nodejs npm
Install https://github.com/dhleong/playactor
sudo npm install -g playactor
Search for PS5
playactor browse
Outputs
  "address": {
    "address": "192.168.1.95",
    "family": "IPv4",
    "port": 9302,
    "size": 170
  "hostRequestPort": 997,
  "extras": {
    "statusLine": "620 Server Standby",
    "statusCode": "620",
    "statusMessage": "Server",
    "status": "STANDBY"
  "discoveryVersion": "0003...",
  "systemVersion": "08540...",
  "id": "78C88...",
  "name": "PS5-635",
  "status": "STANDBY",
  "type": "PS5"
Copy JSON "name":
playactor login --host-name PS5-635 --no-open-urls
Follow on screen steps
Open the following URL in a web browser to login to your PSN account.
When the page shows "redirect", copy the URL from your browser's address bar and paste it here.
  https://auth.api.sonyentertainmentnetwork.com/...
Checking PS5 state
playactor check outputs json but for some reason refuses to play nice with command line sensor so I also installed jq
sudo apt install jq
Home Assistant
These can be combined with a template switch
    scan_interval: 300
    command: ssh -o StrictHostKeyChecking=no -i /config/.ssh/id_rsa [email protected] 'playactor check --host-name PS5-635 | jq -r ".status"'
    value_template: >
      {% if value == 'AWAKE' %}
        ON
      {% elif value == 'STANDBY' %}
        OFF
      {% else %}
        OkƤnd
      {% endif %}
shell_command:
  playstation_5_wake: ssh -o StrictHostKeyChecking=no -i /config/.ssh/id_rsa [email protected] 'playactor wake --host-name PS5-635'
  playstation_5_sleep: ssh -o StrictHostKeyChecking=no -i /config/.ssh/id_rsa [email protected] 'playactor standby --host-name PS5-635'
Great guide! I installed npm, node and playactor on my Pi’s main os, everything is working great.
You can also do a switch entity that automatically updates the state. That way you dont have to do shell_command and an additional sensor, everything can be handled in one place:
switch:
  switches:
      playstation:
        value_template: >
            true
            false
          {% else %}
            Unknown
          {% endif %}
        command_state: ssh -i /config/ssh/id_rsa -o StrictHostKeyChecking=no [email protected] 'playactor check --host-name PS5-639 | jq -r ".status"'
        command_on: ssh -i /config/ssh/id_rsa -o StrictHostKeyChecking=no [email protected] 'playactor wake --host-name PS5-639'
        command_off: ssh -i /config/ssh/id_rsa -o StrictHostKeyChecking=no [email protected] 'playactor standby --host-name PS5-639'
        friendly_name: Playstation 5
