Watts your appliance up to, youāre always in the know from start to finish!
Like this blueprint? Consider hitting the button below
Need help? See our FAQ: Click Here
The Automation Process:
Appliance Trigger:
- Enter the power sensor entity that measures the live current draw of the appliance. Common devices with these sensors include smart plugs, energy meters, etc.
- The automation is triggered when the applianceās current draw exceeds a set wattage.
- The automation ends when the applianceās current draw falls below a set value.
Notification Options:
- Send notification messages to one or multiple devices when the appliance starts, finishes or the watchdog is triggered.
- Your end message can also include estimates of total power consumption and cost.
- Include duration tracking in your end message to track the applianceās operational time for the task or cycle.
- Opt to sends a repeated notifications to remind you when the appliance cycle is complete.
- Limit when notifications can be sent by using Notify Time Restrictions - helpful for avoiding alerts while youāre asleep.
- Notifications are compatible with both Apple iOS and Android devices, ensuring universal accessibility.
Run Status:
- Display your applianceās run status on your dashboard.
Energy Tracking:
- Use energy tracking to estimate the total energy usage (kWh) for each completed cycle. You can also choose to include the estimated cost of that cycle in the end notification.
- Or simply update the start and end helpers without including any energy information in the end notification - useful for your own custom actions or other Home Assistant logic.
Disclaimer - These values are estimates and should only be used as a guide. Please avoid relying solely on these estimates for accuracy and use them at your own risk. We cannot be held responsible for any inaccuracies or resulting losses, damages, inconvenience, or anything else that may occur.
Time Tracking:
- Runtime Tracking - Records the total runtime of your appliance by updating a text helper each time it completes a full cycle.
- Duration Tracking - Tracks how long the appliance was running during each individual cycle and includes this duration in the end notification message.
Cycle Counter:
- Use the cycle counter to track the total number of cycles completed by your appliance. You can also choose to include this information in your end message.
Service Reminders:
- Service reminders help you track appliance usage and perform timely maintenance.
- Cycle-Based Reminder - Notifies you when a service is due based on the number of cycles completed.
- Time-Based Reminder - Notifies you when a service is due based on the total time the appliance has been in use since the last service.
Watchdog:
- The watchdog option monitors an appliance cycle completion.
- It sends a notification if a cycle completion fails within the specified time frame.
Device Tracker:
- You can choose to use the device tracker for Start, End, and Watchdog notifications.
- When enabled, only selected devices currently inside the chosen zone will receive those notifications.
Custom Actions:
- Tailor custom actions to suit your preferences and needs, enhancing the automationās functionality.
- Configure actions such as triggering announcements on platforms like The Voice (HA), Google, Alexa, etc., to keep you informed about appliance events.
Custom Conditions:
- Enter any custom conditions to further customize the automation process.
CHANGELOG
- Version: 3.7 - 19 Aug-25 - Added an option to display your applianceās run status on your dashboard.
- Version: 3.6 - 12 Aug-25 - Now, both Custom End Action & End Notify run simultaneously.
- Version: 3.5 - 15 July-25 - Fixed a spacing issue and converted all conditions from shorthand to longhand format.
- Version: 3.4 - 22 June-25 - Added device tracker and notification icon with colour.
- Version: 3.3 - 10 June-25 - Added notification tags and 2 new options to reminder notifications.
- Version: 3.2 - 6 June-25 - Renamed Time to Notify Time Restrictions. Bug fixes to Notify Time Restrictions.
- Version: 3.1 - 21 May-25 - Renamed Power Tracking to Energy Tracking.
- Version: 3.0 - 18 May-25 - Added new watchdog input for devices to be notified.
- Version: 2.9 - 13 May-25 - Added runtime tracking and a time-based service reminder option. Fix bug that would not update cycle count and service reminder cycle count if time restricted end notification.
- Version: 2.8 - 26 Jan-25 - Added cycle counter and service reminder options. Cleaned up code
- Version: 2.7 - 27 Nov-24 - Update to Home Assistant YAML standards and coding practices.
- Version: 2.6 - 17 Sep-24 - Fix bug in end custom action.
- Version: 2.5 - 7 Sep-24 - Added iOS notification sound and reminder message.
- Version: 2.4 - 25 Aug-24 - Fix bug watchdog high priority.
- Version: 2.3 - 23 July-24 - Notification options for iOS and Android.
- Version: 2.2 - 11 June-24 - Fixed a bug that could stop the automation running.
- Version: 2.1 - 9 June-24 - Added collapsible sections, end repeat count, watchdog notification, watchdog custom action and fixed a bug in time.
- Version: 2.0 - 18 May-24 - Added duration tracking.
- Version: 1.9 - 17 March-24 - Added ability to select an energy sensor for price per kWh.
- Version: 1.8 - 23 Feb-24 - Added power tracking option. New layout.
- Version: 1.7 - 22 Jan-24 - Added a running dead zone
- Version: 1.6 - 13 Jan-24 - Fixed bug in custom action options.
- Version: 1.5 - 5 Dec-23 - Added custom action options.
- Version: 1.4 - 5 Dec-23 - UI Redesign of inputs.
- Version: 1.3 - 4 Dec-23 - Initial release
MY OTHER BLUEPRINTS
Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time
Smart Light - Entity - Sun Elevation - Ambient & Time Triggers
Sensor Light Add On - Media & Movie Lights - House Alarm Lights - Smoke Alarm Lights & Exhaust Fans + More
Holiday & Away Lighting
Bathroom Humidity Exhaust Fan
Low Battery Notifications & Actions
Notifications & Announcements
Calendar Notifications & Actions
State Notifications & Actions
Battery Charger Notifications & Actions
Blueprint Update Notifications
Manual Control Status Tracker
Bee In The Hive Sensor
Android Notification Channel Manager
Toilet Exhaust Fan with time delay
Entity - Run ON Timer
Trigger - Run ON Timer
Manual light control with auto OFF
Closet, Pantry, and Cupboard Lighting
Timer
Temperature Control Fan
Temperature Control Exhaust Fan - Inverted
Toggle Switch - Turn ON & OFF Entities
Press Button - Turn ON & OFF Entities
