Thanks for the 58. It should be 85 and i fixed it. It is now showing connected to Home Assistant. But there is no SoneOff S31 device showing on the MQTT in the dashboard? Here is the tasmota console logs.
0:00:00.770 WIF: Connecting to AP1 Sasha Channel 1 BSSId 68:4A:76:AD:2E:06 in mode 11n as WashingMachinePlug…
00:00:03.544 WIF: Connected
00:00:03.755 HTP: Web server active on WashingMachinePlug with IP address 192.168.86.58
16:11:30.406 MQT: Attempting connection…
16:11:31.361 MQT: Connected
16:11:31.365 MQT: tele/WashingMachingPlug/LWT = Online (retained)
16:11:31.367 MQT: cmnd/WashingMachingPlug/POWER =
16:11:31.377 MQT: tele/WashingMachingPlug/INFO1 = {“Info1”:{“Module”:“Sonoff S31”,“Version”:“12.0.2.1(tasmota)”,“FallbackTopic”:“cmnd/DVES_F41931_fb/”,“GroupTopic”:“cmnd/tasmotas/”}}
16:11:31.382 MQT: tele/WashingMachingPlug/INFO2 = {“Info2”:{“WebServerMode”:“Admin”,“Hostname”:“WashingMachinePlug”,“IPAddress”:“192.168.86.58”}}
16:11:31.386 MQT: tele/WashingMachingPlug/INFO3 = {“Info3”:{“RestartReason”:“Software/System restart”,“BootCount”:1378}}
16:11:31.390 MQT: stat/WashingMachingPlug/RESULT = {“POWER”:“ON”}
16:11:31.394 MQT: stat/WashingMachingPlug/POWER = ON
16:11:32.235 QPC: Reset
16:11:35.168 MQT: tele/WashingMachingPlug/STATE = {“Time”:“2022-08-11T16:11:35”,“Uptime”:“0T00:00:11”,“UptimeSec”:11,“Heap”:27,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER”:“ON”,“Wifi”:{“AP”:1,“SSId”:“Sasha”,“BSSId”:“68:4A:76:AD:2E:06”,“Channel”:1,“Mode”:“11n”,“RSSI”:100,“Signal”:-49,“LinkCount”:1,“Downtime”:“0T00:00:05”}}
16:11:35.179 MQT: tele/WashingMachingPlug/SENSOR = {“Time”:“2022-08-11T16:11:35”,“ENERGY”:{“TotalStartTime”:“2022-07-10T21:56:15”,“Total”:0.010,“Yesterday”:0.000,“Today”:0.000,“Period”: 0,“Power”: 0,“ApparentPower”: 0,“ReactivePower”: 0,“Factor”:0.00,“Voltage”:119,“Current”:0.000}}
16:16:36.208 MQT: tele/WashingMachingPlug/STATE = {“Time”:“2022-08-11T16:16:36”,“Uptime”:“0T00:05:12”,“UptimeSec”:312,“Heap”:24,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER”:“ON”,“Wifi”:{“AP”:1,“SSId”:“Sasha”,“BSSId”:“68:4A:76:AD:2E:06”,“Channel”:1,“Mode”:“11n”,“RSSI”:100,“Signal”:-49,“LinkCount”:1,“Downtime”:“0T00:00:05”}}
16:16:36.218 MQT: tele/WashingMachingPlug/SENSOR = {“Time”:“2022-08-11T16:16:36”,“ENERGY”:{“TotalStartTime”:“2022-07-10T21:56:15”,“Total”:0.010,“Yesterday”:0.000,“Today”:0.000,“Period”: 0,“Power”: 0,“ApparentPower”: 0,“ReactivePower”: 0,“Factor”:0.00,“Voltage”:119,“Current”:0.000}}
16:21:36.171 MQT: tele/WashingMachingPlug/STATE = {“Time”:“2022-08-11T16:21:36”,“Uptime”:“0T00:10:12”,“UptimeSec”:612,“Heap”:24,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER”:“ON”,“Wifi”:{“AP”:1,“SSId”:“Sasha”,“BSSId”:“68:4A:76:AD:2E:06”,“Channel”:1,“Mode”:“11n”,“RSSI”:100,“Signal”:-49,“LinkCount”:1,“Downtime”:“0T00:00:05”}}
16:21:36.184 MQT: tele/WashingMachingPlug/SENSOR = {“Time”:“2022-08-11T16:21:36”,“ENERGY”:{“TotalStartTime”:“2022-07-10T21:56:15”,“Total”:0.010,“Yesterday”:0.000,“Today”:0.000,“Period”: 0,“Power”: 0,“ApparentPower”: 0,“ReactivePower”: 0,“Factor”:0.00,“Voltage”:120,“Current”:0.000}}
16:25:44.615 CMD: SetOption19 0
16:25:44.621 MQT: stat/WashingMachingPlug/RESULT = {“SetOption19”:“OFF”}
16:25:49.739 CMD: SetOption19 1
16:25:49.745 MQT: stat/WashingMachingPlug/RESULT = {“SetOption19”:“ON”}
16:27:09.676 MQT: stat/WashingMachingPlug/STATUS4 = {“StatusMEM”:{“ProgramSize”:621,“Free”:380,“Heap”:23,“ProgramFlashSize”:1024,“FlashSize”:4096,“FlashChipId”:“16405E”,“FlashFrequency”:40,“FlashMode”:3,“Features”:[“00000809”,“8F9AC787”,“04368001”,“000000CF”,“010013C0”,“C000F981”,“00004084”,“00001000”,“14000020”,“00000000”],“Drivers”:“1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37,38,45,62”,“Sensors”:“1,2,3,4,5,6”}}
16:27:09.684 MQT: stat/WashingMachingPlug/STATUS5 = {“StatusNET”:{“Hostname”:“WashingMachinePlug”,“IPAddress”:“192.168.86.58”,“Gateway”:“192.168.86.1”,“Subnetmask”:“255.255.255.0”,“DNSServer1”:“192.168.86.1”,“DNSServer2”:“0.0.0.0”,“Mac”:“E8:68:E7:F4:19:31”,“Webserver”:2,“HTTP_API”:1,“WifiConfig”:4,“WifiPower”:17.0}}
16:27:09.689 MQT: stat/WashingMachingPlug/STATUS6 = {“StatusMQT”:{“MqttHost”:“192.168.86.85”,“MqttPort”:1883,“MqttClientMask”:“DVES_%06X”,“MqttClient”:“DVES_F41931”,“MqttUser”:“Mqttuser”,“MqttCount”:1,“MAX_PACKET_SIZE”:1200,“KEEPALIVE”:30,“SOCKET_TIMEOUT”:4}}
16:27:09.696 MQT: stat/WashingMachingPlug/STATUS7 = {“StatusTIM”:{“UTC”:“2022-08-11T15:27:09”,“Local”:“2022-08-11T16:27:09”,“StartDST”:“2022-03-27T02:00:00”,“EndDST”:“2022-10-30T03:00:00”,“Timezone”:"+01:00",“Sunrise”:“05:37”,“Sunset”:“20:12”}}
16:27:09.701 MQT: stat/WashingMachingPlug/STATUS9 = {“StatusPTH”:{“PowerDelta”:[0,0,0],“PowerLow”:0,“PowerHigh”:0,“VoltageLow”:0,“VoltageHigh”:0,“CurrentLow”:0,“CurrentHigh”:0}}
16:27:09.709 MQT: stat/WashingMachingPlug/STATUS10 = {“StatusSNS”:{“Time”:“2022-08-11T16:27:09”,“ENERGY”:{“TotalStartTime”:“2022-07-10T21:56:15”,“Total”:0.010,“Yesterday”:0.000,“Today”:0.000,“Power”: 0,“ApparentPower”: 0,“ReactivePower”: 0,“Factor”:0.00,“Voltage”:119,“Current”:0.000}}}
16:27:09.716 MQT: stat/WashingMachingPlug/STATUS11 = {“StatusSTS”:{“Time”:“2022-08-11T16:27:09”,“Uptime”:“0T00:15:45”,“UptimeSec”:945,“Heap”:21,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER”:“ON”,“Wifi”:{“AP”:1,“SSId”:“Sasha”,“BSSId”:“68:4A:76:AD:2E:06”,“Channel”:1,“Mode”:“11n”,“RSSI”:98,“Signal”:-51,“LinkCount”:1,“Downtime”:“0T00:00:05”}}}
16:27:09.767 MQT: stat/WashingMachingPlug/RESULT = {“NtpServer1”:“pool.ntp.org”}
16:27:09.792 MQT: stat/WashingMachingPlug/RESULT = {“FullTopic”:"%prefix%/%topic%/"}
16:27:09.842 MQT: stat/WashingMachingPlug/RESULT = {“SwitchTopic”:“0”}
16:27:10.893 MQT: stat/WashingMachingPlug/RESULT = {“MqttRetry”:10}
16:27:10.918 MQT: stat/WashingMachingPlug/RESULT = {“SensorRetain”:“OFF”}
16:27:11.944 MQT: stat/WashingMachingPlug/RESULT = {“TelePeriod”:300}
16:27:11.975 MQT: stat/WashingMachingPlug/RESULT = {“Prefix1”:“cmnd”}
16:27:12.025 MQT: stat/WashingMachingPlug/RESULT = {“Prefix2”:“stat”}
16:27:12.054 MQT: stat/WashingMachingPlug/RESULT = {“Prefix3”:“tele”}
16:27:12.168 MQT: tele/WashingMachingPlug/STATE = {“Time”:“2022-08-11T16:27:12”,“Uptime”:“0T00:15:48”,“UptimeSec”:948,“Heap”:24,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER”:“ON”,“Wifi”:{“AP”:1,“SSId”:“Sasha”,“BSSId”:“68:4A:76:AD:2E:06”,“Channel”:1,“Mode”:“11n”,“RSSI”:100,“Signal”:-50,“LinkCount”:1,“Downtime”:“0T00:00:05”}}
16:27:12.179 MQT: tele/WashingMachingPlug/SENSOR = {“Time”:“2022-08-11T16:27:12”,“ENERGY”:{“TotalStartTime”:“2022-07-10T21:56:15”,“Total”:0.010,“Yesterday”:0.000,“Today”:0.000,“Period”: 0,“Power”: 0,“ApparentPower”: 0,“ReactivePower”: 0,“Factor”:0.00,“Voltage”:119,“Current”:0.000}}
16:27:13.101 MQT: stat/WashingMachingPlug/RESULT = {“StateText1”:“OFF”}
16:27:13.127 MQT: stat/WashingMachingPlug/RESULT = {“StateText2”:“ON”}
16:27:13.155 MQT: stat/WashingMachingPlug/RESULT = {“StateText3”:“TOGGLE”}
16:27:13.206 MQT: stat/WashingMachingPlug/RESULT = {“StateText4”:“HOLD”}
16:27:14.259 MQT: stat/WashingMachingPlug/RESULT = {“Command”:“Unknown”}
