Zigbee buyer's guide
Read my recommendation and explanation in the post above → Zigbee buyer's guide - #2 by Hedda
Summery; Silabs adapters are not yet recommended → https://www.zigbee2mqtt.io/guide/adapters/
As well as note this warning:
WARNING! WiFi-based Serial-to-IP bridges are not recommended as the serial protocol does not have enough fault-tolerance to handle packet loss or latency delays that can normally occur over WiFi connections. See these references that same recommendation applies to both Zigbee2MQTT and ZHA:
In short, if want a more stable Zigbee setup then do not use Serial-to-IP remote adapters over Wi-iFi.
Also see:
