WTH Reusable, or linked Dashboard-Cards (Master-Card)
Hello
I have several dashboards for different purposes. Some cards are used multiple times and, depending on their status, are displayed on multiple dashboards.
→ It would be great if you could create these cards once and link that “original card” in all the different dashboards, where you need it too. This way, only the master card needs to be changed and the changes are effective in all other dashboards. Thanks
google about decluttering-card
This one? lovelace-decluttering-card
Check out my feature request:
You have also streamline card that is more updated…
This WTH could be linked with this one:
Thanks…will check it out, along with other WTH suggestions here.
Hey everyone, bumping this back from 3 years ago.
The concept is create a primary card, then have copies of it around the views and dashboards in order to reduce code needed, and at the same time, change all the cards by changing the primary.
Perhaps create the primary, assign a unique-id to it, then have an “copy-card” where you’ll just enter the unique-id and become a copy of first one?
It’s been discussed that it can be done through yaml-mode, but the ui mode is just too helpful to give up.
Here’s the 2021 feature request with ~75 votes.
Thanks!
