HI again and thanks again, it’s all very much appreciated
I am fairly familiar with the ESP8266/32 as I currently have 32 devices online, either smart sockets that I have re-flashed with ESPHome or straight dev boards, including a couple of the TTGO T-Display ESP32’s with one running as a CO2 sensor and the most recent, a 2 x freezer + 1 x fridge + 3 x Dallas temp sensors. I’ve also modded an Ikea particulate sensor into HA via an ESP8266.
I can often deal with the more straightforward code, dealing with sensors etc (often with a lot of copying and pasting from the net) and I have been helped a lot on the T-Display boards re the use of displays that change colour depending of the situation (freezer too cold = blue, good is green, a bit warm in yellow and panic in red).
But because I was aware of the power consumption of the ESP / WiFi compared with Zigbee and the durability of the MESH network and a fairly busy AP, I thought I’d just check if there was anything.
Seen the M5Stack but not got one as yet.
I already have outdoor temperature and humidity sensing (Sonoff SNZB-02)and home-brew lux and air pressure via an ESP32.
I also have ‘whole home’ power monitoring via Glow and pulse counting of my electric meter, again, using a ESP32 and thought that might make a good template for anemometer pulse counting and integration etc (2s updates).
I now have a couple of anemometer impellers (I tried 3FD printing some but it was cheaper / easier / better to buy) and can print / turn any mechanical parts needed to build the actual speed sensor, it’s just a batter re what to use to feed that into HA. As you say, it looks like an ESP of some sort is the 'easiest way, even if it’s not the best for power consumption,
I think there should be enough ideas from all those links to get me a working solution!
Cheers.
p.s. Is it just me re or is it really not clear what ptov ‘is’ clear from their home page? I mean, what does it actually do and how?
I think this is the nearest to a functional overview?
