New Features
Added numeric state to start and end triggers. You can now select above and below values. Example: You could have a temperature sensor in your bedroom and when the temperature rises above your set value it will send you a message. You then can have 3 action buttons + cancel button to:
- Close the blinds.
- Turn The Fan ON
- Close the blinds and turn the fan ON
- Cancel do nothing
Added time delay to start and end triggers. The state trigger will only fire if the state holds for the set time delay. This helps to stop false triggers. Example: If you are using “unavailable” state sometime it can be “unavailable” for a few seconds to a few minutes and then go back online, or the temp in you bedroom must be above your set value for the time delay before the automation will fire.
Global conditions. You can now enter any global condition you would like to apply to the automation. Example; You could have motion sensors in your home. Then you could set a condition to only run when no one is home. If you detect motion it will send you a message. You then could have action buttons to
- “Sound The Alarm” an play a voice recording “the Police have been called and are on their way”.
- “Sound The Alarm” and turn the lights ON (using by-pass of my sensor light blueprint).
- “Sound The Alarm”, turn on sensor light by-pass “Alarm” and strobe the lights for 10 minutes.
- “Cancel do nothing”
Or you could have an Office with motion sensors & CCTV. You could set a time condition to only run out of hours. If motion is detected it can send you a message with 3 action buttons + cancel button to what you like.
There a lot things this blueprint can now do. Hope you find it useful
If you like this blueprint? Consider hitting the
button in the top post
If you like my blueprints, and would like to show your support or just say thank you? Click Here
Enjoy
Blacky
