♾ Sensor Light Add On - Media & Movie Lights - House Alarm Lights - Smoke Alarm Lights & Exhaust Fans + More
FAQ - How To Use The Automation Link Option
Currently the automation link supports a toggle helper. To create a toggle helper follow these steps.
  1. Go to setting > Devices & Services > click on the helpers tab, then click ‘Create Helper’ and select ‘Toggle Helper’
  2. Add your name you would like to call the toggle helper and change the icon to your liking, then click ‘Create’.
    2
  3. You now will have a toggle helper you can use in both automations :tada:
Once we have a toggle helper we can add it to our automations.
:infinity: Sensor Light Add On
  1. Enable the automation link and add your toggle helper into ‘Automation Link - By-pass Control’
  2. To ensure smooth operation between both automations, it’s important to configure the Lights ON at End options and potentially enable the automation link Time Delay option. When you stop watching a movie, there are two key reasons for setting this up
    1. It ensures that the same lights used in the other automation are set, preventing light flickers.
    2. It allows you to transition the light levels in two steps by enabling the Time Delay option, giving your eyes time to adjust. This creates a smoother shift from movie mode back to your usual lighting, eliminating harsh or sudden changes and enhancing the overall user experience.
    Note:
    • If you’ve opted to create a snapshot of your lights and switches, allowing them to return to their previous state before the automation started, this will still work. However, keep in mind that you may not get the two-step transition.
    • Additionally, be aware that the global conditions in your sensor light automation may affect the outcome. If the automation doesn’t behave as expected, check the global conditions in your sensor light automation to ensure they align with your setup.
    Below are the settings to adjust your lights back to 50%
  3. Your done, click save :tada:
:bulb: Sensor Light
Here are the light settings used in the Sensor Light Blueprint. These settings are identical to those configured in the Sensor Light Add-on Automation’s Lights ON at End options, except the brightness level is set to 100%.
Adding the automation link.
  1. To add the automation link to your sensor light automation:
    1. Choose Option 3 - Enable the Bypass - Keep the lights current state.
    2. Enter the toggle helper used in your sensor light add-on automation into the field labeled Bypass Switch - Keep The Lights Current State.
    3. Set the Time Delay. This step is crucial because it determines what happens when you stop playing a movie and your motion sensor is OFF. The delay allows you to trigger the sensor light automation before turning OFF your lights, switches, or scenes.
  • Tip: Set this delay to match the Time Delay input you use for your sensor light automation.
  • Important: Ensure you do not enable the auto OFF option for this bypass.
    Below are all the settings required.
    Below is a guide if you were to used all the settings in the bypass.
  1. Your done, click save :tada:
    Your lighting experience, your way – take control and customize it to perfection! :bulb::sparkles:
Now it is time to sit back and enjoy.
Lights, Camera, Action! Get ready to grab the popcorn because it’s movie time with a touch of cinematic magic! :clapper::sparkles:
Enjoy
Blacky :smiley:
Back to FAQ: Click Here
