This is a summary article about how to use the IAMMETER`s Wi-Fi energy monitor in the home assistant, including the integrated methods and some solutions.
WEM3080T:3 phase, WYE connection, supports Net energy metering,split phase usage
WEM3080:1phase energy meter,wifi
Integrate methods
There are four ways to integrate the IAMMETER`s Wi-Fi energy meter into the home assistant.
integration method | interface | refresh period | tutorial | video | |
1 | Core integration | HTTP | 1 min | Integrate IAMMETER`s energy meter into Home assistant | Integrate the Wi-Fi energy meter into home assistant |
2 | Modbus/TCP sensor | Modbus/TCP | 1 s | Request the Wi-Fi energy meter from the Modbus TCP sensor in Home Assistant | Integrate the Wi-Fi power meter into home assistant by modbu/tcp |
3 | MQTT sensor | MQTT | 12 s | Set the username and pwd of the MQTT ,connect the energy meter to the Home Assistant | Integrate the wifi energy meter into Home assistant by MQTT mode |
4 | HACS | HTTP | 1 min | IAMMETER@HACS | Video tutorial:HACS |
Solutions
Monitor your solar PV system in Home Assistant( Energy Dashboard VS Energy Management)
Building an Local PV monitoring system with Home Assistant +Grafana+InfluxDB
