Thread working on ESP32-H2 - Example Project
In ESP Home 2025.6.0 support was released for Thread and thread enabled boards the H2 and the C6, I thought I’d document my bumpy experiences getting an example Thread project going with HomeAssistant:
Pre-requisites
Assumed knowledge:
  • You have set up at least 1 ESP Home wifi device before trying a thread device
HA installation with:
  • Thread integration enabled and working
    • Requires at least 1 boarder router, in my case I had a Google Home Display and a SkyConnect (with the OpenThread add-on) on the same network (How to combine networks)
    • An ESP32 H2 or C6 - example below is the H2
    • ESPHome Device Builder (I find it can crash my raspberry pi 4 so I use a seperate docker installation)
    • I believe having IPv6 enabled on your router may be a requirement - but I’m not certain about this - its not clear to me if thread traffic ever goes near your router or whether it all happens on it’s own network with border routers doing 6->4 NAT.
  1. Getting your tlv
    • In home assistant, go to the Thread integration page, click ‘configure’, then click on the circular :information_source: icon in the top right
    • Copy the long TLV somewhere for later
  2. Commissioning your ESP32 with esphome
    • I’d usually recommend using esphome webtools for this first step but it doesn’t yet support the H2
    • Instead connect the H2 to your compute and do the ‘add device’ flow in ESPhome, if you’re like me you’ll see two COM devices appear, I tended to go with the one that started with JTAG.
    • The flow would repeatedly fail for me, I guess it is early days for the H2:
    • Clicking the “skip this step” reveals a list of devices that the H2 isn’t even on.
    • I clicked “ESP32” and then clicked “skip” when it offered to install
  3. Installation
    • Click on ‘edit’ for the new device, we are going to delete/replace most of this default config, except for everything inside the api: and ota: tags so copy and paste them somewhere safe
    •  esphome:
         friendly_name: thread-test
       esp32:
         board: esp32-h2-devkitm-1
         variant: ESP32H2
         framework:
           type: esp-idf
       # Enable logging
       logger:
       # Enable Home Assistant API
       api:
         encryption:
           key: "YourEncryptionKeyGenerated by ESPHome"
       ota:
         - platform: esphome
           password: "yourOTApasswordGeneratedByESPhome"
       network:
         enable_ipv6: true
       openthread:
         tlv: yourTLVfromStep0
       # Output and light configuration for a single red LED
       output:
         - platform: gpio
           pin: GPIO1
       light:
         - platform: binary
           output: red_led
    • Click install → “Plug into this computer” and follow the steps.
  4. Adding to home assistant
    • I found that the device was auto-discovered, I have no idea how I would have added it otherwise.
  5. Breadboarding
I’m trying with an ESP32 H2 and at the end of step 2 I get this error:
“Configuration does not match the platform of the connected device. Expected an ESP32 device.”, any idea on what is going on?
Thanks.
Can you share your YAML,
This bit is the key but, it is possible you’re using a different H2 board, can you share a link to the board you’re using?
 esp32:
   variant: ESP32H2
   framework:
     type: esp-idf
This is my YAML code:
esphome:
esp32:
  board: esp32dev-h2-devkitm-1
  variant: ESP32H2
  framework:
    type: esp-idf
# Enable logging
logger:
api:
  encryption:
And this is the link to my board:
https://es.aliexpress.com/item/1005006252422191.html?spm=a2g0o.order_list.order_list_main.33.c805194dOJrZke&gatewayAdapt=glo2esp
Can you give me a link to a working board?
Thanks.
Hmm I would have thought that board would work.
I used this one: Waveshare ESP32-H2 Development Board - The Pi Hut
The H2 support seems to be quite limited in ESP home at the moment, I would try the C6 instead.
Same here. I had to click “Clean build files” and then it worked:
This is the board config that I’m using:
esp32:
  variant: ESP32H2
  framework:
    type: esp-idf
Thanks bagre, working now.
I am trying to get the TLV for my network, but if i click on the (I) button, i only see network name, channel, dataset ID, panID and extended pan id, no TLV.
Am i missing something?
Last one ?
Tienes que pinchar en “añadir un router fronterizo openthread” y poner la IP de tu border router con http:// y al final :8081
Thanks!
I followed this but cannot get it work :cry:
In my thread network information from the (i) button, I don’t see a TLV. How can I fix that? Is something wrong with my Thread network and/or connection to home assistant?
Note that I don’t have/use Open Thread border router since (a) I have a HomePod mini that does this fine, (b) I don’t have a thread dongle for my HaOS box.
I notice in the iOS companion app, if I go to Debug->Thread and wait a bit, I do see the “active operational data set” there which looks like a TLV number (0e08000…). And I’ve used the “Transfer to Home Assistant” button there multiple times, but the TLV still doesn’t show up in the screenshot above…
I’m thinking either the UI needs a refresh, or HA needs a reboot.
The entry is showing a “key in a phone” icon which is suppose to mean that the HA Thread integration knows the Thread dataset for that Thread network.
I’ve rebooted/refreshed multiple times in the last 2 days (I’m doing lots of development and updating). Still no change to the above UI. I can get the TLV from the companion app, so that’s ok for trying out an ESP32-H2 (I think; we’ll see)
FWIW: the other reason I was concerned is that all 5 of my Thread->HomeKit->HA endpoint devices (QingPing T&H sensors) dropped off my Thread network and refused to reconnect for several days (“Pair verify timed out” messages in the log). This has now rectified itself for 4/5 devices at least. That at least does demonstrate that HA is actively connected to this Thread network, even though the above screenshot suggests there may be an issue.
I’m wondering if that is a bug? If you go into HA’s ./config/.storage/thread.datasets does it show a TLV?
Yes - that file does have the TLV - see below (for security I’ve replaced some of the strings in what I’ve pasted here)
  "version": 1,
  "minor_version": 4,
  "key": "thread.datasets",
  "data": {
    "datasets": [
        "created": "2023-12-09T14:10:39.976173+00:00",
        "id": "01HHXXXXXXXXXXXVEWS6",
        "preferred_border_agent_id": null,
        "preferred_extended_address": "6eXXXXXXXXX1b",
        "source": "iOS-app",
        "tlv": "0e080000000000000000000<snip>"
    "preferred_dataset": "01HHXXXXXXXXXXVEWS6"
With ESPHome 2025.10.3, Home Assistant 2025.10.4, and OpenThread Border Router Add-On 2.15.0, I flashed an ESP32C6 with this example:
substitutions:
  friendly_name: 'ESP32-C6 #2'
  device_name: esp32c6-2
esphome:
  friendly_name: ${friendly_name}
  comment: "${friendly_name} OpenThread test"
esp32:
  board: seeed_xiao_esp32c6
  variant: esp32c6
  framework:
    type: esp-idf
# Enable logging
logger:
  level: DEBUG
api:
  encryption:
    key: !secret api_key
ota:
  - platform: esphome
    password: !secret ota_password
network:
  enable_ipv6: true
openthread:
  device_type: FTD
  force_dataset: true
  tlv: <my_tlv>
  - platform: uptime
output:
  - platform: gpio
    pin: GPIO15
light:
  - platform: binary
    output: led
text_sensor:
  - platform: openthread_info
    ip_address:
    channel:
    role:
    rloc16:
    ext_addr:
    eui64:
      name: "EUI64 Interface ID"
    network_name:
    network_key:
    pan_id:
    ext_pan_id:
      name: "Extended PAN ID"
The module seems to connect fine to OTBR. The connection appears in the “Topology” page of the OTBR web interface:
The OBR + module nrf52840dongle + esp32-c6 under esphome
I have this intégrations in HA:
However, the module does not appear in HA. And I have this error in the module log that would explain the problem:
 [12:46:44][E][api:135]: No clients; rebooting
How does the module connect to the HA API via thread?
Using the ESPHome protocol. Or rather, HA discovers it, and connects to it using that protocol.
Does your HA installation support IPv6? Because AFAIK, it should. I’ve been using both H2’s and C6’s running Thread (using my Apple Thread network) and HA.
The rebooting message you get is normal: if an ESPHome device has no clients (like HA) for a particular amount of time (15m by default), it will reboot (documented here, search for reboot_timeout).
Thanks,
The ha network info return a IPV6 config like that:
  ipv6:
    addr_gen_mode: default
    address:
    - xxxx:xxxx:xxxx:xxxx:xxxx:6c90:1e3d:1ea3/64
    - xxxx::xxxx:xxxx:xxxx:a0dc/64
    gateway: xxxx::xxxx:xxxx:fef4:2920
    ip6_privacy: default
    method: auto
    nameservers:
    - xxxx:xxxx:xxxx:xxxx:xxxx:d8ff:fef4:2920
    - xxxx::xxxx:xxxx:xxxx:2920
That should be good for this point, I think
I thought it was the module that connected to HA.
So it’s the other way around.
HA must be able to access the module via the OTBR.
In the esp32-c6 log, I found his @IPV6:
[20:55:59][D][sensor:131]: 'esp32c6-2 Uptime': Sending state 4.45900 s with 0 decimals of accuracy
[20:56:08][D][text_sensor:085]: 'RLOC16': Sending state 'fffe'
[20:56:11][D][text_sensor:085]: 'IP Address': Sending state 'fd43:b533:bfc7:1:ea75:b1d2:dced:e895'
I can ping this adress:
$ ping fd43:b533:bfc7:1:ea75:b1d2:dced:e895
PING fd43:b533:bfc7:1:ea75:b1d2:dced:e895 (fd43:b533:bfc7:1:ea75:b1d2:dced:e895) 56 data bytes
64 bytes from fd43:b533:bfc7:1:ea75:b1d2:dced:e895: icmp_seq=1 ttl=254 time=204 ms
64 bytes from fd43:b533:bfc7:1:ea75:b1d2:dced:e895: icmp_seq=2 ttl=254 time=28.1 ms
64 bytes from fd43:b533:bfc7:1:ea75:b1d2:dced:e895: icmp_seq=3 ttl=254 time=37.7 ms
And tracepath does show me an ICMP path through the HA server.
So for now, everything is working correctly. The only thing missing is the HA part, which needs to discover this module, right?
