πŸ”Ή Card-mod - Add css styles to any lovelace card
Yup it does, if I put the primary colour hex code from the theme it works perfectly fine. But if I put the variable then it seems to stay as a dark blue color regardless of the theme I select. Seems like I am entering in the variable wrong, have tried with ’ ', " ", and without but doesn’t seem to make a difference!
I suppose you can just do that then. My best guess would be that something’s stopping your primary-color from getting through, but I’m not sure. It looks like --primary-color is plain CSS blue.
Yeah seems that way! Thanks for your help, was hoping to be able to change everything with my themes but I’ll just have to stick to one colour instead for now :slight_smile:
I want to hide mwc-icon-button, remove ha-card works!
The three dot is gone, however it still occupies the space, is there a way to remove that space so the card will be more compact? See below, the red mark is the location of the three dot.
.content {
  margin-top: -48px;
You can also try using card-mod to change the color of the icon.
I changed to -24px which works good on my card, thanks for the help.
I’m using for the first time this mod, and for me it’s the first time that I’m using the CSS (sorry if this is a trivial question).
I have a picture-entity used to show an image (Octoprint mpeg image).
The problem is that the camera is rotated of 180 degree, for this reason I need to rotate the image in the Home Assistant.
I’m able to apply the rotation directly in the picture-entity in this way:
   aspect_ratio: 50%
   camera_image: camera.octoprint
   #camera_view: live
   image: 'http://octopi.local/webcam/?action=snapshot'
   show_name: false
   show_state: false
   type: picture-entity
   style: |
     ha-card {
       transform: rotate(180deg);
When I try to open the ha-dialog to show the live image (I think it’s a β€˜more-info’ panel) the image shown is correctly in live but with the original rotation.
How I can rotate also the image shown in this panel?
I am still a beginner and when I started learning card-mod for me it was not easy since I was not able to find a full info for all the possible cards))).
Let me post sometimes little instructions for different cards.
First, it will be an Entity card:
NOTE:
Do not forget to add a "card_mod:" keyword before "style:" (new in card-mod 3).
ΠΈΠ·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅
type: entity
entity: sensor.cleargrass_1_co2
style: |
  .header .name {
    color: green;
  ha-card {
    color: red;
  .info .measurement {
    color: orange;
  .header .icon {
      color: cyan;
binary_sensor:
type: entity
entity: binary_sensor.service_on_value
style: |
  .header .name {
    color: green;
  ha-card {
    color: red;
  .header .icon {
      color: cyan;
As for the icon - it will be always cyan, for ON & OFF.
Here is an example for OFF (device_class: connectivity):
The code below changes the icon’s color dependently on the sensor’s state (here & below - styling for text is removed) - if the sensor is ON, then the icon is yellow (standard theme’s active color):
type: entity
entity: binary_sensor.iiyama_2_ping_availability_status
style: |
  .header .icon {
  {% if is_state(config.entity,'on') %}
    color: var(--paper-item-icon-active-color);
  {% else %}
    color: var(--state-icon-color);
  {% endif %}
Also we can change the β€œactive” & β€œinactive” colors:
type: entity
style: |
  .header .icon {
    color: red;
  {% else %}
    color: brown;
  {% endif %}
Changing a font-size & icon’s size:
type: entity
style: |
  .header .name {
    color: green;
    font-size: 10px;
  .info .value {
    color: blue;
    font-size: 8px;
    color: orange;
    font-size: 30px;
  .header .icon {
    color: cyan;
  ha-card {
    --mdc-icon-size: 60px;
Changing a background:
type: vertical-stack
cards:
  - type: entity
    entity: sensor.xiaomi_cg_1_co2
    style: |
      ha-card {
        background-color: orange;
  - type: entity
    style: |
      .info {
        padding-top: 16px !important;
      ha-card {
        overflow: hidden;
  - type: entity
    style: |
      .header {
      .info {
      ha-card {
        overflow: hidden;
  - type: entity
    style: |
      ha-card {
        background-image: url("/local/images/blue_low_2.jpg");
        background-size: 100% 100%;
        height: 250px !important;
  - type: entity
    style: |
      .info {
        background-image: url("/local/images/Stan_small.png");
        background-repeat: no-repeat;
        background-position: right;
      ha-card {
        overflow: hidden;
More examples are described here.
Styling a slider entity inside Entities card:
NOTE:
Colored icon (2 options):
type: entities
entities:
  - entity: input_number.battery_level_check
    card_mod:
      style: |
        :host {
          --paper-item-icon-color: red;
    name: Π‘olor icon (#2)
    card_mod:
      style:
        hui-generic-entity-row:
            state-badge {
              color: orange;
Colored text: (without β€œsecondary_info”)
type: entities
entities:
    name: Π‘olor all text
    style: |
      :host {
        color: red;
    name: Color value's name
    style:
          .info {
            color: green;
    style: |
      hui-generic-entity-row .flex .state {
        color: magenta;
Word wrapped text: (without β€œsecondary_info”)
type: entities
entities:
    name: Wrapped Wrapped Wrapped Wrapped Wrapped
    style:
          .info {
            color: red;
            text-overflow: unset !important;
            white-space: unset !important;
    name: Not wrapped Not wrapped Not wrapped Not wrapped
All styles described above: (without β€œsecondary_info”)
type: entities
entities:
    card_mod:
      style:
            state-badge {
              color: orange;
            .info {
              color: red;
            .flex .state {
              color: magenta;
Common style for all sliders: (without β€œsecondary_info”)
type: entities
title: Common
card_mod:
  style:
    hui-input-number-entity-row:
            state-badge {
              color: orange;
            .info {
              color: red;
            .flex .state {
              color: magenta;
entities:
    name: Slider Slider Slider Slider Slider
  - sun.sun
    name: Cannot ovewrite style Cannot ovewrite style Cannot ovewrite style
    card_mod:
      style: |
        :host {
          color: green !important;
Note that a style for the 2nd slider cannot be overwritten individually.
If β€œsecondary_info” is specified then a code changes a little - I have to use ".info" instead of ".info.text-content":
type: entities
entities:
    secondary_info: last-changed
    style:
          .info {
            color: green;
But according to my tests in all the cases described above it is possible to always use ".info" - it seems to work anyway.
Colored secondary-info:
type: entities
entities:
    name: Π‘olor secondary
    style:
          .info .secondary ha-relative-time {
            color: orange;
Different colors for name & secondary_info:
type: entities
entities:
    style:
          .info: |
              color: orange;
            .info {
              color: green;
Colored slider:
type: entities
entities:
    style:
      hui-generic-entity-row: |
        .flex ha-slider {
          --paper-slider-active-color: orange;
          --paper-slider-knob-color: green;
          --paper-slider-container-color: cyan;
Hiding elements:
Hidden icon:
type: entities
entities:
    style:
          state-badge {
            display: none;
Hidden state:
type: entities
entities:
    style: |
        display: none;
Hidden name:
type: entities
entities:
    style:
          .info {
            display: none;
          ha-slider {
            max-width: unset !important;
Minimal view:
type: entities
entities:
    style:
          .info {
            display: none;
          state-badge {
            display: none;
          ha-slider {
          .flex .state {
            display: none;
Adjusting a slider’s width:
type: entities
entities:
  - entity: input_number.test_number
    card_mod:
      style: |
        ha-slider {
          {% set WIDTH = states("input_number.test_number")|int(0) %}
          width: {{WIDTH}}px !important;
Disabled slider:
type: entities
title: Locked slider
entities:
  - entity: input_boolean.test_boolean
    name: Lock the slider
    tap_action:
      action: none
    card_mod:
      style: |
        :host {
          {% if is_state('input_boolean.test_boolean','on') %}
            --paper-slider-active-color: var(--disabled-text-color);
            --paper-slider-knob-color: var(--disabled-text-color);
            --paper-slider-container-color: var(--disabled-text-color);
            --paper-item-icon-color: var(--disabled-text-color);
            pointer-events: none;
          {% endif %}
Styling Entities card.
(including some special row elements - button, section, divider)
NOTE:
Colored background & rounded corners - can be easily achieved by using "--ha-card-background" & "--ha-card-border-radius" variables:
type: entities
title: Title
entities:
  - entity: sun.sun
style: |
  ha-card {
    --ha-card-background: orange;
    --ha-card-border-radius: 14px;
Using background image:
Test image:
By default a background image is placed w/o a resizing:
type: entities
entities:
  - entity: sun.sun
title: Image clipped
style: |
  ha-card {
How to fit the image to the defined card’s size:
Note: the card’s height is defined.
type: entities
entities:
  - entity: sun.sun
title: Image fitted
style: |
  ha-card {
For a content area only:
type: entities
entities:
  - entity: sun.sun
title: Image fitted to content
style: |
  .card-content {
  ha-card {
    overflow: hidden;
For a header area only:
type: entities
entities:
  - entity: sun.sun
  - entity: sun.sun
title: Image fitted to header
style: |
  .card-header {
  ha-card {
    overflow: hidden;
With a defined position:
type: entities
entities:
  - entity: sun.sun
  - entity: sun.sun
title: Image placed on header
style: |
  ha-card .card-header {
    background-size: 30% 50%;
    background-position: 95% center;
Adding a scrollbar:
type: entities
entities:
  - sun.sun
  - sun.sun
  - sun.sun
  - sun.sun
  - sun.sun
  - sun.sun
  - sun.sun
  - sun.sun
  - sun.sun
card_mod:
  style: |
    .card-content {
      overflow-y: scroll;
      max-height: 280px;
    ha-card {
      overflow: clip;
Colored text: (w/o 'secondary_info')
type: entities
entities:
  - entity: sun.sun
    style: |
      :host {
        color: red;
  - entity: sun.sun
    style:
          .text-content:not(.info) {
            color: orange;
  - entity: sun.sun
    style:
          .info {
            color: green;
  - entity: sun.sun
    name: Colored name & value
    style:
          .info {
            color: green;
            color: orange;
Colored text: (with 'secondary_info')
If "secondary_info" is specified then the code changes - I have to use ".info" instead of ".info".
According to my tests in all the cases described above it is possible to always use ".info" - it seems to work anyway.
type: entities
entities:
  - entity: sun.sun
    style:
          .info {
            color: orange;
  - entity: sun.sun
    name: Colored name (with secondary_info)
    style:
          .info {
            color: cyan;
Common style: changing a color for all rows: (except 'secondary_info' )
All text (except a title):
type: entities
title: Some title
style: |
  ha-card .card-content {
    color: red;
entities:
  - entity: sun.sun
Only values:
type: entities
style:
  hui-simple-entity-row:
            color: red;
entities:
  - entity: sun.sun
  - entity: sun.sun
Only names:
type: entities
style:
          .info {
            color: green;
entities:
  - entity: sun.sun
  - entity: sun.sun
Values & names:
type: entities
style:
          .info {
            color: orange;
            color: red;
entities:
  - entity: sun.sun
  - entity: sun.sun
Changing a color for the whole card (i.e. including a title): (except 'secondary_info')
type: entities
title: 'Common: all text'
style: |
  ha-card {
    color: orange;
entities:
  - entity: sun.sun
  - entity: sun.sun
Colored title:
type: entities
title: 'Style: colored title'
style: |
      color: red;
entities:
  - entity: sun.sun
Another option - using a "--ha-card-header-color" variable:
type: entities
style: |
  ha-card {
    --ha-card-header-color: red;
entities:
  - entity: sun.sun
Overwriting styles:
How it is specified:
  • all text is blue
  • all rows’ text is red
  • one row’s text is cyan
type: entities
title: 'Changed color'
style: |
  ha-card {
    color: blue;
    color: red;
entities:
  - entity: sun.sun
  - entity: sun.sun
    style: |
      :host {
       color: cyan;
Other tricks with the header:
type: entities
title: Some title (+card-mod)
card_mod:
  style: |
      border: 3px dotted magenta;
      padding: 0px;
      display: unset;
    ha-card .card-header .name {
      color: red;
      text-align: right;
      font-weight: 1000;
      letter-spacing: 3px;
entities:
  - entity: sun.sun
  - entity: sun.sun
  - entity: sun.sun
Colored secondary_info:
type: entities
entities:
  - entity: sun.sun
    style:
          .info .secondary: |
            ha-relative-time {
Note that I have to use '!important', it does not work without it - do not know why…
Colored secondaryinfo-entity-row:
Sometimes it is required to use 'custom:secondaryinfo-entity-row', here is how to style it (note that 'hui-toggle-entity-row' is added for example):
type: entities
entities:
  - type: 'custom:secondaryinfo-entity-row'
    secondary_info: some colored text
    style:
      hui-toggle-entity-row:
              .info .secondary {
                  color: red;
It looks similarly to the standard 'secondary_info' (no 'ha-relative-time' is specified).
Common styling: changing a color for all 'secondary_info':
type: entities
title: Common styling
style:
          .info .secondary: |
            ha-relative-time {
entities:
  - entity: sun.sun
  - entity: sun.sun
How to set different colors for a name & secondary-info:
type: entities
entities:
  - entity: sun.sun
    style:
          .info: |
              color: green;
            .info {
              color: red;
Additional styles for "secondary-info":
post
Colored RUN button row:
type: entities
title: Run button
entities:
  - type: button
    tap_action:
      action: none
    card_mod:
      style: |
        .flex {
          color: red;
  - type: button
    tap_action:
      action: none
    card_mod:
      style:
        ha-state-icon:
            ha-svg-icon {
              color: green;
  - type: button
    tap_action:
      action: none
    card_mod:
      style:
        .flex mwc-button:
            .mdc-button {
              color: orange !important;
  - type: section
    label: combined
  - type: button
    name: Colored icon & text
    tap_action:
      action: none
    card_mod:
      style:
        ha-state-icon:
            ha-svg-icon {
              color: green;
          .flex {
            color: red;
  - type: button
    name: Colored text & button
    tap_action:
      action: none
    card_mod:
      style:
        .flex mwc-button:
            .mdc-button {
            .flex {
              color: red;
  - type: button
    name: Colored icon, text & button
    tap_action:
      action: none
    card_mod:
      style:
        ha-state-icon:
            ha-svg-icon {
              color: green;
        .flex mwc-button:
            .mdc-button {
            .flex {
              color: red;
  - type: button
    name: Colored icon, text & button (express)
    tap_action:
      action: none
    card_mod:
      style: |
        :host {
          --paper-item-icon-color: green;
          color: red;
          --mdc-theme-primary: orange;
  - type: section
  - type: button
    tap_action:
      action: none
    card_mod:
      style:
        .flex mwc-button:
            .mdc-button {
              background: orange !important;
              margin-right: 10px;
              border: 1px solid black !important;
              border-radius: 10px !important;
Note: when a β€œbutton” row has an β€œentity” option specified - there is a difference in part of styling an icon, check here.
Colored section: (including colored label, colored section’s upper line, invisible section’s upper line)
type: entities
title: Colored section
entities:
  - type: section
    label: Colored section
    style: |
      .label {
        color: magenta !important;
  - entity: sun.sun
  - entity: sun.sun
  - type: section
    style: |
      .label {
  - entity: sun.sun
  - entity: sun.sun
  - type: section
    label: Colored section's line
    style: |
      .divider {
        background-color: red !important;
        margin-top: 32px !important;
        height: 8px !important;
  - entity: sun.sun
  - entity: sun.sun
  - type: section
    label: Invisible section's line
    style: |
      .divider {
        background-color: transparent !important;
  - entity: sun.sun
  - entity: sun.sun
Styling a section’s upper line includes:
  • "margin-top" - a space before the line;
  • "height" - a line’s thickness;
  • "background-color" - a line’s color.
Note: '!important' is specified.
Styling a divider row:
Styling should be done using native β€œstyle” option for β€œEntities card”.
Colored divider:
type: entities
title: Colored divider (not-card-mod)
entities:
  - entity: sun.sun
  - entity: sun.sun
  - type: divider
    style:
      height: 8px
  - entity: sun.sun
  - entity: sun.sun
  - type: divider
    style:
      background-color: magenta
  - entity: sun.sun
  - entity: sun.sun
Invisible divider (may be used as a spacing between rows):
type: entities
title: Invisible divider (not-card-mod)
entities:
  - entity: sun.sun
  - entity: sun.sun
  - type: divider
    style:
      height: 32px
  - entity: sun.sun
  - entity: sun.sun
Changing an icon’s color:
By default for entities like "sensor" (same for "device_tracker" , "person" , "zone" , …) an icon’s color does not depend on the entity’s state.
There are two methods for changing a color:
  • using a "--paper-item-icon-color" variable;
  • using a "color" CSS property.
For some row (methods #1, #2):
type: entities
entities:
  - entity: sensor.cleargrass_1_co2
    style: |
      :host {
type: entities
entities:
    card_mod:
      style:
            state-badge {
              color: red;
For all rows:
Method #1 (using a "--paper-item-icon-color" variable):
Note: for the 3rd row the color was overwritten by an individual style.
type: entities
style: |
  ha-card {
entities:
    name: 'Overwritten color (:host)'
    style: |
      :host {
        --paper-item-icon-color: cyan;
  - entity: sun.sun
Method #2 (using a "color" CSS property):
type: entities
card_mod:
  style:
    hui-sensor-entity-row:
            state-badge {
              color: red;
    hui-text-entity-row:
            state-badge {
              color: cyan;
entities:
  - entity: sun.sun
  - entity: sun.sun
    name: Overwritten color (:host) - failed
    card_mod:
      style: |
        :host {
          --paper-item-icon-color: orange !important;
    card_mod:
      style:
            state-badge {
Notes:
1.The 6th icon was not overwritten: the common styling was done by Method #2, the individual styling - by Method #1, so the overwriting failed.
2.The 7th icon was overwritten: the common styling was done by Method #2, the individual styling - by Method #2 (with "!important").
3.The 5th icon was not colored since the "hui-sensor-entity-row" and "hui-text-entity-row" do not affect the "input_boolean" row - the "hui-toggle-entity-row" must be used instead.
By default for entities like "binary_sensor" , "sun.sun" , "switch" , "input_boolean" - an icon’s color DOES depend on the entity’s state - if the property "state_color: true" is set for the card (or for this particular row). If it is set to "false", then the color DOES NOT depend on the state - use same Methods #1, #2 as for the "sensor" (described above).
  • using "--paper-item-icon-color" and "--paper-item-icon-active-color" variables;
Method #1 (using "--paper-item-icon-color" and "--paper-item-icon-active-color" variables):
For some row:
type: entities
state_color: true
entities:
  - entity: binary_sensor.battery_charging_cleargrass_1
    style: |
      :host {
        --paper-item-icon-active-color: red;
  - entity: sun.sun
  - entity: binary_sensor.service_off_value
    style: |
      :host {
For all rows:
Note: for the 4th row the colors were overwritten.
type: entities
state_color: true
style: |
  ha-card {
entities:
  - entity: sun.sun
    style: |
      :host {
        --paper-item-icon-active-color: green;
        --paper-item-icon-color: magenta;
For some row:
type: entities
state_color: true
entities:
  - entity: sun.sun
    card_mod:
      style:
            state-badge {
              color: red;
For all rows:
Notes:
  • state-color: false option is set;
  • for the 4th row the color was overwritten.
type: entities
state_color: false
card_mod:
  style:
            state-badge {
              color: cyan;
entities:
  - entity: sun.sun
    card_mod:
      style:
            state-badge {
Styling entity_picture:
By default (at least in the default stock theme) an "entity_picture" is displayed in a circle frame:
type: entities
entities:
  - entity: person.ildar
The reason of it - the "border-radius: 50%" property.
Here is how to make a square frame with round corners:
type: entities
entities:
style:
  hui-simple-entity-row $ hui-generic-entity-row $: |
    state-badge {
      border-radius: 10%;
Also we may apply filters to the "entity_picture":
type: entities
entities:
    style:
      hui-generic-entity-row$: |
        state-badge {
          filter: grayscale(80%);
Wrapped text:
type: entities
entities:
  - entity: sun.sun
    name: Wrapped Wrapped Wrapped Wrapped Wrapped Wrapped Wrapped
    style:
          .info {
            color: red;
  - entity: sun.sun
Also check here for an alternative solution:
Changing a font-size:
See here
Resizing an icon:
For the whole card:
type: entities
show_header_toggle: false
entities:
  - entity: sun.sun
  - entity: sun.sun
style: |
  ha-card {
For some row:
type: entities
entities:
  - entity: sun.sun
  - entity: sun.sun
    style: |
      :host {
Resizing β€œentity_picture”:
There are 2 ways:
– increase a placeholder area for an image;
– increase an image with a possible overflow effect.
        type: entities
        entities:
            card_mod:
              style:
                  state-badge {
                    height: 60px;
                    flex-basis: 60px !important;
            card_mod:
              style:
                  state-badge {
                    transform: scale(1.5);
Styling a card’s title if a main icon is specified:
The main icon - an icon in the card’s title.
title: Card with icon
cards:
  - type: entities
    title: Colored icon & title
    icon: 'mdi:car'
    style: |
        color: red;
    entities:
      - entity: sun.sun
      - entity: sun.sun
  - type: entities
    title: Colored icon
    icon: 'mdi:car'
    style:
      .card-header .name .icon:
          ha-svg-icon {
            color: orange;
    entities:
      - entity: sun.sun
      - entity: sun.sun
  - type: entities
    title: Colored icon & title (different)
    icon: 'mdi:car'
    style:
      .card-header:
        .name .icon:
            ha-svg-icon {
              color: orange;
          .name {
            color: red;
    entities:
      - entity: sun.sun
      - entity: sun.sun
  - type: entities
    title: Colored title
    icon: 'mdi:car'
    style:
      .card-header:
        .name .icon:
            ha-svg-icon {
              color: var(--paper-item-icon-color);
          .name {
            color: red;
    entities:
      - entity: sun.sun
      - entity: sun.sun
Resizing the icon:
type: entities
title: Resized icon
icon: 'mdi:car'
style:
  .card-header: |
    .name .icon {
entities:
  - entity: sun.sun
  - entity: sun.sun
Hiding an icon or a state:
type: entities
entities:
  - entity: sun.sun
  - entity: sun.sun
    card_mod:
      style:
              display: none;
  - entity: sun.sun
    card_mod:
      style:
            state-badge {
              display: none;
  - entity: sun.sun
    card_mod:
      style:
            state-badge:
                ha-state-icon {
                  display: none;
Adding a prefix or suffix, math operations, replacing a value:
post
@Ildar_Gabdullin wow! You might want to consider making a PR in GitHub to add this documentation.
Styling β€˜custom:multiple-entity-row’
Intro:
Let’s call the β€œleft” entity as the β€œmain entity” (for which we may display a state on the last right column), all right entities - β€œsecondary entities”.
For secondary entities you may use a β€œstyles” option (no card-mod required) to set a color and some other CSS properties:
    entities:
      - entity: sensor.xxxxxxx
        styles:  ### styling a β€œstate” string
          width: 80px
          text-align: left
          color: red
or
        styles:
          --paper-item-icon-color: red  ### styling an icon
or
        styles:
          --secondary-text-color: red  ### styling a header
Same approach may be used to style the main entity’s state – except changing the main icon.
Using the β€œstyles” option is a good choice if styles (colors etc) are static. If they are dynamic (depend on some conditions) then you should either place the whole row inside config-template-card (supports JS) or use card-mod (supports jinjia2).
Colored whole text:
type: entities
entities:
  - type: custom:multiple-entity-row
    entity: sensor.time_home
    style: |
      :host {
        color: magenta;
    entities:
      - entity: sensor.time_home
        attribute: jamsrate
        unit: ''
      - entity: sensor.empty_value
        unit: false
        icon: mdi:car
        name: Π½Π° Π΄ΠΎΡ€ΠΎΠ³Ρƒ
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: 'mdi:link'
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Note: the last cyan icon is colored by using "multiple-entity-row::styles" property (not by 'card-mod').
Colored title:
type: entities
entities:
    style:
          .info {
            color: orange;
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Colored state & header:
type: entities
entities:
    style: |
      .state.entity {
        color: magenta;
      .state.entity span {
        color: cyan;
    entities:
      - entity: sun.sun
    show_state: true
    state_header: CO2
Colored headers (one color):
type: entities
entities:
    style: |
      .entity span {
        color: red;
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Colored headers (different colors):
type: entities
entities:
    style: |
      .entities-row div.entity:nth-child(1) span {
        color: red;
      .entities-row div.entity:nth-child(3) span {
        color: green;
    entities:
        attribute: jamsrate
        unit: ''
      - entity: sensor.service_empty_value
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Colored values (one color):
type: entities
entities:
    style: |
      .entity {
        color: magenta;
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Colored values (different colors):
type: entities
entities:
    style: |
      .entities-row div.entity:nth-child(1)  {
        color: orange;
      .entities-row div.entity:nth-child(3)  {
        color: magenta;
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Changing a color for 'secondary_info' for some row:
type: entities
entities:
    style:
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    name: Colored secondary_info
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
If secondary_info is not some relative time:
post
Changing a color of 'secondary_info' for all rows:
type: entities
style:
entities:
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
  - type: 'custom:multiple-entity-row'
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Different colors for title & "secondary_info":
type: entities
entities:
    style:
          .info {
            color: orange;
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Colored icons (one color for all icons):
Note that the last icon’s color is managed by 'multiple-entity-row::styles' property.
type: entities
entities:
    style: |
      :host {
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        styles:
        tap_action:
          action: url
          url_path: xxxcc
    name: Colored icons (except one)
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Colored 1st icon:
type: entities
entities:
    entity: sensor.yandex_time_home_person_ildar
    style:
          state-badge {
            color: orange;
    entities:
      - entity: sensor.yandex_time_home_person_ildar
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
    name: Colored 1st icon
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Colored secondary icons:
type: entities
entities:
    card_mod:
      style:
          state-badge {
            color: green;
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
    name: Colored secondary icons
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Colored all icons (different colors):
type: entities
entities:
    style:
          state-badge {
            color: orange;
          div.entity:nth-child(2) state-badge {
            color: green;
          div.entity:nth-child(4) state-badge {
            color: red;
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
    name: Colored all icons
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Wrapped text:
type: entities
entities:
    style:
          .info {
            color: red;
    entities:
        attribute: jamsrate
        unit: ''
        unit: false
        icon: mdi:car
        unit: ''
        styles:
          width: 60px
          text-align: center
        unit: false
        icon: mdi:link
        tap_action:
          action: url
          url_path: xxxcc
        styles:
    unit: ''
    icon: mdi:account
    toggle: false
    show_state: false
    state_header: ''
Rotated icons:
title: Rotate
cards:
  - type: entities
    entities:
        style:
              state-badge {
                color: orange;
                transform: rotate(-45deg);
                color: green;
                color: red;
                transform: rotate(45deg);
        entities:
            attribute: jamsrate
            unit: ''
            unit: false
            icon: mdi:car
            unit: ''
            styles:
              width: 60px
              text-align: center
            unit: false
            icon: mdi:car
            tap_action:
              action: url
              url_path: xxxcc
        unit: ''
        icon: mdi:car
        toggle: false
        show_state: false
        state_header: ''
Changed font-size:
title: font-size
cards:
  - type: entities
    entities:
        style: |
          :host {
            font-size: 8px;
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        name: Whole row (except headers)
        icon: mdi:account
        show_state: false
        state_header: ''
  - type: entities
    entities:
        style:
              .info {
                font-size: 8px;
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        name: Title (incl. secondary_info)
        icon: mdi:account
        show_state: false
        state_header: ''
  - type: entities
    entities:
        style: |
          .entities-row .entity span {
            font-size: 18px
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        icon: mdi:account
        show_state: false
        state_header: ''
  - type: entities
    entities:
        style: |
            font-size: 7px;
            font-size: 17px;
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        name: Headers (different)
        icon: mdi:account
        show_state: false
        state_header: ''
  - type: entities
    entities:
        style: |
          .entity {
            font-size: 7px;
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        icon: mdi:account
        show_state: false
        state_header: ''
  - type: entities
    entities:
        style: |
            font-size: 7px;
            font-size: 17px;
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        name: Values (different)
        icon: mdi:account
        show_state: false
        state_header: ''
  - type: entities
    entities:
        style:
            .info .secondary: |
              ha-relative-time {
                font-size: 20px;
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        icon: mdi:account
        show_state: false
        state_header: ''
Resizing icons:
title: Resizing icon
cards:
  - type: entities
    entities:
        style: |
          :host {
            --mdc-icon-size: 40px;
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        icon: mdi:account
        show_state: false
        state_header: ''
  - type: entities
    entities:
        style:
            state-badge {
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        icon: mdi:account
        show_state: false
        state_header: ''
  - type: entities
    entities:
        style:
            state-badge {
              --mdc-icon-size: 40px !important;
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        icon: mdi:account
        show_state: false
        state_header: ''
  - type: entities
    entities:
        style:
              --mdc-icon-size: 10px;
        entities:
            attribute: jamsrate
            icon: mdi:car
            icon: mdi:link
        name: Seconary icons (different)
        icon: mdi:account
        show_state: false
        state_header: ''
Hidden main icon:
type: entities
entities:
    style:
        state-badge {
          display: none;
    entities:
        attribute: jamsrate
        unit: false
        icon: mdi:car
        unit: false
        icon: mdi:link
    name: Hidden main icon
    icon: mdi:account
    show_state: false
Info below the row (for example, for headers):
Note: states() & any other jinjia2 stuff may be used for content value.
type: entities
entities:
    entity: sun.sun
    tap_action: none
    show_state: false
    entities:
      - entity: sensor.cleargrass_1_temp
        styles:
          width: 50px
          text-align: left;
      - entity: sensor.cleargrass_2_temp
        styles:
          width: 50px
          text-align: left;
        styles:
          width: 50px
          text-align: left;
        styles:
          width: 50px
          text-align: left;
      - entity: sensor.non_existant
    card_mod:
      style: |
        hui-generic-entity-row .entities-row div.entity:nth-child(1) div::after
          color: var(--secondary-text-color);
          font-size: 0.7rem;
          content: "\A kitchen";
          white-space: pre;
        hui-generic-entity-row .entities-row div.entity:nth-child(2) div::after
          font-size: 0.7rem;
          content: "\A hall";
          white-space: pre;
        hui-generic-entity-row .entities-row div.entity:nth-child(3) div::after
          font-size: 0.7rem;
          content: "\A bedroom";
          white-space: pre;
        hui-generic-entity-row .entities-row div.entity:nth-child(4) div::after
          font-size: 0.7rem;
          content: "\A balcony";
          white-space: pre;
Small note for the main entity:
type: entities
entities:
    entity: sun.sun
    show_state: false
    entities:
      - entity: sun.sun
      - entity: sun.sun
    card_mod:
      style:
          .info .secondary::before {
              content: "{{ 'hello\A ' }}";
              color: red;
              white-space: pre;
Move headers to the bottom:
post
Replacing a value, math operations:
post
More examples here.
+1 for this. Extensive examples like this is what we need for a lot of the more complex customisations and cards.
Styling 'custom:fold-entity-row':
Colored text:
      - type: entities
        entities:
          - type: custom:fold-entity-row
            head:
              entity: sun.sun
              card_mod:
                style: |
                  :host {
                    color: red;
            padding: 15
            open: true
            entities:
              - entity: sun.sun
                card_mod:
                  style: |
                    :host {
                      color: lightgreen;
              - entity: sun.sun
              - entity: sun.sun
      - type: entities
        entities:
            card_mod:
              style: |
                :host {
                  color: red;
            head:
              entity: sun.sun
              name: common (:host, card level)
            padding: 15
            open: true
            entities:
              - entity: sun.sun
                card_mod:
                  style: |
                    :host {
                      color: lightgreen;
              - entity: sun.sun
              - entity: sun.sun
      - type: entities
        entities:
            head:
              entity: sun.sun
              card_mod:
                style:
                    .info {
                      color: red;
            padding: 15
            open: true
            entities:
              - entity: sun.sun
                card_mod:
                  style:
                      .info {
                        color: cyan;
              - entity: sun.sun
      - type: entities
        entities:
            card_mod:
              style:
                div#head :first-child $ hui-generic-entity-row $: |
                  .info {
                    color: red;
                div#items div:not(#measure):
                  ':first-child $ hui-generic-entity-row $': |
                    .info {
                      color: cyan;
            head:
              entity: sun.sun
              name: individual (DOM, card level, for head)
            padding: 15
            open: true
            entities:
              - entity: sun.sun
                name: common (DOM, card level, for items)
              - entity: zone.home
              - entity: sensor.processor_use
                name: individual color (DOM)
                card_mod:
                  style:
                      .info {
Colored chevron button:
type: entities
entities:
  - type: 'custom:fold-entity-row'
    card_mod:
      style: |
        div#head ha-icon {
          color: red;
    head:
      entity: sun.sun
    padding: 15
    open: true
    entities:
      - entity: sun.sun
      - entity: sun.sun
Chevron button with a border:
type: entities
title: chevron with border
entities:
    card_mod:
      style: |
        div#head ha-icon {
          border: 1px solid var(--paper-item-icon-color);
    head:
      type: section
      label: More data
    padding: 15
    open: true
    entities:
      - entity: sun.sun
      - entity: sun.sun
How to remove a chevron button for a clickable header:
Usually the items are shown by pressing the chevron button.
If the "clickable: true" property is set, then the items may be displayed by clicking on the header.
Then you can remove the chevron button:
      - type: entities
        entities:
          - sun.sun
            head:
              entity: sun.sun
              card_mod:
                style: |
                  :host {
                    font-weight: bold;
              tap_action:
                action: fire-dom-event
                fold_row: true
            padding: 15
            open: true
            entities:
              - entity: sun.sun
              - entity: sun.sun
            card_mod:
              style: |
                div#head ha-icon {
                  display: none;
                div#head :first-child {
                  max-width: unset;
It will be great if these examples help beginners to learn.
Update:
Animation for Entities card:
NOTE:
Blinking title:
Note: a margin for the 1st row has to be increased.
type: entities
title: Blinking title
icon: mdi:car
entities:
  - entity: sun.sun
  - sun.sun
card_mod:
  style:
    div:nth-child(1):
          hui-generic-entity-row {
            margin-top: 10px;
      .card-header {
        background-color: red;
        color: white;
        animation: blinking 2s linear alternate infinite;
      @keyframes blinking {
        0% {opacity: 0;}
        100% {opacity: 1;}
Whole card blinking:
type: entities
title: Common style
icon: mdi:car
entities:
  - entity: sensor.cleargrass_1_temperature
card_mod:
  style: |
    ha-card {
      color: red;
      0% {opacity: 0;}
      100% {opacity: 1;}
Blinking rows:
type: entities
title: Common style
icon: mdi:car
entities:
card_mod:
  style: |
    .card-content {
      color: red;
      animation: blinking 0.5s linear alternate infinite;
      0% {opacity: 1;}
      100% {opacity: 0;}
Different elements blinking:
type: entities
title: Common style
icon: mdi:car
entities:
  - sun.sun
  - sensor.cleargrass_1_co2
  - sun.sun
card_mod:
  style:
            state-badge {
              color: orange;
              0% {opacity: 0;}
              100% {opacity: 1;}
              color: red;
              0% {opacity: 0;}
              100% {opacity: 1;}
            .info {
              color: magenta;
              0% {opacity: 0;}
              100% {opacity: 1;}
    .card-header:
      .name .icon:
          ha-svg-icon {
            color: green;
            0% {opacity: 0;}
            100% {opacity: 1;}
        .name {
          color: cyan;
          0% {opacity: 1;}
          100% {opacity: 0;}
Blinking for rows’ elements, individual style:
type: entities
title: Individual style
icon: mdi:car
entities:
  - entity: sun.sun
    card_mod:
      style:
            state-badge {
              animation:  blink 2s linear alternate infinite;
            @keyframes blink {
              0% {opacity: 1;}
              100% {opacity: 0;}
              color: red;
              0% {opacity: 0;}
              100% {opacity: 1;}
    card_mod:
      style:
            state-badge {
            @keyframes blink {
              0% {opacity: 0;}
              100% {opacity: 1;}
            .info {
              color: magenta;
              animation: blinking 4s linear alternate infinite;
              0% {opacity: 0;}
              100% {opacity: 1;}
Animations for icons:
type: entities
entities:
  - entity: sun.sun
    icon: 'mdi:fan'
    style:
          state-badge  {
            color: orange;
            animation: rotation 0.5s linear infinite;
          @keyframes rotation {
            0% {
              transform: rotate(0deg);
            100% {
              transform: rotate(360deg);
  - entity: sun.sun
    icon: 'mdi:bell'
    style:
          state-badge {
            color: red;
            animation: wobbling 1s linear infinite alternate;
          @keyframes wobbling {
            0% {
            100% {
              transform: rotate(+45deg);
  - entity: sun.sun
    style:
          state-badge {
            animation: coloring 8s linear infinite alternate;
          @keyframes coloring {
            0% {
              color: red;
            17% {
              color: orange;
            34% {
              color: yellow;
            51% {
              color: green;
            68% {
              color: lightblue;
            85% {
              color: blue;
            100% {
              color: violet;
  - entity: sun.sun
    icon: 'mdi:radio-tower'
    style:
          state-badge {
            animation: resizing 1s linear infinite alternate;
          @keyframes resizing {
            0% {
            25% {
              --mdc-icon-size: 15px;
            50% {
              --mdc-icon-size: 20px;
            75% {
              --mdc-icon-size: 26px;
            100% {
              --mdc-icon-size: 32px;
  - entity: sun.sun
    icon: 'mdi:bus-side'
    style:
          state-badge {
            animation: stretching 1s linear infinite alternate;
          @keyframes stretching {
            0% {
              transform: scaleX(0.5);
            100% {
              transform: scaleX(2.0);
  - entity: sun.sun
    icon: 'mdi:human-handsup'
    style:
          state-badge {
            0% {
              transform: scaleY(0.5);
            100% {
              transform: scaleY(2.0);
  - entity: sun.sun
    icon: 'mdi:timer-sand'
    style:
          state-badge {
            animation: flipping 1s linear infinite;
          @keyframes flipping {
            0% {
              transform: rotateX(0deg);
            100% {
              transform: rotateX(360deg);
  - entity: sun.sun
    icon: 'mdi:arrow-left-right'
    style:
          state-badge {
            animation: shifting 1s linear infinite alternate;
          @keyframes shifting {
            0% {
              transform: translate(-5px,0);
            100% {
              transform: translate(5px,0);
  - entity: sun.sun
    icon: 'mdi:arrow-up-down'
    style:
          state-badge {
            animation: jumping 1s linear infinite alternate;
          @keyframes jumping {
            0% {
              transform: translate(0,-5px);
            100% {
              transform: translate(0,5px);
  - entity: sun.sun
    style:
          state-badge {
            animation: disappear 1s linear infinite alternate;
          @keyframes disappear {
            0% {
              opacity: 0;
            100% {
              opacity: 1;
If you need a conditional animation - see these examples for rotation:
a) rotation ON/OFF:
          state-badge  {
            color: orange;
            {% if ..... %}
            {% endif %}
b) various speed:
          state-badge  {
            color: orange;
            {% set SPEED = .... %}
            animation: rotation {{SPEED}}s linear infinite;
Update (20.05.22):
  1. This animation does not work on iOS 15.4.1, iOS 12.5.5 & MacOS:
            0% {
Use this variants instead:
  - entity: sun.sun
    name: resizing (height, width)
    icon: mdi:radio-tower
    card_mod:
      style:
        hui-generic-entity-row $ state-badge $ ha-state-icon $ ha-icon $: |
          ha-svg-icon {
            0% {
              height: 10px;
              width: 10px;
            25% {
              height: 15px;
              width: 15px;
            50% {
              height: 20px;
              width: 20px;
            75% {
              height: 26px;
              width: 26px;
            100% {
              height: 32px;
              width: 32px;
  - entity: sun.sun
    card_mod:
      style:
          ha-svg-icon {
            0% {
              transform: scale(0.3,0.3);
            25% {
              transform: scale(0.7,0.7);
            50% {
              transform: scale(1,1);
            75% {
              transform: scale(1.15,1.15);
            100% {
              transform: scale(1.3,1.3);
Animation using custom properties is promised to be added in Safari 16.
  1. This animation glitches on iOS 15.4.1, iOS 12.5.5 & MacOS (glitches affecting a whole card):
            0% {
No solution for this so far.
The animation may work OK but also may cause glitches. This is Apple, sorry.
Update 18.04.23: flipping is OK on iOS 15.7.3 (Companion App)
I’m trying to change the size of the text on a light card and I apparently don’t understand enough css to do it. Below is what I have and I’ve tried multiple variants, but I can’t seem to get it to work.
type: light
entity: light.kitchen_lights
style: |
ha-card {
--name-font-size: 10px;
How to change a font-size for Entities card:
type: entities
title: Size for title
card_mod:
  style: |
    .card-header {
      font-size: 35px;
      color: red;
entities:
  - entity: sun.sun
  - entity: sun.sun
    name: Size for whole row
    card_mod:
      style: |
        :host {
          font-size: 25px;
          color: red;
  - entity: sun.sun
    name: Size for name & secondary_info
    card_mod:
      style:
            .info {
              font-size: 10px;
              color: red;
  - entity: sun.sun
    name: Size for name & secondary_info (different)
    card_mod:
      style:
            .info: |
                color: green;
                font-size: 25px;
              .info {
                color: red;
                font-size: 8px;
  - entity: sun.sun
    name: Size for name only
    card_mod:
      style:
            .info: |
                color: orange;
                font-size: var(--mdc-typography-body1-font-size, 1rem);
              .info {
                color: red;
                font-size: 8px;
  - entity: sun.sun
    name: Size for value
    card_mod:
      style:
            font-size: 10px;
            color: red;
  - entity: sun.sun
    name: "!!!! Size for value (w/o sec_info) !!!!"
    card_mod:
      style:
            font-size: 10px;
            color: red;
  - entity: sun.sun
    name: Size for secondary_info
    card_mod:
      style:
            .info .secondary: |
              ha-relative-time {
                font-size: 20px;
Note that for setting a β€œstandard” font size I had to use a "font-size: var(--mdc-typography-body1-font-size, 1rem)" in the "Size for name only" case, I do not think it is good (kind of β€˜hard coding’), and may be there is a better solution…
Another option for changing the title’s font-size - using a "--ha-card-header-font-size" variable:
type: entities
title: 'Style: title font-size'
entities:
  - entity: sun.sun
style: |
  ha-card {
    --ha-card-header-font-size: 35px;
How to change a font-size for a "button" row:
type: entities
title: Size for button
entities:
  - type: button
    tap_action:
      action: call-service
      service: homeassistant.update_entity
      service_data:
        entity_id: sun.sun
  - type: button
    tap_action:
      service_data:
        entity_id: sun.sun
    card_mod:
      style: |
        :host {
          --mdc-typography-button-font-size: 20px;
Can you use triple backticks instead of single ones?
Sorry, apparently I was not paying close enough attention to that warning that popped up. Here ya go:
type: light
style: |
  ha-card {
