πŸ”› Smart Relay - Contactor
GitHub Click Here
Like this blueprint? Consider hitting the :heart: button below :+1:
Version: 1.1
The most common automation used for a relay - contactor. It has Normally Open & Normally Closed contacts controlled by a switch entity :partying_face:
Need help? :eyes: See our FAQ: Click Here
:newspaper: The Automation Process:
  • When you turn the switch ON it will turn ON the Normal Open contact and turn OFF the Normally Closed contact.
  • When you turn the switch OFF it will turn OFF the Normal Open contact and turn ON the Normally Closed contact.
:question: If you have a β€œpush button” rather than a β€œswitch” then I have a different blueprint called :nazar_amulet: Push Button Relay - Contactor for this.
:rocket: CHANGELOG
Version: 1.1 - 30 Oct-22 initial release
:shield: MY OTHER BLUEPRINTS
:bulb: Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time
:shower: Bathroom Humidity Exhaust Fan
:toilet: Toilet Exhaust Fan with time delay
:hourglass_flowing_sand: Entity - Run ON Timer
:gear: Turn Light, Switch or Scene On & Off with Trigger Conditions
:thermometer: Temperature Control Exhaust Fan
:snowflake: Temperature Control Exhaust Fan - Inverted
:stopwatch: Timer Relay - Run ON Timer
FAQ
Q: What type of switch can I use?
A: The switch must have a state that goes ON when you switch / press it, and then when you switch / press it again the state goes OFF. If you have a push button that goes ON/OFF in one press and when you press it again it will go ON/OFF then I have a different Blueprint called Push Button Relay - Contactor. It works the same as this blueprint but the trigger is different.
Q: Can I put the same entity into the normally open & normally closed fields?
A: No, you must only choose one field, normally open or normally closed per entity.
