Smart thermostats again
Hi
I want to implement room-specific underfloor electric heating control in Home Assistant, and seek guidance on the compatible wall thermostats. The ideal thermostat has minimum built-in automation besides saftety (to reduce the price - I’m going to implement that automation) yet good wireless connectivity (ideally WiFi but Zigbee/Z-wave are ok) and tested/proven Home Assistant integration.
This is 230V/16A system and each room has a different thermostat (9 thermostats in total) controlling the respective zone. The control system would be implemented in Python on Raspberry Pi 4, based on a dynamical thermal model I have made for the house addressing individual rooms, local weather forecasts and price of electricity.
There is a local vendor vouching for HeatIt, Heatmiser and the like, which that company claims are compatible with Home Assistant over Z-wave. But the suggested devices are about 3 times more expensive than generic “smart” / “programmable” thermostats on Amazon.de, e.g.
https://www.amazon.de/-/en/Underfloor-Thermostat-Programmable-Thermostats-TGP86WIFI-EP
https://www.amazon.de/-/en/Thermostat-Programmable-Thermostats-Compatible-TR9HB-WIFI-WPB/dp/B08LNS34BX?th=1
https://www.amazon.de/-/en/Thermostat-Programmable-Electric-Touchscreen-TGW60W-WIFI-EP
https://www.amazon.de/-/en/Thermostat-Underfloor-Heating-Digital-Compatible/dp/B09BVT8RH4
https://www.amazon.de/-/en/KETOTEK-WiFi-Thermostat-Compatible-Programmable/dp/B0833N4ZZ3?th=1
https://www.amazon.de/-/en/Wireless-Thermostat-Temperature-Control-Compatible/dp/B095HYP48L
Are there tested Home Assistant integrations available for these (or other) generic “smart” thermostats? If yes, then is there any reason to go for the higher-priced names?
FWIW, there are related threads, such as …
… but none of them seems to address this concern.
I have Mysa thermostats which integrate into HA using Apple HomeKit.
They make an in-floor heating version though it’s rather high in price.
It does have scheduling built-in but I don’t think you have to use it.
I’ve been looking for something similar, unsuccessfully. I have 5 radiant electric in-floor rooms and $200 apiece is hard to swallow.
If I find anything, I’ll post back here.
What specific concern?
I have the Sinope and it works great.
