**Dashboard Hardware & Control** - Show Off Yours
Show Off your Dashboard Hardware and Control.
Hopefully will provide some inspiration and recommendations for people
Follow the below Post Format…(Any other criteria please feel free to chime in and I will add)
HARDWARE PICTURE/S:
HARDWARE DESCRIPTION:
LOCATION OF CONTROL POINT:
  • Living Room
  • Couch Side for easy access
KEY FEATURES OF CONTROL:
  • Google Pixel Tablet
    • Central Control for Home Theatre and other Smart Speakers in the House
    • Air Conditioning Control
  • Aqara Magic Cube
    • Shake to toggle Home Theatre On and Off (Through Harmony Hub)
    • Turn with side 2 up to adjust volume
    • Flip Sides to change the dashboard cast to all Google Displays in the House
  • Logitech Harmony Elite
    • Control for Home Theatre
    • The Harmony Hub is linked to automations and dashboard controls
KEY FEATURES OF INFORMATION:
  • Time and weather
  • Air Comfort of multiple rooms
  • Air Conditioning Status
  • Home Theatre Status
  • Scroll Down - Battery Status of All Devices
  • Scroll Down - Home Assistant Metrics
  • Scroll Down - Watchman Report
SCREEN SHOTS:
(Use chrome developer mode [F12] and adjust screen size for your device, [Win Key+Shift+S] for screen snip.
Main Screen
Scroll Down
HARDWARE PICTURE/S:
  • Bathroom
  • Easy view for morning routine
  • Google Nest Hub Second Gen
    • Central Control of Lights, Mirror, and Coffee Machine and Kettle
    • Music Control When Music Playing
    • Scroll Down - Air Conditioner Control
  • Moes Smart Knob (On back of Display)
    • Adjusts the volume of the speaker group when playing music
  • Tuya 4 Button Switch
    • Activates Music Playing
    • Activates Lights
    • Activates Cast of Bathroom Dashboard to Nest Hub
  • Google nest Hub
    • Time and Hourly Weather
    • Calendar of upcoming events
    • Controls for switches
  • LinknLink eTHS2
  • Temperature and Humidity Readings
SCREEN SHOTS:
Main Screen
Scroll Down
HARDWARE PICTURE/S:
  • Bedroom
  • Bed Side for easy access
  • HP Chrome Base
    • Home Dashboard is 3D Home - Control for all switched and lights in the house
    • Access to All Dashboards
    • Access to Youtube and other Apps to entertain my 7 Year Old
  • LinknLink eTHS2
  • 3D Home Dashboard (With Switch Control and Calendar)
  • Weather Dashboard
  • Garden Watering Dashboard
  • Fish Tank Dashboard
  • CCTV Dashboard
  • Media Dashboard
  • Bathroom Dashboard
SCREEN SHOTS:
Dashboards
HARDWARE PICTURE/S:
  • Fish Tank
    • Aquarium Light Control
    • Clean Fish Tank (Turns off Heaters and Filters for water change)
  • Inkbird 306A Aquarium Thermostat
    • Maintains water temperature with two heaters
  • Chihiros 4 head Doser
    • Local Bluetooth App Control Only - Waiting for new WiFi Hub to be released
  • WiFi Automatic Fish Feeder
    • App control Only unless modifying with ESP Chip.
    • Daily morning feed - with warning if food is out
  • Seneye SWS and Reef
    • Monitors Aquarium parameters
    • Sends warnings via SMS and activates Scripts to rectify
  • Brilliant White 8 Power Outlets Cannes Wi-Fi Power Board with USB-A & USB-C Charging
    • Power Control for all devices
    • Automations to power cycle devices if connect unstable
  • Google Nest Hub
    • Fish Tank Water Temp
    • Ammonia NH3
    • Ammonium NH4 (Calculated)
    • pH
    • ORP (Calculated)
    • View of Camera
  • Arlo Baby Camera
    • Live Camera Feed
    • Monitors water clarity
    • Light on back indicates Green (Good), Red (Bad) if any parameters are not right.
SCREEN SHOTS:
Main Screen
HARDWARE PICTURE/S:
  • Aopen WT22M Commercial Chrome OS Screen (Cheap on Second Hand Market)
  • Ulanzi Pixel Clock
  • Kitchen
  • Central Position
  • HP Chrome Base
    • Access to Recipes online for the Mrs.
    • Hardware buttons to activate Scripts
  • Dashboards as listed in above post
  • Ulanzi Clock Notifications
SCREEN SHOTS:
Ulanzi Awtrix Notifications
BOM Australia Weather Report
BOM
A/C Climate Control and Door Notification
Door Open
Dry Mode
Heat Mode
Off Mode
Cool Mode
Dashboards
HARDWARE PICTURE/S:
  • Living Room
  • Main thoroughfare to bedroom and toilet
  • Uperfect Vertical Touch Monitor
    • Music Control when activated
  • Time and weather
  • Full Weather report from BOM Australia and Sensors Combined
  • (Special Feature Toggle) Fire Events Report
  • Home and Away Status
  • Door and Window Status
  • Animated Weather Display from Ventusky (Changed map layers pending on weather condition)
  • (Special Feature Toggle) Bushfire.io Animated Weather, Flood and Fire Warning map
  • Scroll Down - Air Comfort Status
  • Scroll Down - Temperature Graphs
  • Scroll Down - Wind Status
  • Scroll Down - Rain Graphs
  • Scroll Down - Sensor Status
  • Scroll Down - Sun and Moon Events
SCREEN SHOTS:
Main Weather Screen
Main Fire & Warnings Screen
Scroll Down
Scroll Down
ezgif.com-optimize (1)
HARDWARE PICTURE/S:
  • iPad 10 Inches 2020
  • Kitchen
  • Time and weather
  • Air Conditioning and Heating Status
  • Home security
  • Battery Status of All Devices
  • F1 Schedule
  • Lighting
  • Weather report
  • Devices status
  • PopUp : Forecasts
  • PopUp : Wind
  • PopUp : Rain
  • PopUp : Sun
  • PopUp : Moon
  • PopUp : Season
  • PopUp : Lights on
  • Conditional waste display
SCREEN SHOTS:
Main:
PopUp:
Beautifully laid out.
My panel was linked up in this email thread, but here’s version 2.0:
It’s based on the Raspberry Pi and a full-HD 15" touch screen with a 3D-printed cover frame. It can be easily extended to even larger 4k screen if someone needs it, but I didn’t. Raspberry can also support dual display. In either case 3d-printing a cover for such setup might be a bit of a challenge because of the size. I had to print my top and bottom cover in 2 parts and connect them.
Software wise, working with raspberry is much more pleasent than with an android tablet. Kiosk mode with Chromium is trivial to set up. I’ve also set up a simple mqtt based heartbeat and command interface so basic commands like screen refresh, screen on/off, system restart, etc are sent from HA. In the hearbeat, PI reports CPU and mem usage, temperature and power failures.
For anyone thiking of building similar, bear in mind that reliable power delivery to PI is absolutely essential. USB cable sucks for this purpose.
